Postovi: 12,425
Potreba za 500+W napajanjima?
Što mislite? http://theinquirer.net/default.aspx?article=36066 slične stvari se ovdje tupe već dulje vrijeme ali ipak im aljudi koji govore kako je za 3000+Venice sa X1900GT i jednim 250GB diskom potrebno min 450W brand name
Lokacija: n/a
Postovi: 6,128
Hehehe sta su sve nabacali a ono potrosnja samo 429W ![]() |
Postovi: 12,613
Mene jedna stvar muci....cijelo popodne razmisljam dali postavit pitanje ili...ma ajde. : flyingey Koji qratz napaja recimo jedan lap sa c2d procom, 1-2 giga rama. 7600 grafom, sata diskom...znam da su sve komponente low power ali opet u mislima sam fasciniran a nisam primjetio da je netko to pitao na forumu. Kakav je to sklop i kako se razlikuje od pc napajanja osim po kilazi? Nadam se da ste shvatili, @Wolv sory za OT....
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Može li to više? Naravno da može... 500W+ must have ![]() X-bit labs : " To back up what we have just said, we measured the power consumption of the Quad FX platform (in the tested configuration) with two Athlon 64 FX-74 processors. Even in idle mode with enabled Cool’n’Quiet technology (without the monitor power consumption of course) this system consumed 192W of power, which is more than most contemporary systems would require for 100% workload. As for the maximum power consumption level, we managed to hit 501W when the system was running fully loaded. However, it is no secret that Quad FX systems can consume much more than that, because this time we didn’t take into account the power consumption of the video subsystem, as it wasn’t loaded at all. " Testna platforma: 2 x AMD Athlon 64 FX-74 (2x Socket 1207, 3.0GHz, 2x1024KB L2); ASUS L1N64-SLI WS (Dual Socket 1207, NVIDIA nForce 680a SLI); 2GB DDR2-800 SDRAM (Mushkin XP2-6400PRO) PowerColor X1900 XTX 512MB; Western Digital WD1500AHFD. He, natrpaš gore još 2x8800GTX i da vidiš, kladim se da bi išlo na 600W ![]()
"Everything with a heartbeat can knock you down" Zadnje izmijenjeno od: Vuco. 03.12.2006. u 13:47. |
Postovi: 12,425
vuco imaš tipfeler nije konfa A64 FX74 već 2x A64 FX74 + sve ono.... a čuj to je već opaka mašina a i mora se to imat ćim i opteretit a i ti novi Athlončeki vidim vole cicat ![]() no opet danas kikići odu u dučan di im striček uvali 550W MS ili Raptoxx jer njihov A64 3000+ sa 7600GT i jednim diskom ipak puno troši ![]()
Postovi: 9,505
Ispravljeno, fala ![]() Ma to sam ja samo malo pod****** tebe ![]()
#9 | |
Postovi: 9,505
Mada, stvarno ne bi škodilo da se počne štediti, a ne povećavati potrošnja. Tko će hladiti te zvijeri? Ali ovo su ekstremne situacije....normalni komp, malo OC-an i za današnje standarde ne troši preko 350W, nikako. I to sam previše dao fore...
#10 | |
Beskorisna bitanga...
Lokacija: Sesvete (Zg)
Postovi: 6,956
![]() Stvar je u tome što te dobro napajanje košta barem kunu po watu... Ako krenemo od toga recimo 2x430w te košta oko 850-900kn + big tower koji moraš kupit za dva psua vrtiti bar oko 700 kn (dakle oko 1500-1600kn) dok te kombinacija PSU od recimo 800w i dobrog midi towera košta jednako tolko ili manje, a zauzima i bitno manje mjesta... ![]()
-- Have a nice day... Zadnje izmijenjeno od: yedwy. 03.12.2006. u 19:51. |
Postovi: 1,361
Za Athlona64 3200+, HDD 160 Gb, DVD, Prza, 2 Gb meme, ATI X1950 Pro dosta Cuftek od 360 W ? |
Postovi: 9,505
#13 | |
Avocado
Postovi: 7,856
![]() tak i tak sam mislio ici na nesto 2x550W ![]()
Spoiler alert! |
