Staro 06.03.2006., 22:26   #1
csx
csx's Avatar
Datum registracije: May 2005
Lokacija: .
Postovi: 875
Temperatura AMD Athlona 64 3200+
Evo zanima me koja je temp. navedenog procesora kod vas.
Evo meni je dok sad ovo pišem 34 stupnjeva i u pozadini sam pustio glazbu.
Prije sa starim MS napajanjem temp. je bila oko 22C, ali otkad imam Chieftec 410W temp se popela za 10+.
jel zna tko možda moguci uzrok?
csx je offline   Reply With Quote
Staro 07.03.2006., 04:10   #2
Xtr3m3
Xtr3m3's Avatar
Postovi: 76
Kod mene 33°C trenutno, napajanje Chieftec 400w
AMD Athlon64 3200+ Venice
Epox 9NPA+ Ultra
Gigabyte Geforce 6800 GS
2x512 Kingmax DDR 400
Hitachi 160GB SATA2
Chieftec 400W
Thermaltake Soprano
Xtr3m3 je offline   Reply With Quote
Staro 07.03.2006., 09:55   #3
domy_os
domy_os's Avatar
Postovi: 18,914
35°C idle, box na 5 V, komponente pobacane po stolu...
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 07.03.2006., 15:42   #4
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
Mislim da bi trebao i navesti na kojoj voltaži ti radi proc...
Meni na 1.57 je 37C
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je offline   Reply With Quote
Staro 07.03.2006., 16:04   #5
domy_os
domy_os's Avatar
Postovi: 18,914
Ista mi je temperatura i na 1.1 i na 1.4 V jer je izgleda matična u banani...
Staro 07.03.2006., 16:17   #6
BrunoZG
Junior Member
BrunoZG's Avatar
Datum registracije: May 2003
Postovi: 3,205
Uzrok za temperaturu bi mogao biti drugaciji ventilatori na napajanju .. i drukcije ventiliranje kucista
Autor csx.evolution
AMD 3800+x2@2500, 1,375V
MB-ASROCK DUAL SATA(bios 2.2) 2+ENERMAX485W
2x512 Supertalent CL2
HDD-Hitachi 160GB, WD 800JB
ELSA 7600GT
Leadtek-2000XP expert
DVDROM-LITEON-167T ,DVDRW BENQ 1650,DVDRW NEC ND2500A@2510_fw205C
Monitor: Samsung 997MB (19')
Terratec Sky 5.1,EPSON-C42
BrunoZG je offline   Reply With Quote
Staro 14.03.2006., 17:30   #7
MOrdecai83
Keeper of the Nine Keys
MOrdecai83's Avatar
Postovi: 193
Meni je na idle oko 35C a na max load dodje i do 54C...s tima da sam stavio onu bezveznu silikonsku pastu...jer nisam imao druge pri ruci...kada budem cistio komp staviti cu arctic silver pa javim tad rezultate. Inace, moja jezgra je Newcastle 3200+ 754pin.
L-L-L-Look at you, Hacker. A pa-pa-pathetic creature of meat and bone, panting and sweating as you r-r-r-run through my corridors-s-s. H-h-how can you challenge a perfect, immortal machine? - SHODAN
CPU : AMD 64 X2 4600+ / 2400Mhz (Sckt AM2)
CPU COOLER : Stock
MOBO : Gigabyte GA-M59 SLI-S5 (BIOS - F8)
RAM : 2x1GB SuperTalent CL4 (4-4-3-8) PC6400 DDR2-800MHz
GPU : XFX 8800GT 512MB "Alpha Dog Edition" @ 710/1720/1030
POWER SUPPLY : Thermaltake Toughpower 600W PSU
CASE : Thermaltake Armor Jr
HDD : 2 x Seagate 320GB HDD SATA2
DVD-RW : Pioneer DVD-RW R-110
MONITOR : BenQ G2400W 24" 5ms LCD 1920x1200
MOrdecai83 je offline   Reply With Quote
Staro 14.03.2006., 18:16   #8
PC Maniac
0 dB is my style.
PC Maniac's Avatar
Postovi: 449
Meni je idle 22,5C sa default postavkama i box coolerom, imam tagan 380W.
Silent PC: Biostar GF8100 M2G+, AMD Phenom X4 9650, ZEROtherm BTF80, 2x2 GB Kingmax DDR2 1066MHz, Samsung F1 640 GB, Fortron PNF 400W cooled with Scythe S-Flex 800 RPM
PC Maniac je offline   Reply With Quote
Staro 14.03.2006., 18:19   #9
d tjuner
Von der Kratki Spoj
d tjuner's Avatar
Lokacija: Rijeka & okolica
Postovi: 15
Imao sam i ja neku frku sa temp kad sam mijenjao napajanje. Vjerojatno poluproizvod od MS Industrialsa nije mogao adekvatno obaviti posao pa se proc nije ni grijao Kad sam stavio drugo napajanje temp je skocila nekih 5-8C. Newcastle 3200+@2.2G se sad drzi na 28-30C idle (iako to nije idle idle - uvijek nesto svira ili vrtim neke stranice) i 35-38C max load (tipa Prime ili Far Cry...). E da, na vodi su CPU i GPU, pasta od Zalmana Na stock-u je to islo i do 47C
Edit:sad tek kuzim da mi ovo ispada prvi post - dakle pozdrav svima!
K8N & A64
6600GT@540/1080
Tagan 480W
Custom vodeno@CPU&GPU
Lova?! Lova nije problem. Love nema
d tjuner je offline   Reply With Quote
Staro 14.03.2006., 19:11   #10
Hamm
Pod naletima kopita zla
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
probaj staviti jos dva straznja venta da bacaju zrak van
Staro 14.03.2006., 19:24   #11
Don
je gladan!
Don's Avatar
Postovi: 1,698
s boxom sad 27 a max 45 a imam "poluproizvod"
Don je offline   Reply With Quote
Staro 14.03.2006., 20:03   #12
fanATIk
NITKOV
fanATIk's Avatar
Lokacija: Maksimir / Dugave
Postovi: 4,012
surfanje, mjuza, 30c. hlađeno sonic towerom.
Asrock FM2A78M-DG3+
G.SKILL RipjawsX series 8 GB
Palit GTX 460
Corsair VS550
Thermaltake Core V21
22"LCD LG W2242T
MX Revolution
Logitech X-230
Logitech K740
Canon CanoScan 4400F
Win 10
Unique case by fanATIk
Avatar BIG SIZE
