Staro 11.09.2006., 13:50   #31
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Evo, danas sam je kupio za 1250kn u ve-milu.
Napravit cu mali review malo kasnije ili sutra kad stavim nove vindoze.
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 11.09.2006., 16:44   #32
undo
You'll Never Walk Alone
undo's Avatar
Postovi: 1,287
e to cekamo,pa da vidimo iz prve ruke kakva je
undo je offline   Reply With Quote
Staro 11.09.2006., 17:27   #33
Choob
ECC Registered User
Postovi: 50
Thumbs up
kupio u vemulju u subotu .. do sad sam imao 6600 (isto leadtek) ...
prezadovoljan : goood : ... dobije se serious sam 2
Choob everything.
Choob je offline   Reply With Quote
Staro 11.09.2006., 17:39   #34
joolka
music freak
joolka's Avatar
Lokacija: Sibenik
Postovi: 3,308
Autor Choob Pregled postova
..jesi detaljan,serious sama dobijes i sa 7300gt,daj malo 3d mark i ostale djide midje
LENOVO LEGION 5 Pro Gaming Laptop (AMD Ryzen 7 7745HX,RTX 4060,32gb DDR5,2tb SSD)
joolka je online   Reply With Quote
Staro 11.09.2006., 19:52   #35
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,844
Autor Panzer Pregled postova
ipak ti vrag nije dao mira pa si je kupio,brzo brzo testove da je idem i ja kupiti jer nimeni ne daje mira,samo spusti takt na 3,0 ghz,jer imamo skoro iste konfe: cheers2
Staro 11.09.2006., 21:43   #36
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,850
moraju oni prvo stavit najskuplju novu generaciju kartica u prodaju... da je u vrijeme kad sam ja kupovo grafu bila doticna ne bi ni pomisljo, 7600GT bi bio izbor... ovak sam kraci za par kila kuna, ali ipak imam GS+
Spoiler alert!
Staro 11.09.2006., 21:54   #37
Panzer
Panzer's Avatar
Postovi: 1,814
Ko ceka, taj doceka...
Odoh ja nac drivere za ADSL i rusit windoze...
Kasnije napravim test grafe, ali ovak kaj sam je koristio mogu rec da je dosta brza od 6800LE (16x6)...
UPGRADED...
