Povratak   PC Ekspert Forum > Računala > DIY i Tinkering
Staro 01.06.2025., 06:49   #661
tigerija
Datum registracije: May 2009
Lokacija: Koprivnica
Postovi: 261
Sto vi printate? Nisam vidio ovdje previse slika, ima li neki Hr forum gdje se shareaju ideje?
tigerija je offline   Reply With Quote
Staro 01.06.2025., 08:43   #662
BlackDwarf
BIND SOFT d.o.o.
BlackDwarf's Avatar
Lokacija: Novska
Postovi: 2,416
Samo za posao.
Recimo cepove za nosace kamere, za kanalice, nosace slusalica, okvire...
Staro 08.06.2025., 19:31   #663
Postovi: 8,321
Bambu Lab removes third-party app support for P and A series 3D printers
An update to Bambu Lab’s A- and P-Series 3D printers earlier this week brought the controversial “Authorization Control” or “Security” update to the company’s budget machines, along with “Developer Mode” – a compromise the company promised amid backlash. After P-Series firmware version 01.08.02.00 and A-Series 01.05.00.00, the machines will now refuse communication from unofficial software. This includes software Bambu Lab previously worked closely with, like Orca Slicer. Instead, third-party software will need to use “Bambu Connect”, a middleware application, or set their devices to “Developer Mode” to bypass communication restrictions. Notably, Orca Slicer developer SoftFever declined to integrate Bambu Connect into the slicer, remarking it “would not provide meaningful value for Orca Slicer users.” Bambu Lab notes in the firmware release notes that downgrading the firmware to a previous version remains possible.
In effect, this prevents users from using third-party applications on their machines by default. Thankfully, there are a few ways around this that will still allow you to make the most of your 3D printing workflow using your favorite apps and add-ons. One way is to avoid the update altogether, however this means your printer will be unsupported going forward unless you choose to update it. The other option is to take advantage of Developer Mode, which gives you the authorization to install third party apps. Some features found in third party apps can be found in the Bambu Connect software, like the ability to view your print remotely. However, many users are partial to programs like Octoprint that have their own add-ons. Bambu Labs' decision isn't entirely a surprise as it added the same restriction earlier this year to the X series 3D printers.
Izvor: Tom's Hardware
Staro 08.06.2025., 22:24   #664
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,786
bok ekipa, odlučio sam ući u svijet 3D printera, pa bih nešto uzeo.
Ne bih uzeo neki šrot, ali opet, neću ni printati svaki dan, tako da ne trebam sada uređaj od 1000€.
Imate li kakvu preporuku na temelju ovog što sam rekao?
Ako ne, možete li mi barem reći na što obratiti pozornost pri kupovini printera?
Staro 08.06.2025., 23:05   #665
OuttaControl
OuttaControl's Avatar
Lokacija: Dalmacija
Postovi: 5,843
Ja i dalje mislim da je Bambu a1 mini najbolji ulaz u svijet 3d printera.
Krenio sam sa Anycubic Kobra Go, okejish u pocetku, cca 50% print failure, nocna mora za održavat. Modificira sam ga do bola stavio klipper i svasta nesto, ali petg nikad nisam isprintao sa njim dobro
Kobra 2 bozete sacuvaj sta je to skuplja i puno losija verzija. Nije trebala biti al jednoatavno ima bug neki nikad popravljeni tako da 80% failed printova.
Nakoj toga sam za 200tinjak eura uzeo A1 mini, 99.9% print success, failure je jedino kad ne ocistim dobro plate il ignoriram warning da mi je nesto u zraku. printa sve sta sam mu da i pla i petg i tpu. Nikakvog posebnog cackanja nema. Sve se mijenja lako, ali mislim da su dvije glavne stavke touch based plate leveling, i taj neki flow senzor koji kuzi nekako sam jel triba vise ili manje gurat filamenta, spasava stvar.
Nezz od ovih drugih proizvodjaca tko sad te iste senzore ima al po meni dvije ekstrmno bitne stavke.
Obavezno uz printer uzmi i dryer filamenta, znaju i doci mokri
Zadnje izmijenjeno od: OuttaControl. 09.06.2025. u 16:58.
OuttaControl je online   Reply With Quote
Staro 08.06.2025., 23:21   #666
Ivo_Strojnica
PRO
Postovi: 4,786
aha, hvala na info, znači bamboo je još uvik way to go.
Znam da ima dosta farsi sada oko njihovog firmwarea....
Staro 08.06.2025., 23:21   #667
Mar
Suit up!
Mar's Avatar
Postovi: 5,968
Mislim da je Qidi Q1 Pro najbolji za novac. Meni radi savršeno, par puta kad nije dobro ispalo je zbog moje krivice radi orijentacije printa ili krivih postavki. Za razliku od Bambulaba printa sve bez greške (ABS, ASA, Nylon, PC...) i ne moraš brinuti o padanju prašine i čišćenju print ploče jer je zatvoren. Ja koristim defaultne postavke za 99 posto materijala i nemam prigovora.
Ako bi printa isključivo PLA, PETG i TPU onda je Bambulab super, ali zašto se ograničiti.
- Barney Stinson
Staro 09.06.2025., 00:49   #668
Ivo_Strojnica
PRO
Postovi: 4,786
uuuu, sviđa mi se qidi, a kažu i da je support brutalan.
koliko ga dugo koristiš?
Staro 09.06.2025., 11:36   #669
Ivo_Strojnica
PRO
Postovi: 4,786
Odakle naručujete filamente?
Staro 09.06.2025., 11:39   #670
VandaL.pr!
VandaL.pr!'s Avatar
Lokacija: zaDAR
Postovi: 825
aliexpress ili bambulab.
Ako možeš, idi na CoreXY printer tipa taj Qidi.
Staro 09.06.2025., 16:28   #671
blazer
Lucky Luke
blazer's Avatar
Lokacija: vg
Postovi: 143
I ja imam qidi4 plus vec pola godine. Dobar izbor.
VGWireless
blazer je offline   Reply With Quote
Staro 09.06.2025., 17:39   #672
m4dm4n
Does youer dewg byte?
m4dm4n's Avatar
Postovi: 1,941
Azurefilm ili Amazon.
Staro 09.06.2025., 20:16   #673
BlackDwarf
BIND SOFT d.o.o.
BlackDwarf's Avatar
Lokacija: Novska
Postovi: 2,416
Zadnje narucio azure.
No kolut ne nasjeda bas najbolje na AMS.
Mislim da cu ubuduce kupovati samo refile.
Staro 09.06.2025., 21:23   #674
cane
Amiga fanboy
cane's Avatar
Postovi: 183
Bambulab i prema preporuci ovdje sa foruma Sunlu - https://sunlu.com.de/. Nisam primjetio neku razliku između ta dva proizvođača, PLA na A1 mini printeru.
cane je offline   Reply With Quote
Staro 10.06.2025., 08:55   #675
ICT Avatar
ICT Avatar's Avatar
Datum registracije: Dec 2014
Lokacija: Area 51
Postovi: 229
ICT Avatar je offline   Reply With Quote
Staro 10.06.2025., 11:25   #676
hooligan.no1
matori
hooligan.no1's Avatar
Datum registracije: Feb 2011
Lokacija: ZADAR
Postovi: 168
Autor Ivo_Strojnica
Što se tiče samog printera, uzmi nešto zatvoreno xy-core i zbog mirnijege rada (manje vibracije) i kvalitete isprintanog i zbog buke.
Možda je malo komplicirano i nezgrapno kad se desi neka pizdarija, ali općenito bit ćeš zadovoljan i zadovoljniji.
Nemoj se opterećivati veličinom (kubikažom) prostora za printanje jer u većini slučajeva printaš manje modele, a veći se uvik mogu podiliti u nekoliko dijelova koji se lako spoje.
Eto i ja ću dati glas za Qidi Q1 (uloženo - dobiveno - podrška).
Što se filamenta tiče, pod broj jedan, odluči za vrstu filmenta prema svojim potrebama (PLA zadovoljava većinu) i dok ne uđeš u male tajne 3d printanja (2-3 role su ti dosta za početak).
Drugo ne kupuj unaprid ni previše boja, a ni vrsta filamenta, jer će ti stajati bez veze sa strane i propasti.
Treće vezano za drugo (vrime), kupuj di je veliki promet, uglavnom zbog potražnje to su friško proizvedeni filamenti.
E sad, neko će se busati u prsa hvaleći sušenje, ali činjenica je da i plastika stari, tj. kad stoji neko vrime u tom namotanom položaju, ona se uglavnom skrutne i postaje krta kad je probaš ispraviti (bez obzira što je vakumirana). Kontradiktorno je to što kad je staviš toćati u vodu 24h ona postaje žilavija.
hooligan.no1 je offline   Reply With Quote
Staro 10.06.2025., 12:09   #677
Ivo_Strojnica
PRO
Postovi: 4,786
e hvala na savjetima.
Na kraju si jesam uzea Qidi Q1 Pro, sviđa mi se Klipper i vidim da jako kvalitetno printa.
Naručija sam si 2 kg rola, mislim da mi je to sasvim dovoljno za početak + slun fila dryer.
Htio sam pitati za to spajanje modela?
jel postoji neka uvriježena tehnika spajanja ili ih samo - zalipite?
Staro 10.06.2025., 12:28   #678
prileee
laser
prileee's Avatar
Postovi: 2,346
A vjerojatno ovisi o primjeni. Ja sam dao printat drzace za kamere za pikado, isli su navojni umetci koji se ugriju lemilicom i utope u plastiku na jednu stranu za spojit ih vidama.
Staro 10.06.2025., 12:57   #679
Mar
Suit up!
Mar's Avatar
Postovi: 5,968
Mislim da nećeš falit. Ja ga imam oko 2 ipo mjeseca i fascinantno je koliko stvari ti padne na pamet isprintati pogotovo kad se uhvatiš malo modeliranja pa ne ovisiš o gotovim stvarima
Što se tiče filamenta, Amazon zna imati dobre ponude. Ja sam si uzea i previše toga. Nije mi se dalo uzeti 10kg ali sam uzea 5kg prozirnih višebojnih PETG od Sunlu (iako u retrospektivi bolje bi bilo da sam uzea neprozirne jer ako ne printaš u 100% infilla izgleda čudno), onda jedan paket OPY PC (polikarbonat) za specifične zahtjeve, 3x Tinmorry ABS PRO (bila cijena oko 12-13e za 1kg), 1kg Overture ASA, 2kg Tinmorry PETG+CF (pokazalo se super), 2kg Eryone TPU 95A (isto genijalna stvar kad ti treba nešto fleksibilno, meni super došlo kao košuljica za nosač pile kad mi se originalna otopila zbog varenja).
Nije me zanimao PLA jer sve što izrađujem ima neku funkcionalnu upotrebu, a PLA nije baš za to nego više za modele i prototipove iako se mislim uzeti isto koji KG ili možda ako bi tko mjenjao za SUNLU PETG
Ja ga držim u WC-u gdje se ne čuje i dobro je ventilirano
- Barney Stinson
Staro 10.06.2025., 13:40   #680
Ivo_Strojnica
PRO
Postovi: 4,786
da, vidim da je PLA shit, nije otporan ni na toplinu ni na sunce ni na napor, tako da njega skippamo
Meni će printer također biti isključivo za funkcionalnu primjenu, tu i tamo igračkica za malog, ali funkcionalno prije svega.
Staro 10.06.2025., 14:12   #681
c-shadow
c-shadow's Avatar
Postovi: 3,482
Nije PLA shit...
Skužiti ćeš s vremenom: igračkice za klince ti je najbolje u PLA, općenito bolje se printa nego PETG
Kojekakve kutijice doma i sl., to sve rokam u PLA, em se brže printa, ne razvlači niti, ne hebe ga podloga na kojoj printaš,...
Staro 10.06.2025., 15:24   #682
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,249
Otkud si ga narucio?
Staro 10.06.2025., 15:37   #683
Ivo_Strojnica
PRO
Postovi: 4,786
sa njihove stranice direktno.
Staro 10.06.2025., 15:40   #684
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,249
Ok. Javi kad stigne, tj. koliko je trebalo da stigne 😁
Staro 12.06.2025., 13:48   #685
Ivo_Strojnica
PRO
Postovi: 4,786
može, poslan je, kaže tracking "expected 16.06".
Staro 12.06.2025., 20:39   #686
OuttaControl
Lokacija: Dalmacija
Postovi: 5,843
Sunlu vs azure crni petg single layer
Staro 12.06.2025., 20:45   #687
c-shadow
c-shadow's Avatar
Postovi: 3,482
Kako ti se pokazao taj Sunlu na miniju?
Relativno sam zadovoljan s Azure, doduše imam samo bijeli.
Staro 12.06.2025., 22:04   #688
OuttaControl
Lokacija: Dalmacija
Postovi: 5,843
Meni odlican, odaberem bamu basic petg profil i to ide top. Doduse zna doc malo vlazniji pa ga obavezno ubacim u susac. Azure je dolazio mokar ko u bazenu da je pliva.
Sto se tice kvalitete sunlu ima ocito puno vise boje i time je dosta crnji, azure je polu proziran, rekak bih klasa iznad.
Mana sunlua je sto nikako slozolit kombinaicju koja mi pase, uvijek nesto fali u storeu. Btw vidio sam da su dobili glow in the dark petg. To mi je fora
Staro 13.06.2025., 08:54   #689
c-shadow
c-shadow's Avatar
Postovi: 3,482
Azure jedini petg dosad koji je oob pucao ko da kokice pečem kako je bio mokar
Baš ću uzeti za probu Sunlu PETG idući put kad naručujem, dosad sam fulao s ostalim brandovima, nekako sam pogodio sve lošije nego azure
Sunlu PLA sam uzeo neki paket zadnje, po svojstvima se printa identično kao Bambu PLA = brzo i kvalitetno. Bijelu sam doslovno gledao jedan kraj drugog filament i isprint i ne vidim razliku. Jedino su mi boje kod nekih filamenata (obični PLA orange, blue) svjetlije i prozirnije nego kod bambua.
Staro 17.06.2025., 07:35   #690
BlackDwarf
BIND SOFT d.o.o.
BlackDwarf's Avatar
Lokacija: Novska
Postovi: 2,416
gdje nabavljate lubrikante za podmazivanje printera?
