Staro 17.09.2006., 16:56   #1
Ace88
Ace88's Avatar
Lokacija: Bihac, BIH
Postovi: 77
USB problem na Abitu NF7-S2G
Neznam da li je ovo hardverski ili softverski problem ali nadam se da je rijesiv. Naime, svaki put kad komp iskljucim iz struje moram USB kabal od modema i Gamepada istekati i opet ukljuciti da bi radili, BIOS mi je flashan na najnoviji za ovu plocu(iz 2005te kraj). Moglo bi biti do drivera jer nisam dobio CD uz maticnu pa sam trazio po netu,
Pomozite!
Ace88 je offline   Reply With Quote
Staro 17.09.2006., 23:49   #2
Postovi: 23,635
Staro 18.09.2006., 23:46   #3
Ace88
Ace88's Avatar
Postovi: 77
odatle sam skidao driver za USB, a nista pokusacu reinstall windowsa, ionako mi je pola godine star i sljaka mi komp malo
Staro 19.09.2006., 01:41   #4
joolka
music freak
joolka's Avatar
Lokacija: Sibenik
Postovi: 3,317
...meni se to isto desavalo na gigabyte k8nsc ploci,rijesenje nisam nasao,a nisam ga ni trazio
LENOVO LEGION 5 Pro Gaming Laptop (AMD Ryzen 7 7745HX,RTX 4060,32gb DDR5,2tb SSD)
Staro 19.09.2006., 11:28   #5
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
A pokusaj staviti neki stariji bios. NF7 ima tone biosa, jedan bi ti mogao proraditi. Vjerojatno je greška u tome...
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je offline   Reply With Quote
Staro 19.09.2006., 12:57   #6
Ace88
Ace88's Avatar
Postovi: 77
imaju samo 2 biosa za NF7-S2G, a sa starim biosom je nestabilna kad dignem FSB za 1 , radije cu se muciti sa USB-om nego se vratiti na 2600+
