Staro 04.01.2007., 12:18   #1
Twisted_XD
Lokacija: Sisak, Croatia
Postovi: 2
Kupujem komp... (jel ok konfiguracija?)
The digital home ATX AM2/NVIDA solution
Digital Home
The rise of digital home is just like a tsunami that is poinsed to take over the PC industry. To enjoy the digitalized convinience, you need the ASUS Digital Home series motherboard, a system that is designed solely for this purpose. ASUS Digital Home series motherbaord enables users to control the computer at a distance away, setup wireless network to enjoy wireless Skype phone, charge mobile devices even when the PC is turned off, and backup the database automatically. Enjoy the comfort of digital home you deserve.
Industry Standard
Supports AMD Socket AM2 Athlon 64 X2 / Athlon 64 FX / Athlon 64 / Sempron
The motherboard supports AMD socket AM2 single-core Athlon 64/ Sempron and dual-core Athlon 64 X2/ Athlon 64 FX processors with 2MB / 1MB / 512KB L2 cache, which is based on 64-bit architecture. It features 2000 / 1600 MT/s HyperTransport Bus, dual-channel un-buffered DDR2 800 memory support and AMD Cool 'n' Quiet! Technology.
Dual-Core CPU
The advanced processing technology contains two physical CPU cores with individually dedicated L2 caches to satisfy the rising demand for more powerful processing capability.
Dual-Channel DDR2 800
DDR2 is the next generation memory technology to replace the current DDR. With the highest speed up to 800MHz, DDR2 memory provides great performance for 3D graphics and other memory demanding applications.
M2N-VM DH supports AMD Cool 'n' Quiet! Technology, which monitors system operation and automatically adjusts CPU voltage and frequency for a cool and quiet environment.
NVIDIA Essential Vista
NVIDIA nForce ® -based motherboards are essential for accelerating the Windows Vista experience by offering an enriched 3D user interface, increased productivity, and vibrant photos as well as delivering uncompromising performance, quality, and reliability.
Digital Home features
Asus DH Remote™
It's finally here, the convenient remote controller for your PC!
Introducing DH Remote™, a convenient PC remote controller that gives users unprecedented control over their PCs from the comfort of their couches. With the touch of a button, users can quickly power their PCs on/off, put the computer into suspend mode, and turn the computer noise down. Moreover, revolutionary ASUS technology allows users to run wireless devices such as Skype and wireless AP while the computer is still sleeping. Of course the remote gives you all of the features of a more traditional remote as well, such as volume control, play, pause, fast-forward or rewind. Users can also customize the buttons to suit specific needs. Have DH Remote™ in your hand and do more with your PC at a distance away!
ASUS WiFi-AP Solo
Why buy wireless AP off the store when you can have it on board?
WiFi AP Solo allows a new level of versatility for your PC, enabling it to create a complete wireless home network in either AP or wireless client mode. Users will be able to play LAN games, connect to the Internet, access and share printers, and use Skype from anywhere within range. WiFi-AP Solo can provide these functions even when the PC is in sleep mode, so users can use Skype as a true replacement for tradition long distance telephone service. WiFi-AP Solo is an on-board feature, which means that user will save the extra WiFi AP cost.
ASUS MP3-In™
Turn your mp3 player into a stereo system!
You can turn off your PC, and still use your computer speakers for any of your portable music players. Better sound quality without further stereo equipment cost.
ASUS Unique features
ASUS O.C. Profile
The motherboard features the ASUS O.C. Profile that allows users to conveniently store or load multiple BIOS settings. The BIOS settings can be stored in the CMOS or a separate file, giving users the freedom to share and distribute their favorite overclocking settings.
CrashFree BIOS 2 The CrashFree BIOS2 feature now includes the BIOS auto-recovery function in a support CD. Users can reboot their system through the support CD when a bootable disk is not available, and go through the simple BIOS auto-recovery process. ASUS motherboards now enable users to enjoy this protection feature without the need to pay for an optional ROM.
ASUS EZ Flash 2 EZ Flash 2 is a user-friendly BIOS update utility. Simply press the pre-defined hotkey to launch this tool and update BIOS from a USB flash disk before entering the OS. You can update your BIOS only in a few clicks without preparing an additional floppy diskette or using an OS-based flash utility.
ASUS Q-Fan 2 ASUS Q-Fan2 technology intelligently adjusts both CPU fan and chassis fan speeds according to system loading to ensure quiet, cool and efficient operation.
ASUS Q-Connector The ASUS Q-Connector allows you to connect or disconnect chassis front panel cables in one easy step with one complete module. This unique adapter eliminates the trouble of plugging in one cable at a time, making connection quick and accurate.
Other features
PCI Express Architecture
PCI Express is the latest I/O interconnect technology that will replace the existing PCI. With a bus bandwidth 4 times higher than that of AGP 8X interface, PCI Express x16 bus performs much better than AGP 8X in applications such as 3D gaming. PCI Express x1 also outperforms PCI interface with its exceptional high bandwidth up to 500MB/s.
SATA 3Gb/s RAID The NVIDIA nForce® 430 chipsets incorporate four SATA 3Gb/s ports with high performance RAID functions in RAID 0, 1, 0+1, 5 and JBOD. This motherboard is the ideal solution to enhance hard disk performance and data back up protection without the cost of add-on cards.
High Definition Audio Enjoy six-end sound system on your PC! The onboard 6-channel HD audio (High Definition Audio, previously codenamed Azalia) CODEC enables high-quality 192KHz/24-bit audio output, jack-sensing feature.
S/PDIF-out on Back I/O Port This motherboard provides convenient connectivity to external home theater audio systems via an optic
Grafička:
2.481,60 kn
nVidia PciX Gainward BLISS 7950GT DDT ,512Mb
(nema opisa)
Hard:
HDD Seagate 320GB ,16Mb , SATA2 , 7200.10 , ST3320620AS
3,5 "
Capacity: 320 GB
Buffer size: 16 MB
Interface: SATA II
Rotational speed: 7500 rpm
2x RAM:
RAM DDR2 GEIL 512MB , 533MHz , Retail
GeIL is proud to announce DDR2 PC4300 533MHz, supports CAS 4-4-4 with 256MB, 512MB and 1GB Single Channel modules.
GEIL PC2-4300 533Mhz DDR2 Single Channel
Available in 256MB to 1GB Single Channel
PC4300 533MHz CAS 4-4-4-12
64x8 DDR2 FBGA Chips
240pin, Non-ECC, Un-buffered DDR2 SDRAM DIMM
Aluminum Heat-spreader
6 Layers Ultra Low Noises Shielded PCB
Retail package
Life time warranty
1.8V Power Supply
6211,92 kn
Ovu si mislim konfiguraciju kupiti, pa samo da mi kazete misljenje o njoj jer kosta oko 6500 kn, a ne zelim neko sra.nje kupiti za toliko novaca.
Mislio sam staviti neku maticnu sa SLI, ali nisam mogao naci neku dobru, pa sam stavio ovu asusovu, ovo je naravno bez monitora...
Stavio sam i opis za svaku komponentu:
Procesor:
1.584,00 kn
Processor AMD Athlon™ 64 X2 Dual-Core
Model 4200+
Ordering P/N (Tray) ADO4200IAA5CU
Ordering P/N (PIB) ADO4200CUBOX
Operating Mode 32/64
Stepping F2
Frequency 2200Mhz
HT Speed 2000
Voltage 1.20V/1.25V
Max Temp 72°C
Thermal Power 65W
L1 Cache 128KB x2
L2 Cache 512KB x2
CMOS Technology 90nm SOI
Socket Socket AM2
Matična:
1.038,40 kn
MB Asus M2N DH
Support AMD® Socket AM2 Athlon 64 FX/
Athlo 64 X2/ Athlon 64 / Sempron
- AMD Live!™ Ready
- Excellent expansion: 1 x PCI-E x 16; 2 x PCI-E;
3 x PCI
- ASUS WiFi-AP Solo
- Asus DH Remote™
- ASUS MP3-In™
- ASUS Q-Connector
- High Definition Audio
Digital Home
Industry Standard
Dual-Core CPU
Asus DH Remote™
ASUS WiFi-AP Solo
ASUS MP3-In™
ASUS O.C. Profile
Other features
Grafička:
2.481,60 kn
(nema opisa)
Hard:
3,5 "
Capacity: 320 GB
Buffer size: 16 MB
Interface: SATA II
2x RAM:
Retail package
Life time warranty
1.8V Power Supply
6211,92 kn
Twisted_XD je offline   Reply With Quote
Staro 04.01.2007., 12:20   #2
aski
Je suis Schumi
aski's Avatar
Postovi: 1,524
Umjesto X2 stavi Dore 2 Duo - E6300 i 1GB u komadu i naravno socket 775 matična
Di sam stao?
Staro 04.01.2007., 12:27   #3
jonyb
jonyb's Avatar
Datum registracije: Apr 2004
Postovi: 887
kao što aski kaže umjesto X2, e6300 i npr. gigabyte S3 ili DS3.
za ram kingmax 667
jonyb je offline   Reply With Quote
Staro 04.01.2007., 12:27   #4
Gagi
Gagi's Avatar
Postovi: 197
Autor aski Pregled postova
MENI KONFA OK!
Gagi je offline   Reply With Quote
Staro 04.01.2007., 13:16   #5
PcKinG
Čiča s tamića
Lokacija: Prezid
Postovi: 326
eh da... i jas sam sastavio nku konfu za svoj upgrade i stavio sam isti CPU, grafu ali još neznam za MBO!! dilema između Asus M2N DH i MSI k9n Platinum nForce 570 bez sli-a. koja bi bolje šljakala??
@ Twisted_XD
meni je isto confa ok.... zakaj bi c2d?? mislim proc je i pol za pare koje stoji ali MBO??
moj komp no2:
Intel Pentium 4 Prescott 2.8GHz @ 3.4GHz, 1GB RAM 400 MHz @ 450 MHz, ASUS P4S800, Club 3D 7600GS AGP @ 470/450, 80GB WDC , 400W MS Industrial
moj komp3:
Intel Pentium 3 800MHz, 20GB HP HDD, 256 MB SDRAM, 200W CODEGEN PS, NvIdia TNT RIVA 32, MBO:MS-6309 LITE
PcKinG je offline   Reply With Quote
Staro 04.01.2007., 14:02   #6
gorluk
Čovjek
gorluk's Avatar
Postovi: 1,166
Twisted, kao što su ti i drugi rekli, bolje stavi Intel Core 2 Duo E6300 i odgovarajuću matičnu (npr. Gigabyte P965 DS3).
Što se tiče matične koja podržava SLI - mislim da ti tako nešto ne treba. Jedna jača kartica je bolja od dvije slabije u SLI, tako da se ne trebaš previše zamarati sa SLI / Crossfire.
Rekao bih ovako nešto:
Procesor: Intel Core 2 Duo E6300
Matična ploča: Gigabyte P965 DS3
1GB Kingmax 667Mhz, DDR2
Grafička: 7950GT
HDD: 320GB Seagate Barracuda, 16MB cache, SATAII (serija 7200.10)
Optički pogon: Pioneer / LG / NEC
Napajanje: Seasonic S12 380W / Silverstone Element 500W
Kućište: po izboru
Ako bi eventualno htio modularno napajanje, uzmi Corsair HX 520W (radi ih Seasonic). Što se tiče grafičke kartice, ja bih na tvojem mjestu prije uzeo 7900GS ili X1950Pro za 1500kn, pa napravio upgrade kad na tržište dođe više DX10 kartica i kad im cijena padne. I ovako i onako ćeš u jednom trenu napraviti DX10 upgrade, a 7950GX će se brzo obezvrijediti. 7900GS ili X1950 Pro će ti odlično služiti, a cijena im je u odnosu na performanse pristojna.
Umjesto tog Kingmaxa bi eventualno mogao uzeti Super Talent (CL5 ili CL4), ali te memorije su nešto skuplje, pa sam vidi.
Ovakav sistem ćeš moći fino OC-ati, ako te tako nešto zanima (C2D se tako dobro i lako clocka, da bi bilo grijeh ne nabrijati ga barem malo).
gorluk je offline   Reply With Quote
Staro 04.01.2007., 21:06   #7
PcKinG
Čiča s tamića
Lokacija: Prezid
Postovi: 326
što se tiče matične za X2 jel bolja Asus M2N DH ili MSI k9n Platinum i po čemu?
moj komp no2:
moj komp3:
Staro 04.01.2007., 22:24   #8
jonyb
jonyb's Avatar
Postovi: 887
MSI k9n Platinum ima užasno loše riješeno hlađenje, a kao što je poznato nforce 5 se grije dosta, za klokanje baš i nije nešto, nema neki raspon voltaža, te fsb neide više od nekih 260-270...
sa druge strane Asus M2N nije loša ploča ali je malo preskupa za to kaj nudi.
pono bolji izbor je Gigabyte M55plus-S3G, ploča je odlična. stabila i vrlo dobra za oc. i kaj je najvažnije povoljna.
Staro 04.01.2007., 22:55   #9
PcKinG
Čiča s tamića
Lokacija: Prezid
Postovi: 326
moj komp no2:
moj komp3:
Staro 04.01.2007., 23:12   #10
jonyb
jonyb's Avatar
Postovi: 887
Staro 05.01.2007., 00:11   #11
PcKinG
Čiča s tamića
Lokacija: Prezid
Postovi: 326
al ova ima inegriranu grafu... kak bi onda to kaj šljakalo s 7950 GT koju planiram stavit u PCI-E?
moj komp no2:
moj komp3:
Staro 05.01.2007., 00:26   #12
Juicy
Lokacija: Autocesta A1
Postovi: 251
Koliko znam nema nikakve veze sta ima integriranu grafu ti koristis svoju grafu u PCI-e slotu a to ti recimo moze posluziti ako ti se sta dogodi sa tom "glavnom" grafom da mozes bar raditi na kompjuteru
Juicy je offline   Reply With Quote
Staro 05.01.2007., 00:50   #13
gorluk
Čovjek
gorluk's Avatar
Postovi: 1,166
PC King, ne znam samo zašto si zapeo za tog Athlona od preko 1500kn. Za kojih 100-200 dobiješ E6400 ili za kojih 200kn manje dobiješ E6300, koji su bolji procesori (a kasnije ih možeš nadograditi i na neki Quad proc).
Autor PcKinG Pregled postova
Kako misliš "ali MBO"? Za C2D imaš veliki izbor ploča, nekoliko odličnih čak, i ne koštaju sve preko 1500kn. Već za 650kn možeš dobiti Asrock ConroeXFire, i ako ne namjeravaš overclockati ta ploča je čisto dovoljna, a ima i dobre onboard dodatke. Za 800kn dobiješ Gigabyte P965 S3 koja je sasvim ok, a za 1000kn dobiješ Gigabyte DS3, s kojom možeš fino naclockati E6300 ili E6400 (preko 3GHz). To ti se puno više isplati uzeti.
Staro 05.01.2007., 00:55   #14
Sam Fischer
Džabe si krečio!
Sam Fischer's Avatar
Postovi: 5,190
Ja bih kada kupujem vec takav komp na tvome mjestu isao na 2Gb rama
Sam Fischer je online   Reply With Quote
Staro 05.01.2007., 10:44   #15
tomifish2002
Honda Prelude 2.0i driver
tomifish2002's Avatar
Lokacija: Zagreb Dubrava
Postovi: 1,128
giga rama je totalno premalo. grafa če davat veliki framerate a igre će trzat zbog nedostatka rama. to je bezveze. ak baš nemaš love kupi sad 1 pločicu od gb i za par mjeseci drugu
tomifish2002 je offline   Reply With Quote
Staro 05.01.2007., 10:50   #16
Twisted_XD
Postovi: 2
da, to sam i mislio, jer trenutno nemam jos oko 1000 kn za jos 1 GB RAM-a, ps cu sad kupiti 1 GB, pa kasnije kad skupim novaca jos 1 GB, iako me to ne muci, nego me muci koji da procesor uzmem, vjerovatno cu E6300 sad kad sam sve ovo procitao
Staro 06.01.2007., 00:42   #17
Sam Fischer
Džabe si krečio!
Postovi: 5,190
E 6300 definitivno najisplatljiviji
Staro 06.01.2007., 16:08   #18
brale_
brale_'s Avatar
Lokacija: ST/Dalmacija/Hrvatska
Postovi: 10
Autor gorluk Pregled postova
...a za 1000kn dobiješ Gigabyte DS3, s kojom možeš fino naclockati E6300 ili E6400 (preko 3GHz). To ti se puno više isplati uzeti.
Di se to kod nas za 1k kn može uzeti ta ploča?
Po online cjenicima našao sam je jedino kod Ve-Mil-a za ~ 1200kn, tj samo 30ak kuna manje od DS4.
I koja je razlika između DS3 i DS4?
brale_ je offline   Reply With Quote
