Staro 09.11.2023., 22:25   #11761
ibme74
ibme74's Avatar
Datum registracije: Jan 2013
Lokacija: Planet Zemlja
Postovi: 1,632
Zato se savjet traži dan-dva prije kupnje a ne mjesec i pol dana prije jer će se uvijek cijene, ponuda i dostupnost komponenti mijenjati
1 * AMD CPU Desktop Ryzen 5 6C/12T 7600X (4.7/5.0GHz Boost,38MB,105W,AM5) box, with Radeon Graphics
Šifra: 100-100000593WOF
1 * ID-Cooling CPU Cooler - SE-214-XT RING
Šifra: SE-214-XT RING
1 * ASROCK B650M PG RIPTIDE mATX MB AM5 B650M PG RIPTIDE
Šifra: 46140538
1 * Kingston DDR5 32GB 6000 MHz, (2x16GB) FURY Beast KF560C40BBK2-32
Šifra: king-d5-60k2-32gb
1 * XFX RADEON RX 7800 XT SPEEDSTER QICK319 RX-78TQICKF9
Šifra: 46487577
1 * KINGSTON KC3000 1024GB M.2 PCIe SKC3000S/1024G
Šifra: 4360542
1 * SilverStone Decathlon Series, 850W 80 Plus Gold ATX PC Power Supply, Low Noise 120mm, 100% modular
Šifra: SST-DA850-G
1 * Phanteks Eclipse G300A DBK02 Tempered Glass, ARGB, 3 fans - black
Šifra: GEPH-164
Sveukupno s popustom: 1.535,70 € (-2%=1.504€)
Besplatno slaganje i dostava
ibme74 je offline   Reply With Quote
Staro 22.11.2023., 01:38   #11762
SilveR_D
Lokacija: Sl.Brod
Postovi: 57
Helpara
Poz ekipa!Molim za savjet što bi vi izmjenilli u ovoj konfiguraciji,i ako se može što proči jeftinije,a da je otprilike to tu negdje.Od grafe posjedujem 2080ti oc Thx
Asrock Intel LGA1700 B760M PG RIPTIDE, DDR5, S.1700
ASR-B760M PG RIPTIDE
174,00 €
INTEL Core i7-14700KF 3.4Ghz LGA1700 BOX
508,00 €
Kingston DRAM 64GB 6000MT/s DDR5 CL40 DIMM (Kit of 2) FURY Beast RGB XMP EAN: 740617331868
KF560C40BBAK2-64
320,31 €
Kućište MS ARMOR V715, ARGB, Mesh, SPCC 0.7mm, TG -HIT-
577,67 Kn
76,67 €
Arctic Liquid Freezer II CPU Komplet-vodeno hlađenje - 280mm ACFRE00066A
128,00 €
Gigabyte 850W 80+ GOLD napajanje
135,00 €
Samsung 990 PRO Series NVMe SSD, PCIe 4.0 M.2 Type 2280, with heatsink - 1TB MZ-V9P1T0CW
SSSS-195-CK
178,00 €
Porez osnovica:
1.215,98 €
Porez iznos:
304,00 €
Uplata na račun - popust 11%:
- 167,20 €
Standardna dostava:
22,60 Kn
3,00 €
SVEUKUPNO:
1.355,78 €
Slagao na racunala.hr .
p.s. može biti i amd varijacija
Zadnje izmijenjeno od: SilveR_D. 22.11.2023. u 01:56.
SilveR_D je offline   Reply With Quote
Staro 22.11.2023., 02:03   #11763
ibme74
ibme74's Avatar
Postovi: 1,632
Meni ovo sve nešto zbrda s dola, skup i otključan CPU na jeftinu zaključanu ploču, štednja na kućištu.
BTW nije vraga da računala.hr stvarno naplaćuje dostavu kad potrošiš 1.355€?
Za početak, za čega ćeš koristiti računalo? Koja je rezolucija i refresh rate monitora?
Staro 22.11.2023., 11:31   #11764
SilveR_D
Lokacija: Sl.Brod
Postovi: 57
Zato i pitam btw brzinski sam bacao komponente u košaricu... Što se tiče namjene kompa , a jbga koristiti će se za video editing na 4k zaslonu sa 120-144 hz , pa i za gaming i općenito multimediu
Napiši prijedlog pa bilo to u konačnici i skuplje , ionako će mi biti ovo kupovina nove konfe nakon 8 godina
Staro 22.11.2023., 17:39   #11765
ibme74
ibme74's Avatar
Postovi: 1,632
1 * INTEL Core i7-14700K 3.4Ghz LGA1700 BOX BX8071514700K
Šifra: 46484347
1 * Vodeno hlađenje za procesor Arctic Liquid Freezer II - 360 ACFRE00068B
Šifra: 0001216626
1 * Gigabyte Z790 UD, DDR5, s1700 Z790 UD
Šifra: gig-ga-z790-ud-d5
1 * Kingston 64GB 6000MT/s DDR5 CL40 DIMM (Kit of 2) FURY Beast RGB XMP, EAN: 740617331868
Šifra: KF560C40BBAK2-64
1 * Western Digital 1 TB M.2 SSD, Black SN850X Gen. 4x4
Šifra: WDC-WDS100T2X0E
1 * Fortron HYDRO GT PRO ATX3.0 850W, 80+ GOLD PPA8503510
Šifra: fsp-hyd-gt-pro-850
1 * COUGAR | Duoface Pro RGB | PC Case | Mid Tower / TG & Airflow Front Panel / 4 x ARGB Fans / TG Left Panel
Šifra: CGR-DUOFACE PRO RGB
Sveukupno s popustom: 1.464,10 € (-2%=1.434€)
Staro 25.11.2023., 17:28   #11766
Kokolinac
Datum registracije: Nov 2023
Lokacija: GB
Postovi: 5
Question
Bok,
Radim svoj prvi pc za igrice i gaming uzeo sam procesor Ryzen 7 5800x3d, Asus ROG STRIX B550-F GAMING WIFI II matična ploča, Socket AM4, AMD B550, 4x DDR4, max. 128 GB, ATX, Grafička Sapphire Pulse AMD Radeon RX6600, 8GB GDDR6 i kingstone fury memoriju (2x 8gb) 3600 mhz, CL17.
Uzet cu terabajt ili dva na ssd-u. Koje hladenje i koje napajanje mi preporucate? Takoder trebam li nesto promijeniti.
Hvala
Kokolinac je offline   Reply With Quote
Staro 25.11.2023., 19:31   #11767
ibme74
ibme74's Avatar
Postovi: 1,632
pa kad već ideš na 5800x3d mogao si i neku jaču grafu uzeti (osim ako ne gamaš isključive esport igre i ostale MP gdje ionako većina postavki ide na low i off).
Koji je budžet za cooler i napajanje?
Staro 25.11.2023., 19:42   #11768
Kokolinac
Lokacija: GB
Postovi: 5
Nekih 200-300€ ne vise. A koju graficku preporucas?
Staro 25.11.2023., 20:00   #11769
ibme74
ibme74's Avatar
Postovi: 1,632
pa barem rx6700/6700xt, idealno rx6800/6800xt.
1 * BF - ID-Cooling CPU Cooler - SE-206-XT
Šifra: SE-206-XT-16542
1 * BF - XPG CORE REACTOR 750W Gold Modular
Šifra: 0001240980--16320
Sveukupno s popustom: 158,00 €
Staro 25.11.2023., 20:07   #11770
Kokolinac
Lokacija: GB
Postovi: 5
A jel znas gdje mogu nabaviti to?
Staro 26.11.2023., 11:02   #11771
gogoklepci
Datum registracije: Sep 2019
Lokacija: Mostar
Postovi: 365
Zadnje izmijenjeno od: gogoklepci. 26.11.2023. u 11:43.
gogoklepci je offline   Reply With Quote
Staro 26.11.2023., 20:29   #11772
ibme74
ibme74's Avatar
Postovi: 1,632
taj zalmanov cpu nema podršku za AM5 a ionako je drek kupnja s obzirom da je više plastike nego heatsinka na njemu, ID-Cooling CPU Cooler - SE-206-XT puno bolja kupnja i još jeftiniji 3€
Staro 09.12.2023., 21:40   #11773
NTN
Postovi: 230
Trebao bih preporuku za komponente u konfiguraciji koja bi bila all around s malom prednošću za gaming. Nvme ssd je kupljen, monitor bi bio 27" 2K(nije u okviru ovog iznosa). Iznos od 1000-1100 Eur za komponente, može nešto više ako bi se dobila neka zamjetna razlika.
NTN je offline   Reply With Quote
Staro 09.12.2023., 22:07   #11774
ibme74
ibme74's Avatar
Postovi: 1,632
1 * AMD CPU Desktop Ryzen 5 6C/12T 5600 (3.6/4.2GHz Boost,36MB,65W,AM4) Box
Šifra: 100-100000927BOX
1 * ID-Cooling CPU Cooler - SE-224-XTS
Šifra: SE-224-XTS
1 * Matična ploča Asus PRIME B550M-A 90MB14I0-M0EAY0
Šifra: 0001221296
1 * KINGSTON 32GB 3600MHz DDR4 CL18 DIMM KF436C18BBK2/32
Šifra: 4245000
1 * XFX AMD Video Card RX-6800 SWFT 319 CORE 16GB GDDR6 256bit, 2105 MHz / 16Gbps, 3x DP, HDMI, 3 slot, 3 fan
Šifra: RX-68XLAQFD9
1 * MSI MAG A750GL PCIE5, 750W, 80 Plus Gold, ATX Form Factor, 100~240 Vac Input Voltage, 47Hz ~ 63Hz Input Frequency, 120 mm Fan, 140 x 150 x 86mm, Active PFC, OCP, OVP, OPP, OTP, SCP, UVP, ATX, 2xEPS, 4
Šifra: MAG_A750GL_PCIE5
Šifra: GEPH-164
Sveukupno s popustom: 1086,99 €
Besplatno slaganje i dostva
Staro 10.12.2023., 10:02   #11775
7carlos6
7carlos6's Avatar
Lokacija: Senj
Postovi: 238
Pozdrav,
kćer mi želi kupiti komp i traži me savjet, a ja sam malo zahrđao i baš ne pratim ni tržište ni komponente baš previše. Komp bi bio uglavnom za gaming. Uglavnom ona i dečko su našli ovo: https://www.instar-informatika.hr/ra...6ymgyXdIlUxGv0
Ja baš i nisam sklon kupovini gotovih konfiguracija (ne piše marka napajanja itd.)
Može li se za te novce složiti nešto bolje? Ja san malo skloniji AMD-u.
Zadnje izmijenjeno od: 7carlos6. 10.12.2023. u 17:44.
7carlos6 je offline   Reply With Quote
Staro 10.12.2023., 10:39   #11776
ibme74
ibme74's Avatar
Postovi: 1,632
nikada prebuild konfe ne uzimati.
Staro 10.12.2023., 13:50   #11777
7carlos6
7carlos6's Avatar
Lokacija: Senj
Postovi: 238
Autor ibme74 Pregled postova
Ne znam, za prvu ruku bi bio spojen na neki 4k Samsung tv. Monitor će kupovati naknadno.
Staro 10.12.2023., 17:06   #11778
ibme74
ibme74's Avatar
Postovi: 1,632
moraš reći rezoluciju i refresh rate ako zelis dobiti najoptimalniju konfu
Staro 10.12.2023., 17:38   #11779
7carlos6
7carlos6's Avatar
Lokacija: Senj
Postovi: 238
Trenutno bi kristili ovo https://www.samsung.com/hr/tvs/uhd-4...e55au7172uxxh/
a kroz neko vrijeme bi uzimali monitor.
Staro 10.12.2023., 19:08   #11780
ibme74
ibme74's Avatar
Postovi: 1,632
pa koji monitor bi kupili to te pokušavam pitati
Staro 10.12.2023., 20:14   #11781
7carlos6
7carlos6's Avatar
Lokacija: Senj
Postovi: 238
E to stvarno ne znam jer još im baš nije u planu. Ima još dosta renoviranja i svašta nešto.
Staro 10.12.2023., 20:17   #11782
listerstorm
listerstorm's Avatar
Datum registracije: Apr 2011
Postovi: 1,431
Pozdrav,
Je li ovo OK?
Zasad imam 1080p60 monitor, uzeo bih za mjesec-dva 1440p.
AMD
MSI Mainboard MAG B650 TOMAHAWK WIFI
ID-Cooling CPU Cooler - SE-224-XTS ARGB
AMD Ryzen 5 7600 Box AM5
Corsair 2X16GB DDR5 6000 C36
Kingston 1000GB/1TB NV2 M.2 2280 PCIe 4.0 NVMe SSD, up to 3500/2100MB/
Gigabyte RX7800XT GAMING OC, 16GB
Napajanje Seasonic B12 BC-750 Bronze
Kućište Lian Li Lancool 216 RGB E-ATX
1.540,69 EUR
INTEL
Asrock Intel LGA1700 Z790 PG LIGHTNING
INTEL Core i5-13600KF 3.5GHz LGA1700
1.610,89 EUR
Ne mogu se odlučiti...cijena je približna, stavio sam DDR5 u obje konfiguracije.
I dodatno, nisam siguran za grafičku. Stavio sam RX 7800 XT no razmišljam i o RTX 4070.
EDIT: I kako bi 1440p radilo na 4K OLED-u pošto grafa i nije baš za 4K?
Zadnje izmijenjeno od: listerstorm. 11.12.2023. u 07:44.
Staro 10.12.2023., 23:48   #11783
Okec
Postovi: 2
Bok svima,
Molim vas preporuku za konfu. (bez periferije) i monitor. Budžet cca 1200e samo za pc. Kupujem na rate.
Treba mi za:
1) video montažu za youtube kanal.
2) audio montažu i snimanje el.gitare -skladanje pjesama.
Video montaža mi je prioritet, znači ne bi volio da mi u video softwareu trza čim primijenim par efekata prijelaza. Pretpostavljam da je potrebna dobra grafička i dosta rama. Ne znam koje druge parametre moram gledati kod izbora komponenti za ovo što mi treba.
Za audio montažu sam na stranim forumima našao neke savjete, mozda pomogne:
- da je bitnije da su jezgre pojedinačno brze nega da ih ima više (ne znam da li je ovo istina)
-brzi ram, mogućnost nadogradnje
-matična sa puno ulaza - spajanje vanjskih audio interfejsa,..
- dobar integrirani zvuk
- usb 2, 3
-brzi ssd
- 2 diska, npr 1 ssd za software i os, i jedan hdd za projekte. Je li to baš potrebno?
Također molim i preporuku koji monitor je dobar za video montažu, znači koji refresh rate, kakav panel, ips ili VA. Nemam 4k kameru za sad, da li je ok uzeti 4k monitor da imam za budućnost?
Razmišljam o 24in. Da li bi 28in bilo previše?
Hvala unaprijed!
Okec je offline   Reply With Quote
Staro 11.12.2023., 13:55   #11784
ibme74
ibme74's Avatar
Postovi: 1,632
7carlos6
1 * AMD Ryzen 5 7600 Box AM5
Šifra: AMD-100-100001015BOX
1 * Asrock AMD AM5 B650M PG RIPTIDE
Šifra: ASR-B650M PG RIPTIDE
1 * Corsair 2X16GB DDR5 6000 C36
Šifra: COR-CMK32GX5M2E60C36
1 * Gigabyte RX7800XT GAMING OC, 16GB GV-R78XTGAMING OC-16GD
Šifra: gig-r7800xtgoc-16g
1 * SSD Western Digital*Black™ SN770 1TB M.2 NVMe WDS100T3X0E
Šifra: 0001291195
1 * Kućište ENDORFY Regnum 400 Air
Šifra: EY2A008
Sveukupno s popustom: 1465,69 € (-2%=1.435€)
listerstorm
Može se ugurati i jača grafa:
Šifra: 0001291195
1 * XFX AMD Video Card RX-7900XT Speedster MERC310 20GB GDDR6 320bit, 2535 MHz / 20Gbps, 3x DP, 1x HDMI, 3 fan, 2 slot
Šifra: RX-79TMERCU9
1 * GIGABYTE Mainboard Desktop B650M D3HP (AM5, 4xDDR5, 1xHDMI, 2xDP, 2.5GbE LAN, mATX, Retail)
Šifra: B650M D3HP
1 * Kućište DeepCool CC560 Crno
Šifra: HAZDEECC560
Sveukupno s popustom: 1698,90 € (-2%=1.664€)
Okec
1 * Intel CPU Desktop Core i5-13400F (2.5GHz, 20MB, LGA1700) box
Šifra: BX8071513400FSRMBN
1 * ID-Cooling SE-226-XT BLACK
Šifra: SE-226-XT BLACK
1 * Gigabyte B760 Gaming X, DDR4, s1700 B760 GAMING X DDR4
Šifra: gig-b760-gx-d4
Šifra: 4245000
1 * GIGABYTE Video Card NVIDIA GeForce RTX 3060 WINDFORCE OC 12G GDDR6 12GB/192bit, PCI-E 4.0 x16, 2xHDMI, 2xDP, WINDFORCE 2X, Retail
Šifra: GV-N3060WF2OC-12GD
Šifra: 0001291195
1 * Zalman S2 Mid Tower Case
Šifra: ZAL-S2
Sveukupno na rate: 1.244,78 € (-2%=1.219€)
Staro 13.12.2023., 00:31   #11785
Okec
Postovi: 2
Ibme74
Hvala ti, budem proučio komponente, a može i savjet za monitor koji bi dobro legao za video montažu? Ne znam koji regresh rate gledat itd..? Cca 200eur, moze i manje
E da, i koji je to dućan, može na pm
Staro 08.01.2024., 11:17   #11786
prileee
laser
prileee's Avatar
Postovi: 2,356
Trebam preporuku za kolegu kako nisam u toku s novijim komponentama. Trazi kanta+monitor kombinaciju za video obradu, adobe premiere.
Naletia je na ovu ponudu na marketplaceu za 1200 eur, sta meni zvuci puno previse za "star" procesor i platformu:
Pa ako moze komentar jesam li u pravu da je ovo preskupo za polovno i ako moze preporuka za kanta+monitor za navedenu upotrebu u rangu 1000-1200 eur, novo, po mogucnosti sa windowsima i slaganjem.
Staro 08.01.2024., 11:39   #11787
bambi56x
bambi56x's Avatar
Postovi: 357
Novo za te novce ide ovako, teško je išta drugo pametno staviti, jedino možeš posebno dijelove zatražit po volji, ali glavni dio je taki (proc, grafa, ram). Ostane <200 eurića za kaki QHD monitor, ili ima onaj jeftini LG 4K ako je potrebno(27UL550p-W).
U dijelovima ovako nekako:
LG 27UL550P-W, 27" IPS, 4K, HDMIx2, DP, HDR10
CPU AMD Ryzen 7 5700X BOX, AM4, 100-100000926WOF
Gigabyte B550M DS3H, AMD B550, AM4
LC-POWER Cosmo Cool LC-CC-120 intel/AMD
DDR4 32GB (2x16) G.Skill 3600Mhz Ripjaws V, F4-3600C18D-32GVK
Samsung SSD 1TB 970 EVO PLUS M.2, MZ-V7S1T0BW, 600TBW
Palit RTX3060 Dual 12GB, NE63060019K9-190AD, LHR
Zalman Midi Tower S2 Black
Napajanje Fortron 600W Hydro K PRO, 80 PLUS Bronze, PPA6005605
Zajedno 1190 eura, no bez Windowsa i slaganja.
Cijene su za gotovinu/odjednom u oba slučaja.
Edit: brzam nešto danas. Ako je potreban quicksync, može proc i ploča se zamijenit samo na 12400/13400 i B660/760 ploča (B760M-DS3H recimo).
Zadnje izmijenjeno od: bambi56x. 08.01.2024. u 12:06.
bambi56x je offline   Reply With Quote
Staro 08.01.2024., 17:16   #11788
ibme74
ibme74's Avatar
Postovi: 1,632
1 * AOC LCD 27", 2560x1440, 4ms, 16:9
Šifra: AOC-Q27V4EA
1 * AMD CPU Desktop Ryzen 7 8C/16T 5700X (3.4/4.6GHz Boost,36MB,65W,AM4) Box
Šifra: 100-100000926WOF
1 * CPU Hladnjak ENDORFY Fera 5 Dual Fan
Šifra: EY3A006
1 * KINGSTON 32GB 3200MHz DDR4 CL16 DIMM KF432C16BB1K2/32
Šifra: 4244810
Šifra: 0001291195
Šifra: HAZDEECC560
1 * ASUS Dual GeForce RTX 3060 V2 OC DUAL-RTX3060-O12G-V2
Šifra: 4214702
1 * Gigabyte B550M DS3H , AM4, mATX GAB55MDSH-00-G12
Šifra: gig-b550m-ds3hi
Sveukupno s popustom: 1221,90 € (-2%=1.196€)
Za Windows najbolje da sam skine Win po zelji sa MS stranice, instalira i onda za par € kupi aktivacijski ključ na netu mjesto da za istu stvar da trgovini cca 100€.
Osim ako se kanta ne uzima na firmu onda mora uzeti Windows iz trgovine.
Staro 09.01.2024., 21:52   #11789
Smartic
Smartic's Avatar
Datum registracije: Mar 2011
Postovi: 2,707
Kućište Thermaltake S100 TG Micro
Crucial SSD P3 1000GB/1TB M.2 2280 PCIE Gen3.0 3D NAND, R/W: 3500/3000 MB/s, CT1000P3SSD8
GIGABYTE NVIDIA GeForce RTX 3060 WINDFORCE OC 12G GDDR6 12GB/192bit, PCI-E 4.0 x16, 2xHDMI, 2xDP, WINDFORCE 2X
LG 27UL550-W, 68,6cm/27'' (3840x2160), 5ms, 16:9, IPS, 2xHDMI, DP, VESA Pivot, Speaker, UHD
Matična ploča Asrock B650M PRO RS- micro ATX - Socket AM5
T-FORCE VULCAN - DDR5 - kit - 32 GB: 2 x 16 GB - DIMM 288-pin - 6000 MHz / PC5-48000 - unbuffered
AMD AM5 Ryzen 7500F Tray 3,7GHz 6x Core 65W Boost 5 GHz 32MB Cache
Hladnjak Thermalright Assassin X 120 SE (1200/1700/AMD)
Napajanje 750W, ANTEC Cuprum Strike CSK 750H, 120mm vent., 80+ Bronze, semi-modular
Ukupno: 1.243,60 €
Staro 10.01.2024., 23:23   #11790
prileee
laser
prileee's Avatar
Postovi: 2,356
Hvala svima, prenio sam prijedloge dalje!
