Staro 06.06.2006., 10:53   #1
Jerry
Jerry's Avatar
Postovi: 1,816
Conroe vs. FX-62@Tomshardware
Conroe je jako brz proc ali izgleda da je TH komp s FX-om ipak malo brzi od onoga kojeg su slagali intelovci na Anandtechu
http://www.tomshardware.com/2006/06/...nroe_vs_fx-62/
Stupid is as stupid does
Jerry je offline   Reply With Quote
Staro 06.06.2006., 11:01   #2
B@re
B@re's Avatar
Lokacija: Split,Hrvatska(Croatia)
Postovi: 313
Ma still for me Intel Rulzz
B@re je offline   Reply With Quote
Staro 06.06.2006., 11:44   #3
Daddy
The Kwisatz Moderach
Daddy's Avatar
Postovi: 921
Pa kaj se nije tam radilo o FX-60?
Staro 06.06.2006., 12:25   #4
Jerry
Jerry's Avatar
Postovi: 1,816
Autor Daddy
Clockan na 2.8GHz.
Staro 06.06.2006., 12:35   #5
Swarm dude
Premium moderator
Swarm dude's Avatar
Postovi: 4,600
Again, we must emphasize that our testing situation was not optimal, because the Intel system had been preconfigured and didn't represent the final version. Even so, we were able to determine that not even AMD's top-of-the-line Athlon FX-62 CPU running at 3.0 GHz could clearly best the pre-release model of the Core 2 Duo (2.66 GHz Conroe) processor we tested. This comparison didn't even use the top-of-the-line Conroe processor, which Intel plans to introduce soon.
Bez obzira na ovo, Conroe se držao i te kako dobro
MBO: MSI 760GM-E51 FX
VGA: Nvidia Quadro K600
SSD: Crucial BX500 1TB
Staro 06.06.2006., 15:45   #6
Smartguy
Spiderpig
Smartguy's Avatar
Postovi: 2,043
zaboravljamo da je toms hardware posta reklamna stranica i zna pisati svakakve gluposti.
Smartguy je offline   Reply With Quote
Staro 06.06.2006., 15:46   #7
Smartguy
Spiderpig
Smartguy's Avatar
Postovi: 2,043
premda nekažem da je ovo glupost.
Staro 06.06.2006., 18:11   #8
mat
Postovi: 2,105
nemres rec da "tom" promovira intel vise od amd-a?
mat je offline   Reply With Quote
Staro 06.06.2006., 19:39   #9
Hamm
Pod naletima kopita zla
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
ma ne volim takve testove na takvim stranicama..druga bi stvar bila da npr masni uzme ta dva proca i i doma ih on istestira pa da vidimo
Staro 06.06.2006., 20:16   #10
mc_fish
the luda ribetna
mc_fish's Avatar
Postovi: 3,952
testiranje je bezvezno napravljeno jer intel nije niti klokan niti nis...dok je kod amda nafrljen ram i cpu...no dobro kaj cu im ja...
hamm ovo kaj velis...stoji svakako=) al nas dragi ivan ima posla sa faznim ehheeh nikak da prestane s time=)
@jerry sljedeci put obrati pozornost na te cake koje sam naveo gore...conroe zari i plai pred sobom doduse am2 je napravio JAKO lijep posao sa mem kontrolerom i popratnim sklopovljem
blup
mc_fish je offline   Reply With Quote
Staro 06.06.2006., 20:17   #11
maxxp
maxxp's Avatar
Postovi: 323
nebrinem se...kad budem odlučivo koja od ta dva proca uzeti, masni će i zaboravit da ih je testiro.
maxxp je offline   Reply With Quote
Staro 06.06.2006., 20:24   #12
Jerry
Jerry's Avatar
Postovi: 1,816
Autor mc_fish
Ma znam ja koje su cake samo mi nije jasno kako se razlika izmedju Conroa i FX smanjuje kako vrijeme ide s nekih 50% (prije 2 mjeseca) na nekih 10%-20% (sto je i realno za ocekivati)!
Staro 06.06.2006., 23:35   #13
BrunoZG
Junior Member
BrunoZG's Avatar
Datum registracije: May 2003
Postovi: 3,205
Nikad nije bilo 50%, cak je i onaj site koji je prvi objavio rezultate ispravio se.
a ne treba ni zanemarit da je takt conroe-a u testu skoro 400 MHZ manji od AMD-a.
Iako to jos nista ne znaci, kad dodju moze kostat ko 2 amd-a onda je ta razlika u performansama zanemariva, ili ih mogu sakatit skidat cache ko zna sta.
Malo bi mi bilo cudno za intel da ima dosta bolji proizvod a da ne odere cijenom.
Pentium 4 je bio losiji i skuplji a opet su ga dosta prodavali.
Jedino me sad cudi onaj njihov dvojezgreni D805, izgleda trenutno ko naj best buy. Iako su i tu sakatili radi cijene, izgleda da su se ipak zeznuli , pa dali pre dobar proc za premalu cijenu
Autor Jerry
AMD 3800+x2@2500, 1,375V
MB-ASROCK DUAL SATA(bios 2.2) 2+ENERMAX485W
2x512 Supertalent CL2
HDD-Hitachi 160GB, WD 800JB
ELSA 7600GT
Leadtek-2000XP expert
DVDROM-LITEON-167T ,DVDRW BENQ 1650,DVDRW NEC ND2500A@2510_fw205C
Monitor: Samsung 997MB (19')
Terratec Sky 5.1,EPSON-C42
BrunoZG je offline   Reply With Quote
Staro 07.06.2006., 02:04   #14
masni
masni's Avatar
Datum registracije: Apr 2003
Lokacija: Zagreb,Travno
Postovi: 2,110
test je ok...razlika od 10-20% je sasvim realna...prvi testovi od oko 30-tak % razlike u korist intela su ispravljeni...
ne zelim si niti zamisliti kakva bi bila razlika da je conroe na recimo 4ghz (moze i fx biti na 4ghz - ako uopce moze ) i ram na 1000mhz+...STRAŠNO!!!
inace, 805-ica ide još dole, na cca 80$, a presleri ce biti od 130$ pa nadalje...to znači da ce 920 presler doci oko 1000kn + pdv...: goood :
najjači conroe (2.66ghz) bi trebao koštati oko 500$, što je sada 50% jeftinije od fx62...zamisli šta sve možes kupiti za razliku u cijeni...i još dobiš bolji cpu...
Staro 07.06.2006., 13:37   #15
Lesa
Lesa's Avatar
Postovi: 1,130
još jedan test...FX62 versus Conroe ....
http://www.anandtech.com/cpuchipsets...oc.aspx?i=2771
bome lijepo...
..smartphone...
Lesa je offline   Reply With Quote
Staro 08.06.2006., 10:47   #16
mat
Postovi: 2,105
conroe će ić na 775 jel?
Staro 08.06.2006., 11:04   #17
RAK
Feldwebel
RAK's Avatar
Datum registracije: Feb 2002
Lokacija: bolnica
Postovi: 3,739
Autor Smartguy
Na stranu to koliko ih netko plača.
Njihov najgenijalniji zaključak je kako je nVidia 6600GT u Antec P180 kućištu podosta brža od ATI 9800pro. Kućište je jako dobro.
U istom se članku navodi kao je AMD 4200+ nasljednik, nova verzija i kopija Northwooda 3000.
Postoji i članak o ASUS dvoprocesorskoj ploči. Zaključak poprilici glasi kako je SMP sa AMD-om loš i neisplativ jer nema dovoljan broj aplikacija koje ga podržavaju a Intelov je odličan izbor.
Za one koji još nisu pročitali ćlanak preporučam da to i dalje ne čine jer je sigurno fake. Nisu jednom bezočno falsificirali podatke. Ne govorim samo o iskrivljavanju uvjeta testiranja.
Tih kao mačka
Brz kao gepard
Jak kao lav
Elegantan kao leopard
Nisam to ja, to je moj komp.
Staro 10.06.2006., 03:53   #18
olivers
Lokacija: bih sa
Postovi: 31
ispravnije je smp je efikasniji na intel platformi.
olivers je offline   Reply With Quote
Staro 10.06.2006., 10:47   #19
baterija
baterija's Avatar
Lokacija: ̣
Postovi: 1,019
Autor mat
Yep, podržava i975x chipsete, ali ,nažalost , 90% motičnih ploča ne podržava njega...
baterija je offline   Reply With Quote
Staro 10.06.2006., 12:23   #20
mat
Postovi: 2,105
vidjeti cemo. ne zelim se jos oprostiti s pentiumom, ali conroe-a bih volio isprobati sto prije u svakom slucaju
Staro 10.06.2006., 15:39   #21
Mar
Suit up!
Mar's Avatar
Postovi: 5,975
Još jedan od njihovih "genijalnih" zakljucaka je da je (mislim 6600GT) u nekom testu bila sporija overclockana nego na stock clockovima. : hitthewa
- Barney Stinson
Mar je online   Reply With Quote
Staro 10.06.2006., 17:10   #22
BrunoZG
Junior Member
BrunoZG's Avatar
Postovi: 3,205
Nesluzbeno
http://www.cdrinfo.com/Sections/News...x?NewsId=17328
Nesluzbena najava velikih pojeftinjenja proceva, osobito AMD-ova
ELSA 7600GT
