Staro 10.07.2003., 09:20   #1
Corvin
Corvin's Avatar
Lokacija: Zagreb, Hrvatska
Postovi: 144
Lopovi iz Epsona
Ovo sve objašnjava:
Printer manufacturer EPSON was caught with their pants down today, and not a little.
Here in the Netherlands we have a very important 'consumer watch' entity which test many products and business in many ways. What did they discover .. you know the formula right ? Buy a printer cheap and sell the inkt-cartridges for a lot of money. Well, it seems that EPSON implemented a small chip on the cartridges a while ago that will prevent the cartridge from printing after a number of prints.
So basically you think your cartridge is emtpy, your PC will actually report it, then you replace it with another 35-40 dollar cartridge(s) right ? Well, it seems that the remaining ink in the 'emtpy' cartridge is good for another 30 to 100 pages !
EPSON was caught red handed, the consumer watch recommends consumer not to buy Epson printer anymore and I agree, the prices for ink are so ridiculously high and with that in mind EPSON pulls this trick, ridiculous.
I just wonder if EPSON is the only one doing this trick, or perhaps it's the entire inkjet mafia.
Corvin je offline   Reply With Quote
Staro 10.07.2003., 09:42   #2
gospar
Faraon
gospar's Avatar
Datum registracije: Oct 2002
Lokacija: Cork
Postovi: 948
izvor nista nevrijedi bez izvora
Konane, koja je najbolja stvar u životu? Skršiti svoje neprijatelje, gledati ih pod sobom poražene i slušati naricanja njihovih žena!
gospar je offline   Reply With Quote
Staro 10.07.2003., 10:25   #3
miato
(°_°)
miato's Avatar
Postovi: 3,249
To Epson radi vec barem 3 godine (od generacije x80 - 480-680-880)
Ili si nasao staru vijest, ili su Nizozemci sa naprednim "consumer watchom" u zakasnjenju....
Naime to su oni Epson Chipped cartridges, i naravno, sto ja pokusavam svima objasniti, ono sto ti kompjuter prikazuje kao stanje tinte, nije ni priblizno stvarnom stanju tinte u cartridgeu... jel taj chip ni na koji nacin nije u stanju mjeriti kolicinu tinte.
Ali zato ima vise rjesenja :
1. kupiti kompatibilne cartridgee JetTec (koji su 2-3x jeftiniji)
2. nabaviti resetter chipa, uredjaj koji resetira chip u roku par sekundi (imam ga ja ) tako da se moze bez problema punit cartridge
3. nabaviti software kojim bez tog uredjaja se moze resetirat chip, samo pomocu kompjutera -> vrijedi za model 680, za ostale nisam siguran
Staro 10.07.2003., 10:57   #4
greg SE
greg SE's Avatar
Datum registracije: Oct 2001
Lokacija: Vinkovci
Postovi: 5,231
neznam kako je sad ali prije je sigurno palilo.uglavnom printer javlja da je prazan, samo izvadis boje, vratis ih nazad i kreten sad pokazuje da je pun (toliko o naprednim chipovima ) i printas dok nevidis da je ispis u kurcu....tad kupis nove boje ako si normalan ili nekupujes dok nepocme izbacivati potpuno bijel papir ako si skrtac
Staro 10.07.2003., 16:18   #5
Trash
Trash's Avatar
Datum registracije: Apr 2002
Postovi: 786
Ovo je tocan odgovor. Mislim da nije potrebno napominjati da sam ja skrtac
Mog starog Epson Stylusa 660, pokoj mu dushi, sam derao tako jedno godinu dana sa zamjenskim tintama dok konacno nije riknuo trafo.. A onda sam ga poklonio
Trash je offline   Reply With Quote
Staro 10.07.2003., 16:31   #6
Mrvica
samo kad bih znao
Mrvica's Avatar
Datum registracije: May 2003
Lokacija: Međimurje malo
Postovi: 173
Moje iskustvo mi govori da to ne radi, izvadi pa vrati i puno je! Mozda na tintama bez chipa radi ali na ovima s chipom ne isprobano na 680,895,1290!
Mrvica je offline   Reply With Quote
Staro 11.07.2003., 09:52   #7
CatKiller
al se nekad dobro jelo...
CatKiller's Avatar
Postovi: 3,312
Primjetio sam jednu zanimljivost vezanu uz epsonove tinte.
Imam C42UX , ništa posebno, ali za moje potrebe i više nego dosta. Nakon nekog vremena s orginalni tintama svako malo treba pročistiti mlaznice i samim tim ode tinta i tako dok ga nisam počeo tankati na OEM tinte iz VeMila , od tada NITI JEDAN "nozzle check" nije bio potreban. Toliko o nazovikvalitetnoj orginalnoj tinti.
Staro 11.07.2003., 11:36   #8
Mrvica
samo kad bih znao
Mrvica's Avatar
Postovi: 173
cime resetiras chip?
Staro 11.07.2003., 14:00   #9
CatKiller
CatKiller's Avatar
Postovi: 3,312
Ne resetiram čip , to je zamjenski catridge , 30kn crna, 40boja
Staro 11.07.2003., 19:22   #10
STRMX
STRMX's Avatar
Datum registracije: Sep 2002
Lokacija: kuca
Postovi: 1,567
i koliko traju ti toneri??
STRMX je offline   Reply With Quote
Staro 11.07.2003., 19:30   #11
Mrvica
samo kad bih znao
Mrvica's Avatar
Postovi: 173
Dok se ne potrose !
Ja nisam primjetio nikakvu razliku od originala i zamjenske tinte nit u kvaliteti nit u kolicini; i rijec je o tintama ne o tonerima
