Staro 04.12.2006., 12:29   #1
Fire Fox
Fire Fox's Avatar
Lokacija: Dalmacija
Postovi: 135
Lightbulb Kako do najboljih performansi
Molio bi za pomoc ako moze nabavi sam MB Gigabyte GA-M59SLI-S5 Procesor AMD Dual core 3800+ Memorija je Kingmax Super Ram 800Mhz 2x512 stavio u dual chanel mod
Sve mi je sad po difoltu jel moze netko tko ima takvo nesto da mi predlozi kako da podesim da dobijem sto bolju performansu : hitthewa : hitthewa
Hvala unaprijed na pomoci : goood : : goood :
Pozdrav svima
Fire Fox
Sve je hitno kad se kasno trazi !
Fire Fox je offline   Reply With Quote
Staro 04.12.2006., 12:42   #2
nino
nino's Avatar
Postovi: 12,613
Ajde definiraj "po difoltu". Koje su postavke? Usputno pitanje kako si stavio 9200es na tu MB?: stoopid
Staro 04.12.2006., 14:55   #3
^SuperUnknown^
Prečupavi mod
^SuperUnknown^'s Avatar
Postovi: 9,129
Mozda je 9200SE PCI
EDIT: mislim da smo i ti i ja zabrijali, ta 9200 mu je upiknuta u Barton konfu : lol2 :
Primary macine:
Apple Mac Pro 5,1
64 GB ECC DDR3 800 MHz
Geforce GTX 980 4 GB
Kingston 120GB SSD
30 TB HDDs
Sharkoon QuickPort@USB
Optiarc DVD RW AD-7170A
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
22 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 970 4 GB
Seagate 500GB 7200.10
Hitachi 1000GB 7K1000.B
Seagate 1000GB 7200.11
Hitachi 7K3000 3000GB
Mac OS X 10.10.3
Work rig:
Apple Mac Pro 1,1@2,1
13 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 660 2GB
Seagate 500GB 7200.12
2xWD Black 1000GB
2xSharkoon QuickPort@eSATA
Mac OS X 10.10.3
Sony KDL-26U2000 26"@HDMI
Apple Alu Keyboard
Logitech MX518
LAP:
Apple Macbook Pro 3,1
Intel Core 2 Duo 2.53 GHz
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
iPhone 6S 64GB black
iPad 16GB WiFi 4.3.2
* Connected via:
90/90 Mbps Iskon Trio
* "Powered" by:
UPS APC Smart-UPS1500VA
* Playing:
Tama Arstar II
Yamaha DTXPRESS IV Special
Staro 04.12.2006., 17:50   #4
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Ako već nije, djelitelj memorije na 800 staviti, tako da memorija radi na defoltu svom. Sniziti latencije na nekih 4-4-4-12 i provjeriti dal će raditi.
Sve ostalo je stvar OC-anja, a pošto nisi stavio u OC podforum, nisam siguran dal ti to oćeš?
Ako oćeš, onda djelitelj memorije na 667 (latencije 4-4-4-12), HT multy na 4x. i sa tim postavkama si osigurao da ti do ~250Mhz HTT-a ne koči ništa osim procesora. Lagano, dizati po 10-20Mhz HTT i testirati sa Super PI 32M ili OCCT-om ili Orthos Prime-om (nekih 30min). Kada je nestabilno, odlučiti, je li dovoljna dobivena frekvencija (pa onda malo smanjiti i opet testirati) ili dodati malo više napona Vcore-u i ići dalje.
Iznad HTT 250, spusti HT multy na 3x i memoriju na 533, tako da te opet ne koči ništa. Kada dođeš do zadovoljavajuće frekvencije, onda se ide isprobavati do kuda ide memorija. I onda se najbolje od jednoga i drugoga pokuša složiti tako da se dobiju najbolje performanse od procesora i memorije. Jer kod AM2, bolje je da memorija radi na malo višim frekvencijama (>800Mhz) pa makar sa CAS 5.
Ovako od oka, mogao bi povući 250-260x10 na defolt naponu. Možda manje, a možda i više....
