Staro 01.12.2025., 22:27   #4861
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,266
Landlock is a Linux API that lets applications explicitly declare which resources they are allowed to access. Its philosophy is similar to OpenBSD’s unveil() and (less so) pledge(): programs can make a contract with the kernel stating, “I only need these files or resources — deny me everything else if I’m compromised.”
It provides a simple, developer-friendly way to add defense-in-depth to applications. Compared to traditional Linux security mechanisms, Landlock is vastly easier to understand and integrate.
This post is meant to be an accessible introduction, and hopefully persuade you to give Landlock a try.
↫ prizrak.me blog
Here is a fact-based summary of the story contents:
The numbers on Linux installations are finally starting to show some life, and despite what some people might say, it's not all down to just one or two major moves. But, undeniably, the rise of Linux gaming has something to do with it.
After decades of being inviable as a primary gaming platform, things are changing fast in the world of Linux gaming. This time it doesn't feel like a flash in the pan, but trying to understand why it feels that way to me turns out to be a little complicated.
> Why everyone suddenly cares about Linux gaming—and it's not just the Steam Deck
Miguel Ojeda has already submitted the core Rust programming language infrastructure updates intended for the Linux 6.19 merge window. In the pull request he also notes that moving forward the minimum supported Rust version for compiling the Linux kernel will likely follow whatever the minimum Rust version currently in use by the latest Debian stable release.
The Rust for Linux 6.19 updates include adding support for Syn as a parsing library for parsing strams of Rust tokens into a syntax tree of Rust source code.
Rust in this next version of the Linux kernel also continues enhancing its "kernel" crate with support for more features, support for C string literals in Rust 1.77+, and documentation updates.
As part of the documentation updates it's noted in the pull request:
"We are planning to propose that the minimum supported Rust version in Linux follows Debian Stable releases, with Debian 13 being the first one we upgrade to, i.e. Rust 1.85."
> Rust Updates For Linux 6.19, Rust Minimum Baseline To Likely Follow Debian Stable
KubeCon + CloudNativeCon North America 2025, Atlanta: After being founded in 1992 in Germany, open source and Linux vendor SUSE built itself into a well-known brand across Europe, Asia, and Latin America. Yet SUSE’s footprint in North America has never been anything close to that of its major enterprise open source Linux competitor, Red Hat, which dominates the Linux and open source market here.
But SUSE’s new chief marketing officer, Margaret Dawson, who began her new job in September, says she is already working to change that scenario and earn SUSE a bigger slice of the pie in the North American marketplace.
> KubeCon 2025 Report: SUSE Is Diving Deeper Into the Channel
Zadnje izmijenjeno od: tomek@vz. 01.12.2025. u 22:34.
Staro 02.12.2025., 17:31   #4862
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,266
Steam's November 2025 survey shows Linux gaming climbed to its highest share in a decade "thanks to the success of the Steam Deck, the underlying Steam Play (Proton) software, and now further excitement thanks to the upcoming Steam Machine and Steam Frame," writes Phoronix's Michael Larabel. From the report:
A decade ago in the early Steam days the initial use was around 3% and back then the Steam user-base in absolute terms was much smaller than it is today. Back in October Steam on Linux finally re-crossed that 3% threshold after for years being stuck in a 1~2% rut. Now the Steam Survey results were published minutes ago for November and they continue an upward trend for Linux.
Steam on Linux is up to 3.2%, an increase of 0.15% for the month. One year ago Steam on Linux was at 2.03% last November, 1.91% for November 2023, and a decade ago for November 2015 was at just 0.98%. [...] Due to AMD APUs powering the Steam Deck, AMD CPUs continue to power nearly 70% of Linux gaming systems. Meanwhile under Windows, AMD has around a 42% CPU marketshare.
Staro 02.12.2025., 18:14   #4863
Postovi: 10,234
Pokušavam na Debian VM-u mountati NFS share na NAS-u i, osim što sam to radio gro puta i koristim identične fstab komande koje sam uvijek koristio, nemam uopće ideju zašto mi je ne želi mountati nakon reboota. Ako ručno mountam nakon boota s "mount -a" onda sve radi.
Koji vi pristup koristite za mountanje shareova (multimedija), kroz fstab (i koju komandu) ili kao service (ovo nisam do sada koristio)?
Ne kužim zašto mi recimo Proxmox uredno spaja na NFS share, a Debian VM neće:
Code:
10.27.20.2:/media /mnt/media nfs vers=3,nouser,atime,auto,retrans=2,rw,dev,exec 0 0
Probao sam dodati i "_netdev", ali nema promjene. Probao sam i čekati x minuta u nadi da će se mount dignuti naknadno.
Staro 02.12.2025., 18:26   #4864
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,266
Autor xlr Pregled postova
Code:
Probaj mu implementirati delay...moja je pretpostavka da u trenutku kad zeli mountat da mreza nije spremna pa posto nemoze do ciljnog servera - mount ne uspijeva a kasnije ni ne pokusava. Cekiraj i autofs. Imas cak opciju mountanja mount pointa tek kad neka aplikacija zatrazi pristup lokaciji.
Staro 02.12.2025., 18:27   #4865
strikoo
strikoo's Avatar
Postovi: 1,011
Proxmox je debian
mi na valjd 200 debiana imamo nfs u fstabu
strikoo je offline   Reply With Quote
Staro 02.12.2025., 18:27   #4866
domy_os
domy_os's Avatar
Postovi: 18,940
Jesi li pregledao logove? Čini se kao da presporo digne mrežu ili DHCP kasni.
EDIT: Kasnim, briši.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 02.12.2025., 18:37   #4867
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,706
Da treba staviti delay bar 10-15s, onda ce mountati pri bootu.
Sent from my SM-S931B using Tapatalk
Zadnje izmijenjeno od: Bono. 02.12.2025. u 19:59.
Staro 02.12.2025., 18:43   #4868
Neo-ST
Neo-ST's Avatar
Postovi: 8,550
Zar ne postoji neki "queue" sistem kod bootanja servisa nego ih moraš ovako napamet delayati ?
Tipa:
Service 1 up? If yes -> Load Service 2. If not -> wait for Service 1.
Service 2 up? If yes -> Load Service 3, itd.
Staro 02.12.2025., 18:51   #4869
Dule
Dule's Avatar
Postovi: 691
Autor Neo-ST Pregled postova
Tipa:
Postoji, zove se systemd
Vjerojatno bi trebalo dodati ovo u fstab mount opcije:
Code:
x-systemd.automount
x-systemd.after=network-online.target
npr.
Code:
 10.27.20.2:/media /mnt/media nfs vers=3,nouser,atime,auto,retrans=2,rw,dev,exec,x-systemd.automount,x-systemd.after=network-online.target 0 0
Dule je online   Reply With Quote
Staro 02.12.2025., 20:08   #4870
Postovi: 10,234
Hvala, ovo je napravilo razliku "x-systemd.after=network-online.target" i to sad radi kako sam zamišljao. Dodao sam tvoje parametre, a taj naglašeni mi je izgleda falio. Naletio sam na sličan savjet, vrtilo se oko "_netdev" koji kod mene nema funkciju, ako je taj parametar uopće još aktualan:
https://www.reddit.com/r/linuxmint/c...mment/l8yw3g1/
Hvala svima još jednom. Ljepše je ovdje nego u W11 temi
Staro 02.12.2025., 20:10   #4871
Neo-ST
Neo-ST's Avatar
Postovi: 8,550
Uživaj dok traje. Mladen je probao Linux i svidio mu se.
Staro 02.12.2025., 20:31   #4872
Postovi: 10,234
Hahahaha, once you go black...
Staro 03.12.2025., 14:06   #4873
Postovi: 10,234
Svašta se tu očito promjenilo između Trixiea i Bookworka. Kao, odlučih dignuti čisti Debian 13 VM umjesto da upgrejdam stari i samo prebacim mountove i Docker podatke na nj, pokrenem i zaboravim na to sljedećih godinu dana. Nejde baš bajno, dugo nisam ovoliko udarao u zid
Kontejneri mi se ne žele pokrenuti poslije reboota, bace exit code 128 "error while mounting volume..." i vezano je za NFS mount o kojem sam prije pisao. Taj mount se na kraju uspješno digne, ali očito prekasno za Docker.
Srećom vikend je pred nama, imat ću šta raditi.
Staro 03.12.2025., 14:12   #4874
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,266
Hint: systemd izmedu ostalog...poceli su kao i svi sa prebacivanjem configova iz /etc u /usr/etc/ i /usr/local/etc. Jedna od mozda najvecih izmjena zadnjih 5 godina na "standarda" datotecne strukture. Stavi da se docker starta nakon nfs-a i sve 5.
Staro 03.12.2025., 15:12   #4875
Postovi: 10,234
Mislim da je to sad to.
Code:
systemctl edit docker.service
Dodao:
Code:
[Unit]
After=remote-fs.target
RequiresMountsFor=/mnt/media
Morao sam specificirati mount, nije radilo ako umjesto RequiresMountFor stavim "Requires=remote-fs.target".
Staro 03.12.2025., 16:47   #4876
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,266
Odlicno
Staro 03.12.2025., 17:56   #4877
Dule
Dule's Avatar
Postovi: 691
Ovo mi je novost, prvi put čujem. Arch i Gentoo su i dalje na /etc, a Arch prati upstream kad god je to moguće...
Imaš neki link? Google mi izbacuje jedino nekakve openSUSE članke gdje mi se na prvu čini da je to dosta opinionated promjena openSUSE developera?
Staro 03.12.2025., 19:41   #4878
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,266
Autor Dule Pregled postova
E sad da ga hebes nemogu nac to, u sjecanju mi je da sam negdje pred cca godinu dana procitao da je to systemd uvjetovana izmjena, ne samo hir OpenSuse devova ali trenutno mi bas trazenje nejde (14 satna sihta...ne pitaj):
In the longterm, /etc will only contain configuration files that are host-specific or have been modified by the admin. All distribution specific configuration files are located below /usr/ and are not modifiable by the admin (with a read-only root filesystem, this would not even be possible). Instead, the applications need to be enhanced, as far as possible and necessary, to read the configuration files from several locations. If there is a common location for that configuration file already below /usr, e.g. because the application supports already hermetic-usr, this location should stay and not be moved. This would only confuse users.
> openSUSE:Packaging UsrEtc
Kolko vidim vise bi trebalo utjecati na MicroOS (immutable OS) ali znam da drljaju s tim vec od Leap-a 15 jer sam im spominjao mater kod upgrejda sa 15.6 na 16 na par masina.
Red Hat dokumentacija takoder spominje:
The /etc/ directory is reserved for configuration files that are local to the machine. It should contain no binaries; any binaries should be moved to /bin/ or /sbin/.
/usr/etc This directory is used for system-wide configuration files.
Staro 03.12.2025., 23:57   #4879
Piksa
Piksa's Avatar
Lokacija: Chakovec
Postovi: 432
Imam jedan stari laptop koji skuplja prašinu (i3 7th, 8gb). Imao sam gore Win 10 do danas. U nedostatku ljepšeg vremena instalirao sam gore Zorin OS.
To je sad poprilično upotrebljiv laptop, pogotovo za multimediju, streamanje sa Spotifya na zvučnik preko bluetootha, gledanje filmova, youtube...
To mi je prvi doticaj s Linuxom. Imam i jedan stariji desktop, i na to ću stavit Zorin. Samo još ne znam kaj će mi.
Sviđa mi se kak je "čist" od sranja kojeg ima na Windowsima. Praktički sve mogu na njemu radit, osim posla kojeg trebam lol. Nisam IT, bavim se projektiranjem, ovo je iz čistog hobija i znatiželje.
Zadnje izmijenjeno od: Piksa. Jučer u 00:04.
Piksa je offline   Reply With Quote
Staro Jučer, 04:17   #4880
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,266
Autor Piksa Pregled postova
Tak se i pocne
Staro Jučer, 23:01   #4881
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,862
Nego, di se brže otvara file explorer?
Na Fedori ili Ubuntu? hahahahahahahaha
