Staro 02.07.2006., 22:50   #1
Matesonik
prcknedl
Matesonik's Avatar
Postovi: 3,131
Talking Kak su kompjutorasili nasi stari...
evo ovo je kompilacija s nekoliko 5.25" rescue diskova...
Windows Setup requires %ld bytes available on your %c: drive.
Cannot open source file
Cannot open destination file
Cannot copy file
Cannot create a temporary directory
If you have HPFS or NTFS installed on your hard drive, you will need to create an MS-DOS boot partition to set up Windows.
Unable to delete file
Windows requires MS-DOS version 3.2 or later.
Windows requires a computer with an 80386 processor or higher.
This may be caused by too many files in the root directory.
A high memory manager was not found.
Setup will load a memory manager and restart.
Setup cannot find a high memory manager and cannot continue.
Incompatible high memory device driver installed.
Remove this from your CONFIG.SYS file and run Setup again.
Cannot copy Setup files to temporary directory.
Run Setup again without any options by typing SETUP.
Mini Windows subdirectory empty.
Too many options specified.
Run Setup again and specify fewer options.
Disk Drive ): not ready.
Cannot write to the disk.
Setup cannot run from the MS-DOS prompt in Windows.
Setup cannot run from a OS/2 DOS VM.
Windows is not compatible with the version of 386Max memory manageron your computer.
Windows is not compatible with the version of QEMM memory manager on your computer.
Setup Warning G1: Setup cannot run from MS-DOS with EMM386.EXE
Kor other memory managers (such as QEMM or 386Max) running on your computer.
Not enough free Extended/XMS memory to run Setup.
Setup needs approximately %ld bytes of free Extended/XMS memory.
Windows Setup requires 'largest executable program size' to be at least %ld bytes to run.
Missing cache program: A disk cache program was not found.
Cannot load disk cache program, because of low memory.
The following terminate-and-stay-resident (TSR) program(s)or device driver(s) are running on your computer. Windows will not install or run correctly with these programs.
LoadString failed to find entry #win.comwin386.exedosx.exePATHWININST.400mini299133
Invalid temporary directory.
Setup cannot continue until all hard disk problems have been fixed.
Could not find the specified Setup (.CAB) file.
Cannot determine the Setup (.CAB) file version(has detected a corrupt Setup .CAB file).
System has run out of memory
Setup has failed to determine the compression type.
Could not decompress this Setup (.CAB) file.
System is unable to write to the temporary directory.
Setup has detected a Setup (.CAB) file reserve mismatch.
Setup is unable continue with this Setup (.CAB) file.
Decompression has been interrupted or canceled.
Setup detected an internal error(unable to read this Setup (.CAB)) file.
Setup cannot run from MS-DOS mode with a private configuration.
Stack overflow
Integer divide by 0
Not enough space for environment
Floating-point support not loaded
Null pointer assignment
Packed file is corrupt
edit: code tag ne radi :confused:
Staro 03.07.2006., 01:43   #2
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,799
Autor Matesonik
/snip
A svrha svega ovoga je?
Programer
Staro 03.07.2006., 01:48   #3
Robi555
Robi555's Avatar
Lokacija: Pitomača(VT)
Postovi: 621
Autor Bubba
Koliko sam shvatio hoće reći da sve što si napravio u Windowsima nije radilo.
Istina da Win ima svoje "mušice" ali da je baš takav shit dal bi B.Gates bio najbogatiji čovjek na svijetu?
Robi555 je offline   Reply With Quote
Staro 03.07.2006., 02:45   #4
Matesonik
prcknedl
Matesonik's Avatar
Postovi: 3,131
svha je pokazati da je bilo ljepse ovo nego "the system has recovered from a serious error"
edit: send report to microsoft : finger :
Staro 03.07.2006., 08:41   #5
Emissary
ČLAN FKTa
Emissary's Avatar
Datum registracije: Jul 2004
Postovi: 2,264
Pa barem se to lako isključi
