Staro 12.12.2024., 21:02   #3841
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,401
With its latest reales qemu added the Venus patches so that virtio-gpu now support venus encapsulation for vulkan. This is one more piece to the puzzle towards full Vulkan support.
An outdated blog post on clollabora described in 2021 how to enable 3D acceleration of Vulkan applications in QEMU through the Venus experimental Vulkan driver for VirtIO-GPU with a local development environment. Following up on the outdated write up, this is how its done today.
↫ Pepper Gray
Nice
Staro 12.12.2024., 21:04   #3842
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,401
When we announced the security flaw CVE-2024-11053 on December 11, 2024 together with the release of curl 8.11.1 we fixed a security bug that was introduced in a curl release 9039 days ago. That is close to twenty-five years.
The previous record holder was CVE-2022-35252 at 8729 days.
↫ Daniel Stenberg
Not so nice
P.S. - yep 22 godine
Staro 14.12.2024., 01:09   #3843
domy_os
domy_os's Avatar
Postovi: 18,959
Imam dva glupa problema s Proxmoxom 8.3.1...
Kako uključiti firewall na VM-ovima? Na sva četiri moguće mjesta je uključen (datacenter, host, VM options, VM NIC), restartao sam nebrojeno puta i neće pa neće, sve pušta prema VM-ovima.
Drugo još gluplje pitanje, root password ne mogu promijeniti. Puknem sudo passwd root, novi password dva puta i ništa, nakon log off/on se vrati stari password. Zanimljivo je da vipw vidi promjene, salt i hash su drugi, samo badava.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 14.12.2024., 07:16   #3844
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,401
Autor domy_os Pregled postova
Proxmox ponekad moras tretirat kao ono sto je - lijep GUI nad Debianom. Dakle ako GUI ne sljaka ili ima Bugove > Debian way.
1. Konfiguriraj jednostavno firewall na OS-u koji vrtis u virtualci.
https://forum.proxmox.com/threads/us...bridge.158568/
Alternativno mozes i VLAN-ove konfigurirat pa kroz firewall pravila na Debianu odredit sto sa cime moze komunicirat. Sigurno ima pametnije i elegantnije rijesenje ali tolko se nisam sa Proxmoxom igrao da bi mi to trebalo.
2. https://forum.proxmox.com/threads/bu...center.158518/
>> sudo su ; passwd # Promjeni lozinku > reboot i mora ostat. Ako se mijenja tu nekaj ne stima.
P.S. Single Node ili Cluster?
Staro 14.12.2024., 12:05   #3845
medo
#erase startup-config
medo's Avatar
Postovi: 3,733
Linux OS - info, how-to, pitanja, novosti, savjeti, problemi...
Pogledaj /etc/shadow da li se išta mijenja u njemu kada apdejtaš root pass.
Možda ima neki watchdog (npr. Monit) koji pazi na “neautorizirane” izmjene tog filea.
Osobno dosta često to koristim jer mi se događalo npr. da bi neki nadobudni biser (mladi developer) promijenio prava na fileovima u .ssh direktoriju pa bi puknuo pubkey auth i štošta.
Staro 14.12.2024., 18:20   #3846
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,296
Ne vidim sta ce mu sudo kad je vec root. Samo utipkaj passwd i rokaj, sta ne?
Staro 14.12.2024., 19:10   #3847
domy_os
domy_os's Avatar
Postovi: 18,959
E u tom zecu leži grm...
Login u root pa passwd ne radi, /etc/shadow se promijeni, ali nakon novog log-ona i dalje prihvaća stari password. Ono što radi je iz običnog usera sudo passwd root, debilno skroz.
Kad je Proxmox u pitanju, više sam za GUI, čisto zato što jedan klik u GUI-u u pozadini radi puno više naredbi. Tako sam više puta htio nešto kroz shell i nije išlo dok kroz GUI ide.
Lako reći namjesti firewall u VM-u, ali neću iz principa, imam različite OS-ove i ako postoji opcija unutar Proxmoxa, ima da radi. Otvorit ću topic na njihovom forumu, nema druge.
Staro 14.12.2024., 21:44   #3848
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,401
Pa kao koji korisnik si ulogiran kad izvodis tu komandu? Kao sto sam napisao > ako si obican korisnik logiraj se kao root sa sudo su i onda odapni passwd i promjeni lozinku ili se logiraj na proxmox direktno kao root i promjeni lozinku. Nebih se cudi da je sigurnosni feature da nadobudni mladi devovi ne mijenjaju root lozinku kak im se sprdne.
Sto se tice Proxmox foruma ako nisi korisnik koji placa - razocarat ces se. Proxmox nije GUI ispoliran na razini ESXi/Vsphere rijesenja i cesto sam naletio na nesto sto ne radi kroz GUI kak spada. Kod Proxmoxa se ocekuje da zaprljas ruke, jednostavno za ista napredno moras razumijevati sustav ispod haube kao Linux admin.
Staro 14.12.2024., 22:07   #3849
domy_os
domy_os's Avatar
Postovi: 18,959
Logiram se kao običan user kojeg koristim za SSH pristup jer sam rootu onemogućio login preko SSH. Kad sam se logirao kao root sa "su - root" ili "sudo -i", nisam uspio promijeniti password, ali jesam kao običan korisnik sa "sudo passwd root".
Misterij sa firewallom riješen, ZeroTier promet zaobilazi Proxmox firewall, zato me stalno puštalo unutra. Kad malo bolje razmislim, ima logike.
Staro 15.12.2024., 18:43   #3850
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,401
Catching my attention with this morning's KVM changes for Linux 6.13-rc3 is this lone KVM x86-related change:
"Cache CPUID.0xD XSTATE offsets+sizes during module init - On Intel's Emerald Rapids CPUID costs hundreds of cycles and there are a lot of leaves under 0xD. Getting rid of the CPUIDs during nested VM-Enter and VM-Exit is planned for the next release, for now just cache them: even on Skylake that is 40% faster."
Okay, this is intriguing... Resorting to XSTATE caching to deal with newer Intel Xeon Emerald Rapids CPUs being much more costly than prior processors.
https://www.phoronix.com/news/Linux-...VM-Cache-CPUID
Staro 18.12.2024., 23:47   #3851
Dottore
Dottore's Avatar
Postovi: 7,710
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 22.12.2024., 15:36   #3852
domy_os
domy_os's Avatar
Postovi: 18,959
Opet pitanje oko Proxmoxa...
Imam VM s defaultnim sistemskim i dodatnim data storageom. Kako isključiti taj dodatni storage iz VM snapshota? Kad maknem backup kvačicu s njega, onda neće biti uključen u full backup, ali u snapshot hoće. Ako se nešto dogodi s OS-om, ne mogu vratiti snapshot jer će obrisati i sve promjene s dodatnog storagea nastale nakon kreiranja snapshota.
Staro 27.12.2024., 21:54   #3853
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,401
Odličan tutorijal instalacije nvidia drivera sa uključenim secureboot-om na Fedori ako nekome zatreba:
https://github.com/roworu/nvidia-fedora-secureboot
Mali hint ako netko ima Acer lap Optimus opcijom kao ja - nakon prvog reboota resetirat UEFI postavke (samo UEFI Secure Boot) , reboot > dodat shimx64.efi kao boot opciju.
P.S. - Ako se Mok Manager ne pali dodat mmx64.efi kao boot opciju > import ključa > reboot.
Staro 30.12.2024., 08:59   #3854
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,401
Staro 11.01.2025., 09:15   #3855
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,410
Kako mi je Bazzite radio ko krepana kokoš na tom starom laptopu koji imam; relativno dugi boot time i onda svaki put tona updatea te trzanje desktopa i slično...
Odlučio baciti oko na malo ogoljeniju verziju gaming linuxa, CachyOS.
Za sada djeluje puno bolje, postoji verzija za handhelde i za desktope.
Nažalost nije toliko user firendly kao npr Mint i nema baš neki svoj store, ali je sve kako ekipa veli bleeding edge i kažu da je odličan za gejmanje.
Isto tako općenito kažu da je gejmanje na linuxu najbolje sa AMD grafom jer da oni (valjda zbog Steam Decka) imaju naj drivere za linux i gotovo su jednake performanse kao u win. nV zna imati negdje problema, pa performanse mogu biti i do 20% slabije, ali u najavi su razne ispravke koje bi to navodno mogle riješiti. Intel je isto u banani, čini mi se da je još i gore od nV.
A cachy mi se čini OK, ima opciju isključivanja BT, ima odmah profile za laptope da štedi bateriju i ne guta previše resursa. Postoji i nekakv store, ali je baš jako ograničen, ali ima mogućnost da instalira sve vezano uz gaming (wine, proton, steam....) automatski i onda updatea sve automatski. Nisam skužio što je točno wayland (da li su to driveri za grafu ili neš drugo?), ali koristi to čudo i to svi preporučuju za gaming.
Baziran je na Archu i nudi hrpu desktopa, a ja sam odabrao PlasmaKDE.
Čini se na prvo masu življi od Bazzite na ovoj mojoj krami.
A zašto sam ja na neki bzvz lap instalirao ''gaming'' distro? A jer mi se može.
Slobodno me dodajte na PSN
Disco je online   Reply With Quote
Staro 11.01.2025., 10:05   #3856
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,401
Ne postoji Linux "gaming" distro. Pukni na bilo koju distru Steam+Proton-GE+protontricks, wine+winetricks i Lutris i za 90% casual gamera (za ostalo je tu Windows) je to dovoljno. To sto neki manji developeri pokusavaju svakav hype progurat samo zato jer su promjenili neku stadardnu postavku koju im je preporucio chatgpt je notorna glupost. Stvar je jednostavna.
Za pregled aktualnih distri alfa i omega je Distrowatch. Ovdje se najlakse raspozna odakle potjecu korijeni odredene distre (Debian/Arch/Fedora/Suse). Sve te hype distre funkcioniraju dobro dok ekipa ne skuzi da je iza svake katkad samo 1 dev koji nema vremena se brinuti o svakom aspektu (optimizacije, sigurnost / azuriranja) cijelog OS-a i da iako taj jedan "gaming" feature mozda donosi odredena poboljsanja , isti se lako da implementirati na glavnu distru iza koje stoji hrpa developera, sto community sto velikih IT igraca i nemaju spomenutih problema. Tako da je uvijek bolje taj mali feature implementirat na distru koja je napravljena kak spada a ne skalupljena onako "od oka".
Najbolji pokusaj Linux gaming OS-a je Steam OS koji uzima Arch kao bazu i dodaje hrpu optimizacija zbog kojih se isplati isti koristiti te uz to ima kompletan Valve iza sebe i predanost ekipe koja se zaista brine da taj OS se odrzava kak spada. No i on jos nije bas ispoliran kak bi trebao biti za normalnog Stefeka koji samo hoce svoje igrice igrat. Ali je miljama bolje i kvalitetnije rijesenje od bilo koje Linux "gaming" distre.
Drugo - ni KDE ni Gnome nisu lagana sucelja i zato nije preporucljivo koristiti iste na starom hardweru. Da, Linux je brzi na starom hardweru ali samo ako se koristi neko laganije sucelje (XFCE/LXQT/LXDE/i3). Ne treba ni zanemariti poblematiku sa optimizacijom nvidia drivera na bilo kojem Gnome-like sucelju + X11 vs Wayland optimizacijama jer to itekako utjece na dojam fluidnosti grafickog sucelja.
Staro 11.01.2025., 11:45   #3857
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,410
Znam ja to da nije ovo specijalizirano, ali pojednostavljuju za nas koji pomalo istražujemo svijet linuxa.
Napisao sam da je ovaj CachyOS baziran na Archu, OK omašio sam sučelje, što je najbolje, vidim da jednim klikom mogu zamijeniti isto što je opet super za neznalice.
Poanta je da nam oni podastru već predkonfiguriranu distru i da je to super.
A ja volim isprobavat, da nemam nvme u desktopu, odavno bi već imao i neki linux gore.
Neda mi se vaditi nvme van da bi mogao samostalno instalirati linux, pa da zapravo umjestu dual boota biram disk sa kojeg želim da mi se boota OS.
Ugl cachy djeluje jako dobro, i vidim da se najviše hvali na Linux Gaming Redditu.
Ima tamo dobrih upisa sa što i kako, i kako se koja distra ponaša na kojoj konfi, koje igre zezaju, koje ne...
Ugl živio Valve i njihov izgleda ogroman doprinus gamingu na linuxu.
Staro 11.01.2025., 13:32   #3858
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,296
S ovog popisa bih izbacio lxqt.
Nije bas toliko lagan koliko se pokusava prezentirat kao takav.
Bar ne kad je tek izasao kao zamjena za lxde. Otad ga dalje nisam koristio.
Za stariji laptop definitivno xfce ili lxde. Uz to dodati synapse i fino ce radit 🙂
Btw, i3 je laganiji od svega, ali i kompliciraniji, bar za pocetnike.
Staro 12.01.2025., 08:07   #3859
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,410
XFCE i Mint ''reklamira'' kao najlakše sučelje, ali meni na tom lapu uredno radi i cinnamon.
A riječ je o i5 6300U (2/4) i 16gb RAM. Radi to sasvim pristojno, samo je taj Bazzite radio užasno iz nekog razloga. Čudi me da jedna distra koji bi po meni trebala biti lagana, to baš i nije. Pretežno je namijenjeno za ove gaming handhelde koji su dosta jači od ovog laptopa, ali svejedno. Vidjet ću kako se ponaša Cachy, a ako sam dobro shvatio, sučelje mogu mijenjati unutar njega, ne treba reinstall OS-a. Ima čak i cinnamon na izbor, a mislio sam da je to Mint ''ekskluziva''.
Staro 12.01.2025., 09:01   #3860
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,401
Autor Disco Pregled postova
Na Linuxu mozes kombinirati apsolutno sve sa svim, u tome i je jedna od glavnih prednosti Linux OS-a. Na bilo kojoj distri mozes koristiti bilo koju kombinaciju kernel+GNU Tools+X11/Wayland+graficko sucelje. Na Linuxu OS pripada tebi i iako je za pocetnike malo previse skoro uvijek bas zbog svih mogucnosti koje nudi, kad znas sto radis Linux OS mozez pripasat sebi na razini o kojoj na drugim OS-evima mozes samo sanjati. Bas iz tog razloga ljudima preporucam koristenje jedne od glavnih distri jer u repozitorijima ima mnogo vise potrebnih nativnih paketa (Debian je tu car). Te manje distre su na tom polju uvijek kaskale i uvijek ogranicavale korisnika na neki nacin, zato ih ne volim. Problem je naravno da bez kvalitetnog komercijalnog app i driver supporta nikad nece moci u potpunosti zamijeniti Windows platformu bez obzira na sranja koja ce MS gurat (i gura). Moj ti je savjet isprobaj distre, vidi sto ti se svidi i probaj shvatiti koje optimizacije omogucuju da radi tak dobro. Jednom kad predes taj pocetnicki prag i sposoban si primjeniti isto na neku od glavnih distri nema vise granica
P.S. kljucni element su ti driveri za grafu koju jos nisi spomenuo. Pretpostavljam da je nvidia (Optimus) koji samo na nekim distrama radi kak spada na tim manjima je pain in the ass.
Staro 12.01.2025., 09:33   #3861
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,410
U desktopu imam 3060Ti (sve je točno pod moj komp), a u lapu je intel integruša. Ako se dobro sjećam, na nekim distram sam morao koristiti neke ''noveau'' ili tako nekako drivere jer ništa drugo nije uopće radilo. Moram priznat da ne kužim kako i otkuda uopće skidat novije drivere za GPZ za linux. Ovaj Chachy to navodno sve radi sam, što je za mene super.
Staro 12.01.2025., 14:19   #3862
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,401
Za AMD i Intel grafe je dovoljna aktualna verzija opensource drivera (citaj: ne trebas nista extra instalirat). Kad je nvidia u pitanju svaka distra ima upute za instalaciju nvidia drivera - vecinom se radi instalaciji odredenog nativnog paketa za tvoju distru, reboot i to je to. Zato me vise cudi da se Bazzite tako ponasao na Intel integrusi. "noveau" je open source driver. Uglavnom ne zelis to koristiti jer su performanse koma. Uvijek gledaj nvidia driver instalirat po uputama koje distra diktira.
Staro 14.01.2025., 11:26   #3863
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,401
Fortinet researchers uncovered an advanced rootkit malware exploiting multiple zero-day vulnerabilities in enterprise appliances by executing a shell script (Install.sh).
https://cybersecuritynews.com/rootki...tems-remotely/
Staro 14.01.2025., 11:29   #3864
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,401
I MS opet igra svoju igru
Unfortunately for Torvalds, a Microsoft-contributed change nearly ruined it, but Intel and AMD had intervened just in time to save the day.
The change in question was related to a ARCH_HAS_EXECMEM_ROX kernel configuration, which would allow caching of executable memory (EXECMEM) with read-only execute (ROX) permissions. It was being added as a performance improvement feature on Linux 6.13 for x86_64/ AMD64, ie, 64-bit AMD and Intel CPUs.
Unfortunately, this was pushed out without acknowledgement (Ack) from an x86 kernel maintainer, and it has broken the CFI or Control Flow Integrity on such CPUs.
https://www.neowin.net/news/microsof...n-the-process/
Staro 15.01.2025., 00:45   #3865
potemkin.hr
Akutna lijenčina
potemkin.hr's Avatar
Lokacija: Fiume
Postovi: 1,834
Bazzite po defaultu na desktop imageovima ima složen daily autoupdate i može ići na živce ljudima, ja ugasio pa manualno svaki tjedan-dva okinem i nema problema.
Do prije nekoliko tjedana sam furao RTX2060 i nakon rebaseanja na bazzite-nvidia-open i nVidijinog kemijanja s novim driverima prije par mjeseci fakat nisam imao razlike u performansama među bazziteom i Windozima 11, al eto to je moje iskustvo bilo koje ne mora biti ko i ostalima.
Osobno sam sretan s Bazziteom i ostajem do daljnjeg na njemu na laptopu (bazzite-nvidia-open) i HTPCu (bazzite-deck), sve mi radi ko violina.
Imamo fortija u firmi da se jebe al srećom nije moj problem
potemkin.hr je offline   Reply With Quote
Staro 15.01.2025., 07:57   #3866
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,401
+1
A change to the Linux 6.13 kernel contributed by a Microsoft engineer ended up changing Linux x86_64 code without proper authorization and in turn causing troubles for users and now set to be disabled ahead of the Linux 6.13 stable release expected next Sunday.
Michael Larabel
Zadnje izmijenjeno od: tomek@vz. 15.01.2025. u 08:11.
Staro 15.01.2025., 08:06   #3867
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,401
Nego...da unesem opet malo produktivnosti iz kucne radinosti na Linux temu. Kupio sam za klinca jos prije godinu dana Nacon EVOL-X gamepad. S obzirom da je MS Xbox kontroler uvijek radio na Linuxu ko iz puske pretpostavio sam da ce i ovaj sto je bila naravno - greska. Kvaka je u tome da iako ga xpad driver koji je integriran u kernel podrzava isti treba "Feedback" da se upali i profunkcionira. Rijesenje u vidu xone drivera sam u startu odbacio jer bi to znacilo da Nacon proradi ali bih izbacio xpad driver iz kernela i MS Xbox kontroler bi prestao raditi. So...rijesio sam na nacin da kontroler kod boota ili spajanja kroz UDEV pravilo dobije potreban "feedback".
/etc/udev/rules.d/98-gamepad.rules
Code:
ATTRS{idVendor}=="3285", ATTRS{idProduct}=="0663", RUN+="/sbin/modprobe xpad" RUN+="/bin/sh -c 'echo 3285 0663 > /sys/bus/usb/drivers/xpad/new_id'"
Product i Vendor ID naravno iscitate iz outputa lsusb komande.
Pa eto mozda nekome pomogne sa slicnim problemom.
Staro 15.01.2025., 13:09   #3868
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,401
Security researchers have uncovered six critical vulnerabilities in rsync, a widely used file synchronization and transfer tool for Linux systems. The most severe flaw could allow attackers to execute arbitrary code on machines running rsync servers with just anonymous read access.
https://cybersecuritynews.com/linux-...vulnerability/
Staro 15.01.2025., 14:24   #3869
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,890
sva sreća nemam ni anonymous read access aktivan
Staro 15.01.2025., 21:20   #3870
potemkin.hr
Akutna lijenčina
Lokacija: Fiume
Postovi: 1,834
Code:
E viš na Fedori 41 su nešto ujebali sa Bluetoothom (što se jasno pretočilo mi i na Bazzite), u smislu da jednostavno ne vidi mi Switch Pro kontroler dok ne reloada BT modul. Stvar proradi ako eksterni BT dongle repluggaš u USB ali glupo mi zajebavat se s tim pa sam na kraju uzeo Xboxov kontroler i onaj USB radio dongle tako da BT izbacim kompletno iz kombinacije. Tipkalo i miš imaju već svoj dongle pa nek se oni igraju sa plavozubom
Radi stvar i sa reloadanjem preko terminala sa sljedećim ali ne vadi mi se tipkalo za takvu glupost
Code:
sudo rmmod btusb
sudo modprobe btusb
