Staro 07.01.2007., 16:44   #1
Tomo
Re-Registered User
Tomo's Avatar
Postovi: 627
LCD do 3300 kn
Pozdrav dobri ljudi!
Imam jedan problem, imam 3000 kn za monitor i ne znam koji da zemem! Isao sam u petak u links ali prodali zadnjeg zamzunga 205BW .... e sada me zanima sta da uzmem jer imam cca 3300 kn i mogucnos kupovine monitora! Kaj da zemem?
Finalisti su:
Eizo FlexScan M1900 i Samsung 205BW ...
Preferiram Wide monitor jer gledam dosta filmova i serija (nemam TV u sobi ) Ne igram se, tako da to nije problem ... Bitno da radi na mojoj All-mighty FX 5200 u 2Du normalno
Hvala svima!
Tomo je offline   Reply With Quote
Staro 07.01.2007., 19:56   #2
^SuperUnknown^
Prečupavi mod
^SuperUnknown^'s Avatar
Postovi: 9,107
Ak ti se neda cekat Samsunga u Linksu, imas ga u Ve-mulju
http://www.ve-mil.hr/opis.aspx?sifra...37941393340795
Primary macine:
Apple Mac Pro 5,1
64 GB ECC DDR3 800 MHz
Geforce GTX 980 4 GB
Kingston 120GB SSD
30 TB HDDs
Sharkoon QuickPort@USB
Optiarc DVD RW AD-7170A
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
22 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 970 4 GB
Seagate 500GB 7200.10
Hitachi 1000GB 7K1000.B
Seagate 1000GB 7200.11
Hitachi 7K3000 3000GB
Mac OS X 10.10.3
Work rig:
Apple Mac Pro 1,1@2,1
13 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 660 2GB
Seagate 500GB 7200.12
2xWD Black 1000GB
2xSharkoon QuickPort@eSATA
Mac OS X 10.10.3
Sony KDL-26U2000 26"@HDMI
Apple Alu Keyboard
Logitech MX518
LAP:
Apple Macbook Pro 3,1
Intel Core 2 Duo 2.53 GHz
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
iPhone 6S 64GB black
iPad 16GB WiFi 4.3.2
* Connected via:
90/90 Mbps Iskon Trio
* "Powered" by:
UPS APC Smart-UPS1500VA
* Playing:
Tama Arstar II
Yamaha DTXPRESS IV Special
Staro 07.01.2007., 20:44   #3
Blue Spirit
Blue Spirit's Avatar
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,181
Jedna preporuka , za 300 kn vise (3600 kn) imas kod vranoge Dell 2007 WFP .
Ima nas tu 3-ca na forumu koji smo kupili taj monitor smartguy, ja, lihto, i svi prezadovolji
+ daleko kvalitetniji prikaza boja,ostrina, citaj : među boljima ako ne i NAJBOLJI 20 LCD trenutno dostupan na trzistu
- velika cijena , te za te novce se moze kupiti 22"
http://www.prad.de/en/monitore/review-dell-2007wfp.html
http://www.behardware.com/articles/6...6-8-16-ms.html
http://www.tftcentral.co.uk/guides/dell_2007wfp.htm
Samsunga ima TN matricu a Dell IPS matricu.
Pogledaj Mar- ov vodič o LCD monitorima pod MATRICE http://forum.pcekspert.com/
showthread.php?t=50691
/connect 185.107.96.125:28990
server rcon: oldschool
Blue Spirit je online   Reply With Quote
Staro 07.01.2007., 20:57   #4
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
ja bi radje samsunga jer je veci
.i.
Razer Blade 15
Staro 08.01.2007., 00:39   #5
Tomo
Re-Registered User
Tomo's Avatar
Postovi: 627
@ dzlobec: ebi ga, preko 3300 fakat nemrem
@ ostali: dajte se javite vi koji ste kupili 205icu sada u zadnje vrijeme i puknite svoje utiske ođe ... ajd bute tak dobri ....
Pozdrav svima, i hvala jos jednom!
Staro 08.01.2007., 00:44   #6
Dule
Dule's Avatar
Postovi: 639
evo uzeo sam ja 205-icu i mislim da je solidan monitor za te novce... jedino imam zamjerke na backlight bleeding na vrhu i malo u dnu... mene to recimo smeta pri gledanju filmova (pogotovo kad je mrak)... inace se to ne primjeti u radu u windowsima. slika isto nije losa. vidi se lagani ghosting (ili sta vec) pri scrollanju u odnosu na crt, ali to je zanemarivo. isto mislim da bi kut gledanja mogao biti pa bar za nijansu cistiji, ali eto. sve u svemu da se mene pita dao bi mu 4/5.
Dule je offline   Reply With Quote
Staro 08.01.2007., 00:57   #7
Conroe
Power Abuser
Conroe's Avatar
Postovi: 388
20-inčni samsung 204B za ravno 3300kn u linksu, nije wide al najbolja TN matrica na tržištu sa visokom rezolucijom 1600x1200
Conroe je offline   Reply With Quote
Staro 08.01.2007., 23:37   #8
Tomo
Re-Registered User
Tomo's Avatar
Postovi: 627
Evo, kupio sam 205BW ... problem je samo sto mi grafa ne podrzava 1680x1050 pa drzim na 1280x960 ...
Jos jednom hvala svima koji su pomogli u odluci!
Zemo lock!
Staro 09.01.2007., 00:57   #9
gorluk
Čovjek
gorluk's Avatar
Postovi: 1,166
Autor dzlobec Pregled postova
Ajde nemoj pričati takve stvari, još će ti netko povjerovati. Dell 2007 WFP NIJE najbolji 20" LCD display, bilo widescreen ili 4:3. Može se naći puno boljih monitora. Doduše budget mu je tanak, pa mu zbog toga taj Dell može igrati igru, ali pričati kako je to ponajbolji ili najbolji 20" display..no no
gorluk je offline   Reply With Quote
