Staro 01.09.2006., 18:27   #1
Dr. Beast
Postovi: 1,505
Gigabyte GI-8I945P-G & Intel D805
Imam slijedeći problem kod o'clocka: zbog čega memorija neće ići preko 592Mhz? Kada je System multiplier u biosu postavljen na 4, fsb mogu dignuti samo do 148Mhz (x4=592MHz), a memorija je 667MHz? Kada idem povećati fsb npr. na 150 moram System multiplier staviti na 3.33 (memorija je onda na 499,5MHz), zašto neće na 4 pa da bude na 600MHz? Prva slika je na default postavkama, a druga na najvišem stabilnom fsb-u (vidi memory bus: 244MHz*2=488MHz, a čitao sam da se ovaj Kingamx bez problema clocka na 800MHz). Jel ja tu nešto krivo računam i gledam ili što? : hitthewa
1. Default postavke
2. Max o'clock
Zadnje izmijenjeno od: Dr. Beast. 05.09.2006. u 01:14.
Dr. Beast je offline   Reply With Quote
Staro 05.09.2006., 01:13   #2
Dr. Beast
Postovi: 1,505
Bump!!!
Staro 05.09.2006., 01:24   #3
mc_fish
the luda ribetna
mc_fish's Avatar
Postovi: 3,952
koji bios imas?
daj mi neki mail pa ti posaljem svoj...inace mislim ad ti ram nejde... ili ti se kolje s necim
blup
mc_fish je offline   Reply With Quote
Staro 05.09.2006., 01:48   #4
Dr. Beast
Postovi: 1,505
Bios je F11, da ne bi ja uzeo sekirče pa zaklao ploču : giljotin
Pronašao sam jedan review gdje piše: "Overall, we had no real issues overclocking our Pentium D 820 from 2.8GHz to an impressive 3.57GHz. We achieved this by running the FSB at 255MHz while dropping the memory divider to 2.0. Unfortunately, eventhough we've pushed this memory up to 672MHz with timings of 4-4-4-12 in previous articles, we had no luck here. The system even reset with CAS 4-4-4-12 timings running at 638MHz with a memory multiplier setting of 2.5. No other combination of memory ratio, voltage or timing settings helped us get past the 510MHz barrier. In the end, the CPU overclocking score was quite good but the memory's results were unimpressive.". Izgleda da na ovoj ploči ne ide baš o'clock memorije, a ja uzeo Kingmaxa 667 :mad:
Još jedan sličan problem.
Zadnje izmijenjeno od: Dr. Beast. 05.09.2006. u 02:11.
Staro 05.09.2006., 02:31   #5
mc_fish
the luda ribetna
mc_fish's Avatar
Postovi: 3,952
ide ko beba...eto meni je mema na 800 4-4-4 proc na 4 gige...
eto ja imam f8 bios...
blup
Staro 05.09.2006., 02:46   #6
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Cime vi hladite te 805-ice na 4GHz?
Staro 05.09.2006., 03:46   #7
Dr. Beast
Postovi: 1,505
Autor mc_fish Pregled postova
Koji proc i koja mema?
Staro 05.09.2006., 11:00   #8
Dr. Beast
Postovi: 1,505
Autor SRV Pregled postova
TT Big Typhoon
Staro 05.09.2006., 14:57   #9
Dr. Beast
Postovi: 1,505
Mogu dizati frekvenciju memorije preko 667MHz jedino ako u biosu ostavim PCI frequency na auto (ne zaključam na 100MHz), ali se nakon restarta bios više ne diže nego moram ugasiti pa ponovno upaliti komp.
Staro 05.09.2006., 23:41   #10
mc_fish
the luda ribetna
mc_fish's Avatar
Postovi: 3,952
imam isti proc 805icu...al imam ocz 2x 512 trenutno...800 4-4-4 dalje proc nemre...
@ zadnji post...da to se i meni zna dogodit...al ne tako...vec kad je oc prevelik ne posta ugasim upalim i sve 5...inace ja hladim stock kulerom jerbo je moja 805ica hladna...load na 1.5@4ghz je oko 70°
blup
Staro 06.09.2006., 00:45   #11
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Bolesno...jos koliko sam vristi box cooler na max. loadu....ufff
Staro 07.09.2006., 13:16   #12
mc_fish
the luda ribetna
mc_fish's Avatar
Postovi: 3,952
nekih 2400 ok...uglavnom podosta
al opet gledano za taj proc je to malo
blup
Staro 07.09.2006., 15:42   #13
Dr. Beast
Postovi: 1,505
Ma ja svoga držim na defaultu i sasvim je dovoljno, u idleu je 30, a full loadu ne prelazi 40
Staro 07.09.2006., 19:56   #14
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Ma zvuci mi nemoguce da ga hladis sa stock-om, mislio sam hajd dobro, mora da taj stock radi na 5k rpm
Pa 805D na 4GHz potegne preko 150W...
Ne kuzim.
Staro 07.09.2006., 21:36   #15
mc_fish
the luda ribetna
mc_fish's Avatar
Postovi: 3,952
dodi i pitaj ga inace na 3k okretaja je na na 2 sry niej najmjerno
enivej evo ti pic
http://img432.imageshack.us/img432/8482/4gigedc4.jpg
blup
