Lokacija: Earth
Postovi: 538
Mikrotik - P2P link
Ovako,imam 2 Mikrotika SXTsq Lite2 i više sam se pogubio u konfiguracijama. Ovo je konfiguracija za Master: Code:
# aug/07/2018 21:10:22 by RouterOS 6.42.6 # software id = N5L5-NAV7 # # model = RBSXTsq5nD # serial number = xxxxxxxxx /interface bridge add name=BrLocal protocol-mode=none /interface wireless set [ find default-name=wlan1 ] band=5ghz-onlyn disabled=no frequency=5200 \ mode=bridge nv2-preshared-key=zzzzzzzzz nv2-security=enabled ssid=Link \ wireless-protocol=nv2 /interface wireless security-profiles set [ find default=yes ] supplicant-identity=MikroTik /ip hotspot profile set [ find default=yes ] html-directory=flash/hotspot /snmp community set [ find default=yes ] addresses=0.0.0.0/0 /interface bridge port add bridge=BrLocal interface=wlan1 add bridge=BrLocal hw=no interface=ether1 /ip dhcp-client add dhcp-options=hostname,clientid disabled=no interface=BrLocal \ use-peer-ntp=no /system clock set time-zone-name=Europe/Zagreb /system identity set name=LiMaster /system ntp client set enabled=yes primary-ntp=161.53.30.170 secondary-ntp=161.53.30.3 /system routerboard settings set silent-boot=no /tool bandwidth-server set authenticate=no /user set 0 password=Trvi2 Code:
# aug/07/2018 21:10:36 by RouterOS 6.42.6 # software id = 7D5Q-3J0E # # model = RBSXTsq5nD # serial number = xxxxxxxxx /interface bridge add name=BrLocal protocol-mode=none /interface wireless set [ find default-name=wlan1 ] band=5ghz-onlyn disabled=no frequency=5200 \ mode=station-bridge nv2-preshared-key=zzzzzzz nv2-security=enabled \ ssid=Link /interface wireless security-profiles set [ find default=yes ] supplicant-identity=MikroTik /ip hotspot profile set [ find default=yes ] html-directory=flash/hotspot /interface bridge port add bridge=BrLocal interface=wlan1 add bridge=BrLocal hw=no interface=ether1 /ip dhcp-client add dhcp-options=hostname,clientid disabled=no interface=BrLocal \ use-peer-ntp=no /system clock set time-zone-name=Europe/Zagreb /system identity set name=LiSlave /system ntp client set enabled=yes primary-ntp=161.53.30.170 secondary-ntp=161.53.30.50 /system routerboard settings set silent-boot=no /user set 0 password=Trvi2 Zadnje izmijenjeno od: Nikky. 17.04.2024. u 21:47. |
Postovi: 23,512
Imaš primjera po netu, npr: https://wiki.mikrotik.com/wiki/Bridg...works_with_SXT https://www.youtube.com/watch?v=DQO9nHXEYhI https://scoop.co.za/blog/how-to-crea...tp-bridge-link možda igra i ovaj (za drugi tip uređaja) > https://help.mikrotik.com/docs/displ...tP+GUI+example Svakako kreni iz početka, obavezno bez default konfiga pa onda slijedi upute. |
Datum registracije: May 2014
Lokacija: istra
Postovi: 3,487
jesi probao ovo uopće podesit ručno ili si samo upucao skriptu unutra? na ap-u ti fale postavke na wifi (širina kanala, regulatory domain za početak, nakon toga ti fale nv2 postavke). na clientu ti fali to isto plus ti fali sken lista i opet regulatory domain. na klijentu ne upisuješ frekvenciju jer to ničemu ne služi, već upisuješ sken listu. skini si winbox i poklikaj to ručno. PS NEMAŠ lite2 nego imaš lite5. |
El Mattador
Lokacija: <->
Postovi: 1,914
- Prvi uređaj staviš kao bridge - Pod security profile postaviš postavke (šifru, itd...) - Izabereš frekvenciju, širinu kanala, daš ime SSID-u, postaviš wireless protocol, postaviš security profile koji si napravio. -Drugi uređaj staviš kao station bridge - Pod security profile postaviš iste postavke kao na prvom uređaju postavke (šifru, itd...) - Izabereš istu frekvenciju, istu širinu kanala, isti SSID, isti wireless protocol kao na prvom, postaviš security profile koji si napravio a koji je identičan prvom. I to je to. |
Lokacija: Earth
Postovi: 538
Ok uspio sam to,ponekad je bolje manje tog podešavati. Oni su se povezali. Međutim,nešto sam profulao jer na ovom drugom koji je u station bridgeu nemam internet konekcije,a ovog u bridgeu sam spojio u ruter. |
Postovi: 4,691
daj se javi na pp remote rješimo |
