Staro 08.11.2023., 15:02   #2701
strikoo
strikoo's Avatar
Postovi: 964
strikoo je offline   Reply With Quote
Staro 08.11.2023., 19:59   #2702
mkey
Datum registracije: Sep 2018
Lokacija: tu
Postovi: 3,469
Meni je slično i linux napravio u par navrata (kako koja distribucija) pa je boot loader znao završiti svakuda. Ali za windows to je garant.
A vađenje M2 diskova je tlaka. Pogotovo ako na taj disk misliš staviti home.
Staro 08.11.2023., 20:37   #2703
medo
#erase startup-config
medo's Avatar
Postovi: 3,714
Ovisi koj distra. Obično te kod instalacije OSa pita na koji divajs želiš instalirati boot loader.
Staro 08.11.2023., 20:43   #2704
domy_os
domy_os's Avatar
Postovi: 18,858
Najbolje sve manualno, pogotovo kad se instalira u kombinaciji s LUKS-om, nema greške.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 08.11.2023., 21:12   #2705
mkey
Lokacija: tu
Postovi: 3,469
Ne sjećam se više koji je instaler bio u pitanju, ali znam da me jednom prilikom nije niti pitao kamo želim da instalira. Pa je sam gađao i promašio.
Staro 23.11.2023., 05:47   #2706
tomek@vz
tomek@vz's Avatar
Postovi: 4,885
Ako koristite OpenZFS 2.2 - updejt sto prije moguce.
Those using OpenZFS 2.2 will want to update to OpenZFS 2.2.1 right away. A block cloning bug was uncovered that is causing data corruption issues for users.
Gentoo users reported a block cloning bug where some copied files are corrupted. Chunks are being replaced by zeroes. This has happened to multiple OpenZFS 2.2 users. With OpenZFS 2.2.1 they have resorted to disabling block cloning by default. Block cloning was one of the new features of OpenZFS 2.2 but is now deemed not stable and shouldn't be enabled by default.
Staro 23.11.2023., 09:13   #2707
Nick7
Lokacija: Velika Gorica
Postovi: 1,524
.. osim ako koristite LUKS.
https://github.com/openzfs/zfs/issues/15533
Bas su napravili fijasko sa 2.2 verzijom...
Inace, sa 2.2.0 je dosta disejblati feature za block cloning.
Mmda... block cloning feature se moze samo enable/disable kod kreiranja poola.
Staro 23.11.2023., 10:25   #2708
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,766
Bog te blagoslovio.
Staro 23.11.2023., 10:32   #2709
tomek@vz
tomek@vz's Avatar
Postovi: 4,885
Nedam se ja od LVM+EXT4 / XFS nikak
Staro 23.11.2023., 18:20   #2710
mkey
Lokacija: tu
Postovi: 3,469
Ako se sjećate mojeg relativno nedavnog slučaja s neprepoznatim USB-C portom na B550...
Bilo je na kraju dio vusranog biosa. Neki dan sam išao skinuti novi bios (mislim da sam onaj prethodni montirao pred kakvih 7 mjeseci) i port je magično proradio. Tako da predmetni USB-C hub prenosi LAN bez problema, ali eto vidiš nisam probao da li bi i sliku dao kroz to.
Edit: jok, ne daje sliku. Možda bi to i radilo da matična ima integriran video izlaz??
Staro 24.11.2023., 09:30   #2711
Nick7
Postovi: 1,524
Eto.. ispada da nije ZFS 2.2.0 uzrok korupcije, vec od prije issue.. i to od 2.1.4 verzije, ali je block cloning samo 'izvukao' to na povrsinu.
https://www.reddit.com/r/zfs/comment...ta_corruption/
Staro 24.11.2023., 16:55   #2712
strikoo
strikoo's Avatar
Postovi: 964
sva sreća da mi je sve bitno da na ntfsu
Staro 24.11.2023., 17:05   #2713
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,245
Za kucne stvari uvijek ext4.
Staro 25.11.2023., 01:46   #2714
Ivo_Strojnica
PRO
Postovi: 4,766
Autor strikoo Pregled postova
Pa neloš izbor, NTFS je super filesystem.
Staro 25.11.2023., 06:27   #2715
tomek@vz
tomek@vz's Avatar
Postovi: 4,885
Pa i je
https://duckduckgo.com/?q=ntfs+data+...=v404-6&ia=web
Uvijek ima takvih buhica al mora se razlikovat izolirane probleme (ZFS gore) od poluproizvoda (BTRFS).
Staro 25.11.2023., 12:46   #2716
strikoo
strikoo's Avatar
Postovi: 964
nema za što nećeš naći bugove tako
Staro 25.11.2023., 13:47   #2717
mkey
Lokacija: tu
Postovi: 3,469
Što bi bio najbolji izbor za format diska kojeg bih dijelio između linuxa i Spyware OSa?
Staro 25.11.2023., 15:12   #2718
strikoo
strikoo's Avatar
Postovi: 964
linux skroz ok radi sa ntfsom. sto se za windows i ext4 ne može reći .
Staro 25.11.2023., 15:14   #2719
tomek@vz
tomek@vz's Avatar
Postovi: 4,885
Autor mkey Pregled postova
NTFS naravno.
Staro 25.11.2023., 15:34   #2720
mkey
Lokacija: tu
Postovi: 3,469
NTFS mi sa ove strane ima stvarno loš write speed. Što bi bilo OK, kada bih koristio windowse, a linux povremeno. Ali kako sam 99+% na linuxu, to mi stvarno nema smisla. Tako sam i krenuo, sa NTFS diskom i nije išlo nikako.
Pa sam se prebacio na BTRFS ali onda gledam write speed na SATA SSD je isto tako očajan, i to s linux strane. Windows ima nekakav BTRFS driver koji je dovoljno dobar za tih <1% koliko meni treba.
Staro 25.11.2023., 16:01   #2721
tomek@vz
tomek@vz's Avatar
Postovi: 4,885
Zaboravi na to sve. NTFS ili nista.
Staro 25.11.2023., 16:02   #2722
Postovi: 23,534
A kakav je ext drajver za winse ?
Stabilnost, brzine ?
Staro 25.11.2023., 16:30   #2723
tomek@vz
tomek@vz's Avatar
Postovi: 4,885
Autor Nikky Pregled postova
NTFS je bolja opcija. A gle iskreno nisam se nikad zamarao s tim, tak je kak je i to je to. Windows ionak tu i tam instaliram samo ako hocu neku igru probat koja prek wine/proton ne radi. Moze probat kemijat sa mount opcijama ntfs-3g drivera al trebalo bi cekirat dokumentaciju.
https://superuser.com/questions/1400...isk-from-linux
Bas napravio mali test i fakat je koma. Read je 700 MB/s a write 160-180 MB/s - 2 identicna Sandisk nvme ssd-a. Vid vraga :P
Zadnje izmijenjeno od: tomek@vz. 25.11.2023. u 16:35.
Staro 25.11.2023., 16:58   #2724
Postovi: 23,534
Znači, radi ali za kua 😆
Za kakvo krpanje može i to sporo.
Staro 25.11.2023., 17:15   #2725
mkey
Lokacija: tu
Postovi: 3,469
4k je i gori, kopiranje parsto hiljada fajlova je baš gnjavaža. Opet, nije da mi je ne znam koliko bitno, nego mi nema smisla da si okljaštram postojeći hardware zbog spomenutih 1%.
Staro 25.11.2023., 17:17   #2726
c-shadow
c-shadow's Avatar
Postovi: 3,479
@tomek
ntfs-3g je userspace = sporiji by design.
Od kernela 5.15 nadalje imaš kernel driver ntfs3. Performanse bi trebale biti nešto bolje, ali kako je to dosta svježi kod, mogući su problemi.
@mkey
Ako je za 1%, briga te koji je ntfs driver u linuxu, potrpiš se to što je sporo
Staro 25.11.2023., 17:28   #2727
medo
medo's Avatar
Postovi: 3,714
Osim kad nije
Događalo mi se da kod migracije podataka nešto ne mogu pročitati sa NTFS particije. Obično bi mi javio read error na fajlu a jednom i na cijelom folderu.
chkdsk - nula bodova
Disk je fizički OK ali Windoze ne mogu doći do fajle.
NTFS radi skoro svuda, a postoji more i more alata za izvlačenje podataka iz NTFSa. I prilično je stabilan.
exfat?
Staro 25.11.2023., 17:29   #2728
mkey
Lokacija: tu
Postovi: 3,469
1% SpywareOS je frende, hvala bogu na tome. Da je obratno onda to ne bi bilo niti bitno jer bi to značilo da sam brain dead
I nije to toliko bitno, nego sam nekako slavodobitno sve prebacio na BTRFS kada sam saznao za windows driver, da bih onda skužio da to nije isto neko pretjerano dobro riješenje. Iako se čini bolje nego NTFS. Doduše, primijetio sam da u windowsima preko tog drivera neke stvari baš i ne rade, recimo dism. Moguće da je problem bio u dužini putanje ili nečem sličnom.
Mislim da budem pustio za sada tako kako je. Ili možda napravim jednu manju BTRFS particiju koja bude sherana a sve ostalo ode na EXT.
@medo možda u tom slučaju odraditi sfc /scannow? Više puta mi je to sranje rješavalo razne probleme. Čak i kada mudro javi kako je našao greške ali ih nije uspio ispraviti
Staro 25.11.2023., 17:57   #2729
c-shadow
c-shadow's Avatar
Postovi: 3,479
Evo nešto za vas koji volite riskirati
https://github.com/maharmstone/ntfs2btrfs
Code:
Ntfs2btrfs is a tool which does in-place conversion of Microsoft's NTFS filesystem to the open-source filesystem Btrfs,
Staro 25.11.2023., 18:00   #2730
mkey
Lokacija: tu
Postovi: 3,469
Evo, dao sam si malo truda. Na Samsung 980 Pro 2TB SSD disku sam napravio 7 particija od 100 GB, raznih formata. Kernel 6.1 na manjaro. Nisam testirao na predmetnom SATA SSD pošto je na njemu tona raznog sranja.
Testiranje sam odradio sa fio - 4k RW, 512m, x5 (fio --name=random-write --ioengine=posixaio --rw=randwrite --bs=4k --numjobs=5 --size=512m --iodepth=1 --runtime=60 --time_based --end_fsync=1)
Prvi broj dolje je write, drugi je min - max range (x5 je zbog 5 taskova, pretpostavljam). IO čini ukupan promet u datih 60 sekundi, ako dobro razumijem fio ugura u dato vrijeme više iteracija zadatih ciklusa, koliko god stigne.
Code:
BTRFS: WRITE: bw=208MiB/s (218MB/s), 40.9MiB/s-42.1MiB/s (42.9MB/s-44.1MB/s), io=12.2GiB (13.1GB), run=60273-60274msec
EXFAT: WRITE: bw=513MiB/s (538MB/s), 102MiB/s-104MiB/s (106MB/s-109MB/s), io=30.2GiB (32.5GB), run=60113-60350msec
EXT2: WRITE: bw=1296MiB/s (1359MB/s), 254MiB/s-269MiB/s (266MB/s-282MB/s), io=76.5GiB (82.1GB), run=60043-60437msec
EXT3: WRITE: bw=1299MiB/s (1362MB/s), 256MiB/s-265MiB/s (268MB/s-278MB/s), io=76.3GiB (81.9GB), run=60015-60117msec
EXT4: WRITE: bw=1185MiB/s (1242MB/s), 232MiB/s-248MiB/s (243MB/s-260MB/s), io=69.7GiB (74.9GB), run=60049-60270msec
XFS: WRITE: bw=1542MiB/s (1617MB/s), 300MiB/s-317MiB/s (314MB/s-332MB/s), io=90.8GiB (97.5GB), run=60202-60319mse
NTFS: WRITE: bw=1231MiB/s (1291MB/s), 240MiB/s-254MiB/s (251MB/s-267MB/s), io=72.6GiB (77.9GB), run=60188-60327msec
Po ovom letimičnom testu ispada da BTRFS unosi penal od preko 80%, e bogati. A NTFS al pari sa EXTx. A xfs najbrži.
Subjektivni dojmovi su jebena stavka A možda se NTFS linux podrška popravila od kada sam to koristio zadnji puta, prošlo je nešto vremena.
