#393 | |
Keeper of the Nine Keys
Postovi: 193
ali kao sto je vec spomenuto, to je samo za collector's edition... ![]()
L-L-L-Look at you, Hacker. A pa-pa-pathetic creature of meat and bone, panting and sweating as you r-r-r-run through my corridors-s-s. H-h-how can you challenge a perfect, immortal machine? - SHODAN CPU : AMD 64 X2 4600+ / 2400Mhz (Sckt AM2) CPU COOLER : Stock MOBO : Gigabyte GA-M59 SLI-S5 (BIOS - F8) RAM : 2x1GB SuperTalent CL4 (4-4-3-8) PC6400 DDR2-800MHz GPU : XFX 8800GT 512MB "Alpha Dog Edition" @ 710/1720/1030 POWER SUPPLY : Thermaltake Toughpower 600W PSU CASE : Thermaltake Armor Jr HDD : 2 x Seagate 320GB HDD SATA2 DVD-RW : Pioneer DVD-RW R-110 MONITOR : BenQ G2400W 24" 5ms LCD 1920x1200 Zadnje izmijenjeno od: MOrdecai83. 14.05.2006. u 18:18. |
#395 | |
Postovi: 193
![]() ![]() Mislim da vec ako se kupuje novi GW, onda se isplati uzeti Collectors Edition...jer je samo 20 kuna skuplji od obicnog...: sweating:clap:
L-L-L-Look at you, Hacker. A pa-pa-pathetic creature of meat and bone, panting and sweating as you r-r-r-run through my corridors-s-s. H-h-how can you challenge a perfect, immortal machine? - SHODAN CPU : AMD 64 X2 4600+ / 2400Mhz (Sckt AM2) CPU COOLER : Stock MOBO : Gigabyte GA-M59 SLI-S5 (BIOS - F8) RAM : 2x1GB SuperTalent CL4 (4-4-3-8) PC6400 DDR2-800MHz GPU : XFX 8800GT 512MB "Alpha Dog Edition" @ 710/1720/1030 POWER SUPPLY : Thermaltake Toughpower 600W PSU CASE : Thermaltake Armor Jr HDD : 2 x Seagate 320GB HDD SATA2 DVD-RW : Pioneer DVD-RW R-110 MONITOR : BenQ G2400W 24" 5ms LCD 1920x1200 |
#397 | |
Postovi: 193
#399 | |
Postovi: 193
![]() ima toliko novih stvari da je bolesno! nema vise tako brzog napredovanja...dosta su usporili igru i trebas se namuciti malo...i jos ono sa factionsima...sa pototkom istrazenog terena...sick!
#400 |
Postovi: 193
@SniperWolf : Odakle ti ovaj avatar...bas je : nuts :
#402 | |
Postovi: 193
#403 | |||
Lokacija: Constantinopolis
Postovi: 1,002
ovo s rankovima je okej. meni stalno upaljen rank 6. ovo kaj si škvadra upali "tyrian explorer 60%" je totalna idiotarija jer toliko ima svaki prophecies lik koji je završio igru. ovi što imaju 90, 95 i 100% su već frikovi. |
#408 |
Postovi: 1,002
vjerojatno. ja sam se posvetio farmanju furzick factiona i trenutno se zabavljam misijom Fort Aspenwood. doživljaje s te misije pogledajte ovdje i ne zaboravite staviti site u favoritse. Zadnje izmijenjeno od: Cataphract. 17.05.2006. u 10:42. |
#409 |
Postovi: 4,193
Aj lajk it ![]() btw dosao sam na mainland. btw neznam dal sam to ja imao srece ali oni afflicted u zadnjoj misiji na onom otoku stvarno dobre dropove imaju ![]() ![]() ![]() slike su mutne jer igram u windowed, pa kad sejva onda ne sejva bas dobro, igram u windowed jer me ekipa nekad zna na IM nesto traziti p.s. oni naga su mi fora ![]() |
#411 |
Postovi: 1,002
imal si sreće. : goood : ja recimo, sreće nemam. 20 kurzick chestova za redom - purple. onda odlučim NE kupovati ključeve. slijedeći chest je bio, naravno, zlatni i nitko mi nije htio prodati ključ da si i ja otvorim. |
#413 |
Postovi: 1,002
kako misliš "farmaš uw" i "ekipa" u istoj rečenici? kada sam ja farmao uw, išao sam s jednim necrom kojega je uvijek igrao netko iz guilda ili s friends liste. onda je otvaranje chestova naizmjenično, a obično prvi otvori onaj kome su monsteri dropali ključ. e da, jučer sam vidio 15k luxon armor za elementalistice. predobar. bolji čak i od 15k hydromancera, ali velikim dijelom jer mi ovaj već pod normalno i imam ga 9 mjeseci. sve mi se čini da ću s eleom raditi luxon questove. : goood : |
#414 |
Postovi: 4,193
Ma mislio sam kad farmaš uw ili fow sa ekipom, onda kad dođete do neke škrinje pričekaš da ostali prvo otvore da se vidi ima što pametno da se ne potroši key za neki purple item ![]() |
#416 |
Postovi: 4,193
http://img219.imageshack.us/my.php?image=gw026b6pd.jpg ![]() |
