Staro 27.10.2023., 14:57   #2671
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,409
Autor strikoo Pregled postova
Moram podijeliti neke s vama
<iframe width="560" height="315" src="https://www.youtube.com/embed/PivpCKEiQOQ?si=fk-gMaKS-Givwa2i" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" allowfullscreen></iframe>
<iframe width="560" height="315" src="https://www.youtube.com/embed/lE4UXdJSJM4?si=vw3wAnkJmaAr8TKq" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" allowfullscreen></iframe>
<iframe width="560" height="315" src="https://www.youtube.com/embed/9n1dtmzqnCU?si=3CDhwa0qBtlkLIEc" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" allowfullscreen></iframe>
Hebote sta je forum potrgan....
Staro 31.10.2023., 21:19   #2672
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,414
Imam na 1 lapu dual boot, ubuntu i mint. međutim nakon nekih updatea ubuntua, mint je nestao, tj nestao mi je meni za dual boot. Može li se to ikako popraviti?
U linux se ne kužim skoro pa niš, ovo samo malo eksperimentiram, pa bi mi trebalo malo detaljnije objasnit.
EDIT: Brzinsko guglanje mi veli da pokrenem mint live sa USB-a i popravim ''grub'' menu...to je koliko sam shvatio linuxov boot menu.
Slobodno me dodajte na PSN
Zadnje izmijenjeno od: Disco. 31.10.2023. u 21:25.
Staro 31.10.2023., 21:24   #2673
strikoo
strikoo's Avatar
Postovi: 1,038
To re-enable os-prober uncomment the following line in /etc/default/grub:
#GRUB_DISABLE_OS_PROBER=false
update-grub
strikoo je offline   Reply With Quote
Staro 31.10.2023., 22:15   #2674
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,414
Ovo je genijalno, ubacim live mint i on u sebi ima boot repair.
napiše mi da će to riješit samo ako upalim UEFI/seucre boot.
Upalim, odradi majstorski posao, i još mi spominje kako je grub na sda4 što mi je mint particija (2 particije su na istom SSDu)....prčka drlja i svašta nešto.
Restartam i pojavi se grub samo sa ubuntuom.
inače do tog gruba sam došao i ranije lupajući po shiftu i f8 jer ne znam koja je točno tipka...pokušaj br 2, reinstalirat sam mint kao in-place upgrade ako ima takva opcija.
EDIT: OK, ja sam panj tj zeznuo me GRUB, opet probao i u grubu vidim ubutnu LTS bla bla i samo ubuntu....e taj samo ubutnu je mint.
dakle riješeno.
Nakon toga u mint terminalu ''sudo update-grub'' i sada sve piše ispravno.
Eto, naučio sam nešto novo. dakle ovo što je strikan napisao, samo sam na netu anšao varijantu za idiote.
EDIT2: zab napomenut, linux tj bar mint nema ugrade sa live-a, samo ponovni install...e to nije kul.
Nego pitanjce, ima li linux neku varijantu device managera pa da npr diseableam BT za stalno, a ne da mi se ponovno upaljen kod svakog restarta (ovo win npr pamte ako ga samo ugasim, a ne diseableam...)?
Zadnje izmijenjeno od: Disco. 31.10.2023. u 22:37.
Staro 01.11.2023., 01:12   #2675
Postovi: 10,331
Fedora i remote gaming - saga jos traje Nisam ocekivao da cu bas tjedan dana izgubiti na to.
Steam link mi je radio, ali trzuckavo. Gasenjem waylanda je bilo nesto bolje, ali i dalje nije to to.
Neki dan sam nanovo roknuo Fedoru (kao, cisti start, toboze) i vise ne uspijevam dobiti Steam link, jednostavno se ugasi kad se hocu spojiti. Cudno... Ugl otpisao sam ga, nisam bio zadovoljan.
Moonlight koji se spaja na Gamestream mi ne prolazi zbog nekakvih firewall problema ako mu je vjerovati. Svi firewallovi su ugaseni, pa ne znam odakle sad to.
Sunshine na hostu i Moonlight na klijentu rade i izgledaju odlicno, jako jako dobro. Ali ne radi mi zvuk na stock postavkama. Vjerojatno negdje moram nesto kliknuti. S obzirom da i jedan i drugi app imaju predetaljnu dokumentaciju, vjerojatno ce mi trebati jos koji dan.
E da, totalno glupo ali nemam pojma gdje upisujem taj GDK_BACKEND=x11. Znaci guglao sam to valjda ise puta u 3-4 dana i nalazim samo neke cudne nepotpune odgovore. Imam filing kao da je nesto tako glupo i logicno u pitanju da od sume ne vidim stablo.
Bas je sjebano preci na linux desktop tako na naglo, makar si godinama brljavio s headless hardverom. Ne volim onaj filing "sad trebam nesto napraviti, a gdje je to uopce i odakle krenuti i koji od tri nacina odabrati". Ko teski njub. I konstantan filing "oke ako sad nesto sjebem, uopce ne znam sto moram napraviti da to ispravim". Jedna radnja vodi ka tri otvorena taba s guglom
Mozda do bozica i dignem koju virtualku ili kontejner... Eh da, treba savladati i taj KVM a taman se uhodao s Proxmoxom kojeg sam stavio po strani.
Staro 01.11.2023., 07:19   #2676
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,409
Autor Disco Pregled postova
Izmjenis verziju sa postojece na onu koju zelis azurirat u /etc/apt/sources.list i lupis apt update && apt upgrade. Default na svim Debian based distrama.
https://itsfoss.com/upgrade-linux-mint-version/
Sto se BT tice - pa iskljuci ga jednostavno u softweru i amen. Ako ga bas zelis na HW razini iskljuciti morao bi disejblat loadanje kernel modula zaduzenog za to (nikaj kliki klik).
Autor xlr Pregled postova
U konzolu? Al napominjem opet - samo ako je Wayland aktivan - ak nije - ne moras. Dakle da nebi bilo zabune:
1. otvoris terminal
2 upises "GDK_BACKEND=x11 remmina"
I otvoris na taj nacin Remmina aplikaciju u X11 modu.
Kaj se tice Steam Link problema nemam pojma kaj bi ti reko, kod mene radi bez greske:
1. glavni komp spojen na 1GB LAN kablom
2. Ipad spojen na WIFI, instaliran Steam Link - radi
3. Samsung smartphone spojen na WIFI, instaliran Steam Link - radi
Da tebe mozda kvaliteta lokane mreze ili preslaba grafa ne zezaju? Znam da sam imao slicnih problema na Ryzenovoj integrusi i kad je komp visio na WLAN-u. Odkad je RX6600 u kompu i komp na LAN-u nema problema.
"Those are rookie numbers"
Staro 01.11.2023., 08:01   #2677
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,414
@tomek: nisi me shvatio. Pod in place upgrade sam mislio kao sa win. Skinem win iso, stavim na USB stick i bootam, te onda sa sticka napravim upgrade ili stavim identičnu verziju win preko postojeće, sa time da mi zadrži profil i sve instalirano. E to mint nema, barem ja nisam našao, nudio mi je samo opcije kompletno nove instalacije.
Ovo što si mi ti ponudio je sve upgrade na noviju verziju iz samog minta, pa to ima sam mint u update centeru.
A BT želim skroz ugasit jer ako ga ugasim softverski, kod svakog restarta se ponovno pali. Znači linux nema device manager, nego ga moram deinstalirati preko terminala. Fala
Zadnje izmijenjeno od: Disco. 01.11.2023. u 08:44.
Staro 01.11.2023., 08:17   #2678
Postovi: 10,331
Kod mene je sve stock, znaci Wayland aktivan.
Ta naredba nije permanentno rjesenje, ne prezivi reboot, ili?
Mda, Steam Link je nesto sj* na mom kraju jer se rusi. Jucer je radio, ma jucer sam imao drugu instalaciju Fedore. Bit ce jos jedan gugl tab!
Kod mene je sve na zici, imam vec iskustva sa Steam Linkom na drugim uredjajima. Grafa je najmanji problem. Zadnjih pola godine se bas nista nije mijenjalo po tom pitanju (mreza, setup, kablovinje) osim sto su kompovi dobili i7 procesore. Iperf3 baca vise nego uredne brojke.
Ovaj Sunshine radi bogovski i filing je kao da igram na hostu, ne vidim nikakve mane. Mislim da cu njega zadrzati, samo da skuzim to oko zvuka.
Staro 01.11.2023., 09:09   #2679
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,409
To ni s Windowsima ne radim za Boga miloga In place upgrade na Linuxu znaci ovo sto sam ti opisao. Nikakvi CD-i, ISO-i i ostala sranja. Fedoru na glavnom kompu upgrejdam na isti nacin vec 4 godine. Kaj se BT tice - Gnome sucelje pretpostavljam - taj bug mi je poznat , jednostavno ga ignoriram posto nije lap. Bluetooth mozes deaktivirat na vise nacina. Najjednostavnije ti je u tom slucaju deaktivacija servisa:
systemctl disable bluetooth
Alternativno ak ne pomogne probaj kroz tlp ga kontrolirat:
https://askubuntu.com/questions/1047...off-as-default
Tom naredbom startas aplikaciju. Ako hoces uvijek tako - moras implementirat kao alias u bashrc ili u desktop fajl.
Ak ti se shebe app samo zbrisi lokalni config (/home/<user>/.config/<put do foldera> i/ili sve .<app> folder u tvom Home.
Sunshine nisam nikad koristio no cekiraj sto po deafultu koristio kao Audio Sink - default bi trebalo biti pulse. I kolko vidim da se korisnici zale i na Win i Linux - cekiraj bitrate:
https://duckduckgo.com/?q=Sunshine+n...401-2__&ia=web
Staro 01.11.2023., 17:39   #2680
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,414
Vjeruj mi popravilo mi je winse više puta na taj način, doma sam radio 1, ali na poslu sam to napravio više puta. Znam da je uvijek bolja friška situacija, ali u enterprise orkuženju gdje netko ima omanju hrpicu razno-raznih programa za koje ni sam ne zna čemu mu sve služe je uvijek brže i jednostavnije skarabuđit da radi u npr 1-2h, nego izgubiti 8+h da mu sve napraviš ispočetka. Plus korisnik nema to vrijeme, mora radit.
Hvala za BT prijedlog. Čudilo me kako se identičan problem dešava i u Ubuntuu i u Mintu, onda skužim da su oba bazirana na istom kernelu/distribuciji ili kako se to već veli kod Linuxa.
Ugl, ovo mi služi za učenje, winsi su mi i dalje go to OS na laptopima jer baterija traje osjetno dulje čak i nakon što sam instalirao neko čudo na Linux za uštedu (3 slova nešto, ne sjećam se imena, ali interneti su to preporučili).
Staro 01.11.2023., 18:12   #2681
strikoo
strikoo's Avatar
Postovi: 1,038
snapappimagewatthever ?
probaj zbildati moonlight iz sorsa ako ne pomogne nešto s google.
jutros sam zbildao na debianu. out of the box sve šljaka
Staro 01.11.2023., 18:26   #2682
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,409
TLP Pocinjem se pitat jel uopce itko cita tutorijal
A kaj se ovog nacina upgrejda tice - ima distribucija koja to dozvoljavaju (OpenSuse na primjer) al ni u snu tako nebih radio - uvijek volim to drzat na oku da unaprijed znam kaj moram popravljat nakon upgrejda
Staro 01.11.2023., 18:59   #2683
mkey
Datum registracije: Sep 2018
Lokacija: tu
Postovi: 3,845
Ja sam načuo od kolega da win10+ odrade taj inplace upgrade korektno. Nisam dugo to probavao, još moguće iz doba win7 beta kad me sjebalo u par navrata pa sam to lagano otkačio. Preko preče, okolo brže.
Inače volim odraditi čistu reinstalaciju OS particije ako ništa drugo zato da mogu očistiti svo nagomilano sranje Reinstaliraš aplikacije koje koristiš a ono čega se ne sjećaš nije niti bitno. Appimage mi se u tom smislu pokazao super jednostavan. Jedino integracija nekih aplikacije je banana (primjer koji pada na pamet je LibreOffice).
Doduše, ono o čemu moram početi voditi računa je da si priremim jedan ozbiljan dev environment i da ga ne diram. Nedavno sam se prebio dok sam osposobio GAE za jednu stariju aplikaciju koju imam (python2) tako da taj dio moram pametnije složiti. Kada budem nešto drugo instalirao mislim da ova Manjaro instalacija bude ostala u rezervi.
Isto tako sam protratio pola dana na pokušaj ospobljavanja da vinci resolve. Manjaro vjerojatno nije najbolja baza za to Iako oni imaju onaj ISO samo za DVS, ali temeljen je na Cent. A ja nije baš da to koristim profesionalno.
Gledao sam distribucije tipa BlendOS, ideja containera mi se čini odlična za setupiranje raznih environmenta. Otvoriš novi container, napraviš sranje obrišeš container i ajmo dalje kao da se ništa nije dogodilo.
Staro 01.11.2023., 19:28   #2684
strikoo
strikoo's Avatar
Postovi: 1,038
Staro 02.11.2023., 05:51   #2685
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,414
Daj mi pliz link na tutorial za TLP da bacim oko. Ekipa po forumima/redditu je većinom pisala da je out of box poštelan na neki optimum pa da je kao bolje ne dirati.
Čak i siteovi na kojima sam našao preporuku za TLP isto vele da je fire and forget, međutim linux i nakon instalacija žvače baterije 3-5 puta brže od win.
Staro 02.11.2023., 09:56   #2686
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,409
Mislio sam na Ubuntu Tutorijal gdje spominjem TLP. Da ne duljim: instaliraj, aktiviraj servis i ne diraj, Linux ima jednostavno losiji Power Management nego Windows.
Staro 02.11.2023., 13:28   #2687
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,414
E tako sam i napravio, onda je to to.
Staro 02.11.2023., 14:07   #2688
BlackDwarf
BlackDwarf's Avatar
Lokacija: Novska
Postovi: 2,441
Lenovo V15
Ne rade tipkovnica i touchpad.
Citam ima patch za arch, a meni treba za mint/xubuntu.
Ima netko iskustvo s tim?
BlackDwarf je online   Reply With Quote
Staro 02.11.2023., 14:34   #2689
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,409
Autor BlackDwarf Pregled postova
Lenovo V15
https://answers.launchpad.net/ubuntu/+question/707571
1. Cekas noviju verziju sa novijim kernelom
2. Probaj bootat distru sa novijim kernelom od ovoga sto imas
Fedoru probaj bootat pa javi jel ima isti problem.
Staro 03.11.2023., 08:40   #2690
BlackDwarf
BlackDwarf's Avatar
Lokacija: Novska
Postovi: 2,441
Neki spominju da radi na starijim verzijama kernela, ali u mom slučaju to nije tako.
Tražio sam distribucije koje imaju noviji kernel... Uglavnom ne radi.
Staro 03.11.2023., 08:59   #2691
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,409
Zadnje sto mozes probat su Manjaro i iduci tjedan kad izade novu Fedoru 39. Ak tamo ne radi - hebiga nije kompatibilno. Gdje si nasao ovo za kernel Patch?
Staro 03.11.2023., 09:36   #2692
BlackDwarf
BlackDwarf's Avatar
Lokacija: Novska
Postovi: 2,441
nasao na bugs.launchpad
korisniku nije problem da za sada koristi externu tipkovnicu i mis.. no vidim da ima malo vise problema da u njihovoj aplikaciju koju su kreirali u unity ne pokrece kameru i live video.
za kameru mislim da je veci problem build jer s drugom verzijom aplikacije to radi... a ovo drugo vjerojatno neki codec.
stavio gore zadnji kernel. isti je problem.
probat cu jos manjaro.
ako nista drugo neka pricekaju koji tjedan na neku drugu distribuciju.
Staro 03.11.2023., 09:50   #2693
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,409
A da das link...mozda bih ti mogao pomoci to implemntirat...mozda???
P.S. Mozda....
https://bugs.launchpad.net/ubuntu/+s...x/+bug/2034477 << Ovo?
Staro 03.11.2023., 09:54   #2694
BlackDwarf
BlackDwarf's Avatar
Lokacija: Novska
Postovi: 2,441
Da to je to.
Manjaro nije pomogao.
Staro 03.11.2023., 09:59   #2695
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,409
Da to je to.
https://git.kernel.org/pub/scm/linux...270a0aaa6656c6
Trazi distru sa kernelom 6.5.10 ili noviji.
Patch ide na kernel modul/source > to je malo tricky. Stavi Linux on hold 6 mjeseci - pa probaj ponovo.
Staro 03.11.2023., 10:07   #2696
c-shadow
c-shadow's Avatar
Postovi: 3,527
U mintu i ubuntu neće dobiti taj kernel tako skoro. Drže se stabilnih LTS kernela ko pijan plota.
Ako patch postoji, mislim da mu je jedino rješenje da skine source i kompilira sve sam, a to nije za početnika.
Jbg, previše nov hardver bez dobrog supporta za linux. Događa se
Staro 08.11.2023., 00:29   #2697
Chuby
Chuby's Avatar
Datum registracije: Feb 2004
Postovi: 1,309
Dakle zabavljam se malo s Linuxom Ubuntu.
Disk 0 Win 10 install
Disk 1 Ubuntu install.
Primjetio sam da prilikom odabira boot drivea, tablica kaze da je windows boot manager završio na drive 1 na kojem je Ubuntu.
Što bi značilo da ako tj. kad formatiram Ubuntu drive više ne mogu bootati Win10?
Mogu li nekako razmjestit boot managere po pripadajucim drajvovima?
ili što mogu učiniti da idući put to završi tamo gdje treba biti?
Chuby je offline   Reply With Quote
Staro 08.11.2023., 05:32   #2698
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,414
Zato se preporuča kod instalacije W10 iskopčat sve druge diskove, jer se šire ko kuga po svemu. A za ovo si izguglaj, vj postoji neka mogućnost. Sjećam se da sam 1 davno popravljao boot manager na W10 jer mi se neš skršilo.
Staro 08.11.2023., 06:00   #2699
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,409
Autor Chuby Pregled postova
Ak je Legacy boot > znaci da ti je disk 1 oznacen kao boot drive i tu je Win isto zapisao MBR boot. Rijesenje bi ti bilo izbisat samo Ubuntu particije a ostalo ne dirat i reinstalirat Windows boot loader (bootas sa recovery i ima par komandi).
Ak je EFI boot > isto ko i gore - ali ne diraj EFI particiju. Samo iz Linuxa izbrisi /boot/efi/EFI/<linux distro> folder. I onda reinstall Windows boot managera (drukcije komande nego kod Legacy boot restore-a).
E sad > ak mislis umjesto Ubuntu nekaj drugo instalirat - jednostavno postojece Linux particije prepisi a Grub ce odraditi svoje.
Uglavnom - prva instalacija Windowsa - istekaj sve osim Win diska. Windows se siri ko kuga di mu pase ak ne pazis.
Staro 08.11.2023., 15:10   #2700
Chuby
Chuby's Avatar
Postovi: 1,309
Dakle najprimitivnija rjesenja daju rezltate
Hvala na odgovorima
