Staro 09.10.2003., 22:51   #1
Overvide
Postovi: 541
**Abit NF7-S Beep Codes
Basic Beep Codes for ABIT AWARD BIOS Motherboards
No beep at all - this means your motherboard is dead, either due to a defective or underpowered power supply, poorly seated CPU or RAM, or a dead-on-arrival board
One beep - board is working fine
One long beep then machine shuts down - faulty, improperly installed or missing CPU
1 short(Beep) System booting is normally
2 short(Beep) CMOS setting error
1 long - 1 short(Beep) DRAM ERROR
1 long - 2 short(Beep) Display card or monitor connected error
1 long - 3 short(Beep) Keyboard Error
1 long - 9 short(Beep) ROM Error
Long(Beep) continuous DRAM isn't inserted correctly
Short(Beep) continuous POWER supply has a problem
A two-tone siren, generally caused by overheating or out of specification voltages
Four beeps then machine shuts down. This is because this version of the BIOS will shut down your machine if no fan tachometer signal is detected on the fan header. Make sure you attach a fan to the FAN1 or FAN4 header or clear CMOS to reset to default (no checking).
Ovo je sa abitovog foruma.Znam da je netko pitao da li abit ima neki dijagnostički sustav.Neda mi se ovo prevest jer već jednom jesam ali je pukla veza sa internetom i cijeli se post izbrisao.
Overvide je offline   Reply With Quote
Staro 10.10.2003., 00:26   #2
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Eto vidiš a ljudi se bune da ABIT nema dijagnostiku. Ima, ima ali moraš slušati da bi čuo, kao curu
Staro 10.10.2003., 02:31   #3
Isus
Headbangig Grunf!
Isus's Avatar
Datum registracije: Aug 2003
Lokacija: headbanger's ball
Postovi: 4,373
Taj netko sam bio ja.Pa dobro to mi je dovoljno doduše bio bi mi draži MSI ev sistem al i ovo je OK!Sam je malo zajebano onih 9 kratkih beepova!
Grunf je moj idol!
Moji Grunf type modovi
Alfisti site, Alfisti forum
Staro 10.10.2003., 17:39   #4
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Moja se glasa ko" hitna
A imam i "dijagnostičke" ledice
Piše na kutiji, a bogme su i na ploči, čist fino svijetle u mraku...
Ni ja, ni priručnik,ni proizvođač neznamo zakaj to služi.
Testovi na netu su otprilike rekli sljedeće:
Postoje ledice za dijagnostiku što je pohvalno-ali proizvođač nije za to isporučio nikakvu dokumentaciju
Nije ni dan danas
