Staro 28.12.2023., 09:19   #61
mann
mann's Avatar
Postovi: 2,221
Autor snake29o3 Pregled postova
Otići ću onda u HT ili benzinsku i kupiti da ne čekam...
Jel netko od Vas tko koristi Visiting Croatia tražio da mu maknu CG-NAT?
U drugoj temi je netko napisao da su mu odgovorili da ne može se maknut na toj kartici. :-(
Ja sam ih pitao, rekli da ne mogu to napraviti. Nisam dalje tupio. Je tko uspio?
Sent from my SM-S901B using Tapatalk
Staro 28.12.2023., 11:13   #62
snake29o3
snake29o3's Avatar
Lokacija: Croatia - Kutina
Postovi: 211
Autor mann Pregled postova
Yap, uspio sam na kraju.
Evo tu sam napisao postupak kako sam odradio:
http://forum.pcekspert.com/showpost....postcount=2592
CPU: INTEL Xeon E5450 3.0 GHz 12 MB Cache
Cooler: Scythe Grand Kama Cross
Mainboard: Asrock P43DE3
RAM: 4 x 4 GB DDR3 1600MHz
GPU: XFX 8800 GT 512 MB DDR3 Alpha Dog XXX Edition
HDD: Kingston HyperX Fury 120 GB (OS) + ( 4 x Toshiba DT01ACA050 500 GB 32 MB (RAID 10) )
PSU: InterTech SL-500A
Case: Antec P180
OS: Proxmox VE
Cooler: Spire Kepler Rev.2
Mainboard: Gigabyte GA-965P-DS4
RAM: 4 x 2 GB DDR2 Kingmax 1066MHz
GPU: Palit GeForce 8400GS 512MB DDR2
HDD: Hitachi 160 GB (OS) + ( TOSHIBA 3 TB 64 MB DT01ACA300 + Toshiba 3 TB 64 MB HDWD130 (ZFS RAID1)
PSU: Xilence 420W
Case: Generic Midi Tower
OS: CentOS 7
Manufacturer: HP
Model: Z440
CPU: INTEL Xeon E5-1650 v4 3.6GHz ( 4GHz Turbo ) 15 MB Cache
RAM: 4 x 8 GB DDR4 ECC 2400MHz
GPU: nVIDIA Quadro P4000 8 GB
SSD: 2 x 240 GB RAID 1 + 256 GB
HDD: 2 x 3 TB RAID 1
Monitor: HP LA2405wg 24" 1920 x 1200
OS: openSUSE Tumbleweed MATE x64
BRAND: ASUS N705FD
CPU: Intel Core i7 8565U 1.8 GHz ( up to 4.6 GHz with TurboBoost)
RAM: 2 x 8 GB DDR4 2400 MHz
GPU: Intel® UHD Graphics 620 Integrated + nVidia GTX 1050 4GB DDR5
SSD: Crucial Micron 1100 256GB
HDD: Seagate ST1000LM035 1 TB 128 MB Cache
Screen: 17.3" 1920 x 1080
BRAND: HP Notebook 15-ba006nm
CPU: AMD Quad-Core A10-9600P (2.4 GHz, up to 3.3 GHz, 2 MB cache)
RAM: 4 GB DDR4 1866 MHz + 8 GB DDR4 1866 MHz
GPU: AMD Radeon R7 M440 Graphics 4 GB DDR3
HDD: 1 TB 5400 rpm
Screen: 15.6" 1920 x 1080 FullHD
OS: Windows 10 Pro x64
Poštene trgovine:
1, 2, 3, 4, 5, 6, 7
snake29o3 je offline   Reply With Quote
Staro 28.12.2023., 12:38   #63
mann
mann's Avatar
Postovi: 2,221
Thnx na info, na koji mail si slao zahtjev?
Staro 28.12.2023., 13:29   #64
snake29o3
snake29o3's Avatar
Postovi: 211
NA ovaj mail:
Prima: tehnicka.podrska@t.ht.hr
Subject: Zahtjev za isključivanje CGNAT-a
Case: Antec P180
OS: Proxmox VE
PSU: Xilence 420W
OS: CentOS 7
Manufacturer: HP
Model: Z440
BRAND: ASUS N705FD
HDD: 1 TB 5400 rpm
Poštene trgovine:
1, 2, 3, 4, 5, 6, 7
Staro 28.12.2023., 13:54   #65
mkey
Datum registracije: Sep 2018
Lokacija: tu
Postovi: 3,466
Vidim da kolega prezime pise kako je signal OK u Medulinu. Ja imam jako loše iskustvo s bonbon mrežom po Istri, pretpostavljam da onda za ovu turističku uslugu ne koriste istu mrežu?
mkey je online   Reply With Quote
Staro 28.12.2023., 14:23   #66
Prezime
Datum registracije: Aug 2013
Postovi: 4,336
Skoro sam 100% siguran da se koristi ista mreza; mozda je ogranicenje na Bonbon karticama., neznam...
Ali da napomenem, brzina ovisi i o polozaju i o dobu dana/noci i o godisnjem dobu i pozaju mjeseca i o raspolozenju uredjaja i o....
Mjerio sam i ja katastrofalne vrijednosti na 4G u Medulinu, cak ispod 1 Mbits
Staro 28.12.2023., 14:42   #67
mkey
Lokacija: tu
Postovi: 3,466
Ma ja sam na bonbonu bio spojen na edge, i to po široj okolici. Znali su mi se i razgovori prekidati odnosno skužio sam u par navrata da me ovaj na drugoj strani uopće niti ne čuje dok ono što dolazi prema meni samo prekida ali se još može razumjeti.
Moguće da lupe neko ograničenje na bonbon, to bi se savršeno uklapalo u moju sliku o njihovom poslovnom modelu.
Staro 28.12.2023., 15:12   #68
Neo-ST
Neo-ST's Avatar
Postovi: 8,363
Mene više zanima kako si ti uspio dodat taj broj u moj telekom aplikaciju? Di treba kliknit? Ako idem na dodaj uslugu, nudi samo da dodam fiksnu uslugu...
Staro 28.12.2023., 15:22   #69
selk
Datum registracije: Jan 2017
Postovi: 273
Autor Neo-ST Pregled postova
Ja sam isto uspio dodati taj broj u aplikaciju....
Kod pokretanja aplikacije pita te na koji način se želiš prijaviti logirati...
Nude se tri opcije;
e-mailom
mob. brojem
Id telekom
Odabereš mob.brojem, upišeš taj broj i onda ti pošalju kod SMS porukom, upišeš taj kod i tako se logiraš u aplikaciju i dodan je taj broj i usluga opcija u aplikaciji...
Poslje u postavkama možeš onda kreirati id telekom upišeš e-mail i onda se poslje možeš logirati tim e-mailom odnosno id telekom opcijom, a taj broj i dalje ostaje dodan u aplikaciji i vidljivo ti je stanje računa i opcija flat surf do kada traje, i naravno možeš obnoviti kupiti bon.
selk je offline   Reply With Quote
Staro 28.12.2023., 15:38   #70
Neo-ST
Neo-ST's Avatar
Postovi: 8,363
Autor selk Pregled postova
Nude se tri opcije;
e-mailom
mob. brojem
Id telekom
Ali ja već imam korisnički račun u aplikaciji gdje su mi druge usluge. Među njih ne mogu dodat ovaj broj, znači morao bih kreirat odvojen račun samo za ovu turističku karticu ?
Staro 28.12.2023., 15:49   #71
Postovi: 10,088
Autor mkey Pregled postova
Volim kada ljeti dodjem u medulin na rucak jer znam da nitko na tmobilu nece visiti na mobu. 4g brzine su na nasoj lokaciji bile nedovoljne za skrolati instagram feed. Potvrdjeno na bonbonu i tmobile poslovnoj preplati. Jednostavno stvar krepa. Ali se zato siti ispricamo
Staro 28.12.2023., 15:50   #72
mann
mann's Avatar
Postovi: 2,221
Nemoj ići preko app nego preko weba. Ni ja nisam mogao preko appa ali kada dodaš preko weba pojavi ti se u appu.
NA ovaj mail:
Zahvaljujem.
Staro 28.12.2023., 16:37   #73
Neo-ST
Neo-ST's Avatar
Postovi: 8,363
E bravo, to je bila caka.
Hvala.
Staro 28.12.2023., 16:46   #74
selk
Postovi: 273
Hvala.
Kako preko weba dodati taj broj da se pojavi u app ?
Možeš mi pojasniti....
Staro 28.12.2023., 21:27   #75
Neo-ST
Neo-ST's Avatar
Postovi: 8,363
Staro 28.12.2023., 22:06   #76
selk
Postovi: 273
Aha ok, eto ja sam uspio na onaj način kako sam opisao preko app, ali nisam imao od prije korisnički račun na aplikaciji i to mi je prva usluga kod njih, pa sam zato uspio sa prijavom i logiranjem preko tog broja.
Staro 28.12.2023., 22:41   #77
snake29o3
snake29o3's Avatar
Postovi: 211
Kako su već i ostali napisali, preko web-a sam dodao broj...
Imao sam telekom id od prije, i onda dodavao broj.
S time da sam ga prvo registrirao jer kod dodavanja broja preko web-a traži i OIB.
P.S.: I da nadodam samo da ovaj Flat Surf radi super... svakih 10 dana mi lijepo naplati 7,96€ i idemo dalje... nikakvih ograničenja ni ništa...:-) Samo treba paziti da ima novaca na računu :-)
Sad sam u potrazi za ZTE MC7010 ili ZTE MC889 da to stavim na krov i da mogu loviti 5G :-)
Case: Antec P180
OS: Proxmox VE
PSU: Xilence 420W
OS: CentOS 7
Manufacturer: HP
Model: Z440
BRAND: ASUS N705FD
HDD: 1 TB 5400 rpm
Poštene trgovine:
1, 2, 3, 4, 5, 6, 7
Zadnje izmijenjeno od: snake29o3. 28.12.2023. u 22:50.
Staro 16.03.2024., 16:16   #78
selk
Postovi: 273
Da li se može preko ove Telemach turističke simice produživati opcija flat unlimited svakih 10 dana, ili se može samo jednom nakon isteka ovih prvih 10 dana.
https://telemach.hr/for-tourists
Pod stavkom pitanja i odgovori ima nešto ovako:
Kako mogu aktivirati neograničenu opciju?
Možete aktivirati:
- Još jednom neograničeni internet (7,96 EUR | 60 HRK) na 10 dana slanjem SMS-a s ključnom riječi UNL na 13999.
Staro 16.03.2024., 20:01   #79
dhalan
Datum registracije: Apr 2008
Lokacija: Gračac
Postovi: 177
Tu sam grešku već napravio. Pa sad imam 8€ na toj SIMici.
Može se jednom produžit i to je to.
Iako sam slao mail prije i pitao da li je ista opcija kao i kod HTa i netko mi potvrdno odgovorio, da se sama obnavlja.
Slao sam prigovor, ali džaba, tele, tele.
Nemam volje za 8€ pisat i slat pisani prigovor. Eto im, znam da ću ih zaobilaziti u širokom luku, koliko god je moguće.
dhalan je offline   Reply With Quote
Staro 16.03.2024., 21:29   #80
Tirkiz
Poludrago kamenje
Tirkiz's Avatar
Datum registracije: Apr 2023
Lokacija: Ogulin
Postovi: 318
Možete aktivirati:
Telemach i dalje ima razne limite, bježi od njih ako ti treba neograničen net.
Već je provjereno da HT turistička SIM-ica se može neograničeno produživati, max brzine, nema SMS-ova za brzinu, 5G pristup, gase i CGNAT na zahtjev
Tirkiz je offline   Reply With Quote
Staro 03.05.2024., 15:19   #81
dinos3
Dino Saur
dinos3's Avatar
Datum registracije: Jan 2012
Postovi: 940
Ne znam je li ovako i prije bilo, ali mislim da su malo promjenili ove godine Visiting Croatia. Samo ne kužim na šta se odnosi ovo pay 1 get 2... Šta se točno dobije duplo?
https://www.hrvatskitelekom.hr/visiting-croatia
BTW 120gb ima jeftinije ovdje
https://www.a1.hr/hr/privatni/mobite...rnet-na-bonove
Koristim to zadnjih 10ak mjeseci
dinos3 je offline   Reply With Quote
Staro 03.05.2024., 16:31   #82
johnsmith
Lokacija: vž
Postovi: 1,331
Autor dinos3 Pregled postova
Trebalo bi biti 2 sim kartice, ALI dolje je oznaceno samo esim i upute za esim su pa sam malo zbunjen i ja I jos pise free delivery haha. Moguce da su slali simice a sad presli na esim i zaboravili popraviti sve. Ili misle, platis 10e a dobis fizicki i esim. Dva esima bas i nemaju smisla imho. Trebalo bi ih na chat pitati, mozda oni znaju
Staro 07.05.2024., 12:22   #83
robimarko-bug
Datum registracije: Jul 2013
Lokacija: Tenja(Osijek)
Postovi: 1,127
Vjerovatno je obje, jer prije je bilo samo fizički SIM a nema mi smisla da su samo na e-SIM prešli.
Staro 07.05.2024., 16:46   #84
acmevagabundo
Datum registracije: Jul 2015
Postovi: 316
Što to znači za mene ako je fizički sim i e-sim, mogu li fizički staviti u ruter a e-sim aktivirati u mobu i koristiti flat na obje? To mi malo nategnuto zvuči (dva flata za 10 eurića).
acmevagabundo je offline   Reply With Quote
Staro 07.05.2024., 17:14   #85
Postovi: 10,088
Ako je isti broj u pitanju, onda samo jedan moze biti aktivan u isto vrijeme, dakle ili jedan ili drugi sim. Osim ako se tmobile upucao u stopalo ovom ponudom, a cisto sumnjam. Prije ce bit da mi nesto ne vidimo ili krivo tumacimo.
Zadnje izmijenjeno od: xlr. 07.05.2024. u 17:42.
Staro 07.05.2024., 17:41   #86
johnsmith
Lokacija: vž
Postovi: 1,331
Svi se boje cura na chatu pa nitko nece pitati, gatamo iz kave i dalje?
Staro 07.05.2024., 18:06   #87
acmevagabundo
Postovi: 316
Iskustvo kaže da cure na chatu baš i ne poznaju materiju, onda ti njoj objašnjavaš što piše, što želiš, ... Pa ona ide pitati višu instancu... Do godišnjeg će već neko provjeriti i dati informaciju
Staro 07.05.2024., 19:14   #88
johnsmith
Lokacija: vž
Postovi: 1,331
evo, skupio hrabrosti i zivota ti vidim, ko da Bloger Krule legenda to izmislio
preko weba mozes SAMO esim dobiti i ovaj 2 za 1 je akcija da taj esim onda ima 2 paketa po 10 dana za cijenu jednog, znaci 7.96e gratis (koliko je cijena drugog, prvi je 10e).
Ako ne zelim esim, onda mogu preko chata, u tcentru ili preko prodajnih partnera kupiti simicu ALI ona nema 2za1 promo kao na webu.
Staro 09.05.2024., 20:22   #89
mkey
Lokacija: tu
Postovi: 3,466
Pomozite mi neukom, esim možeš rinuti kamo? To je ona šema samo za "pametne" satove?
BTW Johne čestitke na hrabrosti i odlučnosti da kontaktiraš SZK i preneseš tu ubitačnu informaciju svekolikoj populaciji u čitjlivom obliku.
Autor George Carlin
But there’s a reason. There’s a reason. There’s a reason for this, there’s a reason education sucks, and it’s the same reason that it will never, ever, ever be fixed. It’s never gonna get any better. Don’t look for it. Be happy with what you got. Because the owners of this country don't want that. I'm talking about the real owners now, the real owners, the big wealthy business interests that control things and make all the important decisions. Forget the politicians. The politicians are put there to give you the idea that you have freedom of choice. You don't. You have no choice. You have owners. They own you. They own everything. They own all the important land. They own and control the corporations. They’ve long since bought and paid for the senate, the congress, the state houses, the city halls, they got the judges in their back pockets and they own all the big media companies so they control just about all of the news and information you get to hear. They got you by the balls. They spend billions of dollars every year lobbying, lobbying, to get what they want. Well, we know what they want. They want more for themselves and less for everybody else, but I'll tell you what they don’t want: They don’t want a population of citizens capable of critical thinking. They don’t want well informed, well educated people capable of critical thinking. They’re not interested in that. That doesn’t help them. Thats against their interests. Thats right. They don’t want people who are smart enough to sit around a kitchen table to figure out how badly they’re getting f*cked by a system that threw them overboard 30 f*cking years ago. They don’t want that. You know what they want? They want obedient workers. Obedient workers. People who are just smart enough to run the machines and do the paperwork, and just dumb enough to passively accept all these increasingly shittier jobs with the lower pay, the longer hours, the reduced benefits, the end of overtime and the vanishing pension that disappears the minute you go to collect it, and now they’re coming for your Social Security money. They want your retirement money. They want it back so they can give it to their criminal friends on Wall Street, and you know something? They’ll get it. They’ll get it all from you, sooner or later, 'cause they own this f*cking place. It's a big club, and you ain’t in it. You and I are not in the big club. And by the way, it's the same big club they use to beat you over the head with all day long when they tell you what to believe. All day long beating you over the head in their media telling you what to believe, what to think and what to buy. The table is tilted folks. The game is rigged, and nobody seems to notice, nobody seems to care. Good honest hard-working people -- white collar, blue collar, it doesn’t matter what color shirt you have on -- good honest hard-working people continue -- these are people of modest means -- continue to elect these rich c*cksuckers who don’t give a f*ck about them. They don’t give a f*ck about you. They don’t give a f*ck about you. They don't care about you at all -- at all -- at all. And nobody seems to notice, nobody seems to care. That's what the owners count on; the fact that Americans will probably remain willfully ignorant of the big red, white and blue dick that's being jammed up their assholes everyday. Because the owners of this country know the truth: it's called the American Dream, because you have to be asleep to believe it.
Staro 09.05.2024., 21:27   #90
jp_rv
Datum registracije: May 2014
Lokacija: istra
Postovi: 3,495
u bilo koji moderni telefon si gurneš esim.
inače ja sam shvatio iz reklame da dobiješ 2 sim kartice. znači fail samotakav sa tim marketingom
