Staro 17.06.2006., 02:45   #1
deToNaTor
AMD XP2800+ (2412MHz)
deToNaTor's Avatar
Lokacija: ST
Postovi: 74
AMD konfa šta vi mislite?
Prika mi oce kupit novi kompic sa monitorom od 4500kn do 5500kn na podruciju Splita (hgspot, vemil, procesor, filip, iq...)....pa sam mu ja nesto sastavija, ali prije nego krene kupovat tija bi cut vase misljenje i vase prijedloge....inace tija bi igrat na kompicu stare (napet mu je UT i Far cry) i nove igre i tu i tamo pogledat film i ponesto radit u autocad-u.....
1. MB Albatron K8NF4U, Socket 939, NVIDIA nForce4 Ultra, 4 x
Serial ATAII, SATA RAID, UDMA133, 2PCI, 3PCI-E x1, PCI-E x16,
4DDR (Dual Channel, 400/333/266MHz), 6-channel Sound, Gigabit
LAN, nVidia FireWall (ActiveArmor support), USB2.0, ATX
(659kn)
2. CPU AMD Athlon64 3000+ BOX
(744kn)
3.
Codegen midi tower 604AL-CA, 400W, P4, USB, LCD (255kn)
4. Leadtek GF 7600 GS, 256MB (1089kn)
5. DDR 2x512GB PC3200 (433MHz) kingmax (680kn)
6. HDD Maxtor 6V160E0, S-ATA300, 160 GB/8MB/7200rpm (645kn)
7. LG GSA-4167BLB (305kn)
8. LG 17" T710BH (883kn)
9. miš+fdd+tipkovnica+2.1 zvučnici (250kn)
UKUPNO : 5510 KN
T-N-T
Formula : C7H5N3O6 ; Boiling pointecomposes at 295°C
MW (g/mol) : 227 ; Melting point: 81°C
DEf (kJ/mol) : -54.39 ; Explosive velocity: 6,900 m/s
deToNaTor je offline   Reply With Quote
Staro 17.06.2006., 08:33   #2
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,505
Ploča: Epox
CPU: 3200+ eventualno
DDR: Super talent CL 2.5 npr.
HDD: Hitachi
i 304KN Chieftec 410W
Staro 17.06.2006., 08:43   #3
Buly
Buly's Avatar
Postovi: 108
pozdrav,daj reci frendu da prodajem komp ,posto mi je hica za lovu,spusti cu mu maximalno ,eo ti link pa se javi na pvm molim te,sve sa garancijom http://forum.pcekspert.com/showthread.php?t=40845
Amd Athlon 64 3000+ venice E6/zallman 9500 LED
Epox 9nda3+//G.E.I.L Ultra X Kit One TCCD 2x512@630 mhz
GF 7800GS@GT 256 GDD3 CLUB 3D//Hiper Typer-r Black 580w
Lg Tft Lcd 19" 12m/s //X-Fi Creative
Platinum soundblaster
Thermaltake Armor Black/Razer Copperhead/Razer eXactMat
Buly je offline   Reply With Quote
Staro 17.06.2006., 09:44   #4
Postovi: 33,946
Zamijeni hard za nešto solidnije tipa Seagate, Hitachi ili Samsung. btw, nešto ti je skup taj hard. Za manje love u ve-mulju dobiješ 200Gb Seagate (632 kn), a 40 Gb nije za bacit.
I neka kupi 2x1 Gb rama.
Staro 17.06.2006., 09:54   #5
Postovi: 33,946
Staro 17.06.2006., 11:15   #6
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,370
Ploča je sasvim OK kad se uzme kakva su iskustva drugi imali s nf4 Albatronom i da ima 3 godine grancije. HDD vjerojatno Hitachi, čak za isti novac dobiješ 250GB T7K250. Maxtor je imao problema s nekim serijama u kombinaciji sa nf4.
Kartica svakako Gainward Bilss kad je već 7600GS (ako je još ima za uzeti), skuplja je 60kn a dobiješ DDR3 (vjerojatno 1.4ns s obzirom na clock koji je Thoroughbred B dobio) .
2x512Mb će biti dosta ako je buđet takav, isto bih uzeo SuperTalent CL2 ... uglavnom su jako dobra iskustva s njim bila, a nije skup.
stef je online   Reply With Quote
Staro 17.06.2006., 13:12   #7
Buger
Postovi: 4,388
ma krivo je napisao cijenu hdd-a, za tu lovu dobiš maxtora od 250GB
promijenio bi ploču, al bi to sve kupio početkom 9-og mjeseca kad će cijene značajno pasti, a i am2 stabilizirati, mogo bi uštedit cca 500kn, pogledaj si nedavno objavljeni članak(pogle cijene)
http://www.dailytech.com/article.aspx?newsid=2800
Staro 17.06.2006., 14:24   #8
deToNaTor
deToNaTor's Avatar
Lokacija: ST
Postovi: 74
Sorry, je hdd sam falija cjena mu je 465kn
Cuja sam i ja da je maxtor u banani, tako da cu mu onda stavit hitachi ili segate prihvacam.
Sta se tice polovnog kompica premda san vidija BULY-jevu ponudu i kompic je ludilo, ali kaze da nece nego novo.
Ja sam sa svoim kompicem ima problema s epoxom crkle su mi 2 ploce (8rda3+) pa sam naposljetku uzeja albatrona i dan danas radi u brata pune 2g., tako da sad neznam kakav je epox premda ima garanciju samo 1g., a albatron 3g.
Danas sam vidija grafulje : VGA PCI-E CLUB 3D ATI Radeon X1600 XT, 256 MB, VIVO, Dual DVI (1217kn ) i Powercolor Radeon X800GT PCIE dd3 (1161kn), pa sam sad neznad sta bi bilo bolje da stavim sa gore navedenom konfom ili da uzmem kako je reka STEF Gainward Bilss 7600GS.
Neznam je li pametno (amd 64bit 3000+ 939 box) zaminit (Intel Pentium 4 2.66GHz 2x1MB S775 DUAL CORE D805 BOX ) sta bi bilo bolje ???
Gleda sam super talent i ni neka velika razlika tako da stavljam SuperTalent CL2.Oce mu 1gb meme bit dosta za igranje ?
T-N-T
Zadnje izmijenjeno od: deToNaTor. 17.06.2006. u 15:15.
Staro 17.06.2006., 15:36   #9
E.T.
E.T.'s Avatar
Postovi: 2,458
Autor deToNaTor
Nemozes bas tako rezonirati...No mozes slobodno uzeti albatron...
Autor deToNaTor
Uzmi:
-Leadtek GF 7600 GT TDH, 256MB, PCI-E, TV-out, 2 x DVI
za 1390Kn (ve-mil) i miran si
Autor deToNaTor
Imho i 805 je dobar procesor...Sto se tice njegovih perfomansi on je u igrama danas 10% sporiji od AMD3000+ ali se situacija drasticno mijenja u igrama koje podrzavaju smp i iskoristavaju dvojezgrene procesore pa je tako npr. u Quake4 (nakon patcha) 25% brzi od 3000+ a u CoD2 (nakon patcha) gotovo 30% brzi od 3000+, a ipak buducnost ide u tom smjeru... Takoder bolji je od 3000+ u multi taskingu, obradi videa i zvuka, i svim aplikacijama koje iskoristavaju dvojezgrene procesore (npr. 3DStudio max)...
Autor deToNaTor
1GB je trenutno preporuceno a memoriju je i najlakse nadograditi, no za nju vrijedi:memorije nikad dovoljno...
www.rabbits-clan.com
E.T. je offline   Reply With Quote
Staro 17.06.2006., 19:42   #10
deToNaTor
deToNaTor's Avatar
Lokacija: ST
Postovi: 74
Evo smo nesto uz vasu pomoc sveli na najuzi krug :
1. MB Albatron K8NF4U (ve-mil 659kn)
2. CPU AMD Athlon64 3000+ BOX (744kn)
3. Gainward Bilss 7600GS (ve-mil 1149kn)
4. DDR 2x512GB PC3200 (400MHz) SuperTalent CL2 (ve-mil 790kn)
5. LG GSA-4167BLB (ve-mil 305kn)
6. LG 17" T710BH (ve-mil 883kn)
7. miš+fdd+tipkovnica+2.1 zvučnici (250kn)
8. HDD Seagate ST3160812AS, 160 GB 8MB, S-ATA300, 7200 (ve-mil 526kn)
UK: 5306kn
E sad ostala je dilema kuciste i napajenje....problem je u tome sta nece imat dovoljno love za to pa mu ostaje [Codegen midi tower 604AL-CA, 400W, P4, USB, LCD (255kn)] ili da kala nesto gore u konfi jer neznam i mene muci oce li ovo napajane bit ok za ovo gore ili truba....sad stvarno neznamo sta bi ???
T-N-T
Staro 17.06.2006., 20:19   #11
Postovi: 7,568
Prijedlog:
Umjesto Albatron K8NF4U, deni Albatron K8NF4X za 439 kn. Ploča ima nForce4-4x chipset, ali po performansama nije ništ slabija od ove s nForce4 ultra chipsetom....dapače. Umjesto 160GB Seagate diska, deni 160GB Hitachi za 494 kn. S tim izmjenama košta sveukupno 5.055 kn, a kaj se tiče napajanja i kućišta, moreš deti npr. Therlmatake Mambo za 330 kn i 350W-ni Fortron za 229 kn ili 400W-ni Chieftec za 340 kn. Ovisno za koje napajanje se odlučiš, na kraju cijena cijele konfiguracije ispadne 5.614/5.725 kn.
Staro 17.06.2006., 21:57   #12
Milentije
Adrenaline junkie
Milentije's Avatar
Lokacija: Doboj - Banja Luka
Postovi: 3,593
Razmisli malo i o ovome. Sve je iz Ve-Mila
ABIT, s. 939, KN8 SLI, nForce 4 SLI, BUS 2000 MHz, serial ATA II, 7.1 zvuk, DDR 400, 1Gbps, Firewire, Firewall, ATX 2 792kn 24
Gainward BLISS 7600GS, GF 7600GS, 256MB, PCI-E, TV-out, DVI 1149,36kn 12
DDR 1 GB PC3200, 400MHz, SuperTalent 691,86kn 36
CPU AMD Athlon64 3000+ BOX (64-bit, integ. mem. kontr., 512K L2 on-chip cache), Venice jezgra (90nm), Socket 939 784,75kn 36
Seagate ST380817AS, 80 GB 8MB, S-ATA150, NCQ, 7200 349kn 36
OPTIKA DVD+RW/-RW Pioneer DVR-111D, Dual Layer, 16x, bulk 293,97kn 12
CHIEFTEC midi tower DG-01B-D-U, bez PS, crno, 2×USB 2.0, 1×Fire wire, 3×5,25", 4×3,5" 318,77kn 24
Chieftec power supply 450W, ATX 2.0, 2×12V, Active PFC, AFC, 12cm FAN, CE, FCC, TUV, OVP, SCP, OCP 380kn 24
UKUPNO: 4759,71 kn
Ovo je uzeo jedan moj frend i puer je prezadovoljan. Za tebe jedino mozda da uzmes malo veci disk cca.160-200GB
BTW Ploca je SLI jer planira sebi uzeti za 2 mjeseca jos jednu 7600GS.
BTW2 Sorry na nepreglednosti
BTW3 ovo sto piswe 12,24,36 to je garancija izrazena u mjesecima
EDIT: jbem ti. Pa nisam vidio da mu i monitro treba. Konto sam da ide bez njega, ali kako god cinimi se da je ovo dosta solidno za ulozene pare.
Milentije je online   Reply With Quote
Staro 18.06.2006., 12:58   #13
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,505
Ako uzimaš napajanje posebno uzmi Chieftec 410W. Hard Hitachi kao što je McG rekao. I 1GB rama jedan stick da kasnije možeš komotno još jedan stick staviti. Optika LG, i možda uzeti u startu 7600GT. A što se tiče napajanja ako stvarno nema love, nek tera 6mj. na Codegenu pa nek skupi koju kunicu i ubaci chiefa 410W (304KN).
Staro 18.06.2006., 20:15   #14
deToNaTor
deToNaTor's Avatar
Lokacija: ST
Postovi: 74
Ja mislim da ce bit kako je reka Eddie 3-6mj na Codagenu (nadam se da ce sljakat ako ovo bude odabir), a posli na Chiefteca 410W, postoji jos jedan kombinacija citajuci vase postove, a to je tako da uzmemo Hitachia i jedan keks meme od 1gb i na kraju usteda oko 200 kn i neka jos doda 100kn i eto i Chiefteca u startu...ali to cu vidit koliko ce imat tocno love....u sridu idemo u kupovinu jer tad ce imat lovu...pa javim cim ga sastavimo i isprovamo kako radi....samo vam mogu zafalit na vasem trudu jer ste nam turbo pomogli !!!
Thanks svima !
PS
Ako budete imali jos kakve prijedloge svakako su dobrodosli....
T-N-T
Staro 19.06.2006., 13:51   #15
Buger
Postovi: 4,388
@milentije, otkad ve-mil drži Abit???
a detonator pričekaj kolovoz kad će nabavna cijena a64 X2 3.8+ biti 1000kn što znači oko 1300kn za maloprodaju
Zadnje izmijenjeno od: Buger. 19.06.2006. u 16:54.
Staro 20.06.2006., 00:21   #16
thuNdeR
thuNdeR's Avatar
Lokacija: na sombra
Postovi: 1,047
Autor blablu
ja u vemulju samo vidim albatron, epox...al abit ne: hitthewa
thuNdeR je offline   Reply With Quote
Staro 20.06.2006., 13:54   #17
deToNaTor
deToNaTor's Avatar
Lokacija: ST
Postovi: 74
U vemlia u Splitu nema traga o Abitu.....a sta se tice cjena u kolovozu sta je reka blablu stvarno zvuci primamljivo samo neznam sta ce mi prika na to rec (pitanje oce bit strpljiv), ali da sam na njegovom mistu sigurno bi prigriza 2mj. i ima naposljetku lipi stroj...bas cu ga danas pitat sta misli o tom podhavatu
T-N-T
Staro 20.06.2006., 14:47   #18
Router
Hejter
Postovi: 6,521
cekati 2 mjeseca je glupost . opcenitno cekanja za nabavku su glupost jer i za ta 2 mjeseca bu nekaj novo , pa onda opet kaj budes cekao ? uzeti lovu i u ducan , ovdje je napisano svasta dobro i u izobru nema greske .
Router je online   Reply With Quote
Staro 20.06.2006., 17:48   #19
Buger
Postovi: 4,388
Autor $$kiLL3Rr
to sam ja upravo i rekao
detonator, ja bi ipak pričekao tih 2 mjeseca jer je cijena -50%, a ako još i ima kakav komp onda nevidim razlog zašto ne pričekati, iako je router dijelom u pravu
pričekaj 2 mjeseca!
Staro 20.06.2006., 23:26   #20
Milentije
Adrenaline junkie
Milentije's Avatar
Postovi: 3,593
E vidis to nije iz Ve-Mila. Sad sam se sjetio da je to uzeo u HG-u.
