Postovi: 12,425
review Tagan TurboJet 1100 W
Evo jedan dobar review napajanja nema testova u smislu opterečenja no ima u smislu detaljne analize komponenti (nešto što će posebno dragu zanimati) pa uživajte http://www.hardwaresecrets.com/article/403/1 i da moram li reči da su duboko razočarani u napajanje jer je topower opet uspio uništiti dobro započet posao :sad: We were very disappointed by this power supply. It comes with a terrific presentation, however the design it uses inside is flawed: it has two transformers but instead of using two complete separated circuits, this power supply shares the same switching section between the two transformers and the same secondary filters for the +12 V outputs coming from the two transformers, making it impossible to achieve its labeled power. Tagan TurboJet 1100 W is labeled at 25º C and our friends at Planet3Dnow.de couldn’t pull more than 768 W from the +12 V lines (which are labeled 960 W) even at 25º C. What a bummer! This could be a good product if Tagan labeled it at a lower power rating (e.g. 850 W) and lowered a lot its price. Which the current settings, this product is simply a no buy. u istom review-u n azadnioj stranici imate link na ovaj roundup pa ak šprehate švapski samo naprijed http://www.planet3dnow.de/artikel/ha...nd/index.shtml
Lokacija: n/a
Postovi: 6,128
ccc al se Tagan ovih dana bruka...kad se jos sjetim 530W(jel ono bi 530W) Taganceka kod jonny-ja...uhhhh Strasno. |
Prečupavi mod
Postovi: 9,107
Strasno ![]() ![]() ![]() ![]()
Member of PCE 100+kg demolition squad Pozz, nezz, ojzz, jbt, owak, onak, inst, bzvz, svst, kuiš, neam, dns, nzm, oc, went, graf, laikam, oču, neču, e ovako, e sad, probo, neče, psmtr, ne beliiwam, ugl probo o5, tkđ neradi, pčkmtrnu, mslm onaak haaalo, reko dbr, stv, dali, jeli, zato jel, jer mi može neko, rispekt, thx......... ...wau, radi, zkn, pozz!?!?11 |
Lokacija: n/a
Postovi: 6,128
Hehehe makar ga nijedna danasnja konfa nece opteretit sa vise od 500W ![]() A to sto je deklarirano za 1100W a max. je u biti 768...to je drugo ![]() |
