Staro 03.05.2003., 18:35   #31
msvrtan
Datum registracije: Oct 2001
Postovi: 2,735
pa vani se prica po forumima da ce se performanse na fx-ici vidjeti tek s detonatorima 50.xx
i nekakva ubrzanja od cak 25%...ali vidjet cemo jel to je do sada samo rekla-kazala
msvrtan je offline   Reply With Quote
Staro 04.05.2003., 00:15   #32
Srky
Srky's Avatar
Postovi: 3,263
Mozda jos nesto i bude od te FX-ice
Staro 04.05.2003., 08:45   #33
BSA<AK-47>
Napokon dočekao DNF :)
BSA<AK-47>'s Avatar
Postovi: 1,460
MOŽDA je ključna riječ......
I dont know you. I dont know what you want. If you leave, that will be the end. I wont look for you, I wont pursue you. But if you dont, I will look for you, I will find you and I will ignore you.
BSA<AK-47> je offline   Reply With Quote
