Staro 20.09.2006., 15:46   #1
neno20st
Lokacija: Višnjevac
Postovi: 202
Chieftec power supply 400W
iskustva sa doticnim napajanjem? u vemila:
Chieftec power supply 400W, ATX 2.0, 2×12V, Active PFC, AFC, 12cm FAN, bulk
napaja bi ovo nesto:
PROCESOR
Intel Core 2 Duo E6400 BOX, 2×2.13GHz, 1066MHz, 775-pin, 2MB
MATICNA
MB Gigabyte 965P-DS4, s775, i965, DDR II, SATA II RAID, FW, GLAN
MEMORIJA
DDR2 1GB PC5300 (667Mhz) Kingmax
HARD DISK
HDD Seagate ST3160812AS, 160 GB 8MB, S-ATA300, 7200
GRAFICKA
Leadtek GF 7600 GT TDH, 256MB, PCI-E, TV-out, 2 x DVI
KUCIŠTE
Chieftec midi tower BH-02B-B-B
hvala unaprijed
neno20st je offline   Reply With Quote
Staro 20.09.2006., 15:49   #2
Wolverine
Wolverine's Avatar
Postovi: 12,429
Dosta dobro i kvalitetno napajanje za te novce
Navedeno će moći napajati bez problema
Također je i onaj Fortron od 400W dosta dobar
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 20.09.2006., 16:20   #3
jonyb
jonyb's Avatar
Datum registracije: Apr 2004
Postovi: 887
kak veli Wolv dosta dobro napajanje, stabilni naponi... ali ako patiš na tišinu možda bi te mrvicu mogla smetati buka. ako je tako onda rađe uzmi fortron ipak je dosta tiši.
jonyb je offline   Reply With Quote
Staro 20.09.2006., 16:21   #4
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Ja ga imam. Furam OC-anog P4, 7600GT, 4x Hard Disk, 2xoptika, 4 stika memorije i hrpa ventova. Nikad problema s njim, full kvalitetno i dobro. preporuka.
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 22.09.2006., 21:55   #5
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,507
Najveća zamjerka - GGLLAASSNNOO!! Imao ga 9 mjeseci, zajedno smo hrkali svaku noć.
