Staro 13.10.2023., 01:30   #1
Inovator
Inovator's Avatar
Lokacija: Bjelovar
Postovi: 482
Win10 IRST driveri
Pokusavam instalirati W10 na Acer Travelmate P214 i naravno u setupu kaze da ne vidi disk. Skinem Intel RST drivere, ucitam RST VMD Controller 09AB, ali on i dalje ne vidi M2.
Ima tko sto pametno za ovo?
Staro 13.10.2023., 06:27   #2
BinaryJesus
Datum registracije: Feb 2021
Lokacija: Sveti Petar
Postovi: 306
Autor Inovator Pregled postova
Jel su driveri skinuti s Acerove stranice baš za taj model?
EDIT: Ili probaj ovo: https://community.acer.com/en/kb/art...0-installation
Code:
Select Intel RST VMD Controller 9A08 (TGL), and click Next.
Zadnje izmijenjeno od: BinaryJesus. 13.10.2023. u 07:01.
BinaryJesus je offline   Reply With Quote
Staro 13.10.2023., 09:03   #3
dani77
dani77's Avatar
Lokacija: Val
Postovi: 304
Ili nađi driver (IRST) po serijskom broju (uspio napraviti disk vidljivim nakon pravog drivera, posebno za W10 ili za W11):
https://www.acer.com/gb-en/support/p....009/downloads
Ili napravi ovo:
1. Run BIOS
2. On "Main" menu press CTRL + S to display hidden "VMD Controller" setting
3. Select "disable" VMD Controller
4. Save changes and exit
5. Run Win10 installer again
What is a VMD controller?
Intel® VMD is an Intel® Xeon® Scalable processor feature that enables direct control and management of NVMe SSDs from the PCIe bus without additional hardware adaptors.
What happens if I disable VMD controller?
Disable VMD technology will make your computer can't utilize RAID Array.
"You know, you come from nothing - you're going back to nothing. What have you lost? Nothing!"
Zadnje izmijenjeno od: dani77. 13.10.2023. u 09:09.
dani77 je offline   Reply With Quote
Staro 14.10.2023., 22:07   #4
Inovator
Inovator's Avatar
Lokacija: Bjelovar
Postovi: 482
Autor BinaryJesus Pregled postova
Code:
Hvala, ovo sam probao prije upita ovdje i nije šljakalo.
Autor dani77 Pregled postova
Ovo je riješilo problem!
Ili napravi ovo:
1. Run BIOS
A ovo nisam htio, glupo mi bilo gasiti kontroler, htio sam da radi
Hvala obojici, možda nekome zatreba
