Staro 19.08.2025., 22:31   #1
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,542
Cronos: The New Dawn
još nema temu
Staro 03.09.2025., 19:46   #2
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,542
fine ocjene pobrao
Staro 04.09.2025., 02:38   #3
Miki9
Datum registracije: Jun 2021
Postovi: 374
Lik zgleda ko vojvoda Zill iz Mačak Felix cjelovečernjeg crtića
Staro 11.09.2025., 23:56   #4
biohazard
Datum registracije: Jun 2025
Postovi: 58
vuče dosta na d.space, c.protocol, a ova obleka podsjeća na bioshock
biohazard je offline   Reply With Quote
Staro 12.09.2025., 20:46   #5
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,493
stavio danas. perf koma dok nisam upogonio optiscaler sa frame gen koji rade odlicno.
i naravno reshade sa pluginom za promjenit FOV jer je opet kriminalan defaultni ko i obicno. neznam sta je tim devovima u glavama.
meni igra na prvu (igrao par min samo) vuce skroz na callisto koji sam nedavno igrao.
"We all must hang together, or surly we will hang separately."
AMD Ryzen7 7800x3D+Noctua NH-D14 | MSI Tomahawk WIFI AMD B650 | 2x16GB Corsair Vengeance DDR5-6000 CL30 1,39v | SAPPHIRE Pulse RX 9070xt UV/OC | 1tb NVMe sammy 970 evo plus, 2TB Samsung 990 EVO Plus, Crucial MX500 500GB, Kingston 480gb | Riotoro ENIGMA G2 850W 80 Gold | Corsair Carbide 300R modded | Win10 ENT LTSC IoT (work) + Win11 ENT LTSC IoT (gejming) | logitech g403 | ROCCAT Horde | AOC CQ27C4 + AOC C24G1 + 50" Hisense H50A6140
AMD Ryzen5 2600+Xilence Cryon M806D.B | Asus x370 Prime Pro rev1.03 (bios 6203) | GSkill Aegis 32GB (2x16) DDR4@3,2GHz | 2x Intel 545s 128GB, 1x Crucial MX500 500GB | Gigabyte GTX960 | sisa 620w | Fractal Design Focus G | Win7 x64 + Win10 ENT LTSC IoT | logitech g403 | ROCCAT SuoraFX
intel i5 2500k@4,5ghz (1,28v)+FSP Windale 4 | ASRock Z68 Ext4 Gen3 (bios 1.20) | 2x8gb DDR3 HyperX Savage, 1866mhz, 10-10-11-27,1,5V | Samsung SSD 64gb, 2x256gb SSD | iGPU | corsair vx450w | CoolerMaster Centurion 534 modded | Win7 x64
Staro 13.09.2025., 12:01   #6
Mladenxy
Mladenxy's Avatar
Postovi: 4,479
Odlična igra nakon prelaska sa gamepada na miš i tipkovnicu, od preteške frustracije do normalne težine jer ciljaš sa mišem precizno.
Baš guštam jer volim ovakav tip igre više nego pečeni odojak.
Staro 13.09.2025., 12:21   #7
geronimo_2
geronimo_2's Avatar
Postovi: 4,493
Daj malo detalja. Koju res guras i detalje? Koristis optiscaler ili?
Jer meni se to vuce na 1080p sa max detaljima (ray t off) bez optiscalera i frane gen-a,a vidim da imas puno veći monitor...
Staro 13.09.2025., 12:42   #8
Mladenxy
Mladenxy's Avatar
Postovi: 4,479
Na TV-u sam igrao 4K FSR performance, na monitoru 1440p XsSS qualty, u oba slučaja medium detalji i radi sve odlično i glatko bez frejm gena.
RT uvijek imam ugašeno u svim igrama, to je za neke druge korisnike u moju hižu ne ulazi osim u budućoj konzoli po difoltu.
Staro 13.09.2025., 13:10   #9
geronimo_2
geronimo_2's Avatar
Postovi: 4,493
Koji fps ganjas? Ja 70-75 (pri 1080 i 1440p). Ne kuzim zasto frame gen ljudi ne koriste. Koliko ja vidim kvaliteta slike mi je lošija sa manjom rezolucijom nego sa njime a dobijem 25-50% vise fps. Taj dio mi nikak nije jasan...
Za ray t se slazen, to me ni najmanje ne dira.
Staro 13.09.2025., 13:31   #10
Mladenxy
Mladenxy's Avatar
Postovi: 4,479
Nemam pojma koji je fps, ne koristim više te brojače samo igram i nemam problema sa performansama
Igra je baš osvježenje u žanru.
edit; koristim ja frejmgen u drugim igrama ali u ovoj je ključna brzina odaziva, za beštije je bitna preciznost i brzina reakcije, svaki metak se broji.
Zadnje izmijenjeno od: Mladenxy. 13.09.2025. u 13:37.
Staro 13.09.2025., 13:47   #11
geronimo_2
geronimo_2's Avatar
Postovi: 4,493
il ja ne kuzim tebe il ti mene. meni je igranje ispod 70ak fps lose. odziv shitex, mrzim to.
kak to mislis imas los odziv kad koristis frame gen?? ja to nisam primjetio, a osjetljiv sam na to skroz .
callisto sam prelazio sa optiscalerom, doduse bez frame gen-a (ali sa zescim upscalingom da izgleda predivno) jer onda jos nisam znao da optiscaler koji je widely available (github) nije prava stvar i nema opcije neke kao ovi latest (pre/beta/vatever) sa discord-a (streamless), bar pred par mjeseci.
al kolko vidim ima sad i neki FG noviji koji isto ne kida hud/ui (ne treba hud fix koji je isto ono, los) i taj sam sad upalil za cronos. radi perfektno kolko vidim (nisam igral jos igru, samo testiram).
koristim sve sta mi je na raspolaganju, ali detalje i rezoluciju ne volim snizavati jer sam fina guica i vidim odmah vizualno da to nije to (spasava me jos sto sam na 23 cola LCD-u ).
isto tako ne podnosim ono jadno zamucivanje, najcesce dodajem sharpness-a jos.
drugim rjecima oni FXAA i slicno je za mene glupost notorna. osobno radije cu jaggies nego mutno.
Staro 13.09.2025., 13:51   #12
Mladenxy
Mladenxy's Avatar
Postovi: 4,479
I meni, imam 144 hz tv i 165 hz monitor i naviknut sam na HRR gaming, i velim nemam nikakvih problema sa performansama. Za ovu igru je 60+ sasvim OK s sigurno bi osjetio da pada ispod toga
Kao što rekoh igra sa gamepadom je meni bila frustracija jer se traži brzina i preciznost tak da sam isključio FG da anuliram bilo koju mogućnost kašnjenja sa mišom i tipkovnicom
Staro 13.09.2025., 13:58   #13
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,414
Kažeš bitan ti je odziv a koristiš framegen....reklo bi se kontradikcija.
Na tom i5 2500k i gtx 960 dobro da se i pokreće (da znam, popuni si moj komp sa trenutnom konfom).
Ugl imaš DF optimal setting na YT, potraži i setiraj si tako.
Slobodno me dodajte na PSN
Staro 13.09.2025., 14:02   #14
d0X
Kostolomac
d0X's Avatar
Postovi: 1,566
@Disco, čovjek ima dvije konfe pod Moj komp, pogledaj bolje.
PSN Steam
Staro 13.09.2025., 14:19   #15
geronimo_2
geronimo_2's Avatar
Postovi: 4,493
@mladen, ok, ti pucas nize od mene. meni je vec i 60 na rubu igrivosti, ko sto rekoh fina guica .
opet kazem, ja nisam primjetio nikakav dodatni lag sa FG-om. mozda nisam dost testiro, ali stvarno. osjetljiv sam na to jako pa mi je cudno to sto kazes.
gamepad, kao i konzole me nikad nisu zanimali tak da na tom polju sam 0.
za mene samo komp. kad njega nebu, nebu bilo ni gejmanja vise za mene.
@disko disko,
otvo'r oči .
sendi je tu za ukras, koristim je za skidanje materije, za nis drugo.
rajzen je gejming makina.
Zadnje izmijenjeno od: geronimo_2. 13.09.2025. u 14:30.
Staro 13.09.2025., 14:50   #16
Mladenxy
Mladenxy's Avatar
Postovi: 4,479
eto moj prosječni fps
kaj se detalja tiče između srednjih i epic ja vidim male ili nikakve razlike. Uglavnom savršeno igrivo na 1440p i 4K uz odgovarajući upscaling bez FGa sa mišom te FG uz gamepad ali onda mi je igra preteška, neigriva.
ak smanjim upscaling sa qualty na performance ide na preko 100 fpsa bez problema, ali nepotrebno IMO.
Staro 13.09.2025., 19:35   #17
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,414
Moj bed, nisam ni skužio da ima više konfi.
Ali da, DF video i posetirati igru tako i mora biti igrivo, većina tih ultra detalja se ne vidi ni na 4k, a kamoli na 1080p 23 inča.
Staro 15.09.2025., 09:24   #18
Ninja_Zg
Ninja_Zg's Avatar
Datum registracije: Aug 2013
Postovi: 270
Jesam jedini kojem je ovo dosadno i bezveze?
Obozavam Dead Space serijal i veselio sam se Cronosu jer je kao duhovni nastavak.
Igrao sam ga nekih sat vremena, fora je setting, prica donekle zanimljiva, iako citam u recenzijama da na kraju nis posteno ne saznas u prici, ali su mi gameplay i neprijatelji bezveze.
Cijelo iskustvo mi je takvo da mi jednostavno nije zabavno igrati tu igru.
Ninja_Zg je offline   Reply With Quote
Staro 19.09.2025., 22:51   #19
Mladenxy
Mladenxy's Avatar
Postovi: 4,479
Pri kraju sam, koja igra
Staro 24.09.2025., 23:42   #20
biohazard
Postovi: 58
gamepad i pucačina ne idu u istu priču
Staro 25.09.2025., 08:25   #21
Promo
Promo's Avatar
Datum registracije: Jun 2024
Lokacija: Space
Postovi: 806
Autor biohazard Pregled postova
keep it for yourself
Staro 25.09.2025., 08:35   #22
Mladenxy
Mladenxy's Avatar
Postovi: 4,479
Na zapovijed!
Staro 01.10.2025., 12:13   #23
IHrvojeI
¯\_(ツ)_/¯
IHrvojeI's Avatar
Datum registracije: Sep 2016
Lokacija: Pag
Postovi: 1,255
Taman završio bolnicu, odlična je igrica - trebalo joj je malo duže da me uhvati, ali sad kad je, mogu reći da je mnogo dobra igrica.
Staro 05.10.2025., 10:12   #24
emilblomsky
emilblomsky's Avatar
Lokacija: karlovac
Postovi: 2,094
Evo ,krenuo i ja sa Cronosom,nakon skoro godinu dana da nisam ništa igrao.
Malo mi djeluje teška,al budemo vidjeli s vremenom.
Pošto sam ja fan takvih igara ,tipa D Space,Callisto,pretpostavljam da mi bude sjela.
Čitam malo po netu da treba ići samo sa charge shotovima,lootat,i mijenjat pozicije.
Phil of the future!
Staro 05.10.2025., 14:13   #25
biohazard
Postovi: 58
i treba da je teška, tu je čar, kad se samo sjetim ds-a gdje bježeći piliš onog kripla koji se konstantno regenerira , kad skupim živaca i volje možda jednom na hard i impossible
Staro 06.10.2025., 09:33   #26
IHrvojeI
¯\_(ツ)_/¯
IHrvojeI's Avatar
Lokacija: Pag
Postovi: 1,255
Ja sam je završio jučer... Odlična je, što je je, ali zapravo i nije teško ako igraš "pametno" tj kako igra dirigira... Lootaj sve - nema ostavljanja itema; ako treba vraćaj se u bazu pohraniti "višak", samo charge headshotovi a na velike samo charged shotgun. ide to onda bez problema i bude pravo lako. Ja sam cijelu igru koristio onaj prvi pištolj i prvi shotty, a tek za 2 bossa sam uzeo onaj neki carbine sa pratećom municijom i za zadnjeg arbalest.
