Staro 21.05.2006., 13:47   #1
denac
Datum registracije: Feb 2003
Postovi: 8
GF7900GT..kontrola vrtnje ventilatora???
Radi se o ASUS EN7900GT. Postoji program pod nazivom SmartDoctor od ASUSa. On bi trebao dati gotovo sve potreben kontrole nad grafuljom od istog proizvodjaca (OC, voltazu, i fan speed control). Problem je taj sta sam instalirao sve potrebno ali controlu vrtnje venta i sve ostalo, osim OC opcija, nikako dobit.
Probao sam sa driverima 84.21, 84.37 i 84.66 i nista (naravno instalirao sam enchanced drivere od ASUSa).
RivaTuner=0 bodova, NVHardPage=0 bodova.... nista ne pokazuju.
Postoji li koji programcic s kojim cu moci doci do zeljene kontrole nad ventom? I sa kojim driverima to provjereno radi?
Denac
denac je offline   Reply With Quote
Staro 22.05.2006., 03:02   #2
Wooo13
Lokacija: RI
Postovi: 67
Mislim da nista od toga...navodno samo evga 7900GT imaju sklop za regulaciju vrtnje venta.Meni ovog jadnog stock hladnjaka dosta, sutra idem po ZM80D-HP.
Londo Mollari:
"There comes a time when you look into the mirror, and you realize that what you see is all that you will ever be. Then you accept it, or you kill yourself. Or you stop looking into mirrors."
Wooo13 je offline   Reply With Quote
Staro 22.05.2006., 03:44   #3
Fleks
JDM
Fleks's Avatar
Datum registracije: Sep 2004
Postovi: 6,137
Autor Wooo13
LOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOLčina : goood : : goood : : goood : : goood :
Javi kak si ga uspio montirat i naravno temperature
i da... Da se preko riva tunera regulirat
Staro 22.05.2006., 04:50   #4
Ozy
Spužva Bob Skockani.. :XD
Ozy's Avatar
Postovi: 1,685
Rivatuner/Main - Customize/Low-level system settings/Fan - onda Fixed i na koliko posto okretaja da se vrti
Athlon64 X2 5400BE Brisbane @3000Mhz + KATANA 2 + AirTunel@2x Xilence 120mm
Gigabyte GA-MA78G-DS3H @F4
Mushkin Redline @1000Mhz 5-5-5
XFX 9600GSO @680/1700 || 2000Mhz
Seagate Gonzales 250GB & 320GB && Spinpoint F1 500GB
Coolermaster Elite Power RS460; Sharkoon Silvation; LG GH22NP20/LG GH20NS10/Pioneer DVR107D/Pioneer 216DBK/ Samsung SH-S223F; Logitech MX518; Philips 190P7ES 19" LCD
Ozy je offline   Reply With Quote
Staro 22.05.2006., 15:09   #5
Wooo13
Lokacija: RI
Postovi: 67
Hmm....
1.Po Zalmana upravo idem....
2.Montaza ne bi trebala biti posebno problematicna, a temperature ce sigurno biti nize od stock zujalice, jer ce naravno na Zalmana puhati TT od 92mm na 1200 rpm-a.
3.Preko Rivatunera se NE da regulirati, jer ponavljam vecina 7900GT kartica nema upravljacki sklop....bar moja Gainwardica nema.Danas je izasao novi Rivatuner 2.0 RC16 kojeg su mnogi cekali nadajuci se kako ce on rijesiti problem nemogucnosti regulacije vrtnje venta, medjutim sam autor RivaTunera kaze:"RC16 will allow to adjust 2D/LP3D/3D fan speeds on any 7900GT, however they won't work on the most of reference design 7900GTs due to missing (disabled?) fan control circuit. Currently only eVGA 7900GT series are confirmed to have working fan control. "
Enough?
Londo Mollari:
Staro 22.05.2006., 15:42   #6
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Ima jedna caka kako da se ukljuci kontrola venta u trenutnoj Rivi 15.9. Ja sam to uspio na svojoj 7600GT.
Samo sto se sad ne sjecam kako. Znam da treba nesto promijenit pod "Power User"
Staro 22.05.2006., 16:30   #7
Mar
Suit up!
Mar's Avatar
Postovi: 5,975
Navodno ATi Tool podrzava nvidiu sada...
Tu se za atija moze podesavati, onda bi tribalo moci i za envidiju.
- Barney Stinson
Mar je online   Reply With Quote
Staro 22.05.2006., 18:04   #8
denac
Postovi: 8
RivaTuner 15.9 ne postoji, ako da, volio bih znati link pa da skinem.
A trenutna verzija RivaTuner 2.0 RC 15.8 ne podrzava 7900gt.... i uopce ne mogu vidjet ili dobit tabove za OC (ovdje se nalazi i vent), DirectX, OpenGL....
Denac
Staro 22.05.2006., 18:14   #9
Wolverine
Wolverine's Avatar
Postovi: 12,431
Kupi radije VF700Cu ili VF900Cu a ne to smeče od ZM-a
VF900Cu može 7900GT Extreme držat pasivno u idle-u na oko 46°C a na 5v u load-u ne prelazi 46-48°C
BTW: najzadnja verzija RC16 podržava 7900 kartice
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
