Staro 13.06.2025., 09:38   #781
biohazard
Datum registracije: Jun 2025
Postovi: 58
dal netko zna dal će net bankarstvo biti free, nešto su pričali u medijima ??
biohazard je offline   Reply With Quote
Staro 13.06.2025., 09:45   #782
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,474
prvi put cujem. zvuci nevjerovatno...
AFAIK free bi trebao biti samo glavni racun, sto realno gledano i IMO je oduvjek i trebalo bit obzirom da je obvezno da ga hebeno imas. al ko danas od mlađe gen moze bit da nema net banking preko kojeg nas deru ko tutleke...
"We all must hang together, or surly we will hang separately."
AMD Ryzen7 7800x3D+Noctua NH-D14 | MSI Tomahawk WIFI AMD B650 | 2x16GB Corsair Vengeance DDR5-6000 CL30 1,39v | SAPPHIRE Pulse RX 9070xt UV/OC | 1tb NVMe sammy 970 evo plus, 2TB Samsung 990 EVO Plus, Crucial MX500 500GB, Kingston 480gb | Riotoro ENIGMA G2 850W 80 Gold | Corsair Carbide 300R modded | Win10 ENT LTSC IoT (work) + Win11 ENT LTSC IoT (gejming) | logitech g403 | ROCCAT Horde | AOC CQ27C4 + AOC C24G1 + 50" Hisense H50A6140
AMD Ryzen5 2600+Xilence Cryon M806D.B | Asus x370 Prime Pro rev1.03 (bios 6203) | GSkill Aegis 32GB (2x16) DDR4@3,2GHz | 2x Intel 545s 128GB, 1x Crucial MX500 500GB | Gigabyte GTX960 | sisa 620w | Fractal Design Focus G | Win7 x64 + Win10 ENT LTSC IoT | logitech g403 | ROCCAT SuoraFX
intel i5 2500k@4,5ghz (1,28v)+FSP Windale 4 | ASRock Z68 Ext4 Gen3 (bios 1.20) | 2x8gb DDR3 HyperX Savage, 1866mhz, 10-10-11-27,1,5V | Samsung SSD 64gb, 2x256gb SSD | iGPU | corsair vx450w | CoolerMaster Centurion 534 modded | Win7 x64
Staro 13.06.2025., 10:10   #783
biohazard
Postovi: 58
nesto su pričali političari al navodno tek od 27.me, u pbzu moraš imati net bank. da bi kupovo prek neta dok u rajfasenu to nisi moro imati , trebalo bi navodno i net bank isto biti bespaltan uz osnovni t.r.
Staro 13.06.2025., 11:20   #784
dinos3
Dino Saur
dinos3's Avatar
Datum registracije: Jan 2012
Postovi: 941
dinos3 je offline   Reply With Quote
Staro 28.07.2025., 15:34   #785
mrva_zg
mrva_zg's Avatar
Datum registracije: Feb 2010
Postovi: 959
prije dva dana mi otkazala poslusnost biometrija u aplikaciji
uopce se ne pojavi da skeniram prst.
Probao ugasit pa upalit, ali kad dodje da skeniram prst uopce se ne pojavi na ekranu da skeniram i ne mogu nazad aktivirat
Naravno radilo prije toga.
U svim ostalim aplikacijama radi revolut, keks, cak i MyWay radi
Staro 10.10.2025., 11:25   #786
geronimo_2
geronimo_2's Avatar
Postovi: 4,474
poz. dali znate kako ide procedura gasenja racuna na PBZ-u (viza prepaid i ziro bi ugasio jer nemaju smisla uz revolut).
pretpostavljam da moras doc u poslovnicu.
kolko cca naplacuju doticno?
Staro 10.10.2025., 11:28   #787
Juice
Fresh Juice
Juice's Avatar
Postovi: 4,583
Besplatno je gašenje računa. Bar bilo prošle godine kad sam gasio usluge u PBZu
Staro 10.10.2025., 12:14   #788
geronimo_2
geronimo_2's Avatar
Postovi: 4,474
nemogu vjerovati lol.
a za napravit mbanking na mob-u, treba u poslovnicu (net banking imam, al koristim token, nikad jos preko moba)?
edit:
thx alister
Zadnje izmijenjeno od: geronimo_2. 10.10.2025. u 13:45.
Staro 10.10.2025., 13:42   #789
Alister
Alister's Avatar
Datum registracije: Aug 2009
Postovi: 1,492
Da, moraš ići u banku da ti generiraju kod za aplikaciju. To su promijenili da više ne možeš bez toga.
Mall B&D 1250 pila na prodaji
Staro 14.10.2025., 13:04   #790
geronimo_2
geronimo_2's Avatar
Postovi: 4,474
vec neko vrijeme muku mucim sa tokenom rucnim od PBZ. stavim nove bat (2x cr2032) i on radi. nakon dan dva kod paljenja zamjenite bat. uredno prikazuje display i sve, al neda ic dalje nego samo ta poruka.
jucer zamjenio obe bat opet. jutros smece opet istu poruku.
za pop.
AFAIK novi mi dati nece jel tako jer ne postoji vise, a opet moram u banku za to, isto kao i za napravit mbanking, a to mi trenutno nije zgodno.
Staro 14.10.2025., 17:18   #791
zkljaja
Brat od Đon Vejna
zkljaja's Avatar
Lokacija: zg-vg
Postovi: 1,204
Ne koristi tvom problemu ali me sjetilo
Moj token je slučajno proveo 2-3 godine na balkonu, kisnuo, bio pokriven snjegom, pola ekrana mu se jedva vidi, baterija gubi kontakt, treba ga stisnut u predjelu čipa da bi čitao karticu ali i dalje radi
Staro 14.10.2025., 17:22   #792
geronimo_2
geronimo_2's Avatar
Postovi: 4,474
a eto. ma nije kod mene bat ocito. nesto drugo njega hebe, al mi nije jasno sta. i nije mi nikako jasno zasto to gofno ima 2 bat umjesto jedne, stvarno.
izvucem mu ladicu od bat. pustim vani min dva, ubodem nazad i normalno radi.
razmisljam da ga otvorim i pocistim malo.
btw star je moj isto valjda prek 10g.
Staro 20.10.2025., 01:02   #793
geronimo_2
geronimo_2's Avatar
Postovi: 4,474
svaki put kad mislis da te nemereju vise raspizdit uspiju u tome.
ulogiram se veceras i ocu prebacit sa racuna na racun nesto evra. opcija koju koristim stalno.
ukucam sve sto treba i button "nastavi" na dnu siv.
refresh, ista stvar. WTF.
jel vama radi?
mozda me gamad blacklistala jer toliko kenjam protiv njih i reklamiram revolut loool.
Staro 20.10.2025., 01:17   #794
silver_tip
silver_tip's Avatar
Lokacija: doma
Postovi: 2,922
Novi feature od PBZ-a, nist specijalno... moras otic u izvrsene naloge, nac tekuci sa kojega si vec prije prebacivao i nac takvu transakciju u toj listi izvrsenih naloga pa onda kopiraj/ponovi transakciju. Ako ides direktno na tekuci da nadjes tu transakciju od prije pa ju pokusas kopirati - nece proci.
trebaš seedbox?
Staro 20.10.2025., 09:02   #795
geronimo_2
geronimo_2's Avatar
Postovi: 4,474
Proradilo je jutros, al da pojasnim, nije se radilo o nalogu, već mjenjacnica/prebacivanje unutar mog bankinga. Znaci prebacivanje sa tekućeg na viza prepaid koju koristim za online. Nema tu nikakvog ukucavanja ništa osim cifra i sa kojeg na koji racun.
Staro 20.10.2025., 13:44   #796
Buger
Postovi: 4,398
Može li se potvrda o ibanu kako dobiti mailom ili preko aplikacije?
Staro 20.10.2025., 15:27   #797
silver_tip
silver_tip's Avatar
Lokacija: doma
Postovi: 2,922
Znam, samo ti nisi razumio kako se snaci u tom problemu. Znaci kada hoces izmedju svojih racuna prebacivat novce a isto ne radi onda moras otic na naloge jer svako takvo prebacivanje novaca izmedju svih tvojih racuna ostavlja "trag"/zapis u samin nalozima za svaki pojedini racun.
Konkretno sad posto ti je uspjelo prebacit novce sa racuna y na racun x, odes u naloge i naci ces tu transakciju na racunu y. Dali sad razumijes sta ti pisem? Taj "trag" izvrsenog placanja/prebacivanja/naloga mozes iskoristiti ubuduce kada normalno prebacivanje izmedju racuna ne radi, samo prilagodis cifru....
trebaš seedbox?
Staro 20.10.2025., 15:32   #798
geronimo_2
geronimo_2's Avatar
Postovi: 4,474
Kuzim, hvala, nisam znao.
Staro 20.10.2025., 16:12   #799
buljaka
Datum registracije: Aug 2014
Postovi: 2,947
Autor Buger Pregled postova
Osobno u banci. Išao dizati nekidan zbog poticaja za solare i popizdio što nema online opcije za takve gluposti
Poslano sa mog 2306EPN60G koristeći Tapatalk
buljaka je online   Reply With Quote
Staro 20.10.2025., 19:37   #800
dreammastera
Datum registracije: Aug 2012
Postovi: 117
Mirovinsko traži da ti banka da dozvolu da se uplaćuje mirovina. Onda odeš u PBZ banku jer naravno nema online. Na šalteru djelatnik isto nema digitalno da povuče iz sustava nego uzme šprancu papira za mirovinsko i napiše ručno ime i prezime i IBAN i lupi pečat.
Ništa bez pečata.
Poslano sa mog PGT-N19 koristeći Tapatalk
dreammastera je offline   Reply With Quote
Staro 20.10.2025., 21:30   #801
geronimo_2
geronimo_2's Avatar
Postovi: 4,474
Jad i bijeda.
To je ta famozna digitalizacija.
Ma treba ih sve pozatvarat i oduzet licence za rad. Paraziti.
Staro 20.10.2025., 23:42   #802
Buger
Postovi: 4,398
A ako hoću staviti pbz app na novi mob moram li mob ponijeti u banku ili mi oni samo daju neki aktivacijski kod?
Staro 20.10.2025., 23:46   #803
geronimo_2
geronimo_2's Avatar
Postovi: 4,474
Ovo prvo haha. Hostapleri
edit: bas sam jucer tu opciju trazio po njihovom netbankingu i tamo je, ali ispod pise upozorenje da su zbog bla bla, onemogucili i da je potrebno se javiti u poslovnicu. smješno i jadno.
Zadnje izmijenjeno od: geronimo_2. 20.10.2025. u 23:54.
Staro 21.10.2025., 07:46   #804
buljaka
Postovi: 2,947
Ne moraš nositi mob. Dobiješ kod koji vrijedi 24 sata od trenutka izdavanja
Staro 21.10.2025., 08:10   #805
geronimo_2
geronimo_2's Avatar
Postovi: 4,474
Ne kuzim.
To dobijes u banci i imas 24h za iskoristiti? Ili dobiješ na sajtu privremeni da prezivis 24h njihovu glupost nakon čega opet moras u poslovnicu?
Ako je ovo prvo, u cem je problem da ti to dostave digitalno?
Staro 21.10.2025., 11:31   #806
udarnik60
Datum registracije: Mar 2015
Lokacija: mars
Postovi: 335
Ne kuzim.
Zato što nije sigurno. Npr. netko ti je hakirao mail I samo to čeka....
Ti se stvarno čudiš kao pura dreku s ovim bankarstvom...
Sent from my motorola edge 40 using Tapatalk
udarnik60 je offline   Reply With Quote
Staro 21.10.2025., 11:49   #807
buljaka
Postovi: 2,947
Ne kuzim.
Da da
Odeš fizički u poslovnicu i dobiješ kod za aktivaciju na papiru a drugi dio koda dobiješ sms porukom
Staro 21.10.2025., 11:50   #808
geronimo_2
geronimo_2's Avatar
Postovi: 4,474
Nemogu isprintat i poslat u kuverti na adresu usera kojeg imaju u databazi i koji je zatrazio te kodove?
Budimo realni, znaju oni, a i mi, zasto inzistiraju na dolasku u hebenu poslovnicu.
Edit:
Sjecam se u koronjati natezanja snjima. Nova kartica stigla i traze da dodem u poslovnicu po nju jer eto u to vrijeme nisu jos slali postom.
Moro sam prijetiti i pozvati se na lockdown da bi pristali poslati postom. Hostapleri.
Zadnje izmijenjeno od: geronimo_2. 21.10.2025. u 12:02.
Staro 21.10.2025., 12:05   #809
prileee
laser
prileee's Avatar
Postovi: 2,356
Ja ne znam, reci mi zasto? Mirise na teorije zavjere. Jednom u 3-4+ godine kad promijenim mob odem u banku.
Staro 21.10.2025., 12:54   #810
spawn
spawn's Avatar
Postovi: 8,497
Ne kužim famu oko svega. Da se slučajno desi da poštar krivo odnese kuvertu dizale bi se bune i psovke kako to kako to?
Odeš u banku radi svoje sigurnosti i lijepo si aktiviraš. Izgubio si puno više na razne fb,tiktok yt short idiotarije i videa s razinom iq0, a teško radi sebe otići do poslovnice. Digitalizacija je tu da olaksa neke stvari a ne da zamijeni ljudski mozak.
