Lokacija: split
Postovi: 119
Mišljenje o konfi
Molim vas mišljenje o konfi upotreba Cad,Adobe, statički proračuni, vizualizacija okoliša Memoriju ću poslije još pojačat samo me buni ima ploča dual za memoriju reg i no reg koja je razlika Tyan Thunder h2000M (S3992G3NR) Opteron 2000/ DDR2/ SATA/ RAID/ V&3LAN Server Motherboard MB-S3992G3 $427.45 $427.45 AMD Opteron Dual-Core Processor Model 265, OEM OS-265 $265.74 $531.48 Samsung DDR2-667 2GB/128x4 ECC/REG Original Memory D2667R2G4S $298.70 $1,194.80 Seagate ST3750640AS 750GB SATA2 7200rpm 16MB Hard Drive HD-ST750BS $352.26 $704.52 Leadtek nVidia GeForce 7950GT 512MB 2DVI/HDTV SLI PCI-Express Video Card LT-7950GT5 $303.85 $607.70 Topower/Epower Tagan TG900-U95 900W Quad SLI Power Supply PS-900U95 $267.80 $267.80 Zalman CNPS9500LED-CU Aluminum/Copper CPU Fan For Socket 478/775/754/939/940 FAN-9500CU $53.56 $107.12 Evercase R7270B-E35 350W EPS EATX 2U Rackmount Server Chassis (Black) CA-7270E35 $175.10 $175.10 Plextor PX-755SA 16x DVD+RW/-RW Drive w/Beige Bezel (Black), Retail PX755SA_SW $120.51 $241.02 Any changes above should be verified by pressing'Recalculate' Sub Total $4,256.99 |
the luda ribetna
Postovi: 3,952
tolko jako napajanje?!cemu? inace trebao si napisat da su neek svari 2x tj 4x ![]() edit: pospan sam...ne pitaj uglavnom lijepa konfa/server...to ce ugodno raditi, samo nemoj rec da oce klokat i sve 5 |
Postovi: 718
#4 | |
the luda ribetna
Postovi: 3,952
kak mislis da sam skuzio da je 2x i 4x(za ram samo)![]() a sto se tice napajanja...dosta ce ti bit i 700w (salu na strau) 500w i mos jos nadogradivat |
#5 | |
Postovi: 718
![]() A sto se tice napajanja, danas procitah clanak (nije bitno koji caspois ) i bio neki file server (40ak sata2 diskova) i to chudo trosi 1.2 kW...pa eto...orijentir kad se kupuju wati ![]()
#6 | |
the luda ribetna
Postovi: 3,952
jer disk trosi kojih ajmo rec 10 w(citaj cca dupla snaga nego u stvarnosti) to je onda 400 w na diskove...grafa maticna proc itd... trosi oko 600 max...sad...kad pogledas quad sli trosi ako 400w : bonker : nemoguce da je 1.2 kw...edit: nisi naveo dal je to cijeli rack bio ili samo 1 ![]() |
Postovi: 718
Kako mislis cijeli rack? Hmmm...znam da je bio 2x Opteron i hmmm... 48 ak se ne varam diskova...i da, s razlogom sam napisao nije bitno koji casopis, jer bi me odmah popljuvao (nije bug, ali je na njihovim stranicama )....i da, ako se ne varam pisalo je ovako; "i trosi "samo" 1200 W" ![]()
the luda ribetna
Postovi: 3,952
pa recimo da je ono rack od 5 masina...ok mozda i moze al jedan komp NEMOGUCE |
Postovi: 19
da stvarno...750 GB HDD ??? : giljotin To josh nisam vidio...
CPU Core 2 Duo E6300 DDR2 1 GB 667 MHz nVIDIA GeForce 7600GT 256MB HDD WD 250 GB WD 2500 KS DVD RW ASUS |
Postovi: 718
Suit up!
Postovi: 5,975
Mislim covjek kupuje prakticki miniracunalo i onda pita na pce forum. ![]() Graficka Quadro FX ili FireGL?
Hejter
Postovi: 6,521
kaj na tom kucistu bude pisalo NASA ? bolesno zvuci |
the luda ribetna
Postovi: 3,952
nasa?maximalno pce ovo nejde ni u blizinu nase![]() |
Lokacija: split
Postovi: 119
Moram skinut cijenu konfiguracije šta mislite koji procesor da odaberem OPTERON 246 2GHZ S940 1MB 800FSB BULK $129.00 oko 800 kn OSA246CEP5AU AMD OPTERON 246 OSA246CEP5AU OPTERON 246 2GHZ S940 1MB 1000FSB BULK $150.00 OPTERON 248 2.2GHZ S940 1MB 800FSB BULK -$159.00 OSA248CEP5AL AMD OPTERON OSA248CEP5AL OPTERON 244 1.8 GHZ DP S940 1MB 800FSB -$125.00 A isto neko je na forumu pitao za singl Opteron OPTERON 144 1.8GHZ S940 1MB 800FSB BULK - IN STOCK 74 PCS. manufactured by AMD $99.00 OPTERON 146 2.0GHZ S940 1MB 800FSB BULK - IN STOCK 109 PCS. manufactured by AMD $109.00 OSA146CEP5AT AMD Opteron Processor Model 146 Product Type : Server Processor Processor Type : AMD Opteron Clock Speed : 2.0 GHz Cache Memory : L1 - 128KBL2 - 1MB Compatible Slots : Socket 940 Processor Core : Stepping CG Manufa Memorija Dell X1562 Dell DDR2 Memory 1GB Speed : PC2-3200 Capacity : 1GB Registered/Unbuffered : Registered Ecc/Non-Ecc : ECC Number of Pins : 240 Form Factor : DIMM cl3 --109 Us$ ili 345113-551 HP HEWLETT PACKARD COMPAQ 345113-551 HYS72T128000HR-5-A cl3 109 Us $ |
#17 |
Lokacija: Sinj
Postovi: 1,080
eadtek nVidia GeForce 7950GT 512MB 2DVI/HDTV SLI PCI-Express Video Card LT-7950GT5 $303.85 $607.70 što će ti ovo za statičke proračune,CAD etc...Oćeš se igrati s proračunima? Imaš zato profi kartice aka Wildcat,Matrox...
#18 |
Lokacija: split
Postovi: 119
Konfa je stigla dva dana sam je sastavljao zezala memorija na kraju je ušla no name memorija stroj je pretežak tribaju dvojica za nosit.Benchmark ne pokazuje neke bijesne rezultate u radu sa memorijom.Ali windowsi se dižu u par sekundi,programi se otvaraju u sekundi.Stroj je strašno bučan normalno ima 16 ventova. Znači iako mi niste ništa pomogli hvala vam |
