Staro 24.03.2025., 15:29   #1831
Postovi: 33,990
Intel je podržan od 8. generacije nadalje. Na kompu u firmi sam si htio zamijeniti samo proc, ali čipset (H270) ne podržava 8. generaciju.
Nabavio novi cpu, M.2 i ram, ali nisam stigao mbo jer sam bio u gužvi na poslu. Tokom ljeta ću i to napraviti. Drugi komp sam već prije obnovio i prebacio na W11.
Da mobu negdje jeftino nabaviti neki lap u dobrom stanju, rado bi to napravio i na njega nabacio neki Linux.
Staro 24.03.2025., 18:09   #1832
tomek@vz
tomek@vz's Avatar
Postovi: 4,932
Autor gin.tonic Pregled postova
Procesor je u pitanju
Proc je najmanja briga. Instalirao sam Win11 na I3 5005U lap sa 8GB meme i GF940M grafom - radi ali da nema SSD Win 11 bi ga ubio doslovce. Ovak je samo pokusavao . Pravo pitanje je kvalitete/stabilnost drivera ostalog hardwera. No jos uvijek nisam uspio iz carobne kugle iscitat na koji stroj se pitanje odnosi
Staro 24.03.2025., 19:39   #1833
kasko
kasko's Avatar
Lokacija: Ivanić_Grad
Postovi: 2,009
Također, stavio w11 na svakakav nepodrzani hardware i sve uredno radi, međutim na starim kantama je ssd obavezan kako je kolega gore spomenuo.
Sent from my 23127PN0CG using Tapatalk
Staro 27.03.2025., 16:48   #1834
tomek@vz
tomek@vz's Avatar
Postovi: 4,932
The USB printer problem was first caused by an update from January 2025. You can read the details in our coverage of printers spitting out nonsense after a borked Windows update. The problem specifically affected these operating systems with the following patches:
  • Windows 11 24H2: KB5050009, KB5050094, KB5051987, KB5052093, KB5053598.
  • Windows 11 23H2: KB5050092, KB5051989, KB5052094, KB5053602.
In the update notes, Microsoft writes: “Fixed: USB connected dual-mode printers that support both US Print [sic] and IPP Over USB protocols, might unexpectedly output incorrect or unwanted text.”
Separately, Microsoft has also acknowledged that Windows 11 24H2’s January update caused a corruption in Remote Desktop Protocol (RDP) connections. Microsoft describes the problem as follows:
“After installing the January 2025 Windows preview update (KB5050094) and later updates, users might experience unexpected disconnections with Remote Desktop Protocol (RDP) sessions, including Remote Desktop Services (RDS). We’ve observed a significant increase in reports of this issue following the release of the March 2025 Windows security update (KB5053598).
Users might notice their RDP sessions unexpectedly disconnecting after 65 seconds when establishing UDP-based connections from Windows 11, version 24H2 devices to RDS deployments running versions Windows Server 2016 or earlier. Resulting from this issue, users might experience frequent disconnections from their Remote Desktop and RDS sessions.”
https://www.pcworld.com/article/2650...-nonsense.html
Staro 28.03.2025., 04:51   #1835
tomek@vz
tomek@vz's Avatar
Postovi: 4,932
Discovered by a prolific Windows insider, the new option appears in Windows 11 Build 27823. According to him, a hidden menu – accessed via an invisible button – allows users to format partitions and unallocated disk space using a new "Flexible Storage" option. A pop-up menu then provides two file system choices: the default NTFS format or the ReFS technology.
Techspot
Jeli se tko igrao vec sa ReFs?
Staro 28.03.2025., 05:56   #1836
the.elles.d
Datum registracije: Jul 2010
Postovi: 548
Dev drive to već koristi skoro dvije godine. Radi, ništa nije izgubio ili uništio
the.elles.d je offline   Reply With Quote
Staro 28.03.2025., 07:39   #1837
domy_os
domy_os's Avatar
Postovi: 18,866
Nisam uočio niti jedan od ova dva problema, a stalno koristim RDP i USB printer, ali zato imam drugu glupost, baš nekako od posljednjeg ili pretposljednjeg updatea.
Vrlo često se monitor neće isključiti nakon 10 min ili koliko već je postavljeno. Uopće ne kužim do čega je, u event logu ništa nema, powercfg isto. Mislio sam da je možda do radija što svira u pozadini pa do tipkovnice ili miša, to sve maknem i opet neće isključiti monitor. Ajd sad budi pametan...
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 28.03.2025., 09:15   #1838
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,308
Autor Deamon101 Pregled postova
Kako prestaje support za windows 10 pred kraj godine, koliko opušteno odnosno koliko po ps-u će te u firmama izvršiti zamjenu OS-a?
U principu zahtjevi su malo kontradiktorni, ali realno 1ghz, 64gb disk, 4gb ram, i ono najvažnije, tpm 2.0 su jedini uvjeti.
Ona nekakva lista sa npr. procesorima koji jesu/nisu podržani, izvršio sam jednu instalaciju za test danas i prošlo je bez problema iako procesor nije službeno podržan. PC ima tpm 2.0, ali je star 10 godina.
Realno veća količina odjednom se neće moći prebaciti na windows 11 odjednom.
Vjerujem da se u principu samo radi o tome da pravno gledano Microsoft se na taj način ograđuje itd. za bilo kakve propuste, odnosno daje si više prostora za manevar i bolje rezultate na sudovima npr.
Plaćanje dodatne potpore za sigurnost za windows 10 ne dolazi u obzir jer košta koliko i windows 11 licenca, te vjerujem da kod mnogih većih firmi koje imaju ugovor sa Microsoft će se jednostavno morati naći na pola puta.
Ja osobno mislim da ćemo uspijeti kroz realno 3 godine sve uspijeti prebaciti obzirom na količinu i lokacije.
p.s. osobno mi je win11 smeće te i dalje koristim win10, ali čini se da ću još bolje morati znati naredbe napamet jer windows 11 je napravljen kao labirint sa opcijama i totalno kontra bilo kakvoj logici.
Zdravoseljački rečeno windows 11 je gay i prekrasan kao i oni koji ga veličaju iznad svega drugog
3 godine da prebacite sve mašine na w11 (koliko ih je)? Ne kužim, ovo idete okolo sa USB stickom i tako radite upgrade/update?
SCCM/Intune ništa (ili neki drugi ne MS alat ako postoji...)?
Slobodno me dodajte na PSN
Zadnje izmijenjeno od: Disco. 28.03.2025. u 09:22.
Staro 28.03.2025., 09:27   #1839
tomek@vz
tomek@vz's Avatar
Postovi: 4,932
Autor the.elles.d Pregled postova
Utisci naspram NTFS?
Staro 28.03.2025., 11:01   #1840
mkey
Datum registracije: Sep 2018
Lokacija: tu
Postovi: 3,499
Autor domy_os Pregled postova
Jedna glupa sugestija, da nije možda ušlo nešto dlake ili drugog smeća u mišev laserski otvor? Hoće ponekad poskakivati pa možda to prevenira sleep u raznim oblicima.
Autor George Carlin
But there’s a reason. There’s a reason. There’s a reason for this, there’s a reason education sucks, and it’s the same reason that it will never, ever, ever be fixed. It’s never gonna get any better. Don’t look for it. Be happy with what you got. Because the owners of this country don't want that. I'm talking about the real owners now, the real owners, the big wealthy business interests that control things and make all the important decisions. Forget the politicians. The politicians are put there to give you the idea that you have freedom of choice. You don't. You have no choice. You have owners. They own you. They own everything. They own all the important land. They own and control the corporations. They’ve long since bought and paid for the senate, the congress, the state houses, the city halls, they got the judges in their back pockets and they own all the big media companies so they control just about all of the news and information you get to hear. They got you by the balls. They spend billions of dollars every year lobbying, lobbying, to get what they want. Well, we know what they want. They want more for themselves and less for everybody else, but I'll tell you what they don’t want: They don’t want a population of citizens capable of critical thinking. They don’t want well informed, well educated people capable of critical thinking. They’re not interested in that. That doesn’t help them. Thats against their interests. Thats right. They don’t want people who are smart enough to sit around a kitchen table to figure out how badly they’re getting f*cked by a system that threw them overboard 30 f*cking years ago. They don’t want that. You know what they want? They want obedient workers. Obedient workers. People who are just smart enough to run the machines and do the paperwork, and just dumb enough to passively accept all these increasingly shittier jobs with the lower pay, the longer hours, the reduced benefits, the end of overtime and the vanishing pension that disappears the minute you go to collect it, and now they’re coming for your Social Security money. They want your retirement money. They want it back so they can give it to their criminal friends on Wall Street, and you know something? They’ll get it. They’ll get it all from you, sooner or later, 'cause they own this f*cking place. It's a big club, and you ain’t in it. You and I are not in the big club. And by the way, it's the same big club they use to beat you over the head with all day long when they tell you what to believe. All day long beating you over the head in their media telling you what to believe, what to think and what to buy. The table is tilted folks. The game is rigged, and nobody seems to notice, nobody seems to care. Good honest hard-working people -- white collar, blue collar, it doesn’t matter what color shirt you have on -- good honest hard-working people continue -- these are people of modest means -- continue to elect these rich c*cksuckers who don’t give a f*ck about them. They don’t give a f*ck about you. They don’t give a f*ck about you. They don't care about you at all -- at all -- at all. And nobody seems to notice, nobody seems to care. That's what the owners count on; the fact that Americans will probably remain willfully ignorant of the big red, white and blue dick that's being jammed up their assholes everyday. Because the owners of this country know the truth: it's called the American Dream, because you have to be asleep to believe it.
Staro 28.03.2025., 11:02   #1841
the.elles.d
Postovi: 548
@tomek@vz
Osobno ne vidim ikakve razlike. Na tom disku nemam jako velike projekte pa možda radi toga ne vidim razlike. Ovisi kakav mu posao daješ.
https://blog.maartenballiauw.be/post...or-dotnet.html
Da se mogu konvertirati postojeće particije, ja bi ih konvertirao - ali ja volim nove stvari pa možda nisam mjerilo
Na serveru kažu da ima puno osjetnijih razlika.
https://www.tomshardware.com/softwar...refs-exclusive
Staro 28.03.2025., 12:06   #1842
Deamon101
Deamon101's Avatar
Postovi: 694
Samo opušteno ljudi. Windows 11 će omogućiti kad tad za sve printanje, sleep opciju kao i remote desktop te ostale stvari bez bugova kao i što će se kroz godinu dvije popeglati svi updateovi da ne rade probleme. Svejedno hvala vam što sudjelujete kao podrška razvojnom timu.
Zadnje izmijenjeno od: Deamon101. 28.03.2025. u 13:08.
Deamon101 je offline   Reply With Quote
Staro 28.03.2025., 13:16   #1843
atjeroid
dežurno smetalo
atjeroid's Avatar
Lokacija: Krapinske Toplice
Postovi: 307
Onda će izdati Win12 (beta fkorz') djabe za sve i ajmo opet
atjeroid je offline   Reply With Quote
Staro 28.03.2025., 13:40   #1844
d0X
Kostolomac
d0X's Avatar
Postovi: 1,517
Prekrasan jesam, gay nisam
Ali drago mi je da je ekipa barem prešla sa kriploidnog hvaljenja XP-a verzus svega ostalog, 10-tka je zapravo dobar OS.
PSN Steam
Staro 28.03.2025., 15:03   #1845
mkey
Lokacija: tu
Postovi: 3,499
Znaš kako je OS dobar kada se XP mora prizivati
Autor George Carlin
Staro 28.03.2025., 15:12   #1846
d0X
Kostolomac
d0X's Avatar
Postovi: 1,517
Mora se zapapriti malo :P
PSN Steam
Staro 28.03.2025., 16:03   #1847
domy_os
domy_os's Avatar
Postovi: 18,866
Autor mkey Pregled postova
Miš i tipkovnicu sam fizički bio ištekao i nije pomoglo. Uopće nema pravila, uptime je sad oko dva tjedna, prvi dan pokrenem sve aplikacije koje koristim i stalno su aktivne. Do prije mjesec-dva nije radilo probleme, sad nekad zalocka account i isključi monitor, nekad ne.
Staro 28.03.2025., 19:23   #1848
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,593
Wake timers provjerio?
Također probaj izšpijati ko ga budi.
Staro 28.03.2025., 20:14   #1849
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,066
https://blogs.windows.com/windows-in...6-dev-channel/
Ima tu lepih novosti i nadogradnji, ali nikog ne zanimaju poboljšanja pa bacam kost ovde:
We’re removing the bypassnro.cmd script from the build to enhance security and user experience of Windows 11. This change ensures that all users exit setup with internet connectivity and a Microsoft Account.
A evo i novog rešenja:
Currently, it's also possible to manually re-add the bypassnro command to your system by typing the following into a command prompt:
Code:
"reg add HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\OOBE /v BypassNRO /t REG_DWORD /d 1 /f shutdown /r /t 0"
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Staro 29.03.2025., 04:17   #1850
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,593
Staro 29.03.2025., 06:55   #1851
BinaryJesus
Datum registracije: Feb 2021
Lokacija: Sveti Petar
Postovi: 289
BypassNRO.cmd
Code:
@echo off
shutdown /r /t 0
Kreirate u notepadu i kopirate na USB stick s instalacijom.
Bit će problem kada promijene windows setup da ignorira taj registry key.
Onda će trebati kreirati modificirani windows setup sa starom verzijom OOBE. Ili neki drugi workaround kao Autounattend.
BinaryJesus je offline   Reply With Quote
Staro 29.03.2025., 07:02   #1852
tomek@vz
tomek@vz's Avatar
Postovi: 4,932
E to je onaj dio koji nervira...
Staro 29.03.2025., 09:42   #1853
spiderhr
spiderhr's Avatar
Datum registracije: Jul 2021
Lokacija: Sesvete
Postovi: 1,077
Staro 29.03.2025., 10:44   #1854
Deamon101
Deamon101's Avatar
Postovi: 694
Radije bih popio lošu rakiju, ako postoji, nego kreirao Microsoft account.
Inače "deployment instalacija" ne pita za nikakav račun. Firme će vjerujem na taj način to sve riješiti i nema šanse da taj račun bude apsolutni uvjet za instalaciju jer realno predstavlja sigurnosni rizik, npr. u državnim firmama primarno.
Zadnje izmijenjeno od: Deamon101. 29.03.2025. u 17:42.
Staro 29.03.2025., 13:54   #1855
mkey
Lokacija: tu
Postovi: 3,499
Nažalost, loša rakija postoji.
Autor George Carlin
Staro 29.03.2025., 21:21   #1856
dadoremix
dadoremix's Avatar
Postovi: 4,717
i kakva je loša rakija .
dobra brate .. dobraaa
Staro 30.03.2025., 13:59   #1857
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,593
Staro 30.03.2025., 15:32   #1858
mkey
Lokacija: tu
Postovi: 3,499
"Internet is outraged"
How, yes, no.
Autor George Carlin
Staro 01.04.2025., 06:32   #1859
tomek@vz
tomek@vz's Avatar
Postovi: 4,932
What just happened? Despite still being one of the most popular login methods, developers are gradually replacing passwords with newer, more robust authentication technologies. The "next generation" of online security is coming slowly but steadily, and Microsoft has now decided there is room for a significant redesign of the entire login experience.
Microsoft recently announced that it is rolling out a new authentication experience for over one billion consumers. The redesign focuses on more secure login screens with a modern look. While there is a big focus on the GUI, many users will find the new authentication methods relatively standard.
Za one koji nisu upoznati sa konceptom fino objasnjenje ovdje.
Staro 01.04.2025., 14:54   #1860
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,593
Motherfucker, instaliram LTSC samo da mi ne radi ovakva sranja i danas mi ga nabije u guzicu.
