Staro 17.07.2006., 15:20   #1
Fenix_zealot
Preator Fenix
Fenix_zealot's Avatar
Lokacija: Varazdin
Postovi: 120
OC AMD AthlonaXP 2500+
trebam pomoć pri cloakanju svog amdxp 2500+ procesora ( radi na 1800), na a7v8x-x series i 2x 256 ddr400
Fenix_zealot je offline   Reply With Quote
Staro 17.07.2006., 15:25   #2
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
prvo napisi koje hlađenje imas, kakva ti je temperatura u sobi,napajanje i koja marka je memorije onda ti mozemo pomoci...ovo je prekratki opis da bi ti mogli reci
AMD Phenom 9850be 2,5ghz@2,9ghz@OCZ Vendetta 2 700rpm
DFI Lan Party JR 790GX-M2RS
OCZ Blade 2x2Gb ddrII@1066mhz@1.8v
Gigabyte HD4850 1GB Multi Core @passive
Auzentech Meridian@Opamp LM4562NA
2xWestern Digital 6400aaks@RAID 1 + Seagate S-ATA 160gb@XXX
Tagan 480W Supersilent
Thermaltake V1000+ black with side window
Logitech MX500
DELL 2007FP
AMD Athlon 3000+(venice e3) stock
Abit AV8
Kingmax Superram 2x256ddr433 FHAS stock
Gainward 7600GT GS 256mb
Seagate Barracuda 80gb P-ata
Denon AVR-3805 black finish @DIY 3.5mm > 2RCA(Neutrik RCA plugs)
Focal Jmlab Chorus S 726s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S CC700s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S SW700 classic finish@Bandridge Profigold Subwoofer Cable
Review Chorus S serije
Review Denon AVR-3805
micek_kc je offline   Reply With Quote
Staro 17.07.2006., 15:43   #3
Fenix_zealot
Preator Fenix
Lokacija: Varazdin
Postovi: 120
Matièna ploèa:
Procesor AMD Athlon XP, 1822 MHz (11 x 166)
Naziv matiène ploèe Asus A7V8X-X (6 PCI, 1 AGP, 3 DDR DIMM, Audio, LAN)
Chipset na matiènoj ploèi VIA VT8377 Apollo KT400
Sistemska memorija 512 MB (PC3200 DDR SDRAM)
Tip BIOS-a Award Modular (06/10/04)
Komunikacijski port Communications Port (COM1)
Komunikacijski port ECP Printer Port (LPT1)
BIOS informacije:
Proizvoðaè Award Software, Inc.
Verzija ASUS A7V8X-X ACPI BIOS Revision 1011
Datum izdanja 06/10/2004
Velièina 256 KB
Boot ureðaji Floppy Disk, Hard Disk, CD-ROM
Podržane moguænosti Flash BIOS, Shadow BIOS, Selectable Boot, EDD
Podržani standardi DMI, APM, ACPI, ESCD, PnP
Podrška za nadogradnju PCI, AGP, USB
Informacije o matiènoj ploèi:
Proizvoðaè ASUSTeK Computer INC.
Naziv proizvoda A7V8X-X
Verzija REV 1.xx
Serijski broj xxxxxxxxxxx
[ Memorijski kontroler ]
Informacije o memorijskom kontroleru:
Metoda otkrivanja pogreški Nema
Podržane brzine memorije 70ns, 60ns, 50ns
Podržani tipovi memorije ECC, DIMM, SDRAM
Podržani naponi memorije 3.3V
Maksimalna velièina memorijskog modula 1024 MB
Memorijski utori 3
[ Procesori / AMD Athlon(TM) XP 2500+ ]
Informacije o procesoru:
Proizvoðaè AuthenticAMD
Verzija AMD Athlon(TM) XP 2500+
Eksterna frekvencija 166 MHz
Maksimalna frekvencija 2250 MHz
Trenutna frekvencija 1833 MHz
Tip Central Processor
Napon 4.0 V
Status U upotrebi
Opis podnožja / utora SOCKET A
[ Cache memorija / L1 Cache ]
Informacije o cache memoriji:
Tip Interni
Status U upotrebi
Naèin rada Write-Back
Associativity 4-way Set-Associative
Maksimalna velièina 128 KB
Instalirano 128 KB
Podržani SRAM tip Synchronous, Pipeline Burst
Instalirani SRAM tip Synchronous, Pipeline Burst
Opis podnožja / utora L1 cache
roller ]
Staro 17.07.2006., 15:44   #4
frANZi
Dr. Gonzo
frANZi's Avatar
Postovi: 958
To se ne može klokat. :mad: Imam istu takvu ploču, i to je čista je*ada. Nemaš pci/agp lock i moš ga je*at onda. Što je najgore, memorija ti sada radi na DDR333... ne može se postaviti ni asinkroni mod nit išta.
Uglavnom, ta ploča definitivno nije za klokanje.
Dakle, zaboravi!
frANZi je offline   Reply With Quote
Staro 17.07.2006., 15:45   #5
Fenix_zealot
Preator Fenix
Lokacija: Varazdin
Postovi: 120
Memorijski moduli / DIMM 1 ]
Informacije o memorijskim modulima:
Opis podnožja / utora DIMM 1
Tip DIMM, SDRAM
Instalirano 256 MB
Omoguæena velièina 256 MB
[ Memorijski moduli / DIMM 2 ]
Opis podnožja / utora DIMM 2
Tip DIMM, SDRAM
Instalirano 256 MB
Staro 17.07.2006., 15:47   #6
Fenix_zealot
Preator Fenix
Lokacija: Varazdin
Postovi: 120
Jezgra procesora Barton
CPU stepping A2
CPUID (naziv procesora) AMD Athlon(TM) XP 2500+
CPUID revizija 000006A0h
CPU Brzina:
Brzina procesora 1822.39 MHz
CPU Množitelj 11.0x
CPU FSB 165.67 MHz
Memorijska sabirnica 165.67 MHz
CPU Cache:
L1 cache za kod 64 KB
L1 cache za podatke 64 KB
L2 cache 512 KB (On-Die, Full-Speed)
ID matiène ploèe 06/10/2004-VT8377/VT8235-A7V8X-X
Informacije o chipsetu:
Memorijski tajminzi 2.5-5-4-9 (CL-RCD-RP-RAS)
Command Rate (CR) 2T
SPD Memorijski moduli:
DIMM1: M2G9IA8AMK9F081CAD 256 MB PC3200 DDR SDRAM (2.5-3-3-8 @ 200 MHz)
DIMM2: Transcend 256 MB PC3200 DDR SDRAM (2.5-3-3-8 @ 200 MHz) (2.0-3-3-7 @ 166 MHz)
BIOS informacije:
Datum izdanja sistemskog BIOS-a 06/10/04
Datum izdanja video BIOS-a 03/10/31
Tip Award BIOS-a Award Modular BIOS v6.0
Poruka Award BIOS-a ASUS A7V8X-X ACPI BIOS Revision 1011
DMI verzija BIOSa ASUS A7V8X-X ACPI BIOS Revision 1011
Informacije o grafièkom procesoru:
Grafièka kartica Asus A9200SE
Kodno ime grafièkog procesora RV280 (AGP 8x 1002 / 5964, Rev 01)
Radni takt grafièkog procesora 200 MHz (original: 200 MHz)
Frekvencija memorije 164 MHz (original: 166 MHz)
Staro 17.07.2006., 15:49   #7
Razer
Razer's Avatar
Postovi: 11,642
Moj savjet prodaj taj shit od ploče i uzmi si poštenu sck.A ploču za 300tinjak kn - tipa Abit NF7-S ...i digni tog Bartona u nebesa
Sa memorijom na 400...taj barton će sigurno ići na barem 11*200 (2200->3200+)...i da uzmi si nekog zalmana 7000 i stavi ga gore da hladi i miran si
Staro 17.07.2006., 17:12   #8
Wolverine
Wolverine's Avatar
Postovi: 12,428
uzme neku Abit AN7 ili NF7, cooler može i Scythe Katana (neće je morat rezat ko Zalmana) i digne ga na minimalno 2.2GHz
i ako mi se čini da je i RAM različit.
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 17.07.2006., 17:19   #9
Razer
Razer's Avatar
Postovi: 11,642
Autor Wolverine
Proizvođači memorije jesu različiti ali oba mogu raditi na 400...
EDIT: zašto bi morao rezati Zalmana?
Staro 17.07.2006., 17:27   #10
Wolverine
Wolverine's Avatar
Postovi: 12,428
zato što mu smeta jedan nosač ako ga ide montirat na NF7
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 17.07.2006., 17:29   #11
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Autor Wolverine
Tocno, i poslje nejde ni na jedan drugi socket osim socket A i socket 478... Osima ak se nabavi taj nosac...
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 17.07.2006., 17:41   #12
domy_os
domy_os's Avatar
Postovi: 18,892
Ne mora rezat, samo ga savije prema unutra i šarafi na vanjsku rupu.
Staro 17.07.2006., 18:08   #13
Fenix_zealot
Preator Fenix
Lokacija: Varazdin
Postovi: 120
onda mi ne preostaje drugo nego kupiti novu matičnu, awww
Staro 17.07.2006., 18:20   #14
undo
You'll Never Walk Alone
undo's Avatar
Postovi: 1,287
tako je kad nabavis novu maticnu onda clockaj jer ovako nemozes nista + dobar cooler za proc
undo je offline   Reply With Quote
Staro 17.07.2006., 19:29   #15
Fenix_zealot
Preator Fenix
Lokacija: Varazdin
Postovi: 120
evo ako bi mi dali preporuku za matičnu do 700kn a cooler do 200kn
tnx
Staro 17.07.2006., 19:38   #16
Fenix_zealot
Preator Fenix
Lokacija: Varazdin
Postovi: 120
e jeli ovo normalna temp?
Matična 37
CPU 49
Hard 48
a ništ posebno ne radim, samo je uključen everest i internet
Staro 17.07.2006., 19:40   #17
Wolverine
Wolverine's Avatar
Postovi: 12,428
nisam siguran koliko ti se uopće isplati kupovat novu ploču i trošit pare.
radije nađi neku rabljenu Abit NF7 ili Abit AN7
a cooler kako smo rekli Scythe Katana
http://www.links.hr/index.php?option...kl=050.903.089
BTW
koristi opciju EDIT
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 17.07.2006., 19:52   #18
Razer
Razer's Avatar
Postovi: 11,642
Autor Fenix_zealot
tnx
Moj frend prodaje Abiticu NF7-S rev.2.0 ...garancija iz Linksa još više od godine dana, cijena 300kn...javi se na PM ako si zainteresiran...
Staro 17.07.2006., 19:54   #19
Fenix_zealot
Preator Fenix
Lokacija: Varazdin
Postovi: 120
evo ovaj kooler je dobar ali sam i na toj stranici sam Abit NF7 ili Abit AN7 i to ja jako jeftino (oko 300kn), to vrijedi onda za te novce?
Staro 17.07.2006., 19:54   #20
marikris
made in Usora
marikris's Avatar
Postovi: 215
imam istog AMD Athlona 2500+ cloako sam ga na 2900+, 10x200 i sada radi na 2004MHz, cooler ti i ne treba posebno za ovo lagano clokiranje, meni je temperatura CPU 55, Hard 51, kuciste 41 kada sam na netu ili radim na nekom nezahtjevnijem programu, cooler ti treba samo ako mislis po cijeli dan igrati igre jer onda temperatura skace do 68 na CPU-u
marikris je offline   Reply With Quote
Staro 17.07.2006., 19:58   #21
Wolverine
Wolverine's Avatar
Postovi: 12,428
Autor Fenix_zealot
daj mi ovo prevedi na Hrvatski
što si našao i dal što vrijedi 300kn?
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 17.07.2006., 20:00   #22
Razer
Razer's Avatar
Postovi: 11,642
Autor marikris
Varaš se - ako clockaš drugi cooler je definitivno potreban...onaj trash od stocka nije ni zašto...niti hladi dobro...niti je tih...samo si ti uzmi katanu i miran si...
Staro 17.07.2006., 20:30   #23
Fenix_zealot
Preator Fenix
Lokacija: Varazdin
Postovi: 120
ja se ispričavam na tiskarskim pogreškama
dal si mi prije stranicu za cooler (http://www.links.hr/index.php?option...kl=050.903.089)
i na toj stranici sam našao matične ploče Abit NF7 i Abit AN7 i koštaju oko 300kn pa pitam ako te ploče vrijede za tak malo kn
Staro 17.07.2006., 20:48   #24
Robi555
Robi555's Avatar
Lokacija: Pitomača(VT)
Postovi: 621
Autor Fenix_zealot
Pa 300kn je realna cijena za te matične,možda čak i previsoka...
Robi555 je offline   Reply With Quote
Staro 17.07.2006., 20:50   #25
Wolverine
Wolverine's Avatar
Postovi: 12,428
mogo si nać samo AN7 i to pod Second Hand dakle rabljena i sa nepotpunim bundle-om
http://www.links.hr/index.php?option...kl=800.000.258
odeš u Links pa pitaš o ćem se radi...ali ziher ploča vrijedi one pare a i Razer ti je rekao da ima frenda koji prodaje NF7
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 17.07.2006., 20:57   #26
joolka
music freak
joolka's Avatar
Lokacija: Sibenik
Postovi: 3,316
..vrijede,a cijena im je niska jer je to socket star vec 2 "generacije"
LENOVO LEGION 5 Pro Gaming Laptop (AMD Ryzen 7 7745HX,RTX 4060,32gb DDR5,2tb SSD)
Staro 17.07.2006., 21:00   #27
Wolverine
Wolverine's Avatar
Postovi: 12,428
ma imaš ih i za manje
Soltekica nađeš za 200kn sa garancijom jedino kaj one nemaju rupe oko socketa
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 17.07.2006., 21:03   #28
Fenix_zealot
Preator Fenix
Lokacija: Varazdin
Postovi: 120
sve je to super, ali to je več stara matična a ja bi štel nekaj bolje ( ako ima bolje ) recimo za 500 kn second hand
Staro 17.07.2006., 21:06   #29
Razer
Razer's Avatar
Postovi: 11,642
Autor Fenix_zealot
Nemaš bolje, tj. novije od te plče...po meni broj 1 ploču na sck. A...ne kužim u čemu ti je problem oko te ploče?
Staro 17.07.2006., 21:08   #30
frANZi
Dr. Gonzo
frANZi's Avatar
Postovi: 958
A šta ćeš bezveze davat 500kn za nešto što ne vrijedi 500kn? Za te pare moš preć na noviju generaciju.
