Staro 03.10.2006., 20:44   #1
mante
Datum registracije: May 2005
Postovi: 176
Ima li Win XP PhoneDialer i Fax program ??
U svim prijašnjim verzijama windowsa postojali su programi PhoneDialer i Windows Fax. Da li Xp ima te programe negdje na instalacionom CD-u koje treba naknadno instalirati.
mante je offline   Reply With Quote
Staro 04.10.2006., 00:32   #2
mirkoB
mirkoB's Avatar
Datum registracije: Feb 2003
Postovi: 783
To install the Fax component
Open Add or Remove Programs in Control Panel.
Click Add/Remove Windows Components.
In the Windows Components Wizard, select the Fax Services check box, and then follow the instructions on your screen.
Notes
To open Fax after installation, click Start, point to All Programs, point to Accessories, point to Communications, and then click Fax Console.
Da bi koristio fax moraš biti logiran kao admin.
To Run Phone Dialer on Windows XP
To run Phone Dialer, click Start, click Run, type dialer.exe, and then press ENTER.
Back to the top
To Add Phone Dialer to the Communications Menu
1. Click Start, click My Computer, and then double-click the partition in which Windows XP is installed.
2. Navigate to the following folder:
Documents and Settings\All Users\Start\Programs\Accessories\Communications
3. In the Communications folder, click File, click New, and then click Shortcut to start the Create Shortcut wizard.
4. In the Type the location of the item box, type c:\program files\windows nt\dialer.exe.
5. Click Next.
6. In the Type a name for this shortcut box, type Phone Dialer.
7. Click Finish.
Čovjek nađe čuda u WinXP helpu.
| AVG Free 7 | SPF 5.6 | SS&D 1.4 | MBSA 2.0 |
| Firefox & Thunderbird 1.5 | MozBackup 1.4.4 | POPFile 0.22.2 |
| 7-Zip 4.32 | VMWare Player | nLite 1.0RC7 | Qemu 0.7.2 |
| PDFCreator 0.8.0 | Open Office 2.0 | Readiris Pro 8 |
| UltraVNC 1.0.1 | Media JukeBox 8.0 | Burn4Free 2.3 |
| Pentium D 805 | ThermalTake BigTyp 120 |
| Gigabyte G945P-S3 | 1024/667 Kingmax DDR2 | 160 GB Hitachi SATA2 |
| Enlight 430W | Antec Solution SLK3700AMB | OKI OL400w |
| XP Home SP2 zakrpan do jaja + Windows 98SE Virtual Machine |
| 178/81 |
| Cipele br. 42 |
| 35 godina |
mirkoB je offline   Reply With Quote
