Staro 02.01.2024., 22:30   #12961
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,744
Da, ako je ispravan, neotvaran (sam uređaj), neoštećen i ima račun i garanciju. U tom slučaju je super cijena po mojem mišljenju. Nadam se da koristiš ili misliš koristiti S-Pen. Inače ti je bolje gledati ove s ravnim ekranima.
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
estugarda je offline   Reply With Quote
Staro 02.01.2024., 23:02   #12962
myroman
myroman's Avatar
Datum registracije: Jan 2015
Postovi: 600
Ravnim ekranima? A kaj, ultra ima curved screen? Kak se to slaze s kaljenim staklom?
myroman je offline   Reply With Quote
Staro 03.01.2024., 01:50   #12963
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Da s2x, s23+ i s23fe imaju ravne ekrane, a note serija od note4 edge generacije (mislim da su i neki iz S serije u to vrijeme imali) i s21/22/23 ultra imaju zakrivljeno. Izgleda dobro, osjecaj je dobar i ima neku funkciju, ali i veliku manu; tu obično svi pucaju pri padu. Zaštitna stakla su naravno problem. Skupa su jer moraju biti zakrivljena i moraju se lijepiti. Lako se odlijepe itd...I ne štite puno od najopasnijeg pada - na brid.
Sent from my SM-N986B using Tapatalk
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 03.01.2024., 09:11   #12964
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,890
S22 ultra za 400€ je super cijena
Staro 03.01.2024., 21:13   #12965
GreenLife
Čika Zeljeni
GreenLife's Avatar
Datum registracije: Sep 2013
Lokacija: Tannhausen (Aalen)
Postovi: 486
Autor myroman Pregled postova
Onda je ovo malo žešči fejk (sedma fotka)?
https://www.njuskalo.hr/samsung-osta...oglas-40930871
Mislim da je gsmarena legitiman izvor:
S23 Ultra verzije - 256GB 8GB RAM, 256GB 12GB RAM, 512GB 12GB RAM, 1TB 12GB RAM
Staro 04.01.2024., 23:04   #12966
locks
Datum registracije: Mar 2010
Lokacija: Vukovar
Postovi: 3,658
Samsung razvija 50W i 45W brze punjače...
https://www.sammobile.com/news/samsu...alaxy-devices/
locks je online   Reply With Quote
Staro 05.01.2024., 08:19   #12967
Postovi: 34,085
Bench Exy 2400 vs. SD8G3
https://www.sammobile.com/news/galax...os-snapdragon/
Postoji glasina da će i S24+ ima SD čipset na većini tržišta
https://www.gsmarena.com/samsung_gal...news-61113.php
Staro 05.01.2024., 11:29   #12968
GreenLife
Čika Zeljeni
GreenLife's Avatar
Postovi: 486
Ajde da konačno exynos (bar u benchmarku) bude bliže Snapdragonu.
I super, ali real world use će pokazati da li je to stvarno tako. I kakvi su po pitanju postojanosti kad su zagrijani i pod opterećenjem.
Staro 05.01.2024., 12:09   #12969
Postovi: 34,085
Staro 05.01.2024., 14:29   #12970
ThePornstar
ThePornstar's Avatar
Postovi: 4,403
Autor locks Pregled postova
Ajde, bar su krenuli s razvojem.
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
Battery: 57 Wh internal
ROM: Android 9
Staro 05.01.2024., 14:43   #12971
joolka
music freak
joolka's Avatar
Lokacija: Sibenik
Postovi: 3,317
imali su vatreno krstenje sa Note 7 serijom
LENOVO LEGION 5 Pro Gaming Laptop (AMD Ryzen 7 7745HX,RTX 4060,32gb DDR5,2tb SSD)
Staro 05.01.2024., 19:28   #12972
myroman
myroman's Avatar
Postovi: 600
Istražujući S23 liniju (plus posebno) slučajno naletih na Nothing phone 2.
I sad, uvidjevši specke, pa cijenu... uh, u teškoj sam dilemi.
Samsung (S20 FE 5G) me dobro služio i logično bi bilo nastaviti sa Samsungom.
Ali ovaj Nothing Phone 2 me stvarno golica...
Staro 05.01.2024., 19:56   #12973
BoTiA
Lokacija: doma
Postovi: 254
Pa ako zanemarimo one ledice na nothing phone, s23 plus je bolji mobitel ... Ip68, bolje kamere, procesor, brzi čitac otiska prsta, malo duža SW podrška, Dex ...
BoTiA je offline   Reply With Quote
Staro 05.01.2024., 22:10   #12974
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,762
Autor BoTiA Pregled postova
Potpis.
Meni ga je frend uzeo nedavno i imao sam prilike se poigrati. Moram priznati da sam imao malo veća očekivanja, pogotovo od softwarea. Dosta je gol tj. sličan vanilla Androidu, što je nekome plus ali meni osobno nije - razmazio me OneUi. Isto tako glavne postavke nisu ni blizu dobro organizirane kao na OneUi... Prisiljen si koristiti Googleove aplikacije ili instalirati neke 3rd party za najosnovnije stvari poput galerije jer je Google Photos toliko jadan i škrtav u opcijama . Generalno mob lijepo radi ali ništa bolje od ostalih flagshipova takve klase. Kamere su ok a pogotovo uw samo šteta što nema telephoto... Glyphovi tj. Ledice su zanimljive valjda prva dva dana. Widgeti na home screen pa i Aod-u su čudnog izgleda i funkcionalnosti, valjda prate temu mobitela. Sve u svemu solidan mob al malo precijenjen IMO.
Zadnje izmijenjeno od: Sn4k3. 05.01.2024. u 22:15.
Staro 05.01.2024., 22:44   #12975
Postovi: 10,322
Svaki dan bi zamijenio Pixel experience (almost vanilla) Android za OneUI. A Samsung appse skoro pa nisam ni koristio osim onih koji ne postoje kod Googlea.
Staro 05.01.2024., 22:46   #12976
locks
Lokacija: Vukovar
Postovi: 3,658
Cilj NothingOS-a i jeste da bude minimalistički, a ne pretrpan kao One UI. Ne treba svako toliko podešavanja i bloatwarea. Razumijem da se nekome ne sviđa, ali ima svojih prednosti. Glyph je još nedorađen po meni, nudi premalo s obzirom na mogući potencijal.
Slažem se da je S23+ kompletniji i sigurniji izbor. Nothing je za entuzijaste...
Staro 05.01.2024., 22:48   #12977
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Iako meni izgleda dobro, Nothing Phone mi se čini samo kao gimmick. Umjesto neke bitne nove funkcionalnosti, dodali su neobičnu estetiku. Ne mogu zamisliti scenarij u kojem bi mi te animirane LED trake donijele nešto posebno novo korisno. Iako žalim za vremenima kad je Samsung naprijed imao LED-icu za notifikacije pa se s aplikacijama moglo podesiti boju prema tipu notifikacije ili kontaktu. Ja bih radije to vidio na stražnjoj strani. Samung je tome relativno elegantno doskočio sa edge notifikacijama, iako je cijena zakrivljenog displaya IMHO prevelika za to. Pitam se hoće li ovaj minimalno zakrivljeni S24 Ultra imati edge notifikacije. Da se mene pita, otraga pokraj kamera bi trebalo vratiti običnu jednu RGB LEDicu za notifikacije. Naprijed zadržati always on. If it ain't broken, don't fix it.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 05.01.2024. u 23:09.
Staro 06.01.2024., 09:12   #12978
djzuza
Postovi: 380
Autor coconut Pregled postova
Ako ovo bude istina, uzimam S24+ obavezno
djzuza je offline   Reply With Quote
Staro 06.01.2024., 09:36   #12979
robee
robee's Avatar
Lokacija: VinkovcI
Postovi: 950
Edge noti. radi i na ravnom display-u. Ne mora biti zakrivljen za tu funkciju.
robee je offline   Reply With Quote
Staro 06.01.2024., 12:54   #12980
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Autor robee Pregled postova
A da li se vidi kad je mobitel okrenut da je display dolje?
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 06.01.2024., 13:11   #12981
Postovi: 34,085
Cijena popravka Samsung uređaja u SLO (ima već i S24 seriju)
https://www.mobistekla.si/popravila/Samsung
Staro 06.01.2024., 21:02   #12982
robee
robee's Avatar
Lokacija: VinkovcI
Postovi: 950
Autor estugarda Pregled postova
Odgovor znas
Ne vidi se ni led-ica. Za takve stvari koristi se blic led.
Osobno jos nikada nisam okrenuo mob na display.
Staro 07.01.2024., 12:28   #12983
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Ja sam Note 8-icu stalno imao okrenutu prema dolje, ali 20 Ultra više ne, jer je došla sa smart coverom. Koji bi bio super, da barem malo štiti uređaj. Greška je bila to očekivati.
U teoriji, ako ima kaljeno staklo, recimo 0.3mm, nešto svjetla bi možda moglo proći. Iako, svaka poštena maska to pokriva.
Tu sad dolazi ta moja teorija da je zakrivljeni display dobar ponajviše zbog toga. Kvalitetna estetika i taktilnost se ionak gube kad imaš masku, pa čak i originalni smart cover.
Postoji app za notifikaciju za blic LEDicu? Nisam znao. Ali mana stražnje LEDice u tom smislu je što nije RGB. Barem koliko ja znam.
S obzirom da su stražnji kamera moduli ionako natrpani svim i svačim, kakav bi problem bio da stave jednu običnu RGB ledicu kakve su imali i prije na prednjoj strani? Meni bi to bio moćan feature.
PS. Kako sad stvari stoje, display na S24 Ultra neće biti zakrivljen, ali staklo da. Doduše manje nego prije. Ne znam. Mislim da će opet zbog toga biti slaba točka. Nadam se da će S23 Ultra pojeftiniti nakon 17.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 07.01.2024. u 13:07.
Staro 07.01.2024., 16:28   #12984
Postovi: 10,322
AODNotify sam koristio na Note9 i Pixelu. Mozes podesiti kako da pokaze info na AOD-u i/ili LED-icu. Ima masu opcija, svaka je bolja od defaultnog Samsung i Google AOD-a. Sa 5 metara znam dal mi pise zena ili neka spam wapp grupa, da se ne dizem s kauca za đ
Staro 09.01.2024., 20:18   #12985
Dottore
Dottore's Avatar
Postovi: 7,710
Autor xlr Pregled postova
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Dottore je online   Reply With Quote
Staro 16.01.2024., 15:21   #12986
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Datum registracije: Sep 2012
Lokacija: 00001
Postovi: 2,528
ako neko oce uzimat nesto u zamzung . hr ducanu za odabrane artikle.
Kod
FQW-EY3X-2CDR-SLL9
30€
Sent from my SM-S918B using Tapatalk
Staro 16.01.2024., 17:13   #12987
Postovi: 34,085
Kao što se pričalo, na preorderu za S24 seriju dobiti će se dupli kapacitet za originalnu cijenu. Isto kao što je bilo i za S23.
https://saminsider.com/galaxy-s24-se...clusive-color/
Staro 16.01.2024., 17:41   #12988
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,762
Prije 3-4 dana sletio January security patch...
Name:	Screenshot_20240112_101908_Software update.jpg‎
Staro 16.01.2024., 22:12   #12989
Dottore
Dottore's Avatar
Postovi: 7,710
Autor Sn4k3 Pregled postova
S24U , subota
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 16.01.2024., 22:26   #12990
GreenLife
Čika Zeljeni
GreenLife's Avatar
Postovi: 486
Dakle...unboxed prije samog službenog izlaska:
Samsung Galaxy S24 Ultra unboxed ahead of announcement
Diretni link na twitter:
Video
Ultra verzija je skoro ista kao S23, samo što je ekran sad flat a ne curved.
A bome se ni cijene nisu nešto promjenile, samo je Ultra još mrvicu skuplja
Following are the pricing details leaked for the European market:
Galaxy S24
128GB variant €899
256GB variant €959
Galaxy S24+
256GB variant €1,149
512GB variant €1,269
Galaxy S24 Ultra
256GB variant €1,449
512GB variant €1,569
As per the price details shared by Galaxy Club, it is not shocking why the price range for the Galaxy S24 variant is less than its previous Galaxy S23 base variant that initially launched at €949. It indicates that Samsung will most likely launch its base S24 variant with the Exynos 2400 Setup. Meanwhile, the Galaxy S24+ and S24 Ultra variants are expected to be launched with Snapdragon 8 Gen 3 SoC. Therefore, the pricing is elevated compared to its predecessor version.
