Staro 10.07.2006., 11:06   #1
Traitorous_8
Traitorous_8's Avatar
Lokacija: Vž
Postovi: 81
"Could not perform end of Disc-at-once"
Bok!
Imam nero 5.5 i DVD snimac Pioneer DVR-110D.
Na kraju snimanja mi nero javi "Could not perform end of Disc-at-once"
Da li je to do nera jer imam staru verziju ili je pioneer problematican?
Hvala!
The complexity for minimum component costs has increased at a rate of roughly a factor of two per year ... Certainly over the short term this rate can be expected to continue, if not to increase. Over the longer term, the rate of increase is a bit more uncertain, although there is no reason to believe it will not remain nearly constant for at least 10 years. That means by 1975, the number of components per integrated circuit for minimum cost will be 65,000. I believe that such a large circuit can be built on a single wafer. - Gordon Moore
Traitorous_8 je offline   Reply With Quote
Staro 10.07.2006., 11:19   #2
immortal
Kernel panic
Postovi: 522
Probaj s novijom verzijom. Meni je jednom tak pisalo (imam lite-on pržilicu) i kad sam instalirao novi nero sve je radilo...
Keyboard error or no keyboard present
Press F1 to continue, DEL to enter SETUP
immortal je offline   Reply With Quote
Staro 10.07.2006., 12:12   #3
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
Nero ti zna nekada onako ljepo srati uglavnom drugu ver nera stavi i ak imas ocisti dvd rw sa onim cd cistacem.
.i.
Razer Blade 15
Staro 11.07.2006., 10:04   #4
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
Meni se to dešava sa mojim LG combom a to znam da je u njemu greška. Ili ako stavim peć cd preko limita koji medij dopušta
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je offline   Reply With Quote
Staro 11.07.2006., 14:08   #5
Postovi: 34,062
Kada je Nero 5.5 izašao, DVD prže nisu ni postojale! Stavi noviju verziju. Mislim da bi ti sve iza 6.3.x.x bilo ok. Mnogi su zadovoljni sa 6.6.x.x verzijama i smatraju ih boljim od novijih 7.x.x.x verzija.
Staro 12.07.2006., 00:45   #6
thuNdeR
thuNdeR's Avatar
Lokacija: na sombra
Postovi: 1,048
nero 6 je najbolji instaliraj ga i uživaj
thuNdeR je offline   Reply With Quote
Staro 14.07.2006., 00:01   #7
Traitorous_8
Lokacija: Vž
Postovi: 81
Autor $$kiLL3Rr
Eh ja zaboravio da sam tu otvorio thread na tu temu: bonker :
Da, nabavio sam noviji nero, i sve radi za 5! Netko je spomenuo ciscenje przilice, ne, nije potrebno posto je pioneer nov novcat a i tip greske ukazuje vise na softversku gresku nego li na problem zaprljanog snimaca.
Zahvaljujem svima na trudu: goood :
