#91 |
Postovi: 233
official forum pain in the ass is back : hitthewa ....Zao mi je ljudi al moram pitat nesto...ma eto sta je tu je desilo se nesto tj iskrslo je nesto pa moram cekat do pocetka 10 mj. da kupim komp napokon. Uglavnom neke stvari su se promijenile, nestao je x2 3800+ (u ve-milu je navodno "trenutno nedostupan" i kosta 1380 kn) a slijedeci proc je 1500 kn tj x2 4200+. Moje pitanje je da molim Vas usporedite jednu i drugu varijantu ispod, hvala (da jos nisam makao gigabyte plocu ![]() Gigabyte K8NF-9 Ultra,s939,nForce4, FW, GLAN............................597 kn CPU AMD Athlon64 X2 3800+ BOX, dual core, Sck939...................1378 kn (ili cak stvarno x2 4200+ ako stvarno nigdje ne bude vise x2 3800+, ali to je onda 1500 kn) DDR 1GB PC3200 (400MHz), Samsung, ST...................................783 kn DDR 1GB PC3200 (400MHz), Samsung, ST....................................783 kn HDD Seagate ST3250824AS, 250 GB 8MB, S-ATA300, NCQ, 7200........618 kn Gainward BLISS 7600GT GS, 256MB.............................................1434 kn DVD ROM LG, 16/48x, ATAPI, black, bulk..........................................133 kn DVD+RW/-RW/RAM LG GSA-H10A, Dual Layer, 16x, black, bulk............269 kn Thermaltake mid tower Mambo, bez PS, crno..................................344 kn Chieftec power supply 450W, ATX 2.0, 2×12V................................380 kn Ukupno: 6719 kn OOOORRRRRRRRRRR (izbacen je DVD rom i smanjen HDD): Gigabyte K8NF-9 Ultra,s939,nForce4, FW, GLAN............................597 kn CPU AMD Athlon64 BOX 3800+, Sck939......................................972 kn DDR 1GB PC3200 (400MHz), Samsung, ST................................783 kn DDR 1GB PC3200 (400MHz), Samsung, ST...................................783 kn HDD Seagate ST3160812A, 160 GB 8MB, ATA-100, 7200..................462 kn Leadtek GF 7900 GT TDH, 256MB...............................................2085 kn DVD+RW/-RW/RAM LG GSA-H10A, Dual Layer, 16x, black, bulk............269 kn Thermaltake mid tower Mambo, bez PS, crno................................344 kn Chieftec power supply 450W, ATX 2.0, 2×12V.............................380 kn Ukupno: 6675kn Zadnje izmijenjeno od: yggdrasil. 11.09.2006. u 13:35. |
#92 |
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Prva verzija ako ne se buš previše igral i/ili ako ne patiš da sve bude na max. Druga verzija ako su ti igre život. Ako odlučiš za prvu verziju, preporuka da zamjeniš tercet CPU,MBO i RAM zaa E6300, Asrokicom nekon Conroe Ready i 2x1GB Kingmax-a. Neš moć previše OC-at, ali će biti svejedno brže od ove tvoje prve verzije sa AMD-om.
#93 |
teta Mraz
Lokacija: hr
Postovi: 1,596
definitivno e6300 kako vucko kaže, a napajanje mislim da ti je dosta cheiftec delta 350w za nekih 250-260kn u linksu
#94 |
Postovi: 233
hehhehe hvala Vucko! Nego cuj ma vec sam rekao da necu Oc-at jer sam tudum za to a i malo me strah da ne skratim rok trajanja komponentama. Cak si i ti rekao da je gigabyte sasvim ok ako necu Oc-at a E.T. je rekao da je dapace stabilnija od drugih ako ostane na default-u.A necu sad ic na Conroe nek ostane dobri stari amd. koliko je lose u 2 verziji komponenti imati onakav proc? |
#95 |
teta Mraz
Lokacija: hr
Postovi: 1,596
za te pare mislim da nema boljeg proca, vidio sam ga na djelu, još ako nađeš x2..
#96 | |
Postovi: 233
P.S. napravio sam lagani edit kod vers 2 jer sam zaboravio izbacit DVD rom i smanjit HDD, pa je sad tek cijena uredu... Zadnje izmijenjeno od: yggdrasil. 11.09.2006. u 13:37. |
#97 |
Postovi: 4,190
Za gejmanje bi bolji bio donji, ali idealna kombinacija bi bila X2 i 7900 ![]() Sad ti je dosla 7900GS graficka, pa si uzmes nju i X2, to bi ti savrseno bilo! A napajanje si mozes i neko slabije uzet od 350-400W, bit ce ti dosta... Edit: pogledaj i X1900GT za oko 1700kn.... |
#98 |
teta Mraz
Lokacija: hr
Postovi: 1,596
definitivno 7900gs,(bude u linksu sljedeći tjedan za 1700kn), napajanje koje sam ti već prije rekao je sigurno dosta, a dvd-ove možeš pržit i samo sa dvd-rw (ako ih ne pećeš na veliko), tak da bi ja dvd rom izbacio mislim da sad imaš za 4200 x2!
#99 |
Postovi: 9,505
U većini igara danas još nema MP podrške (za više jezgri). Ali to ne znači da ih neće biti ![]() Ako nećeš OC-at, pređi na Core 2 Duo jer ionako kupuješ novi komp, cijeli. X2 3800+ za soc. 939 teško da ćeš naći. A za 1500kn ti je bolje ići na E6300, DDR2 od Kingmax-a i Asrokicu. Najbolje ti je ovako: E6300 - 1530kn 2x1GB PQI DDR2 667 - 1220kn Asrock ConRoeXFire-eSATA2 - 655kn Leadtek GF 7900 GT TDH, 256MB - 2085kn HDD Seagate ST3160812A, 160 GB 8MB, ATA-100, 7200 - 462kn DVD+RW/-RW/RAM LG GSA-H10A, Dual Layer, 16x, black, bulk - 269 kn Thermaltake mid tower Mambo, bez PS, crno - 344 kn Chieftec power supply 450W, ATX 2.0, 2×12V - 380 kn UKUPNO=6945kn A to padne na 6700kn ako se kupi ova nova 7900GS koja je jeftinija tako 200-300kn a nije niš slabija od 7900GT. Ja ti velim, a ti poslušaj ako oćeš... Ova konfa će ti biti mrcina do jaja. Razvali obje tvoje ![]()
#101 | |
Postovi: 233
sta intel sad toliko lomi Amd? Odnosno E6300 > x2 4200+ oboje 1500 kn? dobro razmislit cu tnx |
#102 |
Postovi: 9,505
Dođe ti isto, ali ti je E6300 brži. Velim ti, ako možeš, pokušaj u moju konfu ubaciti samo 7900GS i cijena ti dođe ko ova tvoja prva...
#103 | |
Postovi: 233
a daj mi objasni (uvjeri) za ovaj DDR2. Jer negdje sam procitao da ako DDR2 nije 800Mhz uopce nema vidljive razlike. tj DDR2 na 667Mhz=DDR tu su negdje |
#104 |
Postovi: 9,505
To je priča za AM2 socket naprema 939 i DDR400. A na E6300 i DDR2 667 je jači od 4200+ i DDR2 667 (a valjda i od DDR2 na 800). Naravno, bilo bi bolje da je i na E6300 DDR2 800, ali nećeš patit toliko. On će svojom brzinom (proc) nadoknadit to. Šteta što više nema Kingmax-a 667-ice jeftino u Linksu, sad je skuplja od Kingamaxa DDR2 800, kojeg nema, ali sigurno kada dođe bit će skuplji nego što sada piše na cjeniku. Možda je u Ve-milu bolja cijena... A sad, što se tiće OC-anja. Ova Asrokica trenutno ne može zbog BIOS-a preko 300mhz. Tvoj proc radi na 266. Bez ikakvog dizanja voltaže, taj E6300 će raditi na 300Mhz (što uz množitelj x7 daje 2,1Ghz), a memu staviš 1:1 i ona radi na 600Mhz sa nekim relativno niskim latencijama i eto ti đabe brzine, a ako ti proc krepa kad ga dižeš na defoltu, ja ću ti osobno kupit drugi E6300 ![]()
#105 |
Postovi: 233
DDR2 1GB PC6400 (800MHz), GoodRAM PRO 863,46 kn http://www.ve-mil.hr/cjenik.aspx?Gru...Oznaka=memddr2 |
#106 |
Postovi: 4,190
Ja isto mislim da ti je sad bolje ici na intela....a uzmi u obzir i X1900GT.. |
#107 |
Postovi: 233
#109 | |
Postovi: 233
mema 1:1 to mislis na dual channel? ili? ajde ti si tu nesto racunao mnozio...ok ok uvjerio si me hehehhe....doobro vec cu nekom da da mi OC-a ko se razumije |
#110 |
teta Mraz
Lokacija: hr
Postovi: 1,596
conroe definitivno! taj goodram je odlićan ali teško da ćeš ga nać tako da uzmmeš u obzir kingmax ili goodram 667Mhz
