Staro 21.05.2006., 21:17   #1
CountZero
What does the scanner see
CountZero's Avatar
Lokacija: Sprawl
Postovi: 99
Normalan Comp
Pozdrav svima
eto susjeda me zamolila da joj slozim jedan Comp (zena mislila da ce morat minimalno izdvojiti 1000 € ),inace je obican korisnik ,i ja sam joj slozio jednu konfu koja je po meni dobra i prilagodljiva buducim tehnologijama ...
Pa mi recite vase misljenje o tome:
-LABTEC Ultra Flat Wireless Desktop(tastatura I mouse-bezicni) Gotovina: 164,70 kn
-Monitor Samsung SM795DF CRT 17”(moja komponenta) Moja Cijena: 700 kn
-MB Gigabyte K8NE, s754, nForce4-4x(PCI-e) Gotovina: 489,70 kn
-CPU AMD Athlon64 BOX 3000+, Sck754 Gotovina: 907,39 kn
-Powercolor Radeon X700 EZ (PCIE) 256 MB DDR2 / 128bit Gotovina: 596,31 kn
-DDR 512MB PC3200 ECC REG, ST, Samsung (moja komponenta) Cijena:400 kn
-HardDisk Maxtor 6E040L0 40 GB Gotovina: 303,80 kn
-DVD ROM LG, 16/48x, ATAPI, bulk Gotovina: 140,82
-Modem Externi USB 56k Gotovina: 128,84 kn
-Kuciste Mode Com Step 207, 400 W, USB 2.0 Gotovina: 235,00 kn
Sve skupa :4067 kn
_________________________________________
"Time moves in one direction, memory in another ..."
-William Gibson
CountZero je offline   Reply With Quote
Staro 21.05.2006., 21:55   #2
Mar
Suit up!
Mar's Avatar
Postovi: 5,963
ECC memorija???
Malo veci disk
Ako se neigra onda x300 i slabiji procesor (sempron) = jeftinije
LCD - bolje za oci - ima sad neka akcija 17" Sony HS-nesto za 1600kn (sa dvi-jem).
- Barney Stinson
Mar je online   Reply With Quote
Staro 21.05.2006., 22:04   #3
Tomo
Re-Registered User
Tomo's Avatar
Postovi: 627
Autor CountZero
Pozdrav svima
Sve skupa :4067 kn
EDIT: ajde ovako rade
CD-RW LG 52x 32x 52x, bulk => 171,83 KN
Modem Conexant 56k, interni, softverski => 46,32 KN
VGA PCI-E SAPPHIRE ATI RADEON X800GTO, 128MB DDR3, DVI, TV => 757,64 KN
HDD 80.0 GB HITACHI Deskstar GST 7K80, Serial ATA II 3.0, 8 MB cache, 7200 okr/min => 348,44 KN
CPU AMD Athlon64 3000+ BOX, socket 939, Venice, 1800MHz, 512kb c., HTT 1000MHz => 835,32 KN
MBO ASUS A8V, VIA K8T800 Pro, DDR, zvuk, S-ATA,G-LAN, AGP, s. 939 => 494,50 KN
ukupno:2.654,06 KN
+ 1300 (tipkovnica, kuciste...) = 3900 a puuuno bolje
Tomo je offline   Reply With Quote
Staro 21.05.2006., 22:32   #4
Lesa
Lesa's Avatar
Postovi: 1,130
bome je na svojim komponentama dereeeš ..
stavi joj X300 grafu, disk minimalno 80Gb i DVD-RW, također nekog Semprona...
ECC, kamoli još Reg memorija nema šanse da ide na tu ploču
možda da joj preporučiš nešto ovako;
..smartphone...
Lesa je offline   Reply With Quote
Staro 21.05.2006., 22:44   #5
celduce
celduce's Avatar
Lokacija: Dimension 8
Postovi: 785
Navedena konfiguracija je ok ali mislim da joj bash i netreba Athlon 3000+ i Radeon X700 EZ
Vjerujem da nece igrati CoD i druge FPS naslove ili se baviti video obradom da ce joj trebati neznam kakva procesorska snaga.
Na onu tvoju konfiguraciju ja bih dodao:
Disk od 80GB (WD,Hitachi,Seagate)
Keks 512 obicne DDR400 memorije (+256 ako bas hoces za graficku na ploci)
MBO ASROCK, s. 754, K8NF4G-SATA2, integrated nVidia GeForce 6100, BUS 2000 MHz, serial ATA II, RAID, 7.1 zvuk, DDR 400, LAN, mATX
400kn
ili
MBO SAPPHIRE, s. 754, Pure Element, ATI RADEON XPRESS 200, BUS 1600 MHz, VGA, serial ATA, RAID, 5.1 zvuk, DDR 400, LAN, mATX
AMD Sempron 64 2600+, 1600 MHz, 128 kb c., socket 754, BUS 800 MHz, BOX (Palermo) cca 460kn.
Integrirana graficka 6100 ili XPRESS 200 je sasvim super za home/office namjenu a cak se moze i igrati ako zazeli.Ploca ima sve na sebi pa je nadogradnja laka ako joj ustreba bolja VGA or something.Jedino sto malo krade rame ali kojih 32mb nece skoditi a mozes dodati jos 256mb rama tako da dodijelis grafickoj 128mb a za rad ostane 640mb.
-Sveukupno cca 2900kn
(Takodjer bi cijena mogla biti niza jer taj monitor vrijedi max 500kn)
Fujitsu C710 • i5 3470 • 8GB DDR3 • Crucial 512GB • nVIDIA Quadro K620 • iiyama 24" ProLite • Win 10
celduce je offline   Reply With Quote
Staro 21.05.2006., 22:48   #6
Tomo
Re-Registered User
Tomo's Avatar
Postovi: 627
ups ja sam fakat pretjero onda... a hebat ga... mislio sam da moze do 4k kuna pa reko ajde da slozim nekaj posteno...
sasvim se slazem sa celduce samo sto bi mozda stavio 2800+ jer ima 256 L2 cache-a!
