Staro 14.12.2006., 15:40   #1
ivan_zd
Lokacija: zadar
Postovi: 5
HP nx6325 EY577ES vs. FUJITSU SIEMENS AMILO PA 1510 120GB
ako mozete rijesiti moju veliku dilemu izmedu ova dva laptopa..prvi dodje 5799kn u ve-mila....
Zaslon 15" XGA (1024x768) Bright View
Procesor AMD Mobile Turion 64 X2 TL-52 (1.6GHz)
Chipset ATI Xpress 1150 HDD80 GB (5400 okretaja)FDD-
Optički pogon DVD+/-RW DL Supermulti
Memorija 1GB DDR2 667MHz (2 DIMM - 2x512)
Grafika Integrirana ATI Radeon Xpress 1150 Do 128-MB dijeljene memorije
Fax modem 56K v.92 modem
Povezivost Broadcom NetLink Gigabit Ethernet PCI Controller (10/100/1000)
Wireless Broadcom 802.11 abg Integriran Bluetooth modul
Multimedia PremierSound High Definition Audio w/24-bit DACI/
ORJ11, RJ45, SD 7u1 čitač kartica, 1x tipI/II PC Card, X34/54, VGA, IEE1394, 3 x USB 2.0, utor za docking,
Fingerprint
TPM 1.2
Disk sanitizer, hard disk protection system
Baterija: 6 cell Li-Ion baterija
HP Fast Charge Technology
drugi je Fujitsu Siemens AMILO PA 1510 120GB i dodje 5699 kn u prosata...
Procesor:
AMD Turion64 X2 Mobile TL-50 (1,6GHz, 256KB L2 cache)
• Ekran:
15.4” TFT / LCD WXGA (1280 x 800) display with CrystalView Technology
• Memorija:
1GB (2x512MB) DDR2 533MHz
• Hard disk:
120GB SATA HDD (5400rpm)
• Optički uređaj:
DVD+/-RW uređaj dual layer
• Grafika:
ATI Radeon® Xpress 1100 do 256MB shared VGA memory
• Zvuk:
2 x stereo zvučnici
• Mreža:
10/100/LAN
• Modem:
56K V.92
• Bežična mreža:
WLAN 802.11b/g
• Portovi:
1x IEEE1394,
3x USB 2.0 ports,
1x S-Video
1x CRT,
1x modem, 1x LAN, 1x WLAN
1x ExpressCard slot (34/54mm)
1x line in shared with microphone in,
1x headphone out shared with 1x SPDIF
1x power supply
1x 4-in-1 card reader SD/MS/MMC/MSPRO
Fingerprint
TPM 1.2
ne razumim sta znaci ovo u FS 256Kb L2 cache tj. zasto je to tako malo kad je svagdi drugo 1Mb tj. da li mi to puno znaci u kupovini kad laptop nece biti upotrebljavan za nista teze cak ni igrice, kod HP-a taj podatak uopce ne pise pa ako netko zna koliki je. Mozete mi i preporuciti neki laptop u ovom cjenovnom rangu koji ima otprilike slicne karakteristike..Hvala svima na odgovorima i oprostite ako je nesto neuredno ali sve sam bio napisa i zabunom mi se izbrisalo, pa sam na brzinu sve morao opet.
ivan_zd je offline   Reply With Quote
Staro 14.12.2006., 16:01   #2
Postovi: 34,058
TL-52 ima 512kb cache-a, a brzina mu je jednaka kao i kod TL-50 (http://www.amd.com/gb-uk/Processors/...13911,00.html).
FJ ima malo zericu slabiji cpu i sporiji ram, ali veći ekran. Grafika im je ista. U praktičnom radu, na nezahtjevnim poslovima (internet, Office,...), se ta razlika ni neće osjetiti.
Osobno sam radio na HP-u, ali kratko. Ništa specijalno da se ističe. Koliko sam vidio, mnogi hvale tu HP-ovu seriju kao kvalitetnu i trajnu.
Staro 14.12.2006., 17:24   #3
ivan_zd
Lokacija: zadar
Postovi: 5
Autor coconut Pregled postova
jel ima 512kb cache-a ili 2 x 512 kako pise na ovoj stranici..
da vidio sam da dosta hvale ovu seriju hp-a i to je jedan od razloga zasto cu se vrlo vjerojatno i odluciti za njega, a to sta je manji ekran nema veze jer vidim da ce tako ujedno i trositi manje baterije a to mi je dosta bitno.
Jos da je imat novaca pa uzeti jacu verziju nx 6235 : hitthewa
Staro 14.12.2006., 19:12   #4
Postovi: 34,058
512kb cache po jezgri. A kako ima dvije jezgre (X2), to ti je 2x512kb
http://www.tomshardware.com/2006/08/...ved/page3.html
