Staro 23.11.2025., 05:57   #3001
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,207
PowerToys 0.96 upgrades Advanced Paste with a redesigned UI and support for multiple AI endpoints, including Azure, OpenAI, Gemini, Mistral, and local models like Foundry Local and Ollama. The release also improves the Command Palette and PowerRename tools.
> PowerToys 0.96 upgrades Advanced Paste with local AI support
Staro 23.11.2025., 11:37   #3002
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,207
"Copilot Actions on Windows 11" is currently available in Insider builds (version 26220.7262) as part of Copilot Labs, according to a recent report, "and is off by default, requiring admin access to set it up."
But maybe it's off for a good reason...besides the fact that it can access any apps installed on your system:
In a support document, Microsoft admits that features like Copilot Actions introduce " novel security risks ." They warn about cross-prompt injection (XPIA), where malicious content in documents or UI elements can override the AI's instructions. The result? " Unintended actions like data exfiltration or malware installation ."
Yeah, you read that right. Microsoft is shipping a feature that could be tricked into installing malware on your system. Microsoft's own warning hits hard: "We recommend that you only enable this feature if you understand the security implications." When you try to enable these experimental features, Windows shows you a warning dialog that you have to acknowledge. ["This feature is still being tested and may impact the performance or security of your device."]
Even with these warnings, the level of access Copilot Actions demands is concerning. When you enable the feature, it gets read and write access to your Documents, Downloads, Desktop, Pictures, Videos, and Music folders... Microsoft says they are implementing safeguards. All actions are logged, users must approve data access requests, the feature operates in isolated workspaces, and the system uses audit logs to track activity.
But you are still giving an AI system that can "hallucinate and produce unexpected outputs" (Microsoft's words, not mine) full access to your personal files.
To address this, Ars Technica notes, Microsoft added this helpful warning to its support document this week. "As these capabilities are introduced, AI models still face functional limitations in terms of how they behave and occasionally may hallucinate and produce unexpected outputs."
But Microsoft didn't describe "what actions they should take to prevent their devices from being compromised. I asked Microsoft to provide these details, and the company declined..."
Nekad davno ovakve stvari se nisu gurale na korisnicka racunala vec su bile oznacene kao experimentalne dodatne opcije koje je korisnik sam morao instalirati ako ih je zbilja zelio i bio svjestan mogucih posljedica instalacije i koristenja istih.
Staro 23.11.2025., 11:45   #3003
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,686
Nekad davno je postojao odjel za kvalitetu i kompatibilnost. Vidim da su i u 2025 otpustili ljude zaduzene za testiranje i zamjenili ih sa AI-em.
Ovo je 2014, kad je krenulo nizbrdo.
Estimated number of QA testers (SDET/QA) affected: Several thousand (commonly cited internal figure: ~4,000–5,000 SDETs and testers globally)
Key change: Microsoft dramatically reduced the traditional tester-to-developer ratio from roughly 2 testers : 1 developer down to ≈1:1 or lower, effectively eliminating thousands of dedicated testing roles.
Bono je online   Reply With Quote
Staro 23.11.2025., 12:09   #3004
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,207
Autor Bono Pregled postova
Znam. Ali ovo je odluka managementa - ne developera ni testera. I to je zapravo jedini jebeni problem Windows 11 kao OS-a. Da je to sve opcionalno OS bi bio top. Mislim da cu se poigrat sa Nikky-evom idejom. Problem je samo da je sve to tolko integrirano u sustav da hoces ili neces izbacivanje tih "kljucnih" komponenti rezultira potrganim sustavom.
Staro 23.11.2025., 12:18   #3005
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,686
To je odluka indijca kad je postao CEO:
Satya Narayana Nadella is an Indian-American business executive who is the chairman and chief executive officer of Microsoft, succeeding Steve Ballmer in 2014 as CEO and John W. Thompson in 2021 as chairman.
Sad je all in u AI, kako bi rekli pukovnik ili pokojnik.
Staro 23.11.2025., 14:48   #3006
Promo
Promo's Avatar
Datum registracije: Jun 2024
Lokacija: Space
Postovi: 726
Sad' su to insider korisnici i "get latest update" korisnici. Ali je problem sto MS ne uzima feedback kao prioritet.
Staro 23.11.2025., 15:02   #3007
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,207
Nego...jel netko skuzio da je na celu vecine tih firmi ili neki indijac ili kinez?
Staro 24.11.2025., 09:37   #3008
spiderhr
spiderhr's Avatar
Datum registracije: Jul 2021
Lokacija: Sesvete
Postovi: 1,124
Nisam pratio tko je na čelu firme...
Nego zna li se kada bude ms ugradio tvin view u file manager
Staro 24.11.2025., 09:45   #3009
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,359
Autor spiderhr Pregled postova
Otvoriš dva i staviš jedan kraj drugog, još najbolje da se zamaraju time....ne radi dobro ni ovo sada, a ti bi nove fićre.
Slobodno me dodajte na PSN
Zadnje izmijenjeno od: Disco. 24.11.2025. u 16:27.
Staro 24.11.2025., 11:16   #3010
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,207
https://multicommander.com/
https://freecommander.com/en/summary/
Ima i ostalih alternativa naravno.
Staro 24.11.2025., 12:44   #3011
spiderhr
spiderhr's Avatar
Lokacija: Sesvete
Postovi: 1,124
Autor Disco Pregled postova
Otovriš dva i staviš jedan kraj drugog, još najbolje da se zamaraju time....ne radi dobro ni ovo sada, a ti bi nove fićre.
Ah... svašta bi ja da se ugradi kad se već ugrađuje...
Ma znam, imam doma double commander u win/lin ali na poslovno ne bi htel puno toga instalirati.
Staro 24.11.2025., 16:26   #3012
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,359
Ja sam sarkastičan, ali evo ovaj free commander ti je sasvim upotrebljiv, pogotovo ako znaš komande tj shrtcoute još iz doba norton commandera, iste su.
Staro 24.11.2025., 21:43   #3013
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,207
The latest Windows 11 releases, versions 24H2 and 25H2, have a very bizarre bug, where closing Task Manager does not close its process properly, and every other launch results in duplicate processes piling up and eating your system's resources. Right now, there are no official fixes, except for a temporary workaround, where Microsoft recommends users kill duplicated processes with the taskkill.exe /im taskmgr.exe /f command executed as Administrator. However, enthusiasts have already discovered a way to resolve the issue.
> How to fix duplicate Task Manager processes in Windows 11
Starting with Windows 11 version 24H2, Microsoft automatically encrypts all drives when you set up a new computer. In the past, BitLocker was a security feature reserved for Professional SKUs, but now, encryption is standard even on Home editions. While BitLocker is not a bad thing per se (it is for your security, after all), the bad part is that Microsoft is not asking users whether they want it or not. Windows 11 won't even let you know that it just encrypted all your drives, and there are already plenty of horror stories about users losing their data. Not cool.
If you want to install a vanilla Windows 11 version 24H2 or 25H2 without any mods, be aware that Microsoft will encrypt your drives if you sign in with a Microsoft Account during the initial setup or even after it. This could be a nasty surprise for those coming from the now-unsupported Windows 10, especially when trying to move a drive from one PC to another. Fortunately, there is a way to reverse that, and this guide will show you how to remove BitLocker encryption in Windows 11.
> How to remove BitLocker drive encryption in Windows 11
Last month, Microsoft announced that it is introducing a new wake phrase, "Hey, Copilot", that Windows customers can speak to trigger their Copilot experience. This brought back memories of the ill-fated "Hey, Cortana" from 2015, but the jury's still out on how Copilot will fare in this domain. Now, Microsoft is looking to go one step ahead in this area by introducing a new phrase.
In an update on its Microsoft 365 Roadmap, Microsoft has noted that while Microsoft 365 Copilot on Windows already has voice activation through "Hey, Copilot", it is in the process of developing a "semantic goodbye word" as well. In simple terms, you'll be able to invoke Copilot's voice interface through "Hey, Copilot" and disengage with it through a phrase like "Bye, Copilot", making it a hands-free interaction.
> Bye, Copilot: Microsoft is making Copilot a hands-free experience on Windows
Staro 26.11.2025., 17:01   #3014
mkey
Datum registracije: Sep 2018
Lokacija: tu
Postovi: 3,704
Evo, imam jednu situaciju za ljude kojima Windows 11 radi sve kako treba i koji znaju koristiti Windows 11, za razliku od nas ostalih.
(doduše, nije ovo moj laptop ali je primjer, rekao bih, pogođen k'o prstom u pekmez)
Dakle, normalni (što god to značilo) korisnik ima dva laptopa (neko totalno smeće kupljeno preko fondova, ali nebitno) koji imaju dva accounta, od čega jedan administratorski. Problem je, naravno, što lozinka nije poznata. Disk unutra je neki najmanji Nvme na kojeg je to moglo stati.
Pokušaj br. 1: učitam taj neki "PC unlocker" ISO s kojim sam već u više navrata rješavao sličan problem, međutim isti ne vidi disk.
Pokušaj br. 2: odem u advanced recovery međutim tamo ne mounta C. HM, sada već pomalo sumnjam na bitlocker. Logiram se u taj jedini standard user account, potražim bitlocker i kaže ovaj da nije aktivan. OK, valjda je u pravu, jer to očito mora sve raditi kako treba.
Pokušaj br. 3: bootam linux distro (arch based) i pokušam mountati particiju i dobijem grešku "unknown file system type BitLocker".
Očito sve ovo radi kako treba, očito da korisnik ne zna šta radi, očito da je gubitak password događaju max jednom u milion godina.
Autor George Carlin
But there’s a reason. There’s a reason. There’s a reason for this, there’s a reason education sucks, and it’s the same reason that it will never, ever, ever be fixed. It’s never gonna get any better. Don’t look for it. Be happy with what you got. Because the owners of this country don't want that. I'm talking about the real owners now, the real owners, the big wealthy business interests that control things and make all the important decisions. Forget the politicians. The politicians are put there to give you the idea that you have freedom of choice. You don't. You have no choice. You have owners. They own you. They own everything. They own all the important land. They own and control the corporations. They’ve long since bought and paid for the senate, the congress, the state houses, the city halls, they got the judges in their back pockets and they own all the big media companies so they control just about all of the news and information you get to hear. They got you by the balls. They spend billions of dollars every year lobbying, lobbying, to get what they want. Well, we know what they want. They want more for themselves and less for everybody else, but I'll tell you what they don’t want: They don’t want a population of citizens capable of critical thinking. They don’t want well informed, well educated people capable of critical thinking. They’re not interested in that. That doesn’t help them. Thats against their interests. Thats right. They don’t want people who are smart enough to sit around a kitchen table to figure out how badly they’re getting f*cked by a system that threw them overboard 30 f*cking years ago. They don’t want that. You know what they want? They want obedient workers. Obedient workers. People who are just smart enough to run the machines and do the paperwork, and just dumb enough to passively accept all these increasingly shittier jobs with the lower pay, the longer hours, the reduced benefits, the end of overtime and the vanishing pension that disappears the minute you go to collect it, and now they’re coming for your Social Security money. They want your retirement money. They want it back so they can give it to their criminal friends on Wall Street, and you know something? They’ll get it. They’ll get it all from you, sooner or later, 'cause they own this f*cking place. It's a big club, and you ain’t in it. You and I are not in the big club. And by the way, it's the same big club they use to beat you over the head with all day long when they tell you what to believe. All day long beating you over the head in their media telling you what to believe, what to think and what to buy. The table is tilted folks. The game is rigged, and nobody seems to notice, nobody seems to care. Good honest hard-working people -- white collar, blue collar, it doesn’t matter what color shirt you have on -- good honest hard-working people continue -- these are people of modest means -- continue to elect these rich c*cksuckers who don’t give a f*ck about them. They don’t give a f*ck about you. They don’t give a f*ck about you. They don't care about you at all -- at all -- at all. And nobody seems to notice, nobody seems to care. That's what the owners count on; the fact that Americans will probably remain willfully ignorant of the big red, white and blue dick that's being jammed up their assholes everyday. Because the owners of this country know the truth: it's called the American Dream, because you have to be asleep to believe it.
Staro 26.11.2025., 17:20   #3015
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,338
Nova zabava na w11. Udem u igru, izadem van, i sad trebam restartat jer iz nekog razloga adrenalin ne otvara. Hebo takav os. Znao sam da je losa ideja ic na to gofno umjesto 10, al nije mi vrag dao mira, reko ajde po prvi put idem against gut feeling... Moron
update ovoga gore,
znaci instalirao sam na drugi nvme drive (najeftinije 128gb sto sam nasao. patriot p3, nekakvih 500/600mb/s).
stavio na njega win 10 ENT LTSC IoT i paralelno testirao identicne stvari.
gore spomenuti problem je sada vjerujem do optiscaler-a, jer se identicna stvar deseva sa w10 kao i na w11.
na w10 su nesto noviji adrenalin driveri.
neznam kako i zasto se to desava jer doticni problem nikad nisam imao na staroj masini (win10, rx6800). budem kopao i dalje...
ako govorim o usporedbi "na prvu", zaista je win10 puno brzi, manje lag-a, "snappier"...
kod igara je stanje nesto drugacije. w11 je uvjek nesto sitno jaci po FPS-u, ali u vecini igara govorimo o margin of error.
my 2 cents. nastavit cu koristit w11 za gejming, za sve drugo w10.
edit: bit-shitex je na oba OS-a iskljucen/nekoristen. bar se nadam, kad mu pogasis servis (BitLocker Drive Encryption Service) da se djubre nemre pokrenut/aktivirat...
am mislite/znate da nije dovoljno pisite da kopam dalje...
We all must hang together, or surly we will hang separately.
Staro 26.11.2025., 17:51   #3016
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,704
"Ispod haube" je W11 superiorniji po mnogočemu vs. W10.
Problem je ono "iznad haube"
IMHO nema smisla vrtit i jedno i drugo sad kad si skužio da je do Optiscalera.
Staro 26.11.2025., 18:08   #3017
mkey
Lokacija: tu
Postovi: 3,704
BTW ja sam ovdje došao da zaključka da zapravo nije moguće utvrditi je li drive zaključan ili nije iz samih windowsa bez administratorskih ovlasti. Što znači da gubitak administratorskog passworda vodi na nezaobilaznu reinstalaciju. Samovoljno paljenje bilockera je vjerojatno MS način da nevjerne Tome privoli da dobro razmisle potrebuju li ipak online account
Autor George Carlin
Staro 26.11.2025., 18:45   #3018
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,359
Naporni su do boli, imam namjerno ugašen TPM u BIOSu uz još neke govnarije i ne oni siluju pa siluju. Ovo mi je w10 22h2 sa aktivnim ESU:
Staro 26.11.2025., 19:15   #3019
Promo
Promo's Avatar
Lokacija: Space
Postovi: 726
Jel moguce da su promjenili zahtjeve za 11? Prvu stvar koju uradim nako win10 instalacije je gasenje TPMa i jos nisam dobio takvu poruku.
Staro 26.11.2025., 20:02   #3020
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,704
Znaju da imate TPM, iako ste ga isključili.
JK
Meni ništ ne iskače na LTSC iako zadovoljavam sve uvjete, osjećam se diskriminirano.
Staro 26.11.2025., 20:20   #3021
calypso
calypso's Avatar
Datum registracije: Oct 2002
Lokacija: Zagreb/Rijeka
Postovi: 2,020
Pitanjce... Jel jos uvijek funkcionira ono hakiranje logina za logiranje na Win11 kad zaboravis password?
Rebootas u troubleshooting mod, odes u command prompt, tamo renameas utilman.exe u nesto drugo, onda cmd.exe renameas u utilman.exe i rebootas... Onda odaberes accessibility features sto ti zapravo starta cmd.exe, i onda imas cmd prompt u pre-loginu i tamo zamijenis password za admin usera...
https://www.youtube.com/watch?v=ZK5mzXPlEHc
GMKTec K8Plus
2x EIZO EV2336WFS3-BK
23" 1920x1080 IPS
Dell Latitude 7390
32GB DDR4-2666
intel UHD 620
13.3" FullHD IPS Touchscreen
Staro 26.11.2025., 20:34   #3022
mkey
Lokacija: tu
Postovi: 3,704
Pa to možeš i kroz advanced recovery napraviti. ALI ako je bitlocker upaljen onda si lagana banana
Autor George Carlin
Staro 27.11.2025., 11:41   #3023
Dule
Dule's Avatar
Postovi: 683
OK, recimo da želiš kupiti Windows 11 LTSC IoT legalno kao firma? Kako bi to napravio jer koliko vidim prodaju ih samo kao Volume License? Koliko bi morao iskeširati za najjeftiniju verziju?
Ne kužim iz ovoga ništa: https://learn.microsoft.com/en-us/wi...vots=windows11
BTW kako to da neki dućani prodaju licence pojedinačno, npr. https://www.senetic.hr/product/DG7GMGF0PP49-0001
Dule je offline   Reply With Quote
Staro 27.11.2025., 11:46   #3024
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,207
Autor Dule Pregled postova
LTSC version is a corporate product so one need to sign a corporate contract with at least 5 licenses.
Dakle...ako imas ugovor sa Microsoftom i kupio si vec 5 licenci zasto nebi mogao kupiti dodatne licence? Barem sam ja tako skuzio. Provjera i sankcije su drugi par rukava.
Staro 27.11.2025., 11:47   #3025
Dule
Dule's Avatar
Postovi: 683
Da ali tražim crno na bijelo koliko košta "corporate contract with at least 5 licenses".
Staro 27.11.2025., 11:55   #3026
Promo
Promo's Avatar
Lokacija: Space
Postovi: 726
Ovo sam ja ranije spominjao pa ti dodje kao siva zona. Mislim da su kljucevi legit samo neiskoristeni, i mogu se naci po tridesetak €. Ali opet, who the fuck knows.
Staro 27.11.2025., 12:04   #3027
zwizard1
Datum registracije: Aug 2013
Lokacija: R Hrvatska
Postovi: 155
Autor Tajl3r Pregled postova
Win11 iot ltsc radi savršeno
Upirem prst u amd ili odakle ti taj image ltsc?inače se skida sa ms legit stranice i onda mass ostalo se nedira jer nema potrebe nema ai govna i ostalih glupoština
Poslano sa mog SM-S918B koristeći Tapatalk
Potpisujem , nikakvih problema .
zwizard1 je offline   Reply With Quote
Staro 27.11.2025., 12:29   #3028
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,207
Posalji sluzbeni upit Microsoftu , taj info sam nasao kao odgovor od MS Supporta i tako je i meni receno na projektu posto grad Minhen nece vjerojatno do 2027 moci na Win11 pa su radili produzivanje licenci i znam da je bila diskusija oko Win 10 LTSC (sluzbeni Support do 12.01.2027) ili produzenje placenog supporta za sve klijente (cca 80.000 Windows 10 klijenata).
Edit:
https://learn.microsoft.com/en-us/wi...dows-licensing
https://community.spiceworks.com/t/e...ense/677472/13
Zadnje izmijenjeno od: tomek@vz. 27.11.2025. u 16:03.
Staro 27.11.2025., 16:55   #3029
Promo
Promo's Avatar
Lokacija: Space
Postovi: 726
Around 500 million PCs are holding off upgrading to Windows 11, says Dell
“We have about 500 million of them capable of running Windows 11 that haven’t been upgraded,” said Dell COO Jeffrey Clarke on a Q3 earnings call earlier this week, referring to the overall PC market, not just Dell’s slice of machines. “
Staro 27.11.2025., 16:58   #3030
Neo-ST
Neo-ST's Avatar
Postovi: 8,525
Autor Promo Pregled postova
A kako to znaju?
