Super Moderators
Datum registracije: May 2002
Postovi: 17,485
I novi Omega driveri...
Evo i njega Based on the official Catalyst 3.8 ATI drivers. (9x/ME/2k/XP) * All the new ATI Control Panel features included in the Catalyst 3.8 drivers are fully available here. (9x/ME/2k/XP) * Added a new intro to the ATI drivers installation. (9x/ME/2k/XP) * Personalized the ATI Control Panel. (Watch out for COPYCATS). (9x/ME/2k/XP) * Disabled 32Bit Z buffer by default in D3D for low end cards (if you need it, you can enable it anytime in the ATI CP). (2k/XP) * Incorporated the 9500/9700/9800SE MODs for Windows 9x/ME. (9x/ME) * Added RadClocker and Artifact Tester 5 for Windows 9x/ME. (9x/ME) * Added support for the Radeon 9800XT. (9x/ME/2k/XP) * Added suport for other Mobility cards. (9x/ME/2k/XP) * Updated the DirectX Control Panel to version 9.0b. (9x/ME/2k/XP) * Added a tweak to remove black borders from TV Overscan. (9x/ME/2k/XP) * Added MWV video DX hardware accelaration support. (9x/ME/2k/XP) REMINDERS: 1- If you have the normal ATI drivers, uninstall the ATI Control Panel BEFORE upgrading to these drivers, the drivers already have the CP integrated and another CP may cause conflicts or other problems. 2- There is no need to uninstall ANY previous drivers (ATI or OMEGA) when installing these, they will override any previous settings. 3- In Windows 2k/XP, ALWAYS disable DDC in the ATI "Displays/Monitor" CP after installing drivers to be able to use ALL the refresh rates and resolutions your monitor supports, also this is the best way to avoid the 60Hz RR bug. 4- The WDM drivers for VIVO and AIW cards are not included, but they can be downloaded separately from a link in my drivers page. 5- I have received various E-Mails asking about FastWrites, there is only one answer to that: TURN IT OFF The Radeon cards do support FastWrites and they will work with it on (on some machines), but it is not recommended, there is NO SPEED gain when using FW, and this option will affect your PC's stability a LOT. Dakle...znate gdije su... www.omegacorner.com |
Administrator
Lokacija: Sesvete
Postovi: 15,964
Je samo im je cjeli dan zagušen server. Nemreš ništ skinuti.. Zadnje izmijenjeno od: Jelc. 10.10.2003. u 12:09. |
Super Moderators
Postovi: 17,485
Super Moderators
Postovi: 17,485
Dakle... Novi driveri delaju fino Mark 01" je otprilike isti, 03" bolji. Igre idu fino. Stabilnost je ok. I to je to... |
#5 | |
Administrator
Lokacija: Sesvete
Postovi: 15,964
