Staro 04.04.2006., 13:46   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
VIA Hyperion Pro 5.07b
There are three main differences between a VIA Hyperion 4in1 driver package and a VIA HyperionPro package, detailed below. All other recommendations remain.
1) The HyperionPro package includes SATA/RAID drivers whilst the Hyperion 4in1 package does not. The extra contents makes the HyperionPro package over 5MB larger than the Hyperion 4in1 package. Therefore if you are not utilizing a VIA SATA or RAID controller in your system, the Hyperion 4in1 package may be a better download choice.
2) The HyperionPro package supports 64 bit Microsoft Windows XP and 64 bit Windows Server 2003 whilst the Hyperion 4in1 package only supports 32 bit operating systems.
3) Compared with the previous Hyperion Pro driver package, version 5.00A, this version does include the IDE Filter driver, V1.20D. For Win9X/ME/2K the IDE filter driver is needed to support UDMA 6. The IDE Filter driver is not needed for WinXP SP1 and later Microsoft operating systems
Version 5.07B includes the following components:
INF V2.70A
AGP V4.50D
RAID V5.20A
IDE Filter V1.20D
Raid Tools V5.26
http://drivers.softpedia.com/get/Oth...Pro-507b.shtml
Staro 04.04.2006., 15:19   #2
nicko
Postovi: 4,190
hvala Jelc!!!
nicko je offline   Reply With Quote
Staro 05.04.2006., 22:56   #3
MOrdecai83
Keeper of the Nine Keys
MOrdecai83's Avatar
Postovi: 193
I jel valjaju sta? Ako se to uopce moze pitati tako...
L-L-L-Look at you, Hacker. A pa-pa-pathetic creature of meat and bone, panting and sweating as you r-r-r-run through my corridors-s-s. H-h-how can you challenge a perfect, immortal machine? - SHODAN
CPU : AMD 64 X2 4600+ / 2400Mhz (Sckt AM2)
CPU COOLER : Stock
MOBO : Gigabyte GA-M59 SLI-S5 (BIOS - F8)
RAM : 2x1GB SuperTalent CL4 (4-4-3-8) PC6400 DDR2-800MHz
GPU : XFX 8800GT 512MB "Alpha Dog Edition" @ 710/1720/1030
POWER SUPPLY : Thermaltake Toughpower 600W PSU
CASE : Thermaltake Armor Jr
HDD : 2 x Seagate 320GB HDD SATA2
DVD-RW : Pioneer DVD-RW R-110
MONITOR : BenQ G2400W 24" 5ms LCD 1920x1200
MOrdecai83 je offline   Reply With Quote
Staro 06.04.2006., 10:45   #4
nicko
Postovi: 4,190
javim ti kad sljedeci put reinstaliram windowse
