Datum registracije: May 2019
Postovi: 96
Updates na Windows11 bez TPM2?
Bok ekipa, nešto se priča da Win11 koji je instaliran na računala koja ne podržavaju TPM neće dobivati updates(za sad to radi normalno), jel to istina ili su samo spekulacije. Isprike ako je tema već bila, tražio jesam ali nisam našao. ![]() |
#2 | |
Prvoklasni Krkan
Postovi: 5,256
Dakle samo ovi veliki updatei na novije verzije/service packovi sigurno ne rade. |
#3 | |
Datum registracije: Feb 2021
Lokacija: Sveti Petar
Postovi: 278
Code:
Get 11 on 'unsupported' PC via Windows Update or mounted ISO (no patching needed) - use Skip_TPM_Check_on_Dynamic_Update.cmd v9+ to add /Product Server on-the-fly - and finally start Windows Update and select Upgrade to Windows 11 Get 11 on 'unsupported' PC via MediaCreationTool.bat - use MediaCreationTool.bat to Auto Upgrade, Create ISO or Create USB with detected edition and language, or Select between consumer or business (Enterprise) media Script creates media that will automatically skip clean install checks setup.exe will not automatically skip upgrade checks - launch the included auto.cmd instead! You already have an ISO, USB or extracted ISO Files and want to add bypass to it for both clean install and upgrade: -use Quick_11_iso_esd_wim_TPM_toggle.cmd to add <INSTALLATIONTYPE>Server without mounting This one toggles installation type to Server (or back to Client if run again on the same file, restoring hash) directly on the iso / esd or wim file - so there's no mounting / dism, just powershell-based hex.. Server type bypasses all hardware checks properly and cleanly |
#4 | |
Prvoklasni Krkan
Postovi: 5,256
Ne vidim da se tu spominju update-i nego upgrade-i. Si probao što od toga? Ja sam pred neko vrijeme probao na jednom starijem laptopu i išlo je samo kako sam opisao, 22H1 sigurnosni updatei, ali 22H2 mi nije nudio iako je bio dostupan. Ili ti misliš da svaki put kada izađe novija verzija W11 napravi in-place upgrade na noviju verziju? Nije to nešto strašno, ali nije ni zgodno. |
Postovi: 278
Pa to je ista stvar. Govorim o većim updatima. Ne ovim mjesečnim zakrpama. |
Prvoklasni Krkan
Postovi: 5,256
Postovi: 278
Ma ona prva opcija koju sam naveo "Skip_TPM_Check_on_Dynamic_Update.cmd" omogućava upgrade preko windows update. All to će opet biti inplace update. Znači windows update skida ESD image windowsa od 3-4 GB i inicijalizira update iz toga. |
Prvoklasni Krkan
Postovi: 5,256
Lokacija: home
Postovi: 572
cek, ovo me cisto iz znatizelje zanima...jel ide klasicni media creation tool i ako je, na koji nacin iniciras skriptu da funkcionira unutar MCT-a?
iconography fucks with me...you look great in bloodstains... |
#10 | |
Postovi: 278
Alternativa je bilo gdje nabaviti Win11 ISO i patchirati ga skriptom " Quick_11_iso_esd_wim_TPM_toggle.bat". Sve je na MDL forumu ili na githubu. |
Lokacija: home
Postovi: 572
ok tenks na pojasnjenju. ![]() nije za mene, jer moja platforma zadovoljava tpm2.0 uvjet, ali par frendova bi zeljeli probat win 11 bez obzira na sve, pa da im proslijedim uputu...a jamacno su kratki za tpm funkcionalnost jer su im konfiguracije starijeg datuma.
#12 | |
DIY DILETANT
Lokacija: Čistilište
Postovi: 3,529
Dotični znatiželjnici nek svakako isključe Core isolation/Memory integrity funkciju jer to ubija performanse na starijim procesorima (prije Zen2/Gen7). |
#13 | |
Lokacija: home
Postovi: 572
![]() obojica su na intelu, jedan od njih jamacno nije gen7 jer vozi na mom starom 4590 ![]() taman kopiram, pa cu poslat kao dopunu uz linkove kolege Jesusa, nek se momci zabavljaju kad imaju volje.... ![]()
