Staro 28.10.2006., 00:39   #121
OveRkiLL
Registered Abuser
OveRkiLL's Avatar
Postovi: 590
stari mi ima amigu 600, 1200 i Commodorca 128. ono šta ne mogu vjerovat je da još rade savršeno, čak i dedica C128 radi.
AMD Ryzen 7700X + Noctua NH-D15
Asus X670 Prime
2x8GB Kingston Fury Beast 6000MHz CL40
XFX RX6800 16GB Qick 319
Kingston NV2 250GB + Crucial P5+ 1TB + Seagate 2TB HDD
EVGA 650W SuperNOVA GQ, 80+ Gold
Fractal Design 7 Compact
23.8" AOC 24G2SPU 165Hz
Windows 10 x64
Logitech G402
Razer Cynosa V2
OveRkiLL je offline   Reply With Quote
Staro 03.01.2007., 01:41   #122
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
WinUAE 1.3.4 released
WinUAE i dalje uredno vozi
WinUAE 1.3.4 (30.12.2006)
Bugs fixed:
- Improved bsdsocket emulation stability
- Winuaeclipboard crash fix
- Windows Vista compatibility problems fixed
- Filesystem flag handling on FAT volumes
- Page Down-key Input panel remapping works properly
- Sound system improved
- ECS Denise/AGA borderblank feature works properly
- Dualcore/SMP random freezes properly fixed
and more minor fixes..
Bugs introduced in 1.3.3 fixed:
- AVIOutput out of sync fix
- CPU emulation condition code fix
- Fixed handle leak in bsdsocket and AHI
- Sound pitch shifting in VSync-mode and more..
- Catweasel MK4 mouse support
New features:
- Improved emulation of AGA sprites outside display window
- uaeserial.device introduced. Multi-port serial device, unit numbers are directly mapped to PC serial ports (unit 0 = COM0, 1 = COM1 etc..)
- Improved serial port detection, virtual devices also supported
- Improved Catweasel MK3/4 support without Windows driver installed (requires TVicPort, http://www.entechtaiwan.com/dev/port/index.shtm)
- Improved debugger features
- Sound system is not anymore reinitialized when losing/gaining focus
- 1M (1024KB) ROM image support
- Sound volume configuration setting also sets AHI audio volume (previously was Paula audio only)
- Custom chipset interrupt timing improved
http://www.winuae.net/
Staro 28.01.2007., 05:11   #123
Yamato9
Postovi: 4
Dreadnoughts-i su bili ZAKON!!! jedna od najrealnijih pomorskih strategija koja je ikada izasla na bilo kakvim kompicima ili konzolama.
Danasnje strategije filaju samo grafiku i nista vise.
Yamato9 je offline   Reply With Quote
Staro 28.01.2007., 05:23   #124
Yamato9
Postovi: 4
Pomagajte! Gdje mogu skinuti dobre igrice za Amigu.
Jos nesto, imam nekoliko disketa sa igricama za A500. Postoji li nacin da ih nekako pokrenem preko WinUAE-a ili neceg slicnog, buduci da PC nemoze citati Amigin zapis.
Staro 28.01.2007., 11:39   #125
Visage
8-bit Gen.
Visage's Avatar
Lokacija: Giethoorn - ZG
Postovi: 3,143
Buduci da ciljas na koristenje emulatora. Zasto ne lociras te igre sa disketa informativno jednostavnije :
Abime
Ako drzis do svog ugleda, nemoj slucajno da ovo ne nabavis. Na cestit i legalan nacin svakako.
PS , S&TF , DFOC , S&G , WOD , ED
Nek ti Jelc da jos pokoji link ako ima. Meni je ovo glavni site za nesto saznati, doduse, DATA zavrsava samo na Amigama.
>>>> PCE kante 2012 <<
>>>>>>>>> PCE & ostalo <<<<<
>>>>>>> Što sam Slušao? <<<<<<
>>>>> Gimnastika za Okulare & LCD Addendum<<<<
>>>>> P o s t ... M j e s e c a <<<<
______________________________
Zadnje izmijenjeno od: Visage. 30.01.2007. u 15:26.
Staro 30.01.2007., 14:57   #126
Jelc
Super Moderators
Postovi: 17,485
Za početak je najbolje baciti oko tu:
http://wiki.abime.net/
Sve lijepo piše, linkovi....
Molim obratiti pažnju da na forumu nema govora o stvarima koje su pod copyrightom
Romovi, igre koje su još pod oznakom "Commercial" i slično.
Ako bude problema-slobodno me se može pingati na mail ili PM.
Staro 31.01.2007., 15:28   #127
Yamato9
Postovi: 4
Hvala decki!
Staro 04.03.2007., 13:46   #128
Jelc
Super Moderators
Postovi: 17,485
WinUAE 1.4.0 released!
WinUAE 1.4.0 (03.03.2007)
New features:
- CDTV emulation, including CD controller, internal SRAM and 64KB SRAM
expansion memory card support.
- More compatible SPTI CD32/CDTV CD support.
- Advanced Chipset configuration. Miscellaneous model specific
hardware configuration entries like real time clock chip type, CIA-A
TOD clock source, RAMSEY, FAT GARY register emulation..
- Rewritten harddisk configuration system. No more lost hardfile or
virtual directory configuration entries if path was missing..
- A3000/A4000 motherboard RAM bank support.
- Added Arcadia bios rom type selection.
- New Windows Vista -style application icon added
- Small CIA and custom chip emulation updates.
Bugs fixed:
- FPU emulation floating point to integer conversion fixed
(proper clamping instead of truncating)
- uaeserial.device compatibility improved
- New serial port detection didn't detect all types of serial ports
- Random sound errors after adjusting sound GUI setting on the fly
- Directory filesystem memory leaks fixed and compatibility improved
- It was not possible to disable keyboard layout C after enabling it.
- Sound panel settings were not always enabled correctly.
- -datapath command line parameter didn't work.
- Disk image drag and drop didn't work.
- Quickstart panel disk swapping is properly delayed again.
- Some Picasso96 display modes were not available.
- bsdsocket freeze fix (Aminetradio)
- Windows driver Catweasel support works again.
- "Faster RTG"-mode lockups fixed.
- External drive sound selection GUI didn't work if fdrawcmd.sys
was not installed.
Staro 30.04.2007., 21:52   #129
Jelc
Super Moderators
Postovi: 17,485
WinUAEHelp
Isvrstan WinUAEHelp u kojem je objašnjeno baš sve
http://www.pcguru.plus.com/files/WinUAEHelp209.zip
700 kila.
I zadnji WinUAE 1.4.1
Major bug fixed:
- Start-up crash introduced in 1.4.0.
Bugs fixed:
- Yet another bsdsocket crash fix.
- ASPI detection ignored NeroASPI, also ASPI detection was improved.
- Some interlaced programs had color stripes or wrong colors in right border.
- Picasso96 RTG RAM mapping error in non-JIT mode
New features:
- New input targets added. (disk swapper, input configuration 1-4)
- Quickstart-mode automatically selects best available CD access mode.
- Master (Windows main volume) volume control added to input targets.
- map "POV Hat"-type joypad control to joystick horizontal and vertical.
Staro 31.07.2007., 12:28   #130
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,005
WinUAE 1.4.3 izašao
Zadnje izmijenjeno od: Jelc. 31.07.2007. u 21:34.
Staro 31.07.2007., 21:37   #131
Jelc
Super Moderators
Postovi: 17,485
New features:
- Built-in lha/lzh and lzx support.
- Mount archives as a harddrive with transparent, recursive
(archives inside archive) decompression. Supported: zip, 7zip,
rar (unrar.dll or archiveaccess.dll required), lha/lzh, lzx.
- A3000 Kickstart ROM and SuperKickstart disk support.
- A590/A2091 SCSI, A3000 SCSI and CDTV SCSI expansion harddrive (HDF)
emulation (WD33C93 + (Super)DMAC based SCSI hardware).
- Action Cartridge Super IV Professional freezer cartridge emulation.
- X-Power Professional 500 (v1.2) freezer cartridge emulation.
- Nordic Power (v2.0) freezer cartridge emulation.
- Debugger improvements (improved deep trainer, copper memwatch points,
CPU-model specific registers can be modified, illegal access logger
improved, process breakpoints etc..)
- Paths-panel default paths selection improved.
- Separate native and Picasso96 vsync setting.
- GUI will "autoscroll" if fullscreen mode is smaller than GUI.
- Improved rtg.library, speeds up Picasso96 in high resolution modes
(obsoletes picasso96fix)
Novosti u
Bugs fixed:
- CDTV emulation improved (DOTC2, Xenon2, ChaosInAndromeda CD player)
- CD32 CD emulation improved (Fightin' Spirit, Base Jumpers etc..)
- Ghostscript printing fixed (again).
- Floppy drive sound selection if fdrawcmd.sys was not installed.
- Video recording sound pitch issue.
- -datapath command line parameter fixed (again..)
- uae-configuration JIT on/off switching fixed.
- Sprite attachment fix, fixes "Great Demo" by "The Tremendous Trio"
- Some FPU fixes from Aranym.
- Directory filesystem locked files (most commonly s:startup-sequence)
after software reset
- Filesystem emulation not initializing if JIT was enabled and no other
expansions enabled (fast RAM, Z3 fast, etc..)
Staro 07.08.2007., 22:46   #132
Jelc
Super Moderators
Postovi: 17,485
AmigaSYS 3 Plus Released!
Feature List :
The followings are translated into three languages (HU,ENG,DE)
- Easy installation with multiple options 3.0/3.1.
- Installation in three languages 3.0-3.9
- Better hungarian, english and german localization of the installers 3.0-3.9.
- Amiga OS 3.9 installers (Os3.9, Amiga Forever , Amithlon, OSXL).
- Appmenu Tools.
- Help files.
- About menu.
- All themes.
- Theme installers.
- Theme Saver.
- Amistart
- All AmigaSYS Scripts
- Cd-mount
- Theme select
- PostED
- No Startup Boot
- Upgrade
- Etc...
The language can be set while installing (3.0/3.1) by selecting system language.
AmigaSYS 3 Plus Installer :
- Completely rewritten 3.0/3.1 installer
- Easy installation with multiple options (HUN,DE,ENG,AmigaForever Installer, Kickstart check )
- Ability to install without the Extras disk (for Amiga Forever users).
- Choice of system language: Hungarian, English, German
- Keyboard layout selection (Hun,Eng,De)
- Resolution selection (Low-VeryHigh 800,1024,1152,1280.)
- 262144 color intro images.
- 262144 color outro images - project contributors and partners.
- The music from WOC92 by Sanity is played during installation
- Status display during installation (%).
- Lots of features, 3-4 times as fast as the previous version!
Amiga OS 3.0/3.1 :
- Brand new formated hdf
- New, cleaned up system with only the necessary components.
- Systems scripts rewritten from scratch for better, faster executions.
- New look, new images, new fonts.
- Completely rewritten Amiga Os 3.9 installer,2 to 3 times as fast as the previous version!
- Completely rewritten Amiga Os XL installer,2 to 3 times as fast as the previous version!
- Completely rewritten Amigathlon installer,2 to 3 times as fast as the previous version!
- Completely rewritten Amiga Forever 6,2005,2006 installer,2 to 3 times as fast as the previous version!
- Completely rewritten Amiga Forever 6,2005,2006 online installer,2 to 3 times as fast as the previous version!
- New, higher quality installer images.
- Theme selection during installation of 3.9.
- Resolution selection during installation of 3.9.
- The emulators, players and games icons bring up menus for faster access to the built-in programs.
- Icon verification (tool, etc).
- Rewritten help files, now placed in the System:Readme directory.
- New about , new graphics, new menus.
- IBrowse configuration converted to version 2.4.
- AmigaAMP plugins detection fixed.
- Some AmigaAMP skins deleted, and compressed into format JPG.
- Some AMR skins deleted.
- New filemaster configuration with useful features.
- Fixed Bareed GLOW icon bug.
- Fixed bareed configuration bug.
- Introduced amigasys-startup and amigasys-user.
- Fixed appmenu configuration bug.
- Fixed IBrowse configuration bugs.
- HOL Game Database added in IBrowse.
- Fixed GACB URL in IBrowsba
- Fixed Packmaster configuration, (Appicon, default extract = ram)
- Fixed font encoding problem in limpidclock.
- Improved German and Hungarian keyboard layout.
- New MCP configuration.
- Fixed FTP mount configuration.
- Faulty icons no longer appear after the installation of amiga forever.
- Added PowerWB (3.0/3.1 only).
- Added toolmanager, works in all resolutions (3.0,3.1,3.9 RetroSYS).
- Ten Toolmanager Icon for menu , CD mount, Players, games, Emulators , Bareed , packmaster , ppaint, ibrowse, yam , wookiechat.
- TinyMeter added; configured to display chipram, fastram, and system dh0 usage(3.0/3.1 és 3.9 RetroSYS).
Amiga OS 3.9 :
- New theme: BLUE
- New theme options.
- New, cleaned up Themes with only the necessary components.
- Preview images from theme while installing.
- Evry theme can change resoulition.
- Themes dont contain configuration files.
- Icon problems have been debuged in themes.
- Theme saving feature has been added, make your own theme and share it with your friends or AmigaSYS Team.
- If you create your own theme background image should be in presets/AmigaSYS/theme directory, it may be anywhere but this is the default directory.
- Wbstartup problems fixed at theme saving.
- All actual settings will be saved at theme saving.
- Fixed def icons bugs in all themes with Amiga OS 3.9 installed.
- Def icons bugs have been fixed in all themes with Amiga Os 3.9 , Amiga Forever , Amiga OS XL , Amithlon install.
- RetroSYS theme actualized (tinymeter , toolmanager)
- Themechanging fixed , only RetroSYS has TinyMeter and Toolmanager just like in 3.1.
- Fixed font encoding problem in limpidclock all themes.
- Def icons supported after installing Amiga Forever.
- Amiga Forever has no Unarc , Editpad, def icons use Packmaster and BareEd is default program.
- New Amistart configuration.
- New Amistart background, logo, etc.
- We had problems with emptying Trashcan , fixed.
lots of fixes,and all 3.0/3.1 fixes and features!
Programs :
- New Mui Class's
- Librarys
- Datatypes
- AmigaAMP
- Bareed
- PowerWB
- Tinymeter
- Toolmanager
- Amiga Spectrum Emu
- WormWars
- Wookiechat.
Deleted programs :
- Amirc, to replace Wookiechat free and very good.
- Songplayer.
- Flamingo Plus 4 emulator.
AmigaSYS 3 Plus OS Support :
- Amiga OS 3.0
- Amiga OS 3.1
- Amiga OS 3.1 Amiga Forever version
- H&P Amiga Os 3.9 series
- Amiga Forever 6 CD (3.9).
- Amiga Forever 6 Online edition (3.9).
- Amiga Forever 6 Installed (3.9).
- Amiga Forever 2005 CD (3.9).
- Amiga Forever 2005 Premium edition (3.9).
- Amiga Forever 2005 Online edition only installed! (3.9).
- Amiga Forever 2006 CD (3.9).
- Amiga Forever 2006 Premium edition (3.9).
- Amiga Forever 2006 Online edition only installed! (3.9).
- AmigaOS XL Amithlon CD. (3.9).
http://amigasys.extra.hu/
Staro 21.09.2007., 21:55   #133
Jelc
Super Moderators
Postovi: 17,485
Evo jedne stvarno dobre vijesti-nakon dužeg vremena legendarni Back to the Roots je ponovno online
http://www.back2roots.org/
Staro 15.08.2008., 20:26   #134
gunther
Postovi: 1,358
WinUAE 1.5.1 (12.08.2008)
Major 1.5.0 bugs fixed:
- Failed to start with some display card/driver combinations.
- Regular (non-RDB) OFS formatted hardfiles didn't mount under KS 1.3.
- Memory corruption in configuration file handling causing random
crashes when loading or saving configuration files.
- Configuration files in subdirectories didn't load if configuration
cache was enabled.
- RTG hardware mouse cursor may have been invisible (or had
wrong graphics) in some cases after resolution change.
- Switching between non-interlaced and interlaced modes caused random
"scanline" graphics corruption.
Other bug fixes:
- Built-in HRTMon crashed in JIT modes.
- Interlace modes fixed in "normal" (non-doubled/scanline) modes.
- Fixed borderblank graphics corruption in interlaced modes.
- Fixed possible crashes when switching Windows desktop resolution or
when using quick user switching.
- "Kickstart Replacement" fixed.
- PCMCIA SRAM emulation didn't work in memory expansion mode.
- Emulation paused if "stop sound while inactive/minimzed" was enabled.
- Improved directory filesystem statefile support.
- AVI recording crash if only audio recording was enabled.
- Native DLL support fixed.
- Forced fullscreen refresh rates didn't work in some cases.
- Multiple identical (same serial number) USB game controllers do not
confuse input system anymore.
- Major blitter slowdown in some AGA modes.
- ADF was not updated if disk write was aborted (Cadaver save disk)
- Crash when USB mouse/joystick was removed or inserted before
emulation was started.
New and improved features:
- Added support for Direct3D pixel shader filters (very fast compared
to software filters, pixel shader 2.0+ compatible display card
required), plain Direct3D filter performance improved.
Latest (August 2008 or later) DirectX required.
- In windowed mode all resolution or chipset/RTG mode switches
resize the window instead of window closing and opening.
- Aspect ratio setting added to RTG and filter panels.
- Window resize enabled in windowed mode (chipset mode).
- Added Picasso96 option "Always scale in windowed mode" which enables
window resizing and disables automatic resize. Keeps aspect ratio
automatically.
- Only reset fullscreen mode when resolution or depth changes.
- On the fly USB mouse/joystick insert/removal does not modify
currently selected input device(s) in Ports-panel.
- Enable ini-mode (registry replacement) if .ini
(without .exe) is found. Previously always used winuae.ini.
AMD Ryzen 5900X; Gigabyte Aorus X570 Elite; Corsair Vengeance RGB Pro SL DDR4 2X16 Gb 3600 Mhz; AMD Radeon Gigabyte 7900 XTX; SSD Patriot Viper VP4300 PCIe m.2 GEN4 2 Tb;Lian Li 011 Dynamic EVO; LG C2
gunther je offline   Reply With Quote
Staro 15.08.2008., 22:42   #135
Jelc
Super Moderators
Postovi: 17,485
Vani je i novi AmigaSYS 4 i to u verzijama za Windows, XBox, PDA, MacOS, Live, Linux, MorphOS, Amiga OS4, Amithlon i Amigu
I thread na English Amiga Board :
http://eab.abime.net/showthread.php?t=35764
Staro 05.01.2010., 23:05   #136
Jelc
Super Moderators
Postovi: 17,485
Boing Bag #3 for OS3.9 released
Boing Bag 3 is a community effort that has accomplished the difficult task
of upgrading, enhancing and bugfixing AmigaOS 3.9. Between many important
goals achieved, we can mention the following features which may give you a
quick overview of this project:
* Large hard disk support, LBA48 support, extending the possible disk
sizes to 128 petabytes (131,072 terabytes).
* A more robust and faster TCP/IP stack
* New video drivers for wide screen monitor support and enhanced graphic
modes
* A fully working web browser
* Huge amount of bugfixes that improve system stability and behaviour
* Impressive update of system components, adding a lot of new features
And much more...
http://amigan.1emu.net/releases/BoingBag3.readme
Ljink
Staro 17.04.2010., 17:11   #137
Visage
8-bit Gen.
Visage's Avatar
Postovi: 3,143
Vrijeme je da se probudi ova tema. Posebno nakon ove gadurije. Nakon dugo vremena i kojekakvih ogavnih natrpavanja Amige u razna "DTK look" genericka PC kucista do sredine 90-tih. Pa vec bogu dosadne revizije ploca i prijedlozi OS-a koji se vuku u nedogled.
Konacno nakon A4000T, pojavilo se kuciste, dostojno Amiga imena! Takodjer nakon dugo vremena, nikad konkretnije specifikacije i projekt nisu krasile Amiginu mogucu buducnost u novom ruhu. Hardver cije specifikacije zadivljuju jer ako se uzme Amigin odnos prema resursima, to je blago receno > 3x vise snage nego na papiru specifikacija. Kuciste bi (navodno) trebalo iznutra biti bazirano na Fractal kucistu, ali to moze potvrditi samo onaj koji je zbilja imao priliku otvarati x1000.
Vlastite ideje i hardver, cine Amigu samo jos posebnijom i dostojno inovativnom :
AmigaOne X1000 specs:
* Dual-core 1.8GHz PowerISA™ v2.04+ CPU
* "Xena" 500MHz XMOS XS1-L1 128 SDS
* ATI Radeon R700 graphics card
* 2GB RAM
* 500GB Hard drive
* 22x DVD combo drive
* customised case, keyboard and mouse
* 7.1 channel HD audio
Ports and connectors:
* 4x DDR2 RAM slots
* 10x USB 2.0
* 1x Gigabit Ethernet
* 2x PCIe x16 slots (1x16 or 2x8)
* 2x PCIe x1 slots
* 1x Xorro slot
* 2x PCI legacy slots
* 2x RS232
* 4x SATA 2 connectors
* 1x IDE connector
* JTAG connector
* 1x Compact Flash
A-EON glavni sajt je doista prepun informacija, svakako ga dobro istrazite. Mjesecima je iz nekog duhovitog razloga bio prepun raznih sifri i probijanje do podataka je bilo vrlo slicno Costinoj igri
Srecom, korisnik je dole u drugom youtube videu, prikazao djelomicno taj humor. Sad je site dostupan za koristenje i manje vicnim poweruserima, jer pravi Amigasi samo takvi dolaze na svijet.
Vidjet cemo rekli bi stari ribari a moguce i Jelc. I zbija, vidjet cemo sto ce biti od toga jer Vesalia uredno drzi kao najavu za mogucu rezervaciju. U svakom slucaju, ako bude kasnjenja i za godinu dana, ovo je prva nova Amiga za koju se poseze ruka u djep bez ikakvog neckanja
Kao sto primarni naslove ove teme odzvanja, ovo su stvarno : Dobre vijesti za Amiga-nostalgičare!
A-EON Frequently Asked Questions and information
>>>> PCE kante 2012 <<
>>>>>>>>> PCE & ostalo <<<<<
Zadnje izmijenjeno od: Visage. 26.04.2010. u 21:34.
Staro 17.04.2010., 20:54   #138
Xenomorph
Arroyo settler
Xenomorph's Avatar
Lokacija: .::Zagreb::.
Postovi: 316
Opasno dobroSvaka čast
Xenomorph je offline   Reply With Quote
Staro 17.04.2010., 21:17   #139
Jelc
Super Moderators
Postovi: 17,485
Naletil sam već na to ali sam zaboravio postat
Nagradnjača:
http://eab.abime.net/showthread.php?t=52010
I tema koja se vuće još od kraja 2007-e
http://eab.abime.net/showthread.php?t=33024
Fakat lijepo kućište....
Nego, sjeća li se itko ove kornjače?
Staro 19.04.2010., 20:07   #140
Visage
8-bit Gen.
Visage's Avatar
Postovi: 3,143
Autor Jelc Pregled postova
Jedna od napornijih nagradnjaca koje sam vidio. Meni ce biti nagradni zgoditak da to pocnu proizvoditi i prodavati. Ne trazim drugaciju nagradu
Naravno, tko bi zaboravio, ali bilo je tu i ekonomicnijih replika kucista
Staro 19.04.2010., 22:27   #141
Jelc
Super Moderators
Postovi: 17,485
Meni je baš žao kaj Walker nije zaživio-koliko god ličio na usisivač.
Sve je to lijepo i krasno ali mene je ubijalo to kaj mi je iz Amige išla IDE kabelčina u midi kućište gdje je bilo napajanje, CD i hard
Staro 19.04.2010., 22:34   #142
Visage
8-bit Gen.
Visage's Avatar
Postovi: 3,143
M'da, ruznjikav je na poseban nacin. Ali opet poseban je i ne moze ga se zaboraviti.
Ma to je zlocin iz A1200 raditi. HDD unutra a Optika ili modaj ili preko karte. Boze me sacuvaj onih PC rugoba od kucista. Ma nikad to ne bih mogao staviti. Imas A2000/3000/4000 pa trpaj sto hoces ako ti treba. Bas sam gledao Vesallia ponudu novih Dual CF HDD zamjena. Dvije CF karte i mozes baciti onaj citac kartica vani
Staro 19.04.2010., 22:52   #143
Jelc
Super Moderators
Postovi: 17,485
Autor Visage Pregled postova
Je, A2000 je ono-posebno gadno kućište, ne bi na tu škatulu ni fikus stavio
Kaj se tiče kablovinja-mi proleteri smo se morali tako snalazit na 1200 a nije bilo drugog načina da se spoji CD i hard...nije svako mogao kupiti A4000 koja je koštala u vražju mater
Staro 23.04.2010., 23:29   #144
Lewis
Freelancer
Lewis's Avatar
Lokacija: Bilje (Osijek)
Postovi: 5,261
Jaoo, sad sam u bedu sto sam prodo A1000 prije 15+ godina .
Lewis je online   Reply With Quote
Staro 26.04.2010., 20:21   #145
Overhaul
Overhaul's Avatar
Postovi: 517
uh, ja imao Amigu 1200... za potrebe dpainta, imaginea, protrackera i genlokanja i sad citam, taj komp se jos uvijek moze kupiti u originalnom pakiranju sa skladista???
Overhaul je offline   Reply With Quote
Staro 26.04.2010., 20:44   #146
Jelc
Super Moderators
Postovi: 17,485
Sudeći po kutiji-to nije orginal Commodore nego Escomova, te su se radile negdje 95-e
Staro 26.04.2010., 21:33   #147
Visage
8-bit Gen.
Visage's Avatar
Postovi: 3,143
Autor Overhaul Pregled postova
uh, ja imao Amigu 1200... za potrebe dpainta, imaginea, protrackera i genlokanja i sad citam, taj komp se jos uvijek URL="http://amigakit.leamancomputing.com/catalog/?currency=EUR&currency=EUR"]moze kupiti[/URL] u originalnom pakiranju sa skladista???
Hm'da, najvjerojatnije je Escom u pitanju, mada, Vesalia je znala imati neke stare serije tu tamo prije.
Staro 02.07.2010., 12:10   #148
kixs
Lokacija: Slovenija/Samobor/ZG
Postovi: 36
Imam doma jos A600 standard, A1200 upgrade 8MB ram, 4GB CompactFlash IDE, PCMCIA CF card, Commodore 1084 monitor i jos jednu A1200 standard koja je pre nekoliko meseci nestala raditi
kixs je offline   Reply With Quote
Staro 11.07.2010., 22:22   #149
Xenomorph
Arroyo settler
Xenomorph's Avatar
Postovi: 316
Autor kixs Pregled postova
Neeeeeeeeee
Staro 12.07.2010., 15:04   #150
Visage
8-bit Gen.
Visage's Avatar
Postovi: 3,143
Autor Xenomorph Pregled postova
Neeeeeeeeee
Vidim da te je pogodio gubitak kolege kad je ovako zakasnjeli post
Ali evo nesto za bolje raspolozenje
Kao i APoV na kojeg mi je Jelc nedavno skrenuo paznju
