Lokacija: Zabok
Postovi: 331
Sapphire ati 9600XT vs. ati 9700 vs. nvidia 5900
Koju uzeti i zašto??? sve 3 mogu za 400kn! malo mi je čudna ova 5900:: Asus V9950 tj.5900 Ultra (450/850) clock-535/1004 + 256 BIT SABIRNICA "Starting at 450 MHz we began to raise the core speed 5 MHz at a time. 485, 490, 495 MHz blew by quickly as did the 500 MHz core mark. Amazingly the V9950 Ultra had a lot more headroom in it and even broke the 525 MHz mark! The highest we were able to overclock the core without it locking up was 535 MHz and that was with stock cooling! The memory on the Asus V9950 Ultra was not to be out done by the awesome core overclock. Starting at a relatively lowly 850 MHz we upped the memory frequency slowly. 900 MHz and 950 MHz was passed very easily, even 1 GHz was no problem for the Asus V9950 Ultra! We finally settled for an amazing 1.04 GHz. Anything higher and the memory would start to artifact during 3DMark tests. " a frend mi veli da je 9600xt bolja jednostavno nemogu vjerovat tolka frekvencija i 256 bita a da je tako slabo zato da pitam vas di je problem!!! Znam da ima nešto s cjevovodima!! 3d mark 2001. 1. ATi Radeon 9800 Pro 16417 2. ATi Radeon 9700 Pro 15565 3. MSI FX5900U-VTD256 Ultra 15870 4. Albatron GeForceFX 5900PV 15548 5. MSI G4Ti4600-TD 13910 6. Asus V9950 Ultra 15995 pogle: 7. Asus V9950 Ultra(5900) (531/1020) 16386 |
N/A
Lokacija: Međimurje
Postovi: 434
9700 je definitivno najbolja |
#3 | |
the luda ribetna
Postovi: 3,952
Lokacija: Zabok
Postovi: 331
A jel mi se to isplati uzet za 400kn??? ili da bolje štedim za 9800pro pa modam na 9800xT??? i kolka je srednja cijena rabljenih 9800 pro s jezgrom r360 ako se ne varam! |
#6 | |
the luda ribetna
Postovi: 3,952
Postovi: 4,190
9700 bez razmisljanja.... |
#9 | |
Lokacija: Zabok
Postovi: 331
#10 | |
Zule
Postovi: 1,993
Ima 8 pajpi, 256bitna je i fino radi, dx9. Što ti više trebamo reć? Od tih koje si naveo je najbolja. |
Lokacija: Zabok
Postovi: 331
ovo mi frend izjavio: hmm 9700 je jachi chip od 9600pro/xt/itd... nije starija jezgra vech je chistunac 9500 je isto tako spushteni chistunac i da se flashati na 9700 ..da 256 bitni su i hebene piletine su i takme se sa 9800pro/xt...takme.. 9800 se -- gowno 9800 pro -ako je 256 bitni,pod haubom ima r360 onda se da flashati (pardon..to je 9800xt spushtene radne frekvencije i voltaze..) u 9800xt..samim time, ovisi kojim,cijim biosom ga flashas..dakle daje i vece voltaze proporcionalno proizvodjacu..ove neke divlje su dobre..recimo gecube i connect3d..daje naravno i jos veci clock od obicnog nekog brand name 9800xt recimo sapphire u vecini danasnjih stvari se 9800 xt drzi jos dalje pri vrhu i medju prvim je u usporedbi sa ostalim koji fluxao gore dolje.. 5900 - ta navedena graficka sa slikom je hebena piletina , negdje dere 9800 a negdje gadno pushi.. evo recimo kako stoje nvidijice (novije nvidijice polako uzimaju u obzir ukradenu,pradon kupljeno 3dfx tehnologiju ali ne dovoljno dobro) http://www.tomshardware.com/2005/07/...l#3d_mark_2005 http://www.tomshardware.com/2004/10/...ml#3dmark_2003 i sad se ja odluči... al sve u svemu mislim uzet na kraju 9800pro(xt) |
#12 | |
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
380/680...8pajpi..r360...tvout... ![]() |
Lokacija: DJAKOVO
Postovi: 12
ja bi slusao tog frenda ![]() ali nadji ipak 9800 pro za 500 kuna i modaj/flashaj u xt i klokaj josh ![]() 9700 je raritet pa tako da..meni on vise znaci nego neki 9800 |
#14 | |||
Postovi: 1,606
#17 |
Lokacija: Sisak
Postovi: 1,127
Razlike između 9700 i 9800 ukoliko su obje "pro" neće osjetit, a sigurno da bih uzeo 9700 samo zato što je legenda, prva dx9 kartica, koja je nakon 4 godine još uvijek itekako sposobna i nijedan PC je se ne bi posramio. 5900 zaobilaziti u širokom luku, imao dvije, obje gainward GS, tada su bile brze, ali to je to, u igrama puša. |
#19 |
Postovi: 12,433
Daj uzmi 9700 i miran si one su mrvicu sporije od 9800 serije tako da ti se ne isplati davat još 100-200kn više za gotovo istu grafu P.S. 9800 serija sa R360 čipom voli riknut iz čista mira
#20 |
Eddie
Postovi: 5,508
9700PRO vs. 9800PRO cca 10% razlike. Ako nađeš 9700 ili 9800 uzimaj isto, klokaju se na taktove PRO. Ovisno o hlađenju i modelu 400-600KN. Ni s jednom nećeš pogriješiti i tu je priča gotova... BTW, koliko ja znam crkavaju R350 a ne R360.
#21 |
Lokacija: pž
Postovi: 1,291
Mali OT: Da li rikavaju grafičke s r350 ili r360?Mislim si uzeti neku grafu za drugi komp,a strah me uzeti 9800 zbog tog razloga |
#23 |
Lokacija: pž
Postovi: 1,291
Ali i ove s r350 često? |
#25 |
Postovi: 12,433
također mislim da je sigurnije ići na R300 tj 9500np ili 9700 @maher ti ih nebi uzimo bez 2-3g garancije? : stoopid pa ko prodaje rabljenu 9800 sa 3g garancije kaj se garancija produljuje sa vremenom uporabe
#26 |
Lost soul still wondering
Lokacija: Aiur
Postovi: 474
Slažem se da ti je pametnije uzeti 9700 pro, malo je sporija od 9800 pro, ali se ne zagrijava toliko. 9800 se zagrijava do bola i dosta krepavaju, meni je jedna krepala sa r360 jezgrom *šmrc*.
Da nije nas bile za grabu bi spal
#27 | ||||||||
Headbangig Grunf!
Datum registracije: Aug 2003
Lokacija: headbanger's ball
Postovi: 4,373
R350 i R360 na drugačiji način izvode shadere. Uz to 9800xt ima 256mb rama dok pro ima sma 128. kkave divlje? Frend ti očito nezna da svi dobivaju iste čipove od ATija te nisu GeCube ili Connect 3D divlje. 9800xt nema veći napon od 9800pro. Citiraj:
i sad se ja odluči... Citiraj:
Porsche 6cyl.boxer se hladi zrakom komp se hladi vodom! Chairman of G.M.S. , Heavy Metal Thunder!Former member of PCE 100+kg demolition squad Grunf je moj idol! Moji Grunf type modovi NB:Mini Monster NB,VGA:Ye Monster C!, Ye Monster D!,Abit NB:Abit mini Monster,PSU:Ultra Monster! ![]() Alfisti site, Alfisti forum |
#28 |
Postovi: 5,458
Ma crkavaju sve 9800 koje se clockaju,možda od 10 primjeraka 3 uspješno rade flashnute.Ne bi se ja igrao...previše riskantno,a za šta..3 sličice više možda u Oblivionu..: nono : ..nije bitno 350/360..to su priče za malu djecu.. Flashaj i jednu i drugu..pa vidi kroz mjesec,dva da li ti rade ili ne..ne znam čemu forsanje..najbolje onda za 100 kn kupit 9200,i iživljavat se..čuo sam da se gpu da sa 250 clocknut na 300+ bez beda..eto...pusti 9800tke..ta serija je preosjetljiva.. |
#30 |
Postovi: 1,583
ima ih još po dućanima novih sa garancijama,ali rabljene 9800 nisam niti rekao da bi uzimao,samo mi fali da krepa |
