Staro 24.12.2006., 18:27   #31
Tomo
Re-Registered User
Tomo's Avatar
Postovi: 627
Autor Bubba Pregled postova
Pf, da, vasi pomodni diskici s fancy Linuks distribucijama. Pravi diskovi tek pocinju raditi na 60ak° C...
Gle znam da oces mi biti frend jer znam lajnuks, ali ono .. daj ohladi : finger :
Tomo je offline   Reply With Quote
Staro 24.12.2006., 20:11   #32
Radeon
Postovi: 23
Oho, pa to je poznata WD Caviar serija diskova
Htio sam poludit sa tim diskom (isto WD2000JS), temperature od 49 C pa skroz tamo do 75 C. Kad ga ni Papst n2gme nije ohladio skužio sam da neš ne štima sa senzorom, a potvrda je došla iz WD-a:
"The temperature being reported is false. We are aware of the problem and are working on a solution. Our apologies for the trouble this issue is casuing. We do not know if and when a utility will be available to fix this. The drive is not defective but the temperatures that the revision of the drive you are using report to software are incorrect If possible, try (once) to open the tower and put your hand on the drive when it is reporting a high temperature to make sure the drive is not hot.
The drive reports 20 to 30 degrees C above the actual temperature. It is not a defective drive. These series of drives built between October 25th, 2005 and before mid-April 2006 have this issue. There is no upgrade utility option to fix this issue in the field. A factory calibration routine anomaly causes the drive to report temperature readings that are up to 20C higher than actual. Otherwise, the drives meet all of WD’s quality, reliability and compatibility standards."
Disk je i sa isključenim ventom hladan na dodir, eventualno malo mlak, tako da svima vama koji imate te diskove investicija u ventove nije potrebna.
Inače svaka čast WD tehničkoj službi kojoj je trebalo 45 min da odgovori...
Radeon je offline   Reply With Quote
Staro 24.12.2006., 20:33   #33
nicko
Postovi: 4,190
Mislis na maxtora?? : lol2 :
nicko je offline   Reply With Quote
Staro 24.12.2006., 23:15   #34
Matesonik
prcknedl
Matesonik's Avatar
Postovi: 3,131
moj maxtor (prva konf iz siga) radi na 29c. i ne laze
ne dirajte mi maxtora
Staro 25.12.2006., 12:17   #35
conquest
conquest's Avatar
Lokacija: Bjelovar
Postovi: 30
budem makno floppy, i jošp moram stavit 1 vent da upuhuje u kučište,
al ak je ovo istina onda neću ništa posebno radit...
conquest je offline   Reply With Quote
Staro 25.12.2006., 13:34   #36
Radeon
Postovi: 23
Ventilator neće nikako škodit, ali velim nemaš nikakve potrebe za njim. Usred ljeta SpeedFan 4.27 pokazuje 75 C, ja sam se htio objesit. Otvorim komp, isprepipavam disk, on mlak i hladniji (na dodir) od Maxtora 30 GB koji javlja 31 C, i nalazi se iznad WD-a.
Staro 25.12.2006., 14:24   #37
Postovi: 34,047
WD laže. Meni stalno pokazuje 56, a mlak je kao Barica koja ima 35. Jedan ventač ispred diska ne bi škodio.
Staro 25.12.2006., 14:35   #38
terminator
Spermich Termich
terminator's Avatar
Lokacija: Zaprešić
Postovi: 885
maxtor 40gb u loadu 30°C
nema venta
kad sam imao hladio je za još 3-5 °C
imo sam s njim problema, odjednom se počne grijat , tak nekoliko dana
terminator je offline   Reply With Quote
Staro 26.12.2006., 18:14   #39
Freek
Freek's Avatar
Lokacija: Zagreb/Dubrava
Postovi: 2,869
Moj WD-ac 120GB 26c konstatno
Staro 28.12.2006., 01:39   #40
Lud76
Leteći medvjedić
Lud76's Avatar
Postovi: 1,204
Jel moguće da je temperatura Maxtora 7200 o/m 17 celzijusa?? Po njemu puše Zalman vent 92mm
Lud76 je offline   Reply With Quote
Staro 28.12.2006., 01:45   #41
TomG
TomG's Avatar
Lokacija: Munich
Postovi: 2,222
Autor lud76 Pregled postova
možda ako živiš na sjevernom polu ili u hladnjači:clap:
neznam ne vjeruem bash...
Staro 28.12.2006., 01:46   #42
Tomo
Re-Registered User
Tomo's Avatar
Postovi: 627
ako HDD nista ne radi i sobna temp je oko 0C moguce ...
Staro 28.12.2006., 03:32   #43
Emissary
ČLAN FKTa
Emissary's Avatar
Datum registracije: Jul 2004
Postovi: 2,264
Po meni, moguće je ako je sobna temperatura dovoljno niska. Meni je sad baracuda na 23.
Staro 28.12.2006., 11:13   #44
Matesonik
prcknedl
Matesonik's Avatar
Postovi: 3,131
disk slobodno opipajte da vidite jel vruc, nije to cura da vas osamari
Staro 28.12.2006., 11:29   #45
thuNdeR
thuNdeR's Avatar
Lokacija: na sombra
Postovi: 1,048
30-35 hitachi čak i nakon obliviona i AA
thuNdeR je online   Reply With Quote
Staro 28.12.2006., 12:11   #46
Deathwish
overpowered
Deathwish's Avatar
Postovi: 915
tak i meni piše,a puše mi 120 mm vent po njemu(imaš stranicu prije),čuj to ovisi di je točno senzor,sumljam da može bit hladniji od sobne temp
@Work HP Zbook15
@Home Acer 5020
Deathwish je offline   Reply With Quote
Staro 28.12.2006., 23:52   #47
svebee
Lokacija: /
Postovi: 2,053
molim lijepo ljudi...btw. nije photoshop...nego samo dobra "ventilacija"...
http://www.imagesforme.com/images/9758PHISSEN 01.jpg
p.s. kopirati CIJELI link....
btw. obratite pozornost na to koje su komponente : lol2 : ("malko" se inače jače griju...)....
svebee je offline   Reply With Quote
Staro 29.12.2006., 01:43   #48
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Autor Radeon Pregled postova
Upravo tako. Moj WD se krece od 36-40C u idle-u do 45C u loadu a maltene je hladan. Senzori lazu, nema sta.
Staro 29.12.2006., 03:36   #49
turbulence
Postovi: 20
Autor SRV Pregled postova
je tako se i moj krece taj stari "crnjak" od 80gb...bez venta...
ali sad nabavih 250KS i vruc je dosta...a nebi rekao da su i na toj seriji lazljivi senzori...
temperature su mi bile bez venta u idlu od 45 do 50, a u loadu cak do 59...sad sam stavio da mi puse 92milimetarac i sad mi je u idleu oko 40 a kad je load ide do 54...
turbulence je offline   Reply With Quote
Staro 12.10.2007., 16:21   #50
esmeraldo
esmeraldo's Avatar
Lokacija: sarajevo
Postovi: 25
pi...n dim
u mene je temperatura hardiska stizala do 58 i to sve sa novokupljenom asus P5B plocom
a prije toga sa svim istim ali sa foxconn p945 temperatura je bila hard diska 40 i mislim da je to normalno.
nije samo hard disk bio vreo nego i juzni mst ICH8 onda tv tuner
reklamirao u trgovini gdje sam kupio, prave me budalom- sve je po njihovom normalno
tek kada sam izrezao bocnu stranicu kucista i ugradio vent 12 cm temperature su spale na evo sada 26 c
Autor Lud76 Pregled postova
mislim da nije
. ne moze biti manja od temoerature ambijenta, sobe u kojoj je racunar
Zadnje izmijenjeno od: domy_os. 12.10.2007. u 17:55.
esmeraldo je offline   Reply With Quote
Staro 12.10.2007., 16:30   #51
Postovi: 34,047
Poznato je da WD ima problema sa senzorima i da lažu oko 20 C.
Staro 12.10.2007., 18:55   #52
Baja 001
Baja 001's Avatar
Postovi: 7,504
Imam 2*40 mm puvala na HDD i moj Hitachi T7K250 radi na 26 i "uopšte" nije mlak nego je hladan!Nisam ga vdio po očitanjima senzora preko 35°C i ljeti!
Staro 15.10.2007., 16:20   #53
Mr.Ex.President
Torrent freek
Mr.Ex.President's Avatar
Postovi: 3,949
Uf teme, iz povjesti
U mene su Seagate 250 i Maxtor 120 u jednom kavezu, ispred njih je 80 mm ventilator na 12V. Ljeti im je load nekih 40-45 °C, a zimi padne na 30-ak
MBO: MSI B450 Gaming Plus
PSU: Corsair RM550X 550W
Periferija
LCD: HP ZR24w
Mouse: Logitech G400
Sound: Genius SP-HF1201A
Printer: HP LaserJet 1020
Scanner: HP ScanJet 4300
Headphones: Philips SHC 2000
MBO: Gigabyte GA-F2A85XM-HD3
HDD: WD Green 2TB [WD20EZRX]
PSU: Antec SU380
TV: Samsung 43E450 @HDMI
LINK
Staro 02.02.2008., 21:19   #54
TomG
TomG's Avatar
Lokacija: Munich
Postovi: 2,222
dosta stara tema,al da nemoram svoju novu kad vec owa postoji...
skontao sam da imam spuzve i tako sam malo natrpao oko harda (nikako hladenje nisam metnuo),temp je 40 sa otvorenim cesom,racunam jos najmanje 5 c gore kad se zatvori...
znam da nije dobro,a oce otapnit ako mu temp bude nesto malo manje od 45c?
fala
Staro 02.02.2008., 21:51   #55
mislav_os
freak
Postovi: 2,688
Autor Tomy no.1 Pregled postova
fala
Ne,ne bih mu trebalo biti nista...sanse su 1:1000 da crkne zbog temp od 45C(da se govori o tempama 50+,ajd..ali ovako (iako je men po ljetu moj Maxtor na 52C u IDLEU(sad je 35 ),al hajd,to je OT ))
Staro 02.02.2008., 22:30   #56
Swarm dude
Premium moderator
Swarm dude's Avatar
Postovi: 4,600
Temperatura jednog U320 SCSI diska:
Hmmm...temperaturom od ~32°C owna dosta 7200 o/min "vulgaris" diskova
MBO: MSI 760GM-E51 FX
VGA: Nvidia Quadro K600
SSD: Crucial BX500 1TB
Staro 04.02.2008., 18:14   #57
tutix
tutix's Avatar
Postovi: 4,069
temp je 40 sa otvorenim cesom,racunam jos najmanje 5 c gore kad se zatvori... znam da nije dobro,a oce otapnit ako mu temp bude nesto malo manje od 45c?
Ne mora bit da će se temperatura popet. Ovisi ti o propuhu koji imaš unutar samog kućišta. Mein Hitachi se popne do 45 °C sa otvorenom stranicom, kad ju zatvorim padne na 39 °C. Ne hladim ga posebno (npr. nemam neki vent usmjeren prema njemu), nego imam na boku 80mm-ac i na ispuhu isti takav (Glacialtech sa hydrobearing ležajevima (hell yeah ) al nije bitno). Al on neće crknut sigurno i od te temperature, diskovi inače podržavaju okolnu, kažem okolnu temperaturu do 55-60 °C.
Staro 04.02.2008., 18:42   #58
TomG
TomG's Avatar
Lokacija: Munich
Postovi: 2,222
fortron 350pnf,vent na procu box (x2 4000),(prvom prilikom ide sonic),jedan vent na 700rpm što puše po grafulji.
komp sad radi 2-3h,zatvoreno sve seagate je na 42.
ove spužvice izgledaju smijesno (gore je jos jedna),ali sluze.naprijed sam puko komad sperploce i također spuzva.
kontao sam okrenuti hdd od ovoga kako je sad i da jedan vent iznutra casea puse na 500 rpm po njemu(ne bi odnikuda vukao ladan zrak),neznam jel bi to sta skinulo temp?
cak mislim da nema potrebe...
Staro 04.02.2008., 18:58   #59
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Imao taj vent ispred HDD-a friški zrak ili tjerao samo onaj unutar kučišta - HDD će biti svakako hladniji. Naravno, sa friškim zrakom bi bile malo niže temperature (ali tu govorimo o 2-3°C što je zanemarivo).
Osobno imam 80mm ispred HDD-a, nema dovod friškog zraka, a HDD je opet na 32-33°C.
Staro 05.05.2008., 17:00   #60
tintin
tintin's Avatar
Lokacija: negdje
Postovi: 1,798
Koliku temp može podnjeti hitachi?
Imam 2 kom od 160gb i penju se na 50 do 52 °C.
tintin je online   Reply With Quote
