Staro 03.04.2006., 18:51   #1
FERRYS
AutoCad & Allplan expert
FERRYS's Avatar
Postovi: 2,159
oc epox 9nda3+ & a64 3000+
jel ima ko doticnu konfiguraciju?
proc je trenutno box cooled ali uskoro mi dolazi nesto bolje pa nece bit problema
ja sam to nest pokusaal clockat ali ne uspijevam bas, na a64 mi je to novo.
pokusal sam povisit fsb proca na 250, htt smanjil na 4x, pci zakljucal na 66 ali ploca ne zeli bootat tako, samo pisti i vrati se na default i ponovno u bios ???
kaj da radim?
mema je kingmax hc500, proc je kupljen od ikocuba-e s foruma revizije je e6 novi stteping i njemu je isao skoro do 3ghz a ja ga nemogu dignut ni na 2250????
none
Staro 03.04.2006., 19:04   #2
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
probaj staviti memu na 2T pa vidi dal onda ide...
Staro 03.04.2006., 19:53   #3
FERRYS
FERRYS's Avatar
Postovi: 2,159
ok proc ispobano ide na 280htt s box collerom ali mema nece preko 440 ni na 2t, moram je odnest na reklamaciju.
none
Staro 03.04.2006., 21:46   #4
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
daj probaj stavit winchestera imao sam probleme sa venicom na 9nda3j
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je offline   Reply With Quote
Staro 04.04.2006., 12:07   #5
FERRYS
FERRYS's Avatar
Postovi: 2,159
probal bi da ga imam od kud posudit...
problem je u memi. kingmax je poluispravan odnosno neispravan.......
none
