Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Catalyst 6.8
As with most Catalyst® releases, performance has increased in various situations. Improved shader compiler and transform engine optimizations have led to many significant performance gains in OpenGL applications across the entire Radeon® X1000 series of products. These include: Doom 3 performance improves as much as 6.5% Quake 4 (v1.2 or higher) performance improves as much as 18% Chronicles of Riddick performance improves as much as 20%. Average improvements of 5-10% are commonly seen Prey performance improves as much as 16% Optimizations made to ATI's graphics memory manager have led to significant gains in DirectX applications that make heavy use of graphics memory on 256MB ATI graphics cards: 3DMark06 performance improves as much as 22% on single ATI Radeon® X1000 series cards with 256MB of graphics memory at 1280x1024 and higher when anti-aliasing is enabled. The largest gains are found on the ATI Radeon® X1800 series and ATI Radeon® X1900 series of products Call of Duty 2 performance improves as much as 30% on single ATI Radeon® X550 cards or higher with 256MB of video memory at 1280x1024 and higher when anti-aliasing enabled. The largest gains are found on the ATI Radeon® X1800 series and ATI Radeon® X1900 series of products www.ati.com
Zule
Postovi: 1,993
Ufff, fino ![]() ![]() |
The Dark Side of Moon
Postovi: 3,945
neka i ovo će fino doći ![]()
Super Moderators
Postovi: 17,485
Ja nisam išao ni na 6.6 ni na 6.7-ostao sam na 6.5 ![]() Ove budem možda probao. Kad izađe novi ATT...
Datum registracije: Apr 2004
Postovi: 97
#7 | |
Super Moderators
Postovi: 17,485
Ovo je posebno zanimljivo: "Optimizations made to ATI's graphics memory manager have led to significant gains in DirectX applications that make heavy use of graphics memory on 256MB ATI graphics cards: 3DMark06 performance improves as much as 22% on single ATI Radeon® X1000 series cards with 256MB of graphics memory at 1280x1024 and higher when anti-aliasing is enabled. The largest gains are found on the ATI Radeon® X1800 series and ATI Radeon® X1900 series of products Call of Duty 2 performance improves as much as 30% on single ATI Radeon® X550 cards or higher with 256MB of video memory at 1280x1024 and higher when anti-aliasing enabled. The largest gains are found on the ATI Radeon® X1800 series and ATI Radeon® X1900 series of products"
Postovi: 1,606
imaju jedan smiješan bug..."predstavljaju" se kao verzija 6.7... |
Postovi: 140
da a ja sa 1900xt imam 1000 manje u 3D2005 |
Lokacija: Čabar/Rijeka
Postovi: 655
Netočno... svaki mjesec jedna verzija... pa vidiš ovo je verzija 6.8 zato što je 2006.g. i 8. mjesec (6 označava godinu, a 8 mjesec), tako je lakše,a ne Detonatori od NVidie koji imaju verziju 80 i nešto...LOL... davno sam imao GeForce 2 MX400,ali prebacio sam se na ATI... |
Beskorisna bitanga...
Lokacija: Sesvete (Zg)
Postovi: 6,956
-- Have a nice day... |
Super Moderators
Postovi: 17,485
Postovi: 3,945
evo verzije 6.8 sa CP http://www.ngohq.com/home.php?page=F...&dwn_cat_id=18
Super Moderators
Postovi: 17,485
Ja sam ih sinoć malo izbenchao ali ih mogu usporediti jedino sa 6.5 koje sam imao do sad. Sve benchano sa 4xAA i 8xANISO. AI-low, sve postavke drivera na High Quality. U igrama postavke na High Quality Far Cry-isto. F.E.A.R. frame više u 1024, 1280 isto. X3 demo: 1024-39.5 sa novima 47.4 1280-31.8 sa novima 39.0 Ovo je puno. Makar mi je to malo prevelika razlika za tri revizije drivera.. DOOM3 1024-67.8 novi 70.6 1280-47.3 novi 48.8 PREY 1024 guru3d demo1-55.3 novi 60.8 1024 guru3d demo2-48.5 novi 52.2 1280 -37.9 novi 41.9 1280 -32.9 novi 35.7 Kao što se vidi-najveći napredak je u OGL-u, pogotovo u Prey-u. Skoro sam zaboravio-za ljubitelje 05 Marka, dobio sam kakvih 45 bodova više...
#16 | |
Administrator
Lokacija: Sesvete
Postovi: 15,963
#17 |
Adrenaline junkie
Lokacija: Doboj - Banja Luka
Postovi: 3,593
Sto jest jest. Stvarno pretjeru sa kolicinom drivera koje izdaju. Ja sam prije 5 dana skinuo 6.7 i nisamih jos stavio, a oni vec servirali 6.8: nono :
Lenovo ThinkPad W530 - Core i7 3840QM, 32 GB RAM, SSD Samsung 512 GB, nVidia Quadro K1000M 2 GB, 15.6" 1920x1080 IPS, baterija 9 ćelija |
#18 |
Datum registracije: Feb 2003
Lokacija: Velika Gorica
Postovi: 499
Pa nije mi jasno zasto kukate! Prije je bila masovna histerija zbog toga sto su izdavali drivere jednom godisnje, za razliku od nVidije koja ih je bacala van svaki dan za dorucak, rucak i veceru. Sad kad su se izjednacili s njima, opet ne valja. : nono : A kao nVidijini driveri su bili svi revolucionarno dobri...
Doctor!!!... Doctor!!!... MY BRAIN HURTS... |
#19 | ||
Lokacija: Solin
Postovi: 1,753
![]() Citiraj:
Nego na stranu to ima li ko jos x1800 x1900 izvjesce onako iz prve ruke..ili da ih ja skinem (a nekako mi se ne da...dobro mi je sila omega 6.7 ![]() |
#20 |
Postovi: 3,945
#21 | |
MadModerator
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
#22 |
Postovi: 2,458
Zanimljivo: Bug-online: "Dobitci u 3DMarku kreću se do čak 22%, a još veće dobitke moguće je ostvariti u Call of Dutyju 2 – do 30%." Hm, morat cu isprobati... @Jelc Gledam tvoje rezultate i citam na bug online: "Službeno deklarirani dobitci kod igara (Doom 3, Quake 4, Riddick, Prey…) kreću se od 5 do čak 20%." I ja bi se onda mogao "modernizirati" ![]() |
#24 |
Super Moderators
Postovi: 17,485
#26 | |
Lokacija: Solin
Postovi: 1,753
atha okani se Marka zatuci koju igru. ![]() Ja sam lijen previse...a ovaj Lihto mi nekako previse ide niz dlaku ![]() ![]() ![]() Citiraj:
#27 |
Postovi: 9,067
Ako me se uputi kako izbenchati nekakvu igru, odnosno gdje skinuti demo za bench, drage volje. Btw, cistite li i vi drivere prilikom izmjene sa Driver Cleanerom? Ja prvo ocistim stare i onda metnem nove. ![]()
___________ Just atha x |
#28 | |
Super Moderators
Postovi: 17,485
![]() bdw-da li je netko igrao Oblivion sa novim driverima? Meni su znali rušiti igru pa sam fino puknuo gore nove 6.8 beta (Chuck Patch) I to ih nisam instalirao preko 6.8 nego solo. Sad Oblivion radi kak treba ![]() I piše da imam X1800XL AIW u kompu ![]()
#29 |
Postovi: 3,945
#30 |
MadModerator
Lokacija: N/A
Postovi: 5,195
Imam problem...kako cu vidit koja mi je sad verzija drivera? ![]() Svukud sam cacko al nista...ni v od verzije ![]() Sigurno je lagano...al ja nemam pooojma... *crveni se*
