Staro 11.03.2025., 08:29   #3481
d0X
Kostolomac
d0X's Avatar
Postovi: 1,510
@mkey, nemoj shvatiti ovo kao soljenje pameti, ali kao stari "heker" mobaća (trenutno na LOS22.1), razumijem firme koje implementiraju te provjere u svoje appove kako bi se pravno zaštitile. Da bi rootao moraš otključati bootloader. Čim si ga otključao olakšao si dušmanu da ti infiltrira mob u situacijama npr. koje je 1v@n naveo. Sa dodanim rootom samo je još nesigurnije. Rendom kvot:
An unlocked bootloader allows anyone who has temporary access to the phone to tamper with the boot process and in consequence with the system partition. This enables a slightly sophisticated attacker to implant a backdoor or extract the decryption key/your passphrase while you unlock the phone the next time.
Of course there are layers of trust and not everyone may want to root their trust into the security of an opaque locked boot process. However, I can hardly think of any thread model in which an unlocked bootloader does not compromise the phone’s security in one way or another.
PSN Steam
d0X je online   Reply With Quote
Staro 11.03.2025., 08:33   #3482
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,066
Da ti je stalo do sigurnosti bil bi na iPhone-u :P
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Mario92 je online   Reply With Quote
Staro 11.03.2025., 08:51   #3483
Taproot7
mag.math.
Taproot7's Avatar
Datum registracije: Dec 2021
Lokacija: Daruvar/Zagreb, Republika Hrvatska
Postovi: 362
dok fala bogu, Zaba me svaki dan zove i pita jesam li dobro, jel mi triba štagod.
"Neno ljubavi, treba li ti što?"
Taproot7 je offline   Reply With Quote
Staro 11.03.2025., 09:59   #3484
spawn
spawn's Avatar
Postovi: 8,422
Revolut
Autor 1v@n Pregled postova
- Situacija #1
Pokvari ti se telefon / pukne mu ekran / krepa mu baterija
Nosiš ga na servis. Na servisu ti zločesti serviser roota mobitel i pukne u njega screen grabber / keylogger / nešto deseto
- Situacija #2
Na putu si i baterija ti je prazna. Jedini izvor struje je javni punjač na random javnom mjestu.
Spojio si svoj rootani mobitel na kompromitirani punjač
- Situacija #3
Ukrali su ti mobitel / izgubio si ga
Da se nabrojati još sličnih situacija gdje svatko tko barata tvojim osjetljivim podacima kao što je bankovni račun, jednostavno ne želi doći u situaciju da zbog korisnikove neodgovornosti i nemara ima potencijalnu pravnu trakavicu.
Bio sam za vikend na sajmu fotografije. Jedan od izlagača je bio Cewe. Renomirana firma, sve čisto. Jedan od proizvoda im je kiosk za printanje fotki (mislim da ih u HR Muller ili Dm koristi).
Na sebi imaju USB portove, čitače kartica i ono zanimljivo....USB-C i Lightning kabele.
U 15 minuta koliko sam se zadržao na štandu, vidio sam barem 20 ljudi koji su bez imalo razmišljanja kabelom spojili svoje mobitele i dali kompletan pristup svojim fotkama, samo da bi iskoristili ponudu od 5 printova besplatno...
Nažalot džaba pričaš. Uvijek su pametniji oni koji ustvari apsolutno nemaju pojma o onome što pričaju. Krađa osobnih podataka je u današnje vrijeme najunosniji posao kod određenih ljudi kojima je to interesu, i nalaze se svakakvi načini da se to ostvari. Jedan običan public wifi zna često biti uzrok krađe podataka a kamoli otključan bootloader ili root access. Ali ljudi ne žele biti educirani jer ih to dira u beskrajno visok ego. Odustaneš i riješio si se gubljenja vremena
Staro 11.03.2025., 13:13   #3485
atjeroid
dežurno smetalo
atjeroid's Avatar
Lokacija: Krapinske Toplice
Postovi: 307
- Situacija #3
Vidio hrpu ljudi kak ovo koristi u DMu, sve za jeftiniju cijenu, a papir im tanak ko moj novčanik
Uglavnom, sve situacije stoje. Sve mobove imam custom ROM, osim onoga na kojem imam banke. Kad kupujem mob, gledam da ima što čišći sustav, maknen prek ADB-a ostalo smeće i mir. Imao show jednom sa PBZom, al ok sitnica iznos.
A tast sa jednom drugom bankom, tak da ne riskiram to vise nikad.
atjeroid je offline   Reply With Quote
Staro 11.03.2025., 18:24   #3486
mkey
Datum registracije: Sep 2018
Lokacija: tu
Postovi: 3,469
- Situacija #1
Hvala na racionalnom pristupu raspravi. Doduše, mislim da ti fale određene informacije.
Root na androidu je sličan rootu na linuxu, pošto su to dva dosta slična operativna sustava. Bitna razlika je to što bi na PC bilo nezamislivo da vlasnik računala nema root access. Na mobilnim telefonima je to industrijski standard.
Situacija #1
Onaj tko bi znao rootati tuđi telefon u neke zle svrhe bi znao to i prikriiti, tako da aplikacije koje pokušavaju detektirati root neće u tome uspjeti. Npr. Apatch + Zygisk modul + PlayIntegrity modul, par restarta, i aplikacije neće znati prepoznati da je uređaj "rootan". Cijeli proces traje 15 minuta, uz određeni rizik, naravno.
Root kontrola će otkriti root samo na unim uređajima koje je rootala neka treća strana koja nije znala instalirati predmetne module. Neka situacija #1 pokriva 0.1% korisnika (mislim da je to jako, jako konzervativna procjena) dok je stvarni zahvaćeni broj korisnika, onih koji imaju rootan uređaj a bez navedenih modula, još i manji od toga.
Kao što je podskup skupa tih korisnika, tj. onih koji imaju instaliranu neku aplikaciju koja provjerava root i koji bi time mogli biti upozoreni da se nešto događa, još i manji. Neka svako za sebe procijeni koji je to udio korisnika, ja ću procijeniti da je to debelo ispod 0.01%.
Ako je moj use case sa 1 ili 0.1% nebitan, ovi su onda 10 ili 100x manje bitni.
Situacija #2
Što očekuješ da će se dogoditi time što je uređaj rootan? Rootani telefoni koriste aplikacije koje obavješatavaju korisnika kako je neka aplikacija zatražila root. U biti to je privileges elevation prompt, slično kako iskače na windowsima, uz "tap jack" protection koji je, koliko ja vidim, u tim situacijama standardan.
Situacija #3
I? Koja je razlika izmrđu izgubljenog/ukradenog mobitela koji je rootan i onoga koji nije nije rootan?
Ako ovime želiš kazati kako nije razborito ne zaključavati mobitel, mogu i ne moram se složiti s time. Ja se nadam kako ćeš se ti svakako složiti kako je to pitanje svačijeg osobnog izbora i kako svatko ima pravo za sebe odlučiti i naći optimalan omjer komfora i sigurnosti.
Kako sam i naveo, rizik gubitka/krađe telefona sam umanjio na način da sam bankovne i kvazi bankovne aplikacije stavio na mobitel koji držim u ladici. Vjerujem da je to sigurnosni korak na kojeg velika većina ovdje niti ne pomišlja. Ali eto, razni glupani (ne ti) tri stranice pljuju po nekome tko se usudio napraviti nešto što oni sami nebi, i nešto što oni sami mahom ne razumiju.
Što se tiče zaštite pinom navesti ću i ovo: pred nekoliko godina smo našli jedan telefon na dječjem nogometnom turiniru. Moja prva ideja je bila potražiti "mama" ili "tata" u imeniku i obavijestiti ih gdje mogu preuzeti izgubljen telefon. Naravno da nisam to mogao uraditi pošto je telefon bio zaključan. Na kraju se neki od klinaca bili dovoljno pametni da dođu pitati pa smo tako našli vlasnika.
Ja ne znam jesi li upoznat s pojmom "EULA"? Smatram kako je ovo od svih iznesenih argumenata debelo najlošiji. Kada tome ne bi bilo tako, onda uz svaki uređaj ne bi dolazila hrpa imbecilnih upozorenja (u vezi neispravnog korištenja istog) kojima se proizvođač ograđuje (ključna riječ, ograđuje) od odgovornosti za to što radi netko tko nema pojma što radi i nije u stanju primijeniti niti malo zdravog razuma na svoje postupke.
Vjerujem kako je to standardna pojava. Ljudi vjeruju svačemu, pa tako i desetak aplikacija koje dolaze predinstalirane na telefonima koje su oni pošteno platili a bez da imaju tehničku mogućnost uklanjanja istih sa telefona koji predstavljaju njihovu osobnu imovinu.
Ja razumijem da je sigurnosni argument jako privlačan mnogima, ali kako sam naveo kada se rade bazične provjere, priči o sigurnosti nema mjesta. To je zadovoljavanje nekakvih uvjeta koji su čista pro forma. To je ništa nego politika.
Što se tiče stvarne sigurnosti, ponavljam svoj slučaj. Koristim stari telefon kojem proizvođač nudi najviše android 13 i to u paketu sa hrpom aplikacija kojima je ne vjerujem, koje mi ne trebaju i koje za moj pojam predstavljaju sigurnosni rizik. Instaliram na uređaj čisti android 18 i smatram da sam onda nekako ipak sigurniji. Izlazi revolut update i kaže kako custom rom (bez ikakvog upozorenja prije updejta) nije podržan. U tom trenutku jedina realna opcija mi je rootati uređaj, primijeniti zaštitu od detekcije roota i napraviti fix za te propertije koje revolut kontrolira.
spawn, kolega poštovani, pojma nemaš što pričaš.
Ovo što reče dox, vezano za bootloader, mislim da taj argument barem djelomično stoji, ali to je po meni utlimativno vrlo slično situaciji u kojoj je BIOS na laptopu/desktopu zaključan. Moguće da podcjenjujem situaciju kao i to da sam slijep na neke moguće vezane opasnosti.
S praktičnog stanovišta, lockani bootloader znači kako se ne bude moglo pristupiti recovery/fastbootu i krenuti u instalaciju drugog roma, koji će zamijeniti postojeći. Da bi isto bilo izvedivo, potrebno je uz otključani bootloader još dodatno:
- uključiti developer settings (većina korisnika pojma nema kako to napraviti)
- uključiti USB debugging (ditto)
- spojiti mob na neko računalo (može biti i neki automat kako je navedeno)
- potvrditi prompt na mobitelu kako je OK da predmetno računalo pristupi predmetnom mobitelu. Neki mobiteli nemaju niti prompt, nego moraš tražiti meni kako biš ondje dopustio spajanje.
Sve u svemu i prema mojoj procjeni, ovo je jedan iznimno malo vjerojatan događaj. Prihvaćam da onaj tko se bavi sa sigurnosti na androidu na veliku ima skroz oprečno mišljenje.
Ja stojim pri svom mišljenju da ja preuzimam rizik postupanja s uređajem dok se ponuđač usluge može lako ograditi od posljedica postupanja s aplakacijom koje nisu u skladu s njihovim preporukama. Case closed.
Autor George Carlin
But there’s a reason. There’s a reason. There’s a reason for this, there’s a reason education sucks, and it’s the same reason that it will never, ever, ever be fixed. It’s never gonna get any better. Don’t look for it. Be happy with what you got. Because the owners of this country don't want that. I'm talking about the real owners now, the real owners, the big wealthy business interests that control things and make all the important decisions. Forget the politicians. The politicians are put there to give you the idea that you have freedom of choice. You don't. You have no choice. You have owners. They own you. They own everything. They own all the important land. They own and control the corporations. They’ve long since bought and paid for the senate, the congress, the state houses, the city halls, they got the judges in their back pockets and they own all the big media companies so they control just about all of the news and information you get to hear. They got you by the balls. They spend billions of dollars every year lobbying, lobbying, to get what they want. Well, we know what they want. They want more for themselves and less for everybody else, but I'll tell you what they don’t want: They don’t want a population of citizens capable of critical thinking. They don’t want well informed, well educated people capable of critical thinking. They’re not interested in that. That doesn’t help them. Thats against their interests. Thats right. They don’t want people who are smart enough to sit around a kitchen table to figure out how badly they’re getting f*cked by a system that threw them overboard 30 f*cking years ago. They don’t want that. You know what they want? They want obedient workers. Obedient workers. People who are just smart enough to run the machines and do the paperwork, and just dumb enough to passively accept all these increasingly shittier jobs with the lower pay, the longer hours, the reduced benefits, the end of overtime and the vanishing pension that disappears the minute you go to collect it, and now they’re coming for your Social Security money. They want your retirement money. They want it back so they can give it to their criminal friends on Wall Street, and you know something? They’ll get it. They’ll get it all from you, sooner or later, 'cause they own this f*cking place. It's a big club, and you ain’t in it. You and I are not in the big club. And by the way, it's the same big club they use to beat you over the head with all day long when they tell you what to believe. All day long beating you over the head in their media telling you what to believe, what to think and what to buy. The table is tilted folks. The game is rigged, and nobody seems to notice, nobody seems to care. Good honest hard-working people -- white collar, blue collar, it doesn’t matter what color shirt you have on -- good honest hard-working people continue -- these are people of modest means -- continue to elect these rich c*cksuckers who don’t give a f*ck about them. They don’t give a f*ck about you. They don’t give a f*ck about you. They don't care about you at all -- at all -- at all. And nobody seems to notice, nobody seems to care. That's what the owners count on; the fact that Americans will probably remain willfully ignorant of the big red, white and blue dick that's being jammed up their assholes everyday. Because the owners of this country know the truth: it's called the American Dream, because you have to be asleep to believe it.
Staro 11.03.2025., 20:10   #3487
Postovi: 10,089
...del...
Zadnje izmijenjeno od: xlr. 11.03.2025. u 23:57.
Staro 11.03.2025., 21:27   #3488
medo
#erase startup-config
medo's Avatar
Postovi: 3,714
Autor mkey Pregled postova
Mislim da i tebi nedostaju neke informacije:
  1. Cyberkriminal je prošle godine postao treća svjetska ekonomija. Da, treća svjetska ekonomija, odmah iza Amerike i Kine! Možeš li si zamisliti koliko se tu love vrti? Ja ne mogu.
  2. Google ima ~10 milijardi security evenata dnevno! Samo jedna velika tvrtka i samo jedan primjer.
Neće tebi haker ukrasti tvoje novce i tvoj account. Nema on vremena za tebe. Uzeti će ti neka njegova skripta raširena na nekoliko (desetaka) tisuća botova po cijelom svijetu koji između ostaloga traže takve poput tebe skenirajući cijeli internet 24/7 za rupe koje im tako rado ostavljaš misleći da si siguran ili nebitan za njih.
Ako si dovoljno nebitan možda će pretvoriti tvoj mobitel ili mobitel od tvojih staraca u jednog takvog bota. Ni prvi ni zadnji. Fala Bogu pa imamo dovoljno jak hardware na tim trikorderima da se to i ne primjeti.
Kada malo počneš pratiti tu scenu vidiš da kuknjave zbog svega toga ima jaako puno
Staro 11.03.2025., 21:43   #3489
mkey
Lokacija: tu
Postovi: 3,469
Jeste, bootloader je prva od više zakračunatih kapija Slažem se da je inherentno otključani bootloader manje siguran od zaključanog bootloadera. Kao što je uključen telefon manje siguran od isključenog telefona.
Autor George Carlin
Staro 11.03.2025., 21:45   #3490
the chosen one
the chosen one's Avatar
Postovi: 753
Daj se držite teme Revolut, root ostavite za neko drugo mjesto na forumu jer ste fkt previše zaspamali temu
Poslano sa mog SM-S928B koristeći Tapatalk
Staro 12.03.2025., 08:19   #3491
atjeroid
dežurno smetalo
atjeroid's Avatar
Postovi: 307
Kad smo kod teme.
Imam paysafecard (bon), te bih htio te novce prebaciti na revolut. Gledao sam malo po webu, ali ništa pametno nisam našao, pa ako netko zna...
Ili treba taj bon...
Staro 13.03.2025., 15:00   #3492
OnionKnight
OnionKnight's Avatar
Datum registracije: Nov 2023
Lokacija: Catarina
Postovi: 69
Mozda je vec objasnjeno, no nisam nasao pa pitam
Dali je moguce s Revoluta slati novac na neciji IBAN. Kako? Vec me pomalo zivcira prebacivanje na tekuci ili sl. da bi platio nesto random
OnionKnight je offline   Reply With Quote
Staro 13.03.2025., 15:07   #3493
Libertus
Libertus's Avatar
Datum registracije: Jul 2017
Lokacija: Ramura
Postovi: 2,785
Da.
Plaćanja / + / Bankovni račun primatelja
Staro 13.03.2025., 15:39   #3494
OnionKnight
Lokacija: Catarina
Postovi: 69
Iskreno ne znam kako to nisam uocio, thanx!
Staro 13.03.2025., 16:50   #3495
ALiEN17
ALiEN17's Avatar
Lokacija: Histria
Postovi: 1,242
kako da kada plaćam revolutom račune maknem e-mail adresu od osobe kojoj bi trebale stizati potvrde o plaćanju?
ševa!
Staro 13.03.2025., 16:51   #3496
mkey
Lokacija: tu
Postovi: 3,469
Moguće je uplatiti i na svoj revolut IBAN. Meni je to pomoglo kada sam jedno vrijeme ostao bez bankovne kartice zahvaljujući odličnim poštanskim uslugama.
Autor George Carlin
Staro 13.03.2025., 16:53   #3497
robert7
robert7's Avatar
Postovi: 1,711
Autor ALiEN17 Pregled postova
Odeš na account koji želiš maknuti ( preko searcha najbolje ), gore desno klik na logo, pa EDIT IBAN i tamo ćeš moći sve podatke editirati.
http://eu.prepsafe.com
robert7 je offline   Reply With Quote
Staro 13.03.2025., 19:58   #3498
ALiEN17
ALiEN17's Avatar
Lokacija: Histria
Postovi: 1,242
Thanks mate, uspio sam. Chat gpt nije imao pojma oko ove banalnosti.
ševa!
Staro 13.03.2025., 23:17   #3499
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,766
iskreno, chatGPT k*rca ne zna.
šta sam ga više koristija, to sam skužija da zaista jako malo zna, a da i to šta zna, često ne zna ili treba provjeriti.
Staro 14.03.2025., 17:39   #3500
strikoo
strikoo's Avatar
Postovi: 964
Potpis ko kuća
strikoo je offline   Reply With Quote
Staro 20.03.2025., 13:16   #3501
p3r02d3r0
p3r02d3r0's Avatar
Postovi: 510
Ima li revolut usluge poput plaćanja parkinga, e-vinjeta itd? Tražio sam, ali ne vidim ih.
Nervira me kaj za takve stvari moram koristit aircash koji ima sve moguće dodatne usluge, a za online plaćanja uglavnom koristim revolut.
p3r02d3r0 je offline   Reply With Quote
Staro 20.03.2025., 14:09   #3502
Juice
Fresh Juice
Juice's Avatar
Postovi: 4,559
Nema, Revolut nije lokalni "igrač" pa nema ni tih usluga.
Staro 20.03.2025., 14:30   #3503
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,096
Nema tog ni na domaćem im tržištu. Svi ti servisi imaju svoje appove u koje se doda bilo koja kartica i vozi
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
OS: Windows 10 Pro x64
Staro 20.03.2025., 18:21   #3504
Juice
Fresh Juice
Juice's Avatar
Postovi: 4,559
Pa aircash ima tu mogućnost (plaćanje parkinga, kupnja vinjete).
Keks pay ima plaćanje parkinga, nema kupnju vinjete.
Naravno, oni nemaju mogućnosti koje ima Revolut, ali vrijedi i obrnuto.
Staro 20.03.2025., 18:33   #3505
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,096
Ne možeš očekivati da će u svijetu gdje svatko ima svoj app i svoj sustav plaćanja i želi to imati pod svojom kontrolom, dati bankama pristup samo tako. Ili da to banke uopće žele.
Konkretno, za plaćanje parkinga samo u Londonu imam 6 različitih aplikacija, jer različite firme drže naplatu u različitim dijelovima grada + različite firme koje održavaju naplatu privatnih parkinga.
Di bi došli da to sve potrpaju u bankarsku aplikaciju i još globalno.
U Zagrebu imaš Zagrebparking i svega 4 zone.
LCD: BENQ PD3200Q
Staro 20.03.2025., 18:55   #3506
nepalac
Datum registracije: Feb 2022
Lokacija: EU
Postovi: 830
Pa ne daješ nikakav pristup nego proširuješ plaćanje svoje usluge i nudiš ga preko trećih aplikacija.
U aircashu možeš kupiti hrpu toga, od raznih karata za sve i svašta, bonova, osiguranja do playstation članstva...
https://aircash.eu/marketplace/
Staro 22.03.2025., 09:42   #3507
...Tihomir...
...Tihomir...'s Avatar
Postovi: 343
Autor p3r02d3r0 Pregled postova
za parking ima odličan bmove app na koji povežeš revolut karticu. Čak imaju za automatsko plaćanje nekih podzemnih garaža ali nisam isprobavao. Pokrivaju dosta gradova u RH. Dodatan (meni) plus, za svako plaćanje na email dobiješ račun pa kada se ide poslovno, lagano trošak parkinga pravdaš računom.
...Tihomir... je online   Reply With Quote
Staro 24.03.2025., 10:44   #3508
rocka11
Datum registracije: Mar 2020
Lokacija: Dubrovnik
Postovi: 28
Autor atjeroid Pregled postova
Kad smo kod teme.
Vrlo jednostavno
Najjača kombinacija
Skrill - naručiš karticu (i nemoraš, možeš virtualnu - ali 10 eura je fizička) i nju dodaš na revolut i ide.
Skrill, neteller - revolut i bunqu
Najjača kombinacija
p.s. neznam jesi došao do odgovora
Živio
rocka11 je offline   Reply With Quote
Staro 18.04.2025., 10:28   #3509
kasper_sky
Drive. vruummm,shatatataa
kasper_sky's Avatar
Lokacija: 1.Rijeka-2.VG-3.Zg
Postovi: 778
S obzirom da mi je bio rođendan nedavno. Revolut je ponudio opciju free slanje fizičke kartice te 1mj free primium acc. Naravno da sam potvrdio i dobio karticu za 3-4 dana na osobnu adresu uručeno u ruke u crnoj kuverti. super...
Pitanje. Nakon što istekne tj. prije nego što istekne free 1mj dali će on automatski produžiti i uzet mj. članarinu s moga acc .koji ima nešto novaca ili moram potvrditi. U slučaju da ne želim premium acc. dalje dali mogu dan prije onemogućiti, ali i dalje korstiti tu karticu koja će naravno imati manje limit standard opcije?
hvala
kasper_sky je offline   Reply With Quote
Staro 18.04.2025., 10:34   #3510
Juice
Fresh Juice
Juice's Avatar
Postovi: 4,559
Meni trenutno stoji promo za dva mjeseca free premiuma i piše ovako: "You can cancel at any point before the end of the free trial, but youll be charged for any ordered card and delivery".
