Staro 30.09.2023., 06:25   #1
tintin
tintin's Avatar
Lokacija: negdje
Postovi: 1,792
Docker - kako napraviti container
Nisam do sad imao potrebe raditi vlastiti docker container, ali po malo prestaje podrška za arm32v7.
Pokušavam napraviti radarr docker container pomoću prerađenog orginal Dockerfile -a, ali se container stalno restarta.
# syntax=docker/dockerfile:1
# Use ARM32v7 Alpine Linux as the base image
FROM arm32v7/alpine:3.18
# Set version label
ARG BUILD_DATE
ARG VERSION
ARG RADARR_RELEASE
LABEL build_version="Linuxserver.io version:- ${VERSION} Build-date:- ${BUILD_DATE}"
LABEL maintainer="thelamer"
# Environment settings
ARG RADARR_BRANCH="master"
ENV XDG_CONFIG_HOME="/config/xdg"
# Install curl and jq
RUN apk add -U --upgrade --no-cache curl jq
RUN \
echo "**** install packages ****" && \
apk add -U --upgrade --no-cache \
icu-libs \
sqlite-libs \
xmlstarlet && \
echo "**** install radarr ****" && \
mkdir -p /app/radarr/bin && \
if [ -z ${RADARR_RELEASE+x} ]; then \
RADARR_RELEASE=$(curl -sL "https://radarr.servarr.com/v1/update/${RADARR_BRANCH}/changes?runtime=netcore&os=linuxmusl" \
| jq -r '.[0].version'); \
fi && \
curl -o \
/tmp/radarr.tar.gz -L \
"https://radarr.servarr.com/v1/update/${RADARR_BRANCH}/updatefile?version=${RADARR_RELEASE}&os=linuxmusl&runtime=netcore&arch=arm" && \
tar xzf \
/tmp/radarr.tar.gz -C \
/app/radarr/bin --strip-components=1 && \
echo -e "UpdateMethod=docker\nBranch=${RADARR_BRANCH}\nPackageVersion=${VERSION}\nPackageAuthor=[linuxserver.io](https://linuxserver.io)" > /app/radarr/package_info && \
echo "**** cleanup ****" && \
rm -rf \
/app/radarr/bin/Radarr.Update \
/tmp/*
# Copy local files
COPY root/ /
# Ports and volumes
EXPOSE 7878
VOLUME /config
Ili ima kakav drugi način da se postojeći docker container preradi za arm32v7?
Zadnje izmijenjeno od: tintin. 30.09.2023. u 06:32.
tintin je online   Reply With Quote
Staro 30.09.2023., 13:43   #2
strikoo
strikoo's Avatar
Postovi: 964
a jesi probao dići bilo koji čisti docker image i ručno instalirati u njemu radarr pa onda od tu krenuti sa izradom docker fajla?
strikoo je offline   Reply With Quote
Staro 30.09.2023., 13:45   #3
tintin
tintin's Avatar
Lokacija: negdje
Postovi: 1,792
Probao sam napravti image sa komandom docker build.
Ovo mi je novo i nije baš da mi ide.
Zezam se cijelo jutro i ne uspjevam baš
Staro 30.09.2023., 17:31   #4
strikoo
strikoo's Avatar
Postovi: 964
znaci uzeti neki tutorijal i krenuti lagano iz pocetka
jer vidim da za arm32v7 ima na dockerhubu imagea
ne bi smjelo biti problema instalirati radarr za koji vidim da ima arm verziju u zadnjoj stable.
