Staro 03.05.2006., 22:50   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
nVidia Releases Gelato 2.0 for Free!
Render Everywhere with NVIDIA Gelato 2.0
NVIDIA® Gelato® rendering software brings high-quality rendering to the masses. A hardware-accelerated, non-real-time renderer, Gelato allows you to use your NVIDIA GPU to create stunning images fast. Originally designed for the creation of 3D visual effects and animation in feature films, Gelato can be used by anyone with NVIDIA hardware to create images of the very highest quality.
Gelato is a software program that leverages the NVIDIA GPU as a floating point math processor. This allows Gelato to render images faster than comparable renderers, but without the quality limitations traditionally associated with real-time graphics processing on the GPU.
It’s Free
Yes, Gelato is available free of charge. Now students, freelancers, startups, and small studios can take advantage of a high-end renderer with the capabilities of renderers costing thousands of dollars.
Podržan je Linux (RedHat Linux 7.2+
RedHat Fedora
RedHat Enterprise Linux ES
SuSE Linux Desktop)
i XP
Tute:
http://www.nvidia.com/page/gelato_download.html
Naravno-postoji i PRO verzija, možete je dobiti za samo 1500$
It’s Full Featured
If you require extra power in your 3D rendering pipeline, you can upgrade to Gelato Pro. With Gelato Pro you get the features required for production rendering:
NVIDIA® Sorbetto™ interactive relighting technology
DSO shadeops
Network parallel rendering
Multithreading
Native 64-bit support
Maintenance and support from NVIDIA’s High-Quality-Rendering Team
Staro 03.05.2006., 23:21   #2
atha
atha's Avatar
Postovi: 9,067
neka si je profesionalno metnu znash kamo...
sutra skidam i isprobavam - kada vech imam kramp.
___________
Just atha
x
Staro 03.05.2006., 23:31   #3
Facelessone
Facelessone's Avatar
Postovi: 4,205
moze neki info kaj je to zapravo?
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 03.05.2006., 23:33   #4
Router
Hejter
Postovi: 6,521
kaj te engleski zeza?
Router je online   Reply With Quote
Staro 03.05.2006., 23:47   #5
Facelessone
Postovi: 4,205
bas i ne , vise ljenost.....evo procital sam....i skinul bi da nema 85mb ovak moram pricekad 2 sata da se frend disconecta da skinem s njegovim accountom
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 03.05.2006., 23:51   #6
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Autor Facelessone
LOL
Ja cu skinut pa ti mogu piknut na mem stick ili cd...
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 03.05.2006., 23:56   #7
Facelessone
Postovi: 4,205
moze
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 05.05.2006., 00:31   #8
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
ok procitao sam na engleskom al jos nekuzim znaci gpu se koristi kao math proc za high res slike ? ali u cemu napraviti te slike sa tim gelatom ili trebam dodati software ili sto ? onako neko zdravolaicko objasnjenje je very nice
.i.
Razer Blade 15
Staro 05.05.2006., 00:41   #9
Jelc
Super Moderators
Postovi: 17,485
Autor Codiac-
Izgleda da nvidiašima treba sve nacrtat
Brijem da ćete jednostavnim klikanjem na dva tri linka puno saznati.
A gdje treba klikati:
Staro 05.05.2006., 01:02   #10
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
A di me nađe, ja prešao baš na ATI
Staro 05.05.2006., 08:36   #11
GoGzS
GoGzS's Avatar
Lokacija: Novi Zagreb
Postovi: 979
Ak sam ja dobro shvatio, on ne sadrži nikakav program za 3d modeliranje, već to radiš u npr. Maya-i ili 3DS Max-u...i onda u njemu renderiraš visoko kvalitetne slikice...
Staro 05.05.2006., 13:26   #12
markkc
markkc's Avatar
Lokacija: Vkci@Zgb
Postovi: 68
Radi se samo o tome da će ti se renderiranje npr. u 3Dsmax-u puno ubrzati. Ja sam s time imao dosta muke. Treba cijela noć da dobiješ jednu sliku 1600x1200.
Budem to testiro pa ću javit rezultate (prvo moram nabavit neku nv grafičku).
Čini se da bi ovo mogao biti pun pogodak za nvidiu s obzirom na ljude koji povremeno rade na 3D-u a nemaju para za Quadro ili neku zverku od SGI-a.
markkc je offline   Reply With Quote
Staro 05.05.2006., 13:33   #13
Jelc
Super Moderators
Postovi: 17,485
Pri instalaciji te pita koju verziju Maye imaš, a Amaretto traži da mu daš putanju do 3Dsmaxa.
Staro 05.05.2006., 14:07   #14
dmd-0
dmd-0's Avatar
Lokacija: /
Postovi: 592
a jel vrijedi i za blendera?
dmd-0 je offline   Reply With Quote
Staro 05.05.2006., 14:13   #15
Jelc
Super Moderators
Postovi: 17,485
Autor dmd-0
Imaš na onoj stranici link na forum pa se raspitaj.
Ali sumnjam nekaj u to.
Staro 06.05.2006., 16:43   #16
Codiac
bycod
Codiac's Avatar
Postovi: 6,699
Jelc jelc znas nas nevidijase
Nego to me zanimalo znaci opet trebam neki prog like 3dmax to mi nepase onda
.i.
Razer Blade 15
